View Full Version : 1st Gen Durango
- intake questions
- ball joint spacers
- Flowmaster baby!
- 2001 durango, what speakers?
- Electronic compass gone haywaire
- starting out in second gear
- question for those with lifted rangos
- pcv valve replacement
- Arizona trail ride
- Need Help on which spark plugs to buy
- Automatic Locks
- 98 Durango remote programming
- Engine Light P0358
- Security system problems
- Maintenance Free Battery?
- 2001 Clock Spring Failure
- Looking to buy!!!
- Can't get rid of code p0700
- PLEASE HELP! 4 Wheel Hi Disengage Problems
- HELP NEEDED 5.9 ltr runs like crap
- check engine light
- RPM low, 'PICTURES INSIDE'
- Durango Won't start
- Check out my Durango
- 2003 Durango 3rd Brake Light
- Sound System
- DELETE
- Engaging 4WD on 2002 Durango
- front differential
- Suspension
- Fan came off!
- KEYLESS ENTRY KEY FOB PROGRAMMING
- need quick answer about removing tailights!
- 2000 Durango overheating
- Chime is driving me crazy...
- oil pressure switch starting to fail?
- code p0320
- Follow Up To 99 Durango surges/missing
- HELP Ignition Switch Troubleshoot and Replacement
- Looking for a part
- distributor/plug wire help
- Help with radio wiring '98
- cooling problems
- fuel pump ??????
- CD player?
- HELP with alarm.
- My Durango won't start, no lights, nothing. Battery is good.
- is it possible to...
- 2000 Durango schematics
- Time to trade in Durango?
- a/c not blowing
- 2000 Durango r/t
- Which shocks should I get?
- Correct Lubricant for Steering Linkage
- Roof Rack
- Has anyone swapped a 99+ Dakota/Durango alternator into a '98?
- 2000 Durango Overhead unit
- Just wanted to introduce myself and say Hi!
- 2003 Dodge Durango SLT - Engine Light
- Brake & A.B.S. light on, no spedometer under 30 ALSO
- Another Exhaust question
- check gauges/oil pressure prob
- Aftermarket Running Boards
- ABS, Break light & speed tack
- having problems with 2 codes
- delete
- location of cam sensor
- 99 Durango surges/missing
- 1999 Durango P0783 issue
- Looking for help on a few problems
- SEREPNTINE BELT
- repair manual
- Help with tag light!!
- Where ???
- Suggestions Please!!!!
- dash light problems 03
- Remote Starter Question
- fog lights
- speaker probs
- cold idle jumps up and down
- Just bought 99 durango, good or bad idea
- 99 Durango Brakes HELP!!!
- srt8 tries to drive away from hitting a curb
- 99 Durango Wheel Hub Replacement
- What exhaust to buy?
- need some info please
- Pictures of the truck back on the road !
- Synthetic Oil Question
- Blower Problem - 02 Durango amost burnt today!
- 01 5.9 Stalls....
- DIY
- just bought a DURANGO
- I need help!
- Car and truck of the month, vote now!!
- Operating temp
- Fail inspection due to 2 Transmission codes??
- 2001 with the dreaded P1740 Code
- Where ??? Chevy 1" Drop shackles
- 99 durango transmission issue
- need some help
- 100K !
- What kinds of Mods for the 5.9??
- spark plug ???
- No Heat in 99 Durango
- want a Durango
- To Rough
- stereo controls not functioning
- What do I need to watch for with used Durangos?
- Horrible thwapping noise
- Illegal Foglights?????
- 1999 Durango light problem....
- headlight
- Will a.......
- Window Regulator '03 Durango
- aftermarket head unit
- No power to driver side door
- Vehicle Speed Sensor
- HELP!!! with install
- questionable swap
- Newbie w/ Question bout 95-02 with 5.2L
- Trim Piece Needed
- No Heat
- Transmission and Tcase Swap
- 2000 Durango Headlights
- wheel Backspacing
- Tire question ?
- battery won't tie down right
- Road Noise
- Winter driving on 4wd ?
- bad miss with history!
- multiple failures
- humming noise up front
- Is there any difference between a 2002 and a 2003 D ?
- Passenger front door look makes a Funky noise
- 01 Durango 4.7l tranny prob
- Not too sure about the Durango
- help! engine miss!
- first post and qrt. mile time?
- 99D Having a lot of trouble accelerating - bad cat converter?
- 2001 Durango R/T
- Towing questions for 2000 Durango
- Accelerator issues
- heater core replacement total cost
- Hello!!!
- First Durango - Help please
- 4X4 NV 233 TRANSFER CASE
- Code P0753
- 01 Tranny
- Luggage Rack Removal
- 2002 Durango electrical problems
- 2002 Durango somtimes hard to shift out if park
- Light around key ignition won't light up?
- 3rd Break Light
- Tire Size for 00 2wd
- 5.9 dying after start up
- 98 Durango Rear washer fluid resevoir
- Fender Flares
- Trans. Cooler
- Back Wiper not intermittent...???
- Possible Front End Problems
- Differential problems
- Heater Problems
- 2000 Durango after driving 2 minutes wont start
- 2001 Durango - Fan cluch
- looking for couple parts
- wishing upon a star
- Speaker size in doors ??
- SQUEELING BRAKES
- Parking Sprag Shaft Reinstall
- Performance for 02 durango
- '03 D Lumbar support
- NOT RIGHT ??!!
- Replacing the indash on my durango
- Power door lock, rear door, won't work
- 2nd generation Durango
- 4.7 w/ 3.92??
- On Board Computer codes 2001 Durango
- need to find..
- Gas mileage?
- brakes on a 2000 slt..help!
- 1st Post!! SLT vs. SLT+
- Part Found in Auto Trans Oil Tray
- 98 Durango heat issue.
- 2001 Durango Power Windows
- 00 Durango 5.2 Won't start
- Torsion Bar Lifting
- DUAL EXHAUST
- 98D 5.2 Tranny Problem
- Thought it was only the RAD !
- 2000 Durango no heating during warm up
- new cam?
- 99 D battery going dead
- truckin suspension
- '02 stuck in Park
- whiplash suspension
- ? about matince.
- 2" Body Lift for 2WD 2000 D???
- Shackle lift, still rubbing 32's
- Will these fit?
- Tune-up Tutorial?
- D for a Vette
- Hot heat, cool defrost
- Help
- Question about Temperture???
- 4wheeling prep without susp.
- Trailer Wiring
- towing
- Dead 98, maybe alternator, help?
- oxygen sensor
- Driverside window
- Batt dies/parasitic drain/Idon't know
- Oil problem
- Regular Unleaded vs. Premium Unleaded
- 2001 4.7L Rebuild it or Buy Remanufacture?
- 02 Durango, one headlight flashes
- 98 Durango likes to stall in 2nd gear.
- '03 Durango Brake Life
- ENGINE TEMP ?
- HO INTAKE, MAN.
- nv233 to nv244 swap
- 4.7 engine sludge
- NV 233 to NV244 swap
- another question about the infinity speakers
- Problem starting in wet weather
- Driver side heated seat not working
- a/c not ice cold
- What are the biggest tires for my Durango?
- 2000 Infinity Amp location
- 2001 rear heater blowing cold air
- new member
- 2000 durango power steering problems
- 2002 durango exterior lighting
- column shift pin won't stay engaged
- Dead cylinder
- Plugs and wires
- Infinity 6012 speakers
- Power Window Problems/ 4WD Light
- wheels
- does any one no of a good lift
- Just wondering ?
- Messed up tires
- Assistance with build sheet codes
- Any help would be great with mods
- Can anyone help!!!
- Transmission fluid filter change
- POWER LOCK PROBLEM
- Need Help fast!!!!
- Antifreeze smell
- Turn Signal problems
