View Full Version : 1st Gen Durango
- heater core help asap
- Durango differential help
- durango radiator help
- Tire size and mileage
- Front bumper and grill
- p1071
- Should I buy a Durango?
- What to look for
- Power window issues
- Ultimate ride Sweepstake
- 98 Durango custom bumper help
- Rear cargo latch
- Ac clutch bearing
- ABS light... yet another question/thread.
- Rear End Housing Swap What Years are interchangeable
- 00 4.7 swap???
- power steering flush
- Tailgate Cancer
- Little Heat Cold Feet
- Rear Diff service question
- Plowing with your D
- help please
- misfire and oil consumption
- 4WD Service light - basic troubleshooting results need feedback
- 1999 Dodge Durgano Acceleration Problem
- 2001 durango 5.9L idle issues, low rpms stuttering, stalling
- Xfer case hosed
- Only have 2nd and 3rd gears- limp mode
- I need ino for our Shelby Durango SP360 #0038
- transmision crossmember
- frusterated
- durango died while driving....wont start
- 2003 Durango Transmission Not Working
- radiator?
- 45rfe tailshaft question-master tech please read
- First snow of the season!
- transmission vent hose
- need opinions on a push bar please
- 2000 Durango trans leak?
- First Post, and its the ABS
- Common passenger side water leak when it rains
- 99 durango problems
- HELP I cant see....
- Can true duel exhaust be installed
- side view mirror replacement
- Which speed sensor...?
- Going from drive to overdrive?
- Dvd player
- Sunroof on a 99 D
- Shackle bolts
- 2000 Durango 4.7 Starter
- Broken thermostat bolt nightmare
- Looking for a place to get affordable 4.11s. . . .
- Dome light short
- Durango 4.7 Exhaust Manifold Bolt Specs
- Fan Clutch Died
- 01 5.9 d fan clutch questions?
- Transmission 99 Durango
- Engine sputtering and rpm fluctuations and stalling in reverse
- 1998 durango tailgate question. Need help
- 1999 power steering question
- 4.7 gaskets
- How to sense park and neutral
- 5.9 wont stay running at start-up
- Funny
- defrost problems
- White letters or Black sidewalls?
- 1999 Rango low on power
- Minor issues with ticking and trans fluid leak, hopefully...
- easy way to loosen fan nut?
- Transmission Coolant Lines - Replacement
- Odd Hesitation in 2000 4.7
- Help!!! I may have a SERIOUS ISSUE
- 03 Druango transmission Fail
- 99 Rear Suspension Question
- Swap '98 parts for '99 parts (diagram request)
- 99 durango brake issues
- cold start
- 99 D Liftgate Cylinder Help
- Stereo Issues
- What oil viscosity for 4.7 ?
- 03 SLT steering
- I need help PLEASE!
- '03 Durango electrical issue
- Lift Shackles- like 'em or hate 'em?
- Just bought a '98 Durango, need some direction
- Help, Electrical plug
- 2001 Durango radiator drain petcock.
- '03 Door locks/Keyless entry
- Computer tune
- interesting read about oil viscosity
- Fuel Mileage Issue
- Remote Distance
- Bad stuff
- Trans shifting weird
- 02 Durango Lift
- 4.7 Quiet exhaust option.
- FOGGY WINDOWS, door panels.
- Starting issue.
- Im so confused and need help from the masters
- 98 durango-No cold air in rear
- Blocks or Shackles?
- Horrible loud noises from truck YES, I searched first, please help
- Stalling
- Tranny issues: Master_Tech
- Keyless Remote Programming
- Durango radiators/cooling
- 4.7 engine swap
- Transmission problems in 2000 4.7L
- Looking for some Cheap power for my 4.7
- need repair panels
- New Trans Pan Pics
- Valvoline NextGen? *General Question*
- originally no start issue, now running problem
- Power windows & Driver Side Door Lock Switch Stopped Working
- 360 starting /idle issue
- 4.7 valve covers leaking, new gaskets
- 2002 4.7L 4x4 Durango aftermarket foglights
- P0320 + P0700 codes
- coil pack stuck in 4.7 head
- 1999 durango transmition parts what to replace
- Help with my 02 4.7 Durango!
- Painting brake drums and calipers
- when it's not as simple as you think...
- Weird ABS problem
- code 0138
- Squeek in my 2003 drex
- 45rfe question
- long cranking
- Question Steering Wheel Play - Located U-Joint on Steering Column - Possible Fix?
- Steering Wheel Play - Located U-Joint on Steering Column - Possible Fix? (Images)
- reverse band adjustment?
- heads up guys
- what do you do...
- Stalling in gear
- Fluctuating oil pressure
- Durango Issues with video.
- sunroof drain clogged?
- Front wipers don't work! Help!
- durango has electrical failure
- Problem with gauges in the dash
- 2 Problems . . . Some Help Needed !
- Tie Rods
- O2 sensor signal wire and vacuum
- 2003 Durango upper ball joint, hub assembly issues
- Fun with the D on Fri night
- The unsolved mystery
- 98 D Transfer case Parts
- Online Parts Views
- Liftgate "shocks"
- Rough transmission engagement
- Pulling a trailer.
- New issue with my Durango
- dodge durango
- Magnaflow muffler question
- trans problem wont shift into 3rd and OD
- Need Help Putting Her Back Together
- Fog lights inop in need of a wiring diagram
- 99 Durango 5.2L Intake problems
- Headlight bulbs
- Cant shift out of Park. 02 durango, 4.7L
- Front End.
- 4.7 issue
- Water Pump R&R
- Abs code reader
- Slight issues with my new Durango
- Changing cluster colors on a budget!
- Ignition Switch Light
- wiper fluid
- 4.7L V8 Exhaust Ideas
- Turn Signal Problem Making Odometer Flash?
- power windows not working
- Possible ECM Failure Well pretty sure
- rear diff fluid
- Can key sentry system be reprogrammed?
- which TPS to buy "Wells or MOPAR" dodge durango 2001
- two issues - overheating and limp mode
- Lock Programming issues
- Cab Running Lights
- bilstein resivoir shocks
- New to the D and long trip ahead
- P0420 code
- Timing Chain Help
- 01 durango break lights are out, keep blowing fuse - PLEASE give advise
- Which Exhaust?????
- What is a code 63, please?!!!
- Vibration in front end
- 01 Durango Towing Capability?
- Electric waterpump and fan conversion
- OBD port
- Fan motor issues
- Thoughts on a few things
- catch-up maintenance
- Rango Fishtails?
- Preferred Ball Joints
- Solution for a lift?>
- Tiny light bulbs behind Homelink buttons
- 01 durango trans/valve body issues, trys to pull in park etc...
- How big of a tire can I go?
- Found part of my rough idle!
- 99 5.2 - A/C Bypass help
- changing bulbs???
- Spare tire issue
- idler arm
- Tranny Problem
- Front Plate Solutions
- '99 Durango 5.9 Front End Vibration...
- 2000 Dodge Durango 5.9 will not start 150k
- 2001 durango 4x4 (4.7l) interchange?
- 4.7L Jumping Time
- 99 Durango transmission swap 5.2 4x4
- question about tires ?
- Magnaflow Catback help
- Brake fluid distribution differences between drum and disc?
- Ford High Flow Fuel Injectors in a Durango 4.7L?
- OEM sunroof for Durango?
- 98 Durango Running rough 5.9
- 2000 4.7 conversion
- Overcooling?
- 98 Durango Keyless Entry
- 98 durango-front blows cold, rear blows warm
- Advice needed with an ABS issue
- Rear Air question?
- Swapping 2003 Discs onto my 1998 Drum Axle.
- Ticking when in park
- New Member Doing Research
- 2002 durango
- Quick Help with Head Lamps on Durango (Electrical Question)
- Need help with my D (trans)
- for all you off roaders out there
- ABS - Brake dash light on
- 03 Durango power windows issue
- Cat-Back Exhaust
- Oil pressure
- Transfer case shift lever problem
- Excessive sway/body roll
- 03 durango wont start wont run
- 99 99 Durango Shifting and now Stalling problems.
- Crazy rpm's, sputtering/knocking.
- Problems with new motor
- Really f&^@(*g anoying
- Weather Stripping
- need help with this trans rebuild
- Do I need new front shocks?
- Oil pressure issue
- Wiring for trailer...help?
- wheels and breaks
- Doors not locking
- 99 Dodge Durango SLT Body Parts Compatibility question
- Possible clogged injectors?
