PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. 2003 Dodge Durango 4.7 SLT p0300
  2. trans temp running high
  3. 02 Durango front end kit
  4. Looking for a metal plug size
  5. 2003 durango rt AC hot
  6. Thank You for everything Old Friend :)
  7. '02 45 RFE.. can't be factory
  8. 2002 Durango CEL Question
  9. Throttle Valve Cable Replaced but not secured
  10. 2002 Durango 4.7L Reverse Lights
  11. 2002 Durango 4.7L 4wd Issues
  12. Just aint my day !
  13. 2003 dodge durango evap
  14. no bus nightmare
  15. Tick-Roarr-Whumpa Connected ?
  16. Biggest engine
  17. 03 Durango Driver Side Rear Quarter Glass - Back Most Window
  18. Hello and could use some help
  19. 1999 Dodge Durango throttle cable
  20. love these new headlights
  21. help with headlights.
  22. P1491 Radiator Fan Ctrl Relay Circ
  23. Fuse location for power outlets for 01 Durango 5.9 slt
  24. Uwharrie Trails in NC
  25. front shocks replacement 2000 SLT 4wd
  26. Many issues. Please help
  27. Nv3500 swapped R/T
  28. no 3rd gear, 4th gear, or overdrive
  29. A/C issue
  30. '00 4.7 engine cutouts with P1596
  31. 2002 Dodge Durango
  32. DTC P0344 Help
  33. 2000 V8 5.9 dead after 2 hours from jump start
  34. Lots of work
  35. manifold screws
  36. 2003 Dodge Durango - front vents not working and more
  37. Security / Service 4x4 Lights
  38. Stumped
  39. Opinion time (tires)
  40. Brake pedal spongy after master cylinder and brake line replacement
  41. 45RFE No first gear?
  42. Ultra Low Mileage Dodge Durango Shelby SP 360
  43. 99 Durango 5.9 Anti-Theft won't disarm
  44. 2003 Durango Emergency/Parking Brake Cable
  45. Brake Lights Increasing with Led Lights or Bars Thoughts Suggestions?
  46. Rebuild or Replace motor
  47. 99 Durango Aftermarket Alarm Issue
  48. Leaving TV cable unclipped
  49. Back Again....2003 Durango
  50. FRUSTRATED! P0121 Code Still! Low idle, stalling!
  51. 1998 durango 5.2 electrical problem
  52. Looking at buying an 01 Durango
  53. Defrost only vacuum line repair help
  54. Need help, engine cutting out
  55. shop quoted me 4500 to rebuild transmission?
  56. 2002 Durango R/T – Side mirror
  57. 2000 Durango trans noise
  58. Issues with brakes on 2001 Durango 4.7 L
  59. Transfer case driveline question
  60. Drivers Blinker
  61. 2002 Dodge Durango transmission
  62. Looking for Interior Door Handle
  63. Warm Air
  64. 99 Durango still has shifting problems
  65. Anyone know how to adjust the camber on 2003 Dodge durango SLT, 2wd, 5.9l?
  66. Help!!! What's wrong with my durango again?
  67. 2001 Durango R/T Owners - Anyone Know What This Sensor Inside Is?
  68. HELP ---"What the ____ is wrong with my Durango this week?!"
  69. 2001 Dodge Durango Transmission Problem
  70. Dashboard lights and gages on 2001 dodge Durango
  71. 2000 Durango 4.7 Suspension Repair
  72. 2000 Rango 2WD 5.2L 44RE replacement
  73. Who makes the best In-Channel Wind Deflectors?
  74. Nope, wasn't broken, yay!
  75. WTB: ECM 2003 Dodge Durango SLT 4.7l
  76. 2001 Durango 5.9l engine layout questions
  77. 2003 dodge durango key won't turn over - 4.7l AWD
  78. Help, Don't really know what to try next with Tranny Issues
  79. 5.2 pcm in a 5.9
  80. A/c issue
  81. 5.2 Magnum engine rebuild questions
  82. Need Help Identifying This
  83. Upper vents not blowing - rest work and switch.
  84. Any ideas what this is hanging out under my dash?
  85. Gear indicator off by one position, any ideas?
  86. 2003 Durango SLT 4.7 Dual Ram Short Air Intake
  87. interior swap
  88. 2001 R/T Owners - Front Bumper Question Metal or Plastic on Yours?
  89. First Durango picked up today, Overheats!
  90. Transfer Case Fill Bolt Stuck - What's the Transfer Case Made of
  91. 2003 Durango hesitation/low idle problem
  92. Bad Fan Clutch or something else?
  93. 2000 5.2 Durango no reverse
  94. Witech Pod & Mini Pod / DRB-III for First Generation Durango
  95. Trans problems
  96. 2002 durango 5.9 wont start, sounds like misfiring.
  97. Newb questions...
  98. 2000 Durango SLT 4.7l V8
  99. Difference Between 2001 R/T Models & Other Facts & Questions
  100. Torque Converter??
  101. Transmission Identification, 2003 Durango
  102. Brake lights won't light up!! Help!
  103. 4x4 SXT 4.7, 3.55 - Most economic exhaust suggestions need.
  104. Rear Defroster light blinking after PCM install
  105. radio install 2000 durango
  106. 2001 R/T Shifting Into Park "P" Light Not Always Coming On
  107. Green Spongey Stuff Blowing Out of Air Vents
  108. Lights won't turn off.
  109. Help on 2000 Durango 5.9L Oil Capacity and Dipstick
  110. Steering Arm
  111. I'm just a girl..
  112. 1998 Dodge Durango
  113. Camshaft and Crankshaft position sensor location
  114. 2002 Problems Starting
  115. Help Needed - HVAC System Issues after Heater Core Replace
  116. Factory infinity amp on 2001 dodge durango
  117. rattling noise near transmission bell housing
  118. Intermittent vibration
  119. 1999 dodge durango wont start
  120. Tires
  121. Screeching front brakes for 2nd gen dakota
  122. Audio question for a 2001 Durango SLT with the Infinity System
  123. Possible engine swap
  124. PCM 5.9L spec differences between a 2000 3500RAM/Van, Dakota & Durango?
  125. Let me have your opinions!!
  126. 03 durango 4.7 sxt rough idle.
  127. How to identify transmission model of my 2000 Dodge Durango
  128. Travel Trailer length vs Durango vehicle width
  129. smoking bad when on a slope, could really use a hand
  130. Lower control arm and torstion bar
  131. 2001-2003 R/T Durango's and Faulty Neutral Switches?
  132. 99 dodge durango wont start
  133. Timken or Moog?
  134. broken vacuum line causing spike in RPM??
  135. 2001 caravan
  136. Getting custom cat back exhaust for my R/T
  137. 2001 Durango R/T Ticking Sound w/Video
  138. wrong wheel hub
  139. In need of some tips and tricks for replacing the exhaust flange to my '99 Durango
  140. No Crank, No Click, No Nothing
  141. What's wrong with this thing this time?
  142. Brake Line Diagram
  143. 2002 no power going to evap solenoid.
  144. Transmission Pan Drain Plug
  145. 2000 Dakota, no brakes
  146. 44re to 46re swap
  147. rear climate control
  148. 2003 Durango I don't know what's leaking
  149. 03 Durango 4.7 bucking/jerking question
  150. No tailights or dash lights. Please Help
  151. only drained 2 gallons of coolant so far...
  152. Traction Control
  153. Injector pulse sequence.
  154. Looking for advice
  155. 2002 Durango Shifter and transmission question
  156. Heater problems
  157. 99 Durango lift gate glass
  158. Dodge Durango How to Tighten Alternator Pulley Nut? Keeps Spinning
  159. car wont start after heater core replacement
  160. 2003 Durango Vent only stays on Face
  161. HVAC box stuck what am i missing??
  162. Can a 4.7 Durango 2002 MOTOR go into a 2000 Durango that also was 4.7 with out changi
  163. Fuse help
  164. Safe Website for parts?
  165. power steering pumps
  166. car wont start, radio displays time but no music
  167. '05 Ram 2500 5.7L 4x4. Truck stalled, Brake and ABS remain on
  168. 2003 Dodge Durango 4.7 - Electrical Issue Following Heater Core Replacement
  169. Taillights
  170. 2003 Dodge Durango - Heater / AC Assembly Removal
  171. 99 Durango Nonresponsive Instrument Panel Gauges and inaccurate warning lights lit up
  172. No crank no start after rookie attempts heater core removal
  173. Engine swap
  174. intake trouble please help
  175. 4.7L Knocking Noise
  176. 2003 durango rear wiper problem
  177. Durango Lifted!
  178. Want to add a Trasnmission Cooler & Temperature Gauge to 4.7 2000 Durango w/45RFE
  179. New Member
  180. Wiring 2 Alternator's
  181. 2000 Dodge durango wont stay running
  182. 98 durango misfire light load
  183. looking at buying a 1st gen and swapping my own 4.7 into - question
  184. 2000 dodge durango replaced TPS still wont stay started
  185. 01 durango 4.7/45re tranny leak
  186. 1996 dodge Dakota starter
  187. '99 Durango stereo
  188. CEL with no codes
  189. Help! Heater core replacement.
  190. 99 Dodge Durango Motor/Trans Serial Question
  191. 02 durango
  192. No heat coming from rear vents
  193. Heater Blower Motor not getting power
  194. 03 Durango 4.7 parking brake not working as it should!
  195. TCCM Part Numbers - Interchangeable??
  196. 2000 Durango 4.7 starting issues
  197. Correct flowmaster muffler for my Durango?
  198. Brake Lights Stuck On / Chime Stuck On
  199. Transponder Key question
  200. 99 durango 5.2 v8 trans issues and identification
  201. Need help with my 2001
  202. 99 Durango check engine light and hesitation.
  203. 2003 Durango 4.7L won't start below freezing
  204. HO intake manifold discussion
  205. No interior lights
  206. help .. ready to go nuts
  207. anyone with heated mirrors? quick question
  208. 2002 durango 5.9 shift linkage will not go into 2,1 or park on the column? Too long?
  209. Looking for a dome light, can't seem to find one
  210. Biggest durango I have ever seen
  211. 99 5.9ci 4x4 durango exhaust in done from catalytic converter runs no power dies
  212. 2000 durango running rich
  213. overheated wont start
  214. engine to bellhousing alignment pin question
  215. 99 durango 5.9 4x4 no start issue
  216. PCV Valve Fluttering
  217. HELP...2002 Durango Problems 4.7
  218. 02 Durango slt 4x4 running rough
  219. Swapped 02 5.9L durango runs for 2-3 seconds and stalls READ DESCRIP!
  220. 01 Durango - Front end thud/thunk/clunk
  221. Ecm
  222. Engine replacement, worth it or a bad idea?
  223. Rough Idle, charging issue, no gauges.. help please
  224. Dodge 4.7 liter engine vs. 5.2 liter engine
  225. Security issue.
  226. Hot air on driver side when AC is on.
  227. New to the Forum, just bought an 01 Sport, few questions
  228. Mystery connector.
  229. Still burning oil
  230. Warning Chimes Start After Driving for 1 to 2 Minutes
  231. Transmission issues 01 Durango
  232. how to check timming 4.7
  233. 99 slt 5.9 4x4 Diving without REAR drive shaft ????
  234. 98 Durango 5.9 auto no overdrive. Please help.
  235. codes 351/355
  236. 46RE 2nd Gear Shifting Problem
  237. 4.7L Engine Swapping
  238. Vendors for new PCM
  239. no dtc found 2003 durango
  240. 2000 durango 5.2 overheating
  241. Dodge Durango
  242. 2001 Durango CTM Replacement Questions
  243. Sudden Misfiring and Trouble Codes
  244. Blower Motor/Fan Speed issues
  245. 2001 Durango w/4.7l cooling issue
  246. intermediate steering shaft
  247. IAC motor replaced high idle
  248. Introduction - TrevorWA
  249. Front end problems
  250. ac compressor runs even with heater on
