PDA
View Full Version : 1st Gen Durango
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. 2000 durango owner
  2. Brake lines
  3. New 2000 D
  4. 2000 4.7 ECM question.
  5. 2002 Durango RT 5.9 not driving in any gear
  6. Need help 2003 durango cruise
  7. 1998 SLT air conditioning only blows when engine is off
  8. Crankcase pressure
  9. 2001 dodge durango
  10. Overcharging
  11. Not running on all cylinders
  12. 1st gen 46re 5.9l shift issues.
  13. R/T 2000 Durango. Misfire and smells rich when idle.
  14. Side turn lights
  15. 00' to 02' dash swap
  16. 2003 Durango 4.7 superchips
  17. 98 5.2 Tune?
  18. HVAC mode door actuator 99 durango
  19. Engine Temperature Fluctuations
  20. PLZ HELP! Overheating- Water Pump Sealant?
  21. 98Gen1 Abs light, no speedo
  22. New Headlight lens
  23. turns over, but won't stay on
  24. Need help 2003 durango
  25. Fan blower motor
  26. Hello Everyone
  27. Overheating issue
  28. AC woes
  29. I cannot stop the thermostat from leaking
  30. Control arm question
  31. 1999 Durango electrical issue
  32. Spark plug threads inconsistent
  33. 02 durango transmission issue.
  34. 4x4
  35. Lost spark on one cylinder.
  36. Engine running ruff
  37. Cant find component name
  38. blend door cable adjustment
  39. 2001 R/T: Which Radiator?
  40. Brake Booster compatability
  41. 03 4.7l runs rough, sluggish.
  42. accertate by itself
  43. 2000 durango EPS / Gearbox conversion?
  44. 2003 durango
  45. Trans swap
  46. 02 Durango Won't Run
  47. Recirculating door broken
  48. 02 Durango R/T 5.9. A/C issues
  49. electric gremlins
  50. Shifter won't shift out of park
  51. front brakes lockup when turning
  52. transfer case
  53. Leaking power steering rack
  54. Going NUTS
  55. Bues Brake.
  56. Going NUTS
  57. 1st gen durango clear headlights
  58. Fuel Pump
  59. New to this forum
  60. RT’s built in 2003?
  61. Amber Flashers for United Kingdom
  62. 2002 4.7 Durango HVAC Actuators
  63. Blowing Smoke - 2000 Dodge Durango Sport
  64. hit a cow... impact sensor
  65. Transmission
  66. Np231 swap
  67. Heads overmilled 4.7?
  68. Front turning light bulbsa
  69. 2003 Durango 4.7 High Idle
  70. 2000/5.9 one more thing to try.. No spark or fuel pump
  71. camshaft reference signal lost at pcm.. et al
  72. Overhead Consol
  73. 1998 Big Brake Conversation?
  74. Another 98 Durango Build.
  75. Just picked up these for 2500$ any thoughts
  76. Steering gear wornout? Why always to the left?
  77. Is this the end????
  78. in need of 4.7 coolant hoses/ heater hoses
  79. Issues with my 99 durango
  80. Shifter
  81. Tuner Reccomendations
  82. 4.7l P0302 code but runs fine
  83. Fuel Consumption/oo,5.9,r/t
  84. 5.9 and transmission out of a 94 Ram 1500 into a Dodge Durango 98
  85. search for 2000 durango brake line diagram (one proportioning unit).
  86. Camshaft location sensor 94 ram for a 99 durango
  87. New to this forum; but need some help on a few things PLEASE??
  88. maintenance
  89. 2000 Durango 4X4 270K and 140 PSI compression
  90. Fast Blinker only when Braking
  91. Anti-glare velvet
  92. Looking at Durango for a Family Rig - Looking for Inputs
  93. '99 Dodge Durango Fuel Rail Leakage
  94. 03 Durango SLT+ 5.9L Radiator Fan Relay
  95. Fixed heater core. New problems :(
  96. 2000 Durango 4X4 Blower works when it wants
  97. Replacement Infinity 6.5" speakers (Found)
  98. 2001 Dodge Durango SLT + Interior rear door handle
  99. engine bay mud guard flaps
  100. can't shift into 4x4
  101. Help with gas mileage
  102. 2000 5.2 Hard to start
  103. 03 4.7 Heater Hose Question
  104. SOS no crank - 2000 4.7 slt
  105. Throttle Body to Carb
  106. Cold starts
  107. Thread not showing up
  108. 2000 Durango 4X4 Anti spin diff clutches falling apart
  109. 98 durango trans swap
  110. Brake Fluid Level Sensor
  111. ISOFIX on 1st Gen
  112. to unscrew an anti theft bolt
  113. where is coolant leak?
  114. Great 4x4
  115. 2000 Dodge Durango Sport - Issues
  116. Transfer case
  117. 4.7
  118. Rear axle broke at wheel
  119. 2003 Durango 32x10.5x17”. With 1.5” spacers rubbing
  120. one fog light out
  121. ABS module - my98 - 5.9 L
  122. New member w/1998 Durango
  123. 2002 4.7L Durango stalls NoBus error
  124. stray wire
  125. Help! 98 4x4 transmission leaking fluid near output cooler line
  126. Engine/battery ground locations for 2000 4.7
  127. battery 12V power outlet
  128. 2002 durango slt 2wd
  129. baby it's cold outside!
  130. I hate Dodge
  131. Durango Acceleration/Hard Start Issues
  132. Electrical head scratcher. Any ideas?
  133. 03 Durango 4.7 Fuel Mileage Issue
  134. No door chime on 02 Durango SLT Plus? (First Durango I’ve owned)
  135. DDI - worth buying as youngtimer?
  136. Transmission Whine 1998 Dodge durango SLT
  137. Hard acceleration engine shuts off
  138. Need advice
  139. Nv133 to nv244 change
  140. What the??
  141. Change the thermostat or the whole water pump?
  142. Turbo-ing 4.7 motor (theoretically)
  143. 2001 4.7 oil pan replacement question
  144. Durango transmission squealing
  145. Bought a 'fixer upper' last week; 2000 Durango
  146. 1999 Durango No Reverse: Posted pics of my fried clutch plates and worn gear
  147. Motor Swap
  148. IAC, AC, No Bus
  149. Truck shuts off
  150. Super Backup Bulb or Aftermarket Cover ?
  151. Advice About Buying a 2003 Durango
  152. 03 Durango 4.7, intermittent stalling on startup
  153. 2000 Durango 4.7 Turn signal issues
  154. The 45 RFE mystery
  155. 99 4WD Rear Jounce Bumpers
  156. 99 dodge durango help
  157. Rear blinkers staying solid, front ones flash.
  158. Power seats
  159. 99 to 03 front brakes
  160. Bleeding cooling system
  161. Chime ringing continually
  162. Top end rebuild advice
  163. Ignition switch woes
  164. 2000 Durango Seat Replacement covers?
  165. Fuel Delivery Mystery 03 Durango 5.2
  166. Fluid pressure actuator
  167. 03 Durango 4.7, Ac Clutch Always running
  168. 4.7 tuning question(s)
  169. Cat Replacement Question
  170. Motor Mounts 'settling'
  171. No Bus or Should I take the bus.
  172. 1st Gen to 2nd Gen swap ideas
  173. Brake Caliber
  174. Back up, & rear brake light problem.
  175. I'm stuck
  176. Engine stall the no transmission engagement
  177. 2002 Durango starts but stall out immediately even with gas pedal depressed!!
  178. 03 stuck in neutral
  179. 2000 Durango 4.7L cabin fan issue
  180. 2000 Durango 4.7L check gauge issue.
  181. 98 Durango 5.9 4x4 steering knuckle part unfindable!
  182. 99 5.9 bottom end work advice
  183. ISO First Gen Durango R/T
  184. 03 Durango ABS light on
  185. air bag light and chime keep coming on
  186. High RPMs on start up, idle, and while driving
  187. 1999 Shelby Durango SP 360 #81
  188. G1 Durango vent door broken in three places - Cause:
  189. 02 durango 4.7 heating up to 3/4 at idle
  190. 4.7 cooling system issues im having
  191. Insane.. best way to approach ?
  192. Body work causing issues
  193. Grounding strap issue
  194. 2 power windows dropped just hours apart
  195. 4.7 cranks but no start
  196. Looking for new grille
  197. Cooling fan connector location?
  198. 03 Larado 4.7 to O1 Durango SLT engine
  199. Alarm problem
  200. Multiple dash lights
  201. Rearm security after remote start?
  202. Transmission control module
  203. bumper covers
  204. Sourcing 08 cams for 4.7
  205. FSM for 98' Durango
  206. Looking at Upgrading campers
  207. Fixing her up
  208. 2000 Durango 4.7L with "gremlins"
  209. Puzzeled about wet floorboard?
  210. 4.7l HOAT vs IAT
  211. Is there supposed to be a bracket between the bellhousing and engine?
  212. Parking brake
  213. Replacement Driver Seat Track
  214. 1999 Dodge Durango 5.9L Front Brake Issue
  215. P0300 ECM Code
  216. God Forsaken Demonic NO BUS
  217. 2000 dodge durango 2wd 5.2l
  218. ECM Codes
  219. Mopar oil filter
  220. Brand new flex plate +TC, Still knocking??
  221. New sheet metal experiences
  222. Help with replacing helicoil in stripped steering knuckle
  223. Drivetrain swap-ability
  224. OEM Trailer Hitch wiring connector is screwy I think
  225. Overhead Console Lights 2003
  226. Liftgate Swap out.. wiring harness
  227. CCD Bus Troubleshooting - Can't Connect to ABS, CTM, MIC But Can Connect to PCM & TCM
  228. 2000 miles out of a idler arm
  229. P0753, I have read may a thread on this but I my be unique.
  230. I need some knowledge
  231. 2000 5.9rt tranny to a 2002 5.9 engine will it work
  232. Need new bolts for front driveshaft
  233. Does The 1st Gen Durango Have A Front Axle Disconnect?
  234. 2000 Durango 5.9 engine vibration
  235. Brake booster spacer
  236. 1998 Dodge Durango Transmission leak
  237. Motor rebuild\electrical issues
  238. Where to mount front fuel line bracket?
  239. Oil Catch cans
  240. Front Differential rebuild
  241. P0201 with rough idle.
  242. Durango 4.7 to 5.2 engine swap
  243. Steering
  244. Front axle
  245. Abs
  246. Brake line question
  247. Transmission band adjustment
  248. Key fob programming
  249. Exhaust Leak Manifold to Cat Pipe Clamp and Bolt Replacement
  250. No bus
