PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63
  1. Durango NOT Starting...
  2. Infinity 63.7i, will they work?
  3. Broken Coolant Level Stick - Trouble?
  4. Can NOT flash used computer!
  5. nascar edition 99 durango
  6. Dealerships
  7. New computer flash
  8. DURANGO WON'T START?? WHAT IS THE PROBLEM?
  9. how much can we tow ?????
  10. Superchargers who has them and experience???
  11. ebay question
  12. intermittant extended cranking???? please help
  13. Squeaking noise.......
  14. Knock in driver's door then window goes down!
  15. Water Pump removal ??
  16. RADIATOR ISSUES 2000 DURANGO SLT
  17. problems... will they ever end???
  18. Newb.. 2nd guessing tune up choices
  19. More Problems.... ARGH will this ever stop
  20. Fan Clutch removal problem
  21. power steering pump leak
  22. Wont Go into Park???
  23. MR.NORM signed my D!!
  24. high idle
  25. So the radio turns on fine, but no sound??
  26. coil over shocks
  27. Upgrades
  28. Thermostat
  29. Durango questions
  30. Thinking of Buying this R/T but something is weird (PICS)
  31. cold start rich fuel
  32. KNN WHISTLE
  33. pros & cons
  34. rough idle,weird up and down reving and stalls
  35. Blinker Problem
  36. 1999 slt with heat stuck on?
  37. driver side power window switch?
  38. universal joint s
  39. Code questions....
  40. THE INNER FLOOD
  41. LEAKING ANTIFREEZE AFTER REPAIR
  42. 2003 4.7 all vents blowing all the time
  43. 03' Dodge Durango Shocks?
  44. Radiator guard/cover
  45. Track Bar for Durango
  46. torque converters
  47. Tune up advice
  48. 99 durango
  49. Highway gas mileage 4.7L V8
  50. 2001 RT transmission swap to manual
  51. How to resolve code P1594?
  52. 2000 vibration
  53. Do It Yourself (top questions and answers) FAQ's
  54. MPG with trailer
  55. Durango with a battery drain
  56. Replacing rear glass on 2001 Durango???
  57. Over head Console
  58. PLUGS
  59. 2000 Durango mirrors
  60. Durango Service Manual
  61. 10K tow rating?
  62. 02 Durango Service Manual
  63. 03' Dodge Durango remote start
  64. Light/Electrical Issue?
  65. A/C problem 2002 Durango 4.7 4WD
  66. Taillight Wiring Connector Fried
  67. Where's the MAP Sensor on 2001 4.7
  68. Window regulators
  69. Idel Air Control Valve
  70. Ignition Fuse
  71. What replacement speakers to get?
  72. Idling Rough
  73. Mside mirror wiring
  74. 2 Durangos / same problem
  75. keyless entry
  76. passenger windows not working
  77. Radiator swap question
  78. Lights all over the place
  79. Milky pink residue- coolant leak???
  80. electric fan
  81. How do you check to see if your IACV is bad?
  82. confused please help
  83. How many times has your blower resistor been replaced?
  84. LICENSE PLATE LIGHT 03 SLT
  85. 02 durango trouble
  86. Horn and Radio Controls on steering wheel don't work
  87. Change to Synthetic?
  88. Steaming issue
  89. noise while a/c is on
  90. What would you do?
  91. 98 durango with a 5.9l gushin antifreeze
  92. P0505 Error on a 99 Durango
  93. New engine $8500???
  94. 1999 Durango 5.2 Transmission problem
  95. Custom made Front RAM air intake
  96. P1784 Durango Tranny problems
  97. New Durango Owner!
  98. help techs/mechanics or anyone who knows trannys.
  99. Speedo & ABS Light
  100. 01 Durango Cold Start Problem
  101. Intake Manifold Gasket
  102. Durango Running Boards
  103. electric fan won't cut off
  104. Need help 2000 dodge durango 5.9L
  105. AC smells like mold
  106. Help! 99 Durango dies out while running
  107. 2000 keyless entry
  108. Problems with my D
  109. Catalytic Converter Replacement
  110. How Much
  111. Stewering Wheel Buzz
  112. some need a nice D/?
  113. 2000 5.9 waterpump
  114. tires
  115. front end noise
  116. left front tire locks up when turning hard
  117. CEL is on. Now it's off.
  118. Front Brake Chirps - Out of Ideas......
  119. Back door problems
  120. Clear headlight lenses
  121. 2002 durango R/T
  122. y won't my keyless work
  123. 'Click' When I Try to Start - Battery is Good
  124. Crap!
  125. Auto lock at 15mph
  126. RT Durango?
  127. A/C only works on MAX
  128. Polyurethane swaybar bushing
  129. runs great after PCM reset... for a few minutes.
  130. OOPS!! Moved from Gen 2. "Clicking Noise"
  131. Why does my 99 Durango keep dying?? help
  132. 99 5.9l acting funky
  133. Gas mileage
  134. #&*@*!$ Oil Pump
  135. engine speed coasting
  136. Trying to help next door neighbor scan.....
  137. Question on baggin my 2002 Durango?
  138. Vin on tailgate?
  139. P0440 EVAP EMISSIONS MALFUNCTION
  140. Newbie...need help with Tune up on my 4.7 2001 Rango! Please and Thank you
  141. Keep A Look Out
  142. SRT-8 6.1 Jeep engine
  143. Overheating installed thermastat...now gage is wacky
  144. Do I Need To Replace The Oxygen Sensor?
  145. How do i put my window back on track, ASAP help
  146. Engine Won't Start - Spark Problem
  147. Fuses! Please help me find it.
  148. 2000 Durango 4x2
  149. Flashing Engine Light – What's It Mean?
  150. How to Remove Viabration Damper / Harmonic Balancer on a 5.9L 1999 Durango
  151. Rear Left Brake Light Help!
  152. REpalced everything, still not working
  153. I think I might have sucked up some water
  154. '00 5-9L SLT. Idle fluctuates from 600 - 1200rpm
  155. Gear Problem! heeeelp
  156. Magnaflow cat back
  157. Overheating Help!!
  158. Fuel Recommendations for Durango RTs
  159. Durango RT?
  160. stereo died while driving, fuse ok, help!
  161. What does this code mean??
  162. Durango vs Dakota Suspension
  163. Left Turn Signal Activates Hazards
  164. Wanting to build a 408 stroker
  165. How many miles??
  166. New to site 1998 Dodge Durango Liftgate Issue
  167. how to add tranny cooler?
  168. 2003 Dodge Durango RT AEM Intake
  169. Problems with tranny sliping in reverse after sitting all night
  170. diameter size of dowel for remote control compartment
  171. 98 Durango side view mirror swap to power, heated
  172. performance parts
  173. exhaust sound
  174. Transmission maintenance
  175. Center Console lid kit FYI
  176. Seat heater not working.
  177. a/c problems
  178. Getting 6 lift knuckles free need help
  179. Lower control arm bushing
  180. Anyone had problems postin a pic in pro
  181. new to site few questions
  182. Extended warranty??
  183. please help me out
  184. Code p0551
  185. Replacement shocks
  186. Rear Diff.
  187. will 24s fit on a 00 durango with stock susp.
  188. newbie need some help brakes and a/c
  189. Got 33S
  190. Body Mods
  191. transfer case / driveshaft
  192. 2003 R/T weird noise from drivers side tire
  193. HELP!!! '99 durango V8/5.9L/4WD
  194. Yet another fan relay question...
  195. Funky electrical glitches...help!
  196. What coolant should I use?
  197. anyone ever seen a diesel 1st gen? v 10
  198. does not whant to take gas kicks pump off
  199. No rear heat.
  200. Need a little help here.
  201. AC blows cold in front warm in rear
  202. P 0455 Code
  203. 2000 dodge durango power windows / locks problem
  204. 5.2 to 5.9 Engine Swap..DONE!!!
  205. Borla/Gibson/Magnaflow
  206. Cat Converter
  207. '02 Durango Service/Repair Manual
  208. Error P0456
  209. Door Lock Solenoid
  210. getting my butt kicked on a stereo install
  211. '00 D: Check Gauges light on -Dealer says no prob
  212. Fan Clutches
  213. Rear Window Defogger/icer trouble
  214. Electronic copy of '00 Durango Owners Manual
  215. Can I use re-use these axles?
  216. Condensate drain
  217. Help - Where is the crankshaft position sensor located on a 2000 Durango
  218. Low power on a 360!! Fed UP!!
  219. Help - Where is the crankshaft position sensor located on a 2000 Durango?
  220. '00 D: Sounds like water trickling
  221. Rough Idle when Durango gets hot
  222. Durango Electrical Problems?
  223. no oil pressure
  224. just bought a used 01 durango
  225. 1999 durango
  226. Engine Surge and Idle Problem
  227. Engine Codes
  228. Lucky to Be Alive...!!
  229. GOT THE LIFT!!!
  230. 5.9 life Expectancy
  231. Its about that time for a lift...
  232. Check Engine Light
  233. hissing sound on 02 durango
  234. Is it overheating???
  235. 2001 xmsn pressure issue
  236. Durango popping noise when turning in reverse...Help!
  237. '98 Durango A/C Problems
  238. what year is better?!
  239. Power Steering Leaking
  240. Auxiliary Pump ?????
  241. code p 0137
  242. help needed - overheating issue
  243. Vibration at 70mph
  244. Neutral Safety Switch
  245. Rear Axle Seal Leaking !!
  246. 2001 Durango xmsn pressure issue
  247. Leaking rear windshield sprayer
  248. Tranny shifting issue?
  249. Possible radiator fan problem?
  250. Rubbing noise right after moving from start
