View Full Version : 1st Gen Durango
- whine in 2001 Durango rear
- whurring noise from back
- Removing a 5.9L from a 1999 Durango
- where are the antifreeze drain plugs on the engine block
- Rear whines on 2001 Durango
- Intermittent burned grease smell
- oil consumption and the PCV valve
- poping sound while turning?
- 4WD Not working, no power to switch
- engine block antifreeze drain plugs
- Squeaky sounds
- 03 durango ac help cold air at low blower speed but not high
- 98 Durango Aftermarket Radio Problems
- How to drop my Transmission?
- Tell me what you think
- lower temp thermostat
- NO REVERSE - Everything else wonderful!!!
- Camber issue
- Replace Instrument Cluster, now 'no bus'
- My poor truck
- A/C Problem
- Trans took a dump
- 2000 durango RT good or bad
- A/C not functioning correctly
- Speedometer Bounces
- Door chime won't stop!
- Turn signals, help!!!!
- 2002-2003 DVD System into 2001?
- 98-99 Towing Capacity?
- '01 Durango went nuts!
- tire pressure
- Chrysler Nationals 2010
- for sale tailights durango
- Intermittent AC problems
- '02 Durango won't start easily
- tune-up
- wiring diagram 2000 4wd 4.7
- Ambient Air Temp Sensor
- '99 5.9L Durango slt feels a lil tired
- O2S Code PO132 Won't go away
- alright heres a random one.
- A/C works sometimes
- I need help bad!!!
- 2001 Durango 4.7L 4x4 overheat
- P0442 & p0455
- blower motor power wire to resistor keeps frying.
- 2000 dodge durango ac problem
- 2003 body lift
- 99 durango cranks for awhile before it starts
- First Durango - Wouldn't start - Thank you!
- Cherry Bomb
- Help please
- Multiple Misfire
- Transmission Noise
- I just changed my brakes on sat
- Thread size?
- Wanted: 60/40 third row seat
- rear locker?
- Brake Dragging
- piece of ****!!!
- 2000 Durango Vibration
- Engine diagram
- Grinding sound
- transmission problems.
- P1740 code ?
- Removing front bumper?!?
- how much for lift kit?
- EVAP Hose '01 5.9L
- Drain & Flush
- Trans interchange
- Trans interchange
- Engine will not warm up + heater doesn't work
- need some help
- Can I Remove the Bolt/Flange on the Back of the Front Diff?
- Duranged408 gets body dropped
- some pictures
- Rear A/C problem
- Replacing liftgate..HELP
- 98 D instrument cluster stopped working
- 2000 durango 5.9
- another electrical gremlin
- Engine upgrade for my R/T
- Transmission Problem?
- Noise/Grinding while driving
- 4x4 problem plz help!!!
- Humid Ventilation Problem
- possible power steering problem??
- 180 deg t-stat on 4.7 ltr
- 2000 Durango 4WD Shift lever.
- humming when i turn left (only)
- low oil pressure problems
- Why am I so stupid...
- Could it be short or something simpler?
- P0455 and Problem Pumping Gas
- how bad is it?
- Replacing Harmonic Balancer
- Chrome touch up paint for lettering
- 99 Durango Stalls While Decelerating/Turning
- Cabin Fan Speed
- IAT sensor
- 01 Durango Engine
- 2002 Dodge Durango Light Problem
- Transfer case?
- Transfer Case?
- Smoke coming in through the middle vents
- IAC and TPS replacement
- 2002 durango 5.9 r/t
- Broken Part
- Brake light help
- Brakes!!!
- Fuse Box
- What's the bleed procedure on these bad boys?
- Heat Issue, Fan, Cooling.
- rebuilt 518 tranny
- Broke the crankshaft position sensor off in the block...
- 01 Durango Engine
- Power windows and cd player
- Auto tranny
- 00 durango 5.9L waterpump
- First Durango
- need serious help here.
- Very poor mileage- need help
- Shift RPM's
- Head Unit Question
- Need some advice on things
- Gremlins in my 98's locks
- Step by Step Directions for Removing/Replacing CV Joints
- 2000 Durango AC wiring guide
- Do I need to reflash for a 2200 rpm converter?
- Rebuilt tranny issues
- No back brakes. Plz help
- Towing pictures
- 2002 durango starts then dies
- Window problem...any ideas?
- What a pain
- The Correct Way To Purge Any Transmission
- PO202 Help please
- Fuel Injectors.
- Transmission cooling lines
- 2003 Dodge Durango Blower Motor
- Heat and A/C Issues
- '01 Durango - Alarm keeps going off
- 46RE issues, 1999 Durango 5.9L
- alittle pressure taken off?
- Any Suggestions?
- Superchips flashpaq works?
- Rotors
- Trouble Shooting a Clicking Sound
- Power window and door lock issue
- front carrier mounting boss
- 98 Cruise problem
- Help!!! Temperature issues.
- Gearbox replace again
- What is "normal" running heat range in the summer?
- CB and PA setup
- Durango lift kits and the risks involved.
- My '02 D!
- free!!
- Dumping fuel/Tach goes Nuts
- quick question.
- Stock E-Fan Taurus Replacement
- Stupid Question
- Buying 2000 Dodge Durango
- transmission problem!
- Which seats are interchangable?
- 2000 Dodge Durango burnt tip on #8 spark plug
- 4.7 head removal
- AC Compressor Question.
- Dash trim/back up camera/stereo/gps
- i went big
- 1999 Dodge Durango 5.2 Upgrades- Ideas and Projects
- 1999 Dodge Durrango - Potential Buyer
- An invite to 3rd Gen. TOTM!!
- Fluid change
- 4.7 engine sounds like a diesel.
- camshaft position sensor
- Power Steering Flush
- Need some help on my durango oil/pinging problems
- Everything electrical is going out at once (blower motor, window) Ugh!
- 3rd gen ram totm! Yall come vote
- What engine will fit?
- Transfer Case 4H PT, 4L PT light
- play in steering...
- 2000 Dodge Durango odometer does not light up
- Strange noise? 02 sensors?
- Irratic idle
- Tranmission issues - Need Help!
- Thermostat ?'s
- PCM failure?
- Chrome eagle eyes ccfl pics
- Steering column universal replacement
- 1999 starts but wont stay running.
- I'm pretty sure I need an alignment
- Power Point fuse help!
- A little help?
- Side view Mirror ??
- 99' Mystery Knock....
- 2000 Mystery Knock....
- need help with dodge durango transmission
- 01 Durango front axle replacement
- just bought a 99 durango\questions
- Cracked wheels
- 02 durango no rear heat
- changing diff and steering fluid
- 99 Durango No start. Am at a stand still please help.
- fuel filters
- 02 Durango Electrical Problem
- my 02' durango keeps stalling at stops after replacing parts. *HELP*
- my 2002 durango keeps stalling after parts are replaced! HELP
- It is a sad, sad day at my house...
- Oh NO!!! Transfer Case, Tranny or???
- Help! 2001 stalls when stopping!
- Front Axle removal
- Ignition cylinder 03 durango, rebuild or replace??
- Black smoke, CEL, and pulled codes
- 5.9 '99 durango shifting problems . . . now possibly ECM/PCM problems
- Well axle seal is blown. Now what?
- Panic Alarm problems
- 99 durango problems
- Need a front differential... help?
- IS there a way to adjust steering box?
- 2ohm speakers?
- 01 Durango control arm bushings
- No Cold Air?
- Dual CCFL Halo headlights pics
- Tires and rims.
- Drive it off a cliff????? (MAJOR Cooling sys. issues)
- 03 up hill studder on power
- Screwed up Installing Cell Phone Mount
- Front End 2000 Durango
- Hesitation issues
- Is this a fair quote?
- Leveling Kit
- Intake Question for the 4.7
- Premium Gas in the RT?!
- Do You Know of Any Good Repair Shops?
- Nitrous on a 5.2L... need advice
- Durango / Dakota . Same Size Tires
- Transmission & differential maintenance - advice needed
- Durango just dies while driving
- help wont start
- replace my generic overhead console
- Chrome Grill on 98 D
- "Squeeky" front end?
- the proper way to convince the wife to get new tires
- Blower motor resistor fail
- 2001 lower ball joint replacment
- Summit Racing G904000 Shackle
