PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. Blower motor acting up
  2. Seafoam
  3. 2001 Durango with a possible ABS brake issue... need help!
  4. 01 4.7 AWD/4WD Coolant Overflowing
  5. Another A/C Question (2000 Durango, 4.7L, Rear Air)
  6. Transmission electronics wiring diagram
  7. New Member with major prob.
  8. WTH? noisy 4.7
  9. 1999 Durango Shift Lever/Cable parts issue
  10. HOW TO INSTALL FRONT SHOCKS ON 03 Durango?
  11. jet chip
  12. 2002 Durango Help
  13. Governor Pressure Sensor?
  14. nv133 info needed
  15. Stalling/Idoling crazy etc
  16. low seeting on heated seat?
  17. Spare questions
  18. Engine making "grinding" noise
  19. another "ticker"
  20. 2001 Durango Rotor Change help
  21. 2002 durango overheating
  22. Window Motor
  23. durango alternator interchange
  24. New member with durango issues
  25. confused on what i need done? is it a tierod? PLEASE HELP **pic inside**
  26. 01 Durango 4.7 won't start
  27. Coolant issue....
  28. 02 durango electric prob
  29. Newbie DIY hesitation problem
  30. Won't keep running
  31. Hemi Swap??
  32. Coolant overheating coolant problem
  33. looking at picking up an 02'
  34. OBD code P0171
  35. can i fit 5 1/4 in my 6.5 holes
  36. 01 durango gas pumping issues
  37. Wanting to replace Crankcase breathers
  38. I need to pass deq!
  39. I Took It In
  40. Cold air intake questions?!?
  41. 99 Durango mystery down gearing, help needed!
  42. 02 Durango batter or alt ?
  43. Shifting issues
  44. Possible Fuel Filter Problem?
  45. New cats and flowmaster?
  46. ugly sounding clunking
  47. 2003 Durango misfire in #8
  48. A/C driving me nuts
  49. 99 druango 5.2 4wd brake problems
  50. intermittent power steering failure
  51. wheel bearing
  52. Ambient Temp Guage
  53. New Steering Rack, any insight?
  54. Wiring durango for trailer?
  55. Check Gauge light on
  56. 2000 durango tranny issues
  57. Durango trailer lights
  58. Help a newbie!! 1999 Durango, 5.2L - O2 sensor issue
  59. 2000 Durango Transmission Lurches
  60. hi all new to this place ... does anyone know about my 4.7
  61. I want to black out my taillights Ideas????
  62. Does a year 2000 PCM work in my 1999 Durango?
  63. dummy o2 sensor
  64. RB1 and Sirius HELP NEEDED
  65. Speakers for 2001 Durango
  66. 2000 Durango Humming Sound
  67. Help
  68. Frame Washable air filter?
  69. Help what type of shock to put in a durango 2003?
  70. Intermittent ignition, Brakes seizing...
  71. What is this?
  72. German Guy needs OEM Wheels (for Winter) for Durango 5.9 (1999)
  73. Hydrashocker help... Alt/PCM
  74. Serious AC Issues :(
  75. Duplicolor wheel painting?
  76. Help!!! Trans cooler lines
  77. Can't fill your gas tank gas pump keeps shutting off like it's full answer
  78. No (Front) Heat or A/C in 03 Durango
  79. where to buy parts
  80. 03 Durango What is this Switch for
  81. Vaccum line to Heater / AC contols
  82. need new TIEROD **please help** tire bald on edge
  83. K & N Air Intake Kit
  84. Any idea what is causing a hum in my Durango
  85. kingoftows Durango and Duster/Trailer photos
  86. 2003 Durango Battery Cover / Heat Shield
  87. less mpg after spark plug change
  88. solid axel swap?
  89. Open AC system
  90. ????
  91. Need new tires, opinions wanted
  92. Cold Air Intake
  93. Cooling Issue
  94. Burning Smell From Hood???? Please help
  95. towing a 29 foot camp trailer
  96. Durango Doors/Body
  97. My T/S lift
  98. Tinting Taillights
  99. Dakota/Durango wheel interchange
  100. Trans Temp worries
  101. 2000 durango 4.7 a/c problem
  102. Modified Fog lights
  103. Brakes
  104. little nervous..
  105. 1999 durango tranny quit working
  106. 2000 durango
  107. Code P0445
  108. 99 Durango Trans problems help!
  109. fog lights question
  110. Suspension, Tires, Throttle body
  111. Brake pull
  112. ac compressor knocking
  113. Rear ac blowing hot, front sort of cool.
  114. Rough idle at first - P0441, P0300, & P302
  115. '02 Durango Blower Motor - not the resistor!
  116. Transmission bands
  117. 98 Durango tranny ?'s
  118. AC Compressor not cycling off at all
  119. 17s that came on my durango, looking for what brand they are
  120. 3000k HID Fogs
  121. 2001 Durango 4.7 "clanking sound"
  122. T/S Lift New Tire Size
  123. Recall: Ball Joints.
  124. 02 dome light falls out
  125. Combined thread....Infinity speakers/A/C line insulation wrap
  126. My New Shocks Suck!!
  127. Rim Size Question...
  128. 1998 Durango 5.2l v8 won't start but battery good?
  129. cooler A/C?
  130. Radiator hose
  131. I found this AMAZING
  132. Mind Boggling
  133. Need some help please. Durango will not start after putting dash back in.
  134. 98 durango transmission issue
  135. 5.2l intake question
  136. Fried fuse holder
  137. 2 Inch Lift
  138. What does this connect to?
  139. Vent door stopped working
  140. Adding an E Fan
  141. Front suspension rubber stop on a 2WD D
  142. Is it possible to crush a Filipino mechanic with a D...??
  143. '02 front left brakes smoking/drag
  144. Clutch Fan vs. Electric Fan
  145. Bilstiens: right ones and worth the $$?
  146. Source for stock suspension components
  147. Day From Hell - have chuckle at my expense ...
  148. Friday the 13th
  149. Looking for a lift for a 03 D
  150. abs brake light
  151. 3-4 shift error code
  152. front end noise
  153. Alignment question
  154. Question about Infinity speakers
  155. Headlights won't turn off
  156. Time for the me to install my system
  157. how do I move pictures from my files to different areas of our Dodge Forum?
  158. Fit in Garage
  159. Front pump bushing?
  160. Need help with lift and tire seize?
  161. Cruise Control Problem
  162. Intermittent Short in Dome Light Circuit
  163. Durango ride height....
  164. Problem
  165. any nicely peformance modded durango's?
  166. Welcome our new section moderator
  167. Empty Connector Under Hood
  168. Still a transmission issue!
  169. Has anyone seen this before?????
  170. New D owner
  171. 1999 Dodge Durango Up Shifting Problem
  172. Adding Tow Hitch
  173. stock cat vs high flow vs test pipe
  174. 4 X 4 Drive shaft/ propellor shaft.
  175. 2001 Durango Shifting problems
  176. 2003 Durango noise
  177. how to change interior bulbs?
  178. 99 5.7 A/C compressor leaking - repair or replace?
  179. something went wrong with my AIR!!
  180. Oil Pressure is dropping to ZERO
  181. Lost
  182. Quick help on differential
  183. New member - Used D
  184. Automatic To Manual Trans swap.
  185. Just Clueless, need help?
  186. Part Question?
  187. Rear Brakes
  188. Weird transmission level problem.
  189. painting door handles and mirrors
  190. 98 durango over heats.HELP!!!!
  191. PCM going bad??
  192. Tranny band adjustment pics/info?
  193. 1998 dodge durango lights
  194. Seeking Help on 03 Durango Transmission
  195. 98 durango A/C stumping me
  196. Radio staying on!
  197. 02 Durango heat/AC fan will not run on high
  198. Tire options?
  199. Swapped the PCM now "no bus"
  200. Bouncing idle
  201. Southeast members...
  202. P0344 code on 03 4.7l
  203. Trans Temp Light.....
  204. scan code po441 and stalling.
  205. Buying parts on Ebay ?
  206. Throttle Body or Fuel pump (Video)
  207. BCM or CTM for '99 Durango wanted
  208. Newbie
  209. Removing grille from Durango?
  210. i have a problem with my 01 dodge durango 5.9 r/t
  211. PCM Failure
  212. Alarm install question
  213. Projector Headlight Issue
  214. Adding Navigation and Rear seat entertainment?
  215. What is the 4 way cross piece called over the grille?
  216. Part number needed
  217. 2000 front a/c only works if rear a/c is on
  218. Rear locker
  219. It just quits running?
  220. low oil pressure!!!
  221. Engine compatibility
  222. Any ideas
  223. Durango wont pass smog
  224. 4.7L intake manifold modification
  225. Engine compatibility
  226. A/C Problems
  227. New member/Dodge owner/Intro- and some problems
  228. AfterMarket Exhaust Thoughts for a 5.9
  229. My new Durango
  230. junkyard rearend swap ?s
  231. Durango won't stay started?
  232. Possible Tranny problem? Help ...
  233. Coputer tuning options?
  234. Body Control Module (alarm troubles)
  235. yet another blower problem...
  236. 1999 SLT Cruise Control
  237. Please Help Me with my 1998 Dodge Durango SLT
  238. Crap, It's Broken...
  239. Rear Stabilizer Nut Size
  240. Blower motor control bad?
  241. my new 99 5.9L.. long crank before start..
  242. Durango Dakota Leaf springs
  243. Radiator Bracket
  244. Time for a new exhaust
  245. Airbox stink
  246. Low cabin airflow
  247. Passenger Power window
  248. Transfer Case linkage issue
  249. 01 Durango alarm trouble Help!!!
  250. transfer case issues
