PDA
View Full Version : 1st Gen Durango
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. Catalytic removal
  2. 46RE Transmission Full Flush and Drain - Fluid in Torque Converter
  3. 98 Durango DRL module swap
  4. battery size questionable.
  5. 98 4x4 durango
  6. Will 5.7 parts fit on the 4.7?
  7. 02 Durango leaky Trans pan
  8. 98 5.2L V8 Durango Oil on Spark Plug
  9. Oil pressure
  10. freshly rebuilt 46re tranny, no OD
  11. Wiring issue.
  12. Heater box
  13. Need help with doom light wiring
  14. Instructions to replace radiator in a 2002 Durango
  15. Drum brake parts needed
  16. 2000 Durango 4X4 given to me by neighbors.
  17. 98 Durango 5.9 4or transmission problem
  18. Throwing code P0753 shift solenoid A
  19. Rear main seal cost to fix?
  20. Starter cranks 2-3x then stops.
  21. 99 durango 5.9
  22. Cost to R&R Governor Pressure Solenoid 2003 4.7L 4WD
  23. 5086518AA evaporator Upper housing
  24. Loose sensor in engine bay
  25. Where is the thermostat located on a 2002 5.9L Durango
  26. P0700 and running out of parts to replace
  27. Blend door, mode door, and other HVAC foam parts
  28. Running Rough After Timing Chain Replacement 4.7l
  29. New Prop Drive Shaft Slinging Grease from Cap
  30. Changing water pump and thermostat for 2002 durango 5.9l
  31. oil leak
  32. 2000 4.7L Dodge Durango Engine power upgrades with out having to change pcm's
  33. Desperately need help!!!!
  34. 99 durango
  35. 98 Durango no spark
  36. clunk when turning end to end
  37. windows falling off track???
  38. 4.7L new lifters possibly failing already
  39. Putting a side window back on track
  40. Power steering question
  41. What type of aftermarket speakers should i get
  42. Transmission slipping
  43. something that drives me absolutely nuts/ how do I stop this from happening?
  44. Newbie
  45. Leaking Coolant from Y-Adapter Heater core Hoses?
  46. Compatible transmissions for the 4.7 to replace the 45 rfe
  47. Pcm swap maybe
  48. Steering play
  49. 4lock engage no power
  50. Brake bleeding
  51. coil pack codes
  52. Engine Noise
  53. 2000 Durango 4.7L Audio Upgrade
  54. Got red powder coated running boards for sale.
  55. ABS bleeding questions!
  56. Is it an Intake Manifold Gasket a Blown Head Gasket or a Cracked Cylinder Head?
  57. 98 dodge durango 5.9 4x4
  58. 4.7 upgrades
  59. PCM Replacement
  60. Hard start 5.9
  61. Rke programming issues
  62. Drb iii
  63. 545RFE replace and relearn
  64. 99 Durango 5.9 v8 Anti spin differential issues
  65. Front drive shaft is stuck
  66. Tail light/ park lamps not working
  67. Transfer case swap
  68. Aux cooling pump
  69. Durango shuts off when I hit a bump or rough road.
  70. Exhaust manifolds
  71. Trans temp light on
  72. O2 sensor information
  73. Thinking about trying a 4.7
  74. 4.7l 08 cylinder heads on a 2000
  75. Durango transfer case
  76. intake manifold gasket
  77. NP133 transfer case information
  78. Tuning Guru
  79. It never ends. Fuel door issue now.
  80. Does the 5.9 have dual intake?
  81. 2001 Dodge Durango
  82. Dies while in drive.
  83. Trans problem
  84. etched part number on camshaft
  85. Interior light bulbs
  86. Part swapping
  87. HVAC issues.... still
  88. 4.7 block oiling question
  89. Instrument cluster dead
  90. No Bus
  91. Mystery Coolant Leak
  92. Durango Noob
  93. AC Control module
  94. Should I bypass radiator trans cooler?
  95. 46RE interchange
  96. Ram ABS Kelsey Hayes module in Durango
  97. 03 4.7 lifter issue need help quick
  98. A/C blows hot out of the front but cold out of the rear.
  99. Test condensor fan
  100. Engine identification
  101. burnt valve?
  102. Preparing for Towing
  103. 2001 Durango 4.7L Electrical Question
  104. Stereo and Speaker Installation
  105. Dash and Cabin conversion to LED's
  106. 4 prong pcm 3 prong pcm swap
  107. I need help identifying a mystery wire
  108. Intermittent Stalling/Won't Start
  109. Super Servo absolutely will not fit
  110. Rear Diff Noise
  111. 2001 Durango Sensor Question
  112. Bumpsteer
  113. Lift kits for first gen
  114. Front brakes smoking
  115. Gear winding noise - Used differential
  116. Transmission not engaging
  117. 2001 Durango 4.7L - No Start
  118. Engine Swap - 01 Durango 4.7-5.9
  119. Rack and Pinion bushings question
  120. 1999 Dodge Durango 44re slips in reverse
  121. 4.7L misfire
  122. There is some shaking going on
  123. HVAC issues
  124. 180 tstat.
  125. Custom infotainment center ongoing build
  126. 46re Valve body reassembly
  127. Check engine light - ignition key
  128. HELP!!! Multiple Cylinder Misfire
  129. Transfer case
  130. 44re or 46re
  131. Need transmission advice
  132. 2001 Durango 4.7L - FINALLY getting back to her!
  133. Engine swap 5.9 gas to 5.9L diesel
  134. 2000 dodge durango 5.2 2wd
  135. Upper control arm bushing torque
  136. No P or N! HELP!?
  137. Instument Cluster Change
  138. T/S lift causing tire wear?
  139. Heater hose "Y" connector
  140. Power Steering Pressure Hose
  141. Transmission ID
  142. 02 Durango SLT Plus
  143. Advice needed transmission temp light coming on
  144. Installing new seats on gen 1 question
  145. 2000 Durango ,no overdrive
  146. P0441 blues
  147. Shift lever stuck in park.
  148. New PCM gauges still dont work
  149. 2001+ Bumper on 2000 Durango?
  150. Yakima roof rack towers
  151. Easy keyless entry programming (2001-2003)
  152. 85 octane in Utah
  153. 2000 Durango 5.9L won't start
  154. Transfer case swap
  155. 2001 Durango - Occasionally Shifting at High RPMs
  156. Motor Swap
  157. 03 Durango manual transmission swap
  158. Likely answered.... Rear Shocks 8" lift....
  159. Passenger window doest work
  160. Need HELP finding oil cooler line!!
  161. Spare tire carrier question
  162. Transmission pan gasket
  163. blinkers won't work (2001)
  164. bulb number for 2000 dodge durango slt
  165. New Steering Gear, Tires Rub
  166. Tail light problems.
  167. Drain Plug Nut Inside Oil Pan Broken - Fix Recommendation?
  168. Help finding parts
  169. 99 5.2 l reinstall tips
  170. Front suspension & steering rebuild.
  171. Supplemental Cooling Fan TSB
  172. mistery coolant leak
  173. I need help!
  174. High voltage codes
  175. 99 Durango with P1391 code after replacing a bunch of parts.
  176. Front differential questions
  177. New key problems
  178. White smoke from valve covers
  179. No Power at all.Speed Bump cause?
  180. DIY 4.7 head porting
  181. 1st gen 4.7 with coyote parts
  182. PCM Information
  183. Tires
  184. Bypass PCM
  185. 46RE random no reverse w/ noise like parking pin
  186. Rear differential overhaul
  187. 9.25 Trac-lok Rebuild - experience?
  188. 2000 Durango 4.7L with Auxilary Transmission Cooler
  189. 2001 Durango Dust Cover Removal AWD
  190. Front oxygen sensor issues
  191. Cranks, fires, dies
  192. The rear axle 9.25
  193. Transmission will not idle in gear while at a stop.
  194. After market radio
  195. Anyone Ever See This Grille? No Cross In Center
  196. Spare tire winch access hatch
  197. Tail lights
  198. Upgrade to heated front seats?
  199. 2ND Gen Durango NV244 Transfer Cases Compatible with 1ST Gen Durangos?
  200. 1999 46re strange problem
  201. 2003 RT Durango Humming Jack Brake Type of Sound All of Sudden
  202. Center dash control problems
  203. Steering help please
  204. I accidentally drove on the freeway in 4 wheel (high) drive!
  205. What weight oil to use?
  206. 46re transmissions.
  207. Vent Ducts
  208. Used 2003 Engine - Things to Refresh Before Install
  209. 01 Durango 4.7
  210. Circuit testing help
  211. Parts for 01 NV 244D Transfer Case
  212. Code P0320 - Crankshaft Position Sensor?
  213. Hey New to Forum! (1st gen Durango)
  214. Ctm help
  215. nother seat question
  216. Question About Rear End Gears (R/Ts)
  217. Used 5.9 Engine Question (Price/PCM)
  218. Blower selector knob help
  219. Please help - Durango won't drive forward or in Reverse.
  220. Help. Heater problems
  221. 2000 Durango 4.7L Cooling question
  222. 98 Durango Build
  223. distinctivetroy
  224. Transmission problems
  225. Brakes!...(brake lines)
  226. Keyless entry
  227. Cold low RPM idle
  228. seats (story involved)
  229. A couple problems and (easy?) Fixes
  230. ‘99 5.9 V8 Durango Stalling in N & Park.
  231. Rear hatch
  232. How to bypass rear heater
  233. Thank you for letting me in :-)
  234. 2000 Durango 4.7L Oxygen Sensor Blues
  235. 01 Durango Door hinge rebuild kit
  236. Check guages light on, voltmeter reads zero
  237. 03 SLT+ Heated seats
  238. No power
  239. 98 Durango, 5.9L blows but no heat, pops out of cruise control. Is it linked????
  240. Could both issues be linked?????
  241. ABS codes 82,83 how to reset
  242. No crank no start. Broke, and can’t afford to replace a bunch.
  243. Can i manually close a cable driven blend door?
  244. Stalling issue
  245. Can this "feature" be undone"
  246. 02 Durango rear end shift?
  247. Slop in steering wheel
  248. Power steering Switch problems
  249. Electric fan relay issues
  250. Lost here.
