View Full Version : 1st Gen Durango
- Need Help to Repair My 1st gen Durango
- distributor cap question
- Engine knocking?
- Cel: P0302
- O2 sensor issues
- I know, I know...Why WHY WHY!!!!!
- Accessories
- Headlight with HID's?
- Cracked Heads, Now what?
- Wheres the air intake for the HVAC?
- Find replacement clock spring
- Differnetial Fluid replacement
- Oil Pressure, A Prob Or Not? With Pictures
- fluids ???
- axle flip
- Same D, different problems!
- ac clutch relay
- Replaced blower motor resistor. Pics inside!
- pinnion seal replacement
- ABS and Brake Indicators on After Replacing PCM
- Blew upper radiator /cooling system
- Wont start
- my 01 durnago's A/C only works on high, did i blow a fuse? PLEASE HELP
- tune up time and retune
- Lighting/electrical issues in my 01 D
- anybody else runnin dex cool
- At a loss.
- Problems with 2002 5.9 liter V8 Durango
- Steering "bump / lump" left and right
- cylinder #1 misfire p0301 headache ouch!
- Pinion nut torque?
- 98' 5.2 Expansion Valve Location
- 5.9 coolant leak
- i need a service an online service manual.
- Recommended tune up parts?
- 10 year old Durango and Still OEM brake drums and pads
- 4x4 & O/D Q's
- Clearance Lights - Anyone have them?
- Need some advice
- Steering gear box rebuild, anybody done it?
- Half door project
- 45RFE Transmission Slipping
- Been a while, but need your held once again.
- Time for first oil change
- Oil and engine temperature
- 2001 Durango R/T warning light problem
- Runs fine on initial start - Wants to stall after a minute.
- Support Braces?
- Some tips for off-roading
- Oil filters revealed - Discussion
- oil filters revealed
- BBK Throttle body?
- Who put the 2002 Service manual up?
- 44re Trans Diagnostic info
- 2001 durango 4.7l won't start
- finished the last of the problems with the 99
- engine treatment and inner cleaning.
- Diagnosis help.. Ign. Coil?
- heli coil help
- pinion seal
- Removing Dashboard
- Transmission Temperature
- Oil Light 2003 Durango
- 1999 Durango started overheating
- Tie rod ends/Steering gear
- 1st post! New rig!
- Tired of doing same work over.
- 2002 Dodge Durango 4.7L NO BUS
- gas filler neck1998 durango 4 x 4
- Trouble with 01 Durango mysterious whining noise
- Coolant resivor bubbling.
- 03 blower dead
- I need help with my A/C
- 1999 Dodge durango died and won't start!
- 44re or 46re
- TCM Reflash: From 2002 to 2004
- high rpms after replacing radiator
- my d is acin wierd
- new to forum and need help, no bus
- 1998 Durango SLT not holding idle
- I wanna see your modded Durango!
- Cold Air Intake Questions
- Need new downstream o2 sensor pigtail
- My first DIY Tune-up
- Fuel injector cleaner ??
- A/C leak in the rear lines. How do I bypass it?
- Transfer case leak
- No headlights
- Opinions on My Situation
- July ROTM
- tv cable issues
- Shift Kit Q's
- Horrible gas mileage!
- Loud AC
- PCM cable lock broken
- Tested used transmission not working properly
- "JEEP" doors on durango??
- 4.7 L No Start Electrical Issue
- Fuel Injectors
- 03 durango 4.7 engine tick
- Looking for a 1st Gen Durango - helpful advice
- trailer brake problems
- neutral safety switch problems
- Leaky Radiator... which radiator to replace it with?
- exhaust system replacement
- 3K miles/yr, how often to change oil?
- 1999 Durango Owners Manual
- Door jammed?
- 1999 Dodge Durango suv shut off when driving help!!
- School me on bored Throttle Bodies
- 99 Durango Rough Cold Start and Idle
- high rev sounds
- where do you get a durango lift kit
- engine losing power
- Infinity speaker woes. . .
- possible transmission isues?
- ideas for 1st gen off the line pulling power
- Durango Vibration
- Wheel bearing?
- 98 Durango Grind/Growl on corners forward/reverse low speed
- Overhead console HomeLink Lights
- Transfer case rebuild
- Dies/stalls when coming to a stop or turning, backfires at times
- 99 dodge durango a/c issues weres the best place to get parts
- Comp Cams
- Performance stuff
- A/C blowing hot
- need a durango specialist in northern nj
- Anyone removed their transfer case shifter knob?
- strange problem arisen
- Upper Radiator Hose replacement
- AC/Blower Issues - 01 Durango
- ABS, airbag lights and no spedo HELP!
- Slight play in front wheels
- removing glove box bulb
- I Got Problems
- engine Knocks .
- 5.9 RT low power
- Still rattles!!!Suggestions Please
- New motor or just fix this one
- govenor
- Loose Flywheel???
- Lower ball joint frustation!!!!!!!!!!!!!
- home brew CAI
- 02 Dodge Durango Issues.
- governor pressure solenoid replacement directions needed. please.
- 98 first to second shift
- Mopar air cleaner
- Towing question to save another Mopar
- console issues
- powersteering oil cooler... where the heck does it mount???
- how do you detect limited slip?
- Shift Shaft Seal
- Personal win, but...
- Electric cooling fan
- 2001 rango 5.9 hungry for crank sensors
- Farewell
- Complete brake failure - HELP
- 2001 dodge durango rear passanger window motor
- Best positon to put it in
- CAMs Question
- 2003 4.7L Durango replacement Cat
- Can I swap seat bottom covers?
- 2001 4.7 4x4 Shifting Problems
- ABS Light and Vibration
- 2000 dodge durango,,,, HELP!!!!!
- I'm back with questions!
- 99 Durango PCM issue
- Factory radio components
- Coolant amount after flush
- Radiator drain valve location (pic)
- 2003 Durango AC issues
- instrument cluster
- Elec fan wires are getting hot
- 02 durango cannot read codes from scanner
- noise while driving 2003 durango
- Dashboard lights don't work unless....
- diagnostic monitor data explenations non can vehicles
- Fuse for O2 Sensor
- polishing the aluminum
- 4.7 Head Removal - Help please.
- Brake Light ISSUES!!!!!!!!!!!!!!!
- Need directions
- 1999 Dodge Durango 5.2L CAMs
- iac or tps cause no start?
- What is this part? From console?
- Help me PO725
- Weird electrical problem
- 2002 Durango - Front Sway Bar Bushings? Where are they?
- AC only works in back seats
- 1999 5.2liter v8 Dodge Durango turns over but no start
- 02 Durango 4.7 need to drop the oil pan
- searching
- tranny question.
- 02 Durango Center Console Power
- Bringing up tender subjects...
- Why these trucks don't bring any money?
- Electrical problem after replacing heater core
- bad fuel pump?
- Tie rods?
- Can a bad t-case cause issues in 2wd?
- 45RFE weird shifting from 2nd to 3rd
- 44re to a 46re swap
- 2000 dodge durango starting problems
- Is there any way around this?
- AC compressor knocking
- just bought a '98 durango and have alot of steering play
- Help!! Transmission issues!!
- Ball Joints or Control Arm?
- 2003 Durango 4x4 4.7L
- No Power when Accelerating
- Replacing upper radiator hose question
- Finally got to tear into her
- ABS module compatibility
- Safari Light Bar
- Driver side window only works
- gearshift problems 46RE
- lower shackle bolt ceased in leaf spring sleve!! t/s lift dream shot down.
- Tranny pronblems
- Backspacing
- Electrical Issue
- Alternative replacement Torsion Bar
- Weird one! 2003 Durango starts easily, no power to certain things
- Removing factory Running boards
- My '02 sounds like a Cessna
- ABS Module P/N ??
- 01 R/T question
- 98 Durango Air Conditioner
- torsion bolt ceased. I want to do my t/s lift!!!!
- Strange sound coming from my D
- IFS Lift must have
- 5W-30 vs. 10W-30
- trans problem
- Replacing rusted oil pan on 2000 durango 4.7 4x4?
- Searched and looked for these a/c problems
- Shelby SP360 #192
- Need pointers to replace condensor fan
- blowing warm air
- T/S lift materials
- Transmission won't shift
- new plug wont tighten
- looking to buy a 2001 durango
- Two questions. Front sway bar and control arms.
- Headlight problems
- need help figuring out radio wiring
- Posible new Durango owner need advice
- Spark Plug Replacement
- Trim panels
- Lifting My D
