View Full Version : 1st Gen Durango
- the possible death of a durango
- Stuck in LOCK
- 53032126AA Baffle, Oil Fill Housing Install
- Trying to diagnose a problem
- 1998 durango front brakes
- 2000 Durango 02 sensors - Need help
- Towing hitch wiring question
- 98 Durango Overdrive Problem
- do the computer mods work? Are they safe?
- Vibration / humming noise - need help
- speaker replacement in a dodge durango
- tie rod ?
- LOUD NOISE -MAYBE AXLE.
- Strange Noise/Vibration
- back hatch 1999 durango
- 2000 missing Durango
- Tranny, Tranny, Tranny
- Air intake
- overheating problems
- Working on a tune-up, need some advice...
- Looking at buying a 99 Durango
- Need help with my seatbelt...
- Radio Woes
- trans speed sensor
- Check 4WD light - Transfer Case Fluid
- Replaced Oil Pump, now no pressure???
- changing out rotors
- stock 5.2/5.9 intake manifold.
- Torque Converter Recommendations
- Using manual entry when you have keyless
- fuel economy
- MeanGreen
- After market radio with factory speakers?
- Touble code P0456?
- 5.2 to 4.7 ??
- when to use OD
- Battery or Alternator Questions?????
- Stock radio and other misc questions
- something is humming.. and it aint me!!
- My dorango is falling apart...HELP
- lowering a 4x4
- Another Headlight Problem
- Transmission Problems
- Got a new engine in today
- has anyone else had this problem???
- Newbie
- air cleaners vs cold air intakes
- destroyed front end
- error code no bu 5
- Gas Light
- heated seats & tune up
- A/C Selector Switch
- 2003 Durago Lift
- steering wheel controls
- Going on a trip in the Durango
- POWER STEERING gone
- p0141
- Air bags
- Fabtec suspention lift
- A Tire & Mileage question on my '01 Durango
- getting the outsider Air when AC is powered ON in D 2003 5.9L
- Front End Drivetrain -hydra??
- AC
- overhead console
- humming noise
- re: 01 durango r/t
- front coil info
- Having problem with studdering
- need tires... help
- durango wont start dont know why
- Attn Fabricators
- need site for OEM parts
- help suspension!!
- Front Brakes
- codes
- Keys, Shackles, Bumper??? HELP!
- lunch-box style lockers
- Durango Serpentine Belt pulley problems
- Have you had this TSB worked on?
- unusual stalling/wont start problems
- BBK Performance Throttle Body
- H0 4.7L ECU
- Finally Got My Trailer!!!!
- 2001 Dodge Durango RT 4x4
- popping sound when I turn or start to backup! Help
- standard swap?
- 2000 5.9 4x4 Tranny Problem
- Dealer refused to give me Build Spec ???
- How much drop on your hitch?
- 2003 Durango Intermittent chime
- Fitment advice........again :)
- Cruise Stopped Working, but light works.
- A/C Blows through Defroster Only
- one problem after another...
- I Have a problem!!!
- front brakes
- ABS & Brake Light Remains On
- dinging at 60mph
- Door lock jacked up
- Where can I find an OEM sideview mirror?
- Gas Mileage problem?!
- 2002 Durango Lug Nuts
- 5.2L cracked block/head?
- New JVC HU
- door lock wiring help please
- Deactivate 15mph locks on a '98
- 01 durango rear heater
- Speakers questions again
- Anyone know what goes on this fitting?
- Dodge Durango 2003 4X4 overheat Suggested solution !
- 99 Durango Transmission
- whats a recommended air intake system?
- 99 Durango Starter Stays Engaged
- Overdrive Problem
- Need help/advice with AC evaporator core replacement
- Engine sludge???
- Muffler and Cat install
- greasing hub
- Panic Alarm problem, please help
- Heat, A/C or read wiper not working
- 03 Durango mystery front end squeak? Shifter Switch!
- 98 durango a/c runs even when heat is on
- oil leak
- Replacement mirrors & brake pads
- Cruise Control
- 2003 Durango
- deleted
- Heater/AC will not blow correct
- What tools will I need for this?
- Durango 03 stereo install/ speakers
- No Air Bag Light, but pulled codes...
- Strange problem, Please Help
- wierd vibrations
- stopping the chiming noise
- sponsors
- Anyone been to Durango Colorado with their Dodge Durango?
- noise in reverse from front end
- EMISSIONS LIGHT
- 99 Durango Wiring Help Please
- How often should the differential fluid be changed?
- '01 Durango Front End problem!
- PCM/ECM P0601 Help Please
- Best exhaust setup for off roading?
- Tranny woes
- CHANGING VENUE
- deleted
- alarm system '99 Durango
- help. all wheel abs diagnostics needed
- 98 D - Brake issue
- Whats the stock backspacing on 98 durango?
- new to the forum
- change durango bolt pattern
- Ignition troubles
- Model year 2000 ABS system?
- New here, with a problem. Can anybody help me?
- Gas Cap: has anyone actually found it helpful..
- Need parts not sure where to turn.
- Engine stallls
- 1500 rpm, too high?
- wiring for radio 98 durango
- 2000 5.9 durango overheating
- trouble code p done
- 2002 Durango R/T unlocking/locking
- oil reccomendations?
- 98 Durango SLT Problems
- idling rpm speed
- 99 Durango blower motor replacement
- 1999 blower motor replacement
- possible tranny problem
- P0420 1/1 Catalytic Converter Efficiency
- Anyone interested?
- code p1391
- Help me! Anyone!
- Noise in glove compartment- Durango 2000 SLT, 2WD
- Help me......
- oil pressure issues
- Intermittant charging problem
- New Durango Owner
- Today's Humor
- New Durango Owner
- Ignition problems
- Engine misfire at low RPM's
- Haloplug Test
- '03 hemi durango r/t 4x4
- Leaking W/P gasket
- Roof Racks
- 99 Durango, ABS light, no speedo, P0500 code
- 2000 bad CV Shaft haven't found a replacement
- Odd problem
- overhead console.
- Odd Request on Failing Emissions Test -1999 Durango
- Grinding/Rubbing noise from front 98 Durango
- Leaking Coolant & Overheating
- 01 r/t front end hum
- 99 Durango blower problems
- problem setting timing
- KC Lights on roof rack?
- short ram air intake ?
- wiring harness for Ram versus Durango
- 98 wont start spark issue
- Couple Questions- 2001 Durango
- Front End protection
- 98 Durango Keyless Entry?
- Wheel Spacers on 98 Durango?
- code p0320
- Front end noise
- Power Steering Issues!
- 31x11.5 mud tires on 98 Durango?
- Groaning while in Reverse
- Transfer Case Update! NV 242 HD
- 98 Durango reared swap??
- Need OEM air box to get smoged for '98 5.9
- 98 Durango sparkplug problem
- ABS/Brake light
- Rebuild or Replace NV233 Transfer Case??
- P0551
- Engine suddenly got louder while driving
- HELP - Multiple tries to get 4wd light to stay on
- Transmission ?
- Steering Controls/Buttons
- CB Radio
- Fog lights
- spare tire crank
- AXLE Swap? need help...
- transmission help
- need help abs light and air bag light on
- Possible tranny issues?????
- 01 Durango R/T - Need help- Front Drive Line
- Fuel Rail and Line AGHH
- Wiper Arm Tension
- Where is the starter located? 2000 SLT 5.9L
- Roof Mounted Off Road Lights
- Steering wheel side buttons 99 SLT
- 2002 Service manuals availability??
- just a big thank you
- 2002 Durango SLT+ 5.9
- clicking noise
- Formula to calculate speed differences on tires
- '00 D leaked A LOT of coolant ... I thnk
- Towing Capacity?
- ouch
- 1998 Durango with Recording devices?
- wont start really worried
- Rattling noise
- Quick 4wd question from new Durango owner
- ummmm . . . . . . 3rd row seat not locking ? ?
- 2003 durango rear heater blows cold but front heater works fine
- Key fob problem/unlock button turns on panic alarm
- Help with mirror defrosters
