PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. Trouble replacing heater core
  2. Acceleration Hesitation
  3. mileage/stalling
  4. Passenger Side Front Wiper Not Working
  5. How to change Spark Plugs?
  6. Durango cuts off at a stop
  7. exhaust video
  8. can i for sure clear them???
  9. The snow Gods delivered
  10. Tire Fitment
  11. Transmission Slipping? Advice Please
  12. 5.9?
  13. Overdrive Question
  14. Blower won't blow at feet.
  15. PARKING BRAKE
  16. 99 Durango Front Lockout Hubs
  17. i need 32" tires
  18. Rear wiper fluid tank
  19. Diagnostic mode stuck on
  20. 2001 increasing vibration during acceleration
  21. 2001 4WD won't engage - clunking noise front end
  22. one awesome SAS'd D
  23. 2000 Dodge Durango
  24. Heated Seats HELP!!!!!!!
  25. Left front end
  26. 1998 Dodge Durango Issues **Please Help**!!
  27. 20" rims
  28. transmission problem
  29. Puzzling Stalling and Idle Issues
  30. Overdrive Button
  31. TRANSMISSION PAN
  32. Where is fuel pump on 98 Durango?
  33. proformance improver
  34. rims for 98 durango
  35. changing tire sizes
  36. Edited: Moderator: please delete
  37. NEED HELP.. No buS
  38. ATF Leak?
  39. Electrical Problem
  40. factory alarm 99 d
  41. 318 360 swap
  42. New Recall. Anyone heard this yet?
  43. 03 Durango Power Door Locks Problem
  44. heater smells of gas
  45. replacing thermostat in a 99 D, few questions
  46. Recall's
  47. Just purchased 03 Durango SLT, questions
  48. 99 durango rear end
  49. Please read before posting!!!
  50. idle
  51. anti-freeze issues
  52. trans dipstich NEED HELP
  53. A/C pump clicking on and off while heat is on.. Help!!
  54. Transfer Case Control Module
  55. 01 DURANGO 2 BROKEN WINDOW SYSTEMS
  56. TWO BROKEN WINDOW'S 2001 DURANGO
  57. 99 Durango 4x4 5.2L pulling to left
  58. Tow hitch ?
  59. no heat @ idle heat w/load
  60. Heated Seats
  61. Massive failure
  62. got this error code this morning
  63. What oil to use? Or is best?
  64. PING and true R/T fuel requirments
  65. need a new fender
  66. Any Difference between '00 & '03 5.9 R/T Durango?
  67. Slight RPM Changes w/ Criuse Ctrl Only???
  68. Electrical problem
  69. Amplifier Wiring
  70. loud vibration noise left front tire on 5.9
  71. torque for 01 wheel bearings
  72. 03 Owners Manual
  73. ABS Sensor Replacement
  74. HELP!! ASAP Engine failure
  75. what's this 'cooler' - part of the stock radiator?
  76. Differance between R/T & SLT???
  77. 98 Durango won't start
  78. Radiator Fill cap tube/hose assembly
  79. ? for the class
  80. 98 durango power adapter
  81. 99 durango CV strength
  82. check engine / new rig
  83. Aluminum Wheel Center Caps 2003 Durango
  84. 2002 durango tps location
  85. rim questions
  86. lift
  87. Aftermarket heated seats, anyone?
  88. Headlamps..Parking Lights..and Dash..HELP!
  89. Brake light stays on ????
  90. DIY TPS sensor Fix...
  91. 2001 4wd not working
  92. steam coming from uder distributer
  93. durango tailgate handle
  94. 2001 Durango Error Codes
  95. How to tell what gear ratio you have in diff
  96. Headunit for 2001 with aux input
  97. ft diff blowing oil out the vent tube
  98. 4.7 plug replacement
  99. Power windows all not working??
  100. tranny
  101. Brake + ABS Light
  102. Anyone have a hitch wiring harness for an 1st Gen D?
  103. 2001 Durango running hot
  104. new exaust and plug wires
  105. Center cap
  106. 2001 Durango Electrical Problems
  107. Driver's side mirror not defrosting
  108. 2000 Durango
  109. can you drop a 4x4?
  110. Steering Wheel Popping
  111. 02 Durango red lining
  112. rear door lock/unlock . also whining steering
  113. Heater Core Pipes
  114. 2000 r/t durango need help timing
  115. heated seats
  116. Transmission fluid change in Torque convert????
  117. 98 dodge rebuild wont start
  118. Headlamp beam relay 1999 D
  119. So long My friends!
  120. can anyone tell if this computer is for an r/t
  121. Help with window
  122. trouble with my other vehicle
  123. Need Oil Change Tips/Info
  124. Runnig Hot
  125. wild graphist wanted $$$
  126. Procedure And Tools For Rear Pinion Bearing Replace??
  127. 2001 durango engine noise
  128. 3rd row seating
  129. leaking power steering fluid!!
  130. Belltech Shackles
  131. smoke from vent
  132. 1999 Durango - 260,000kms too much?
  133. Best Spark Plugs ??
  134. 98 durango 4x4 flexplate
  135. 2000 Durango blinker
  136. vibration in rear
  137. 01 durango
  138. Dash Removal - Vacuum Control Line Connection
  139. Real Dumb Tire Size Question
  140. any one use these tires
  141. High idle on 99 Durango when warm
  142. engine noise
  143. 2003 Durango Radio Removal and Workshop Manual
  144. Hearing rapid 'Clicks' from engine bay...
  145. 98 Durango rear diff
  146. alternator for car audio
  147. Heat / AC Problem
  148. Help!!!
  149. 2001 Durango R/T 5.9
  150. P0441 Please Help
  151. Amperes
  152. New to D
  153. real tranny trouble now
  154. Locate CTM
  155. 99 Durango Hesitation in wet weather
  156. 3rd row
  157. 2001 Durango R/T 5.9
  158. few questions..
  159. stalling
  160. build sheet
  161. 428R Mustang Vs Durango!!!!!
  162. Change Panic Alarm Sound
  163. 03 Durango as my future car?
  164. Tranny oil leaking
  165. Which Transmission Fluid - ATF 3 or 4?
  166. D Factory alarm.
  167. HELP!!
  168. 98 Inner tie rods
  169. Heater core question?
  170. 2002 Dodge Durango first mods
  171. Couple Problems/ Questions
  172. Durango brake pedal goes to the floor
  173. Durango Rear Hatch Won't Open
  174. which is better regular headlights or projection
  175. 1999 - Steering issue
  176. HEATER HELP
  177. EVAP Problems
  178. New owner of an 03 Durango
  179. Anybody tried a HyperTech Chip?
  180. Key Fob
  181. automatic shifter
  182. replace upper ball joints
  183. tranny trouble
  184. just changed the differential fluid
  185. Durango tire/wheel combo ?
  186. tach problem
  187. Transmission Codes P1757 & P1762
  188. 2000 Durango SLT V8 - 4X4 Advice for a Rookie
  189. Brake Replacement
  190. 727 tranny
  191. High Mileage Tranny Advice
  192. Transmission fluid
  193. D sometimes jerks when slowing down
  194. Fuel Saver??
  195. 2003 DURANGO 4.7 V8
  196. Seafoam ?
  197. whining power steering
  198. heater blowing cool air
  199. Got CEL, fixed it, New CEL, fixed it, now more problems.
  200. rims and tires
  201. Electrical problems developing
  202. '03 Worth Buying??
  203. Suspension question
  204. 2001 4.7l durango sometimes shuts off
  205. new Durango owner questions
  206. just plain weird, difficulty starting
  207. No Heat !!!!!!!!!!!!!!!!!!
  208. Front End Noise while turning
  209. leaking exhaust manifold
  210. Cost of transfer case seal replacement?
  211. ALTERNATOR or BATTERY?
  212. Won't shift out of 4-hi or lo to all-wheel! HELP!!
  213. Durango performance brakes
  214. S L P Exhaust???
  215. What class hitch do I need?
  216. Anyone added fake wood trim?
  217. Its hard to turn, any ideas?
  218. how to get codes without scanner
  219. backup lights
  220. Dome Light - A/C Panel Light Issue
  221. 2000 Durango fan won't turn off
  222. New stereo help
  223. what does SLT stand for
  224. evaporative canister hoses
  225. has anybody changed the differential fluid?
  226. Stillen bumper cover ?
  227. Removing a dash from 2000 Durango
  228. losing fuel pressure overnight
  229. Durango bolt ons
  230. Please help me. How do I pull this sensor out?
  231. HELP please '02 5.9 Stalling at idle & P0601
  232. 94 dakota to 98 durango body lift
  233. Upper Ball Joint Replacement
  234. 5.9 Emblems
  235. Water pump
  236. 2001 Durango Won't Shift out of Park?
  237. questions about towing...
  238. '03 durango rt transfer case problems
  239. 2003 durango p0421
  240. spare tire assembly
  241. Pac Man your request
  242. filter mag any one use one?
  243. Help! coolant thirsty 4.7
  244. Durango not starting!!!
  245. Pics and Videos wanted for offroad video
  246. What I do with my D full time now
  247. 98 with a transfercase leak
  248. Headers Available
  249. ??? mileage expectancy on 2000 durango
  250. the day my tranny died....
