View Full Version : 1st Gen Durango
- Just pulled a truck with the D
- '01 V8 overheated today...
- 2001 V8 overheated today...
- 3-4 shift problems
- 2002 security lights,security system help
- Rusted up Sparkplus cap bolt
- Door Locks. Same problem, different approach?
- 98 Durango OBD 1597 HELP
- Exhaust Repair
- where would I buy a new engine and can I install a better one?
- Engine making a tat tat noise
- Dealer 4x4 Service (Differentials)
- Lost power steering assist
- Dealer prices for mechanic work - what would you do?
- ... Head Gasket job... parts list? and a shop to rebuild the heads...
- Squeaky Ride - 2001 Durango
- it time again
- Fornt end noise
- Front end troubles
- cv seals
- Oil Priming idea worked awesome!
- Compression Test Results
- Heat and Air Issue
- HELP!!! No rear breaks with the ABS and Break lights on all the time
- DIY: Rebuilding a Trac-Lok LSD
- 2001 Durango Squeaks
- May bring tears to your eyes
- Newbie with questions
- Tranny Issues
- Free Heated Seat Fix
- What should idle speed be?
- Rear window help please
- Durango R/T Liftgate pistons
- missfire problem
- 2002 4.7L Durango: Spontaneous Overheating Help
- Replace instrument cluster does engine size matter?
- Electrical issues
- durango drivers
- Duun duun dunnn
- I cant find these parts!! help please
- I want more Power!!
- 2000 Dodge Drango
- Quick Differential Help Please!
- Opinions needed
- Dash Removal
- T/S lift forged torsion cams
- wierd noise
- Paint help.
- Power outlet fuse
- Replaced brake line on '98 Durango
- No Headlights, Park Lights, Dash Lights
- CV Shaft
- Edelbrok F1 Intake????
- custom leaf pack
- Pcv
- Durango Oil Filler TSB
- Won't start, help! 1999 5.2 Durango
- SERVICE 4WD Indicator reset
- Hooking up system to stock radio..
- stereo removal, aftermarket installation??
- 1998 Durango brake line replaced
- How do I install new speakers??
- Help I cant find the thump
- Skull Hitch
- P1281 2003 Durango
- I Think I Have Electrical Issues
- RPM's spiking
- Thinking about buying a used Durrango
- New Belt for 2000 Dodge 5.9
- should i buy this durango?
- Installing a tank type eng heater
- TCM Location 2001 Durango SLT 4WD
- Cutting out and not starting.
- transmission surging going uphill pulling load
- Smoke on the water...
- Dodge Repair Manual
- Alternator
- new D owner
- dodge has the shakes--part 2,harmonic balancer?
- rubber/plastic grommets on 4x4 linkage?
- Hopefull New Durango Owner
- Coolant Check
- blinker and dash lite problums
- Couple of Questions on the durango 98
- 'Nother New Guy Willing to learn!
- 01 Durango R/T Tranny Issue
- Gap in between the bumper and grill
- Which exhaust??
- 2000 dodge durango got the shakes??
- Tail lights
- overheating
- durnago OEM Spark Plug Wires $63 at dealer
- New to the board
- Problems with motor fan
- easy mods for 5.2 for more mpg
- Radio replacement
- 1998 durango tach issues
- Sparkplug Durango 5.2
- Mirror problems ended
- 99 durango obd2 port dont work?
- Trans overdrive issue?
- Fog light recommendations
- Dropping gas tank 1998-99 dodge durango
- P0601 PCM Internal Ctrller Failure
- Tire Suggestion
- P 0132
- My inifity speakers suck!!!
- Need Help Hit a pole with front end
- Cold Weather Starting
- Another Transmission Issue
- After hot no crank & trans slipping 98 durango
- Durango Delima
- need some answers
- '02 Dodge Durango SLT Missing When Cold.
- My Stereo Speakers SUCK!!
- Transmission Issue, Can't figure
- waht to do first?
- New to forums and new durango owner
- What battery type...
- Fan Clutch?
- Electric Fan; At What Temp Should It Engage
- Fluid capacity for 45RFE?
- Trans fluid change
- gas issue
- Another Newbie???
- Engine Light On
- 4.7L Durango issue HELP!!!
- heater temp
- Braided, Flat Wire Connection Question from Newby
- Problems with 2003 AC Vents
- I'm afraid to shut off the D!
- Aftermarket Exhaust
- 4X4 not engaging
- question about vacuum lines
- Custom Cold Air Intake for 4.7L V8
- tires again
- Fuel issues
- Reverse lights don't work
- Alarm will not shut off
- Low Speed Wobble
- 98 D Blower power
- Sub with a stock stereo.
- No Rear Heat!
- Help with wheel hub!
- Air noise on a 2000 Durango.
- Where is the Leak Detection pump on a 2002 Dodge Durango
- Transmission Trouble
- 2002 Dodge Durango (Newbie)
- NEWB Question: Part # request
- NEWB Question: Part # request 2002 Durango
- Body Parts Durango and Dakota
- Transfer Case Q&A
- Need Help w/ 2000 Durango Sport
- Leaf Spring Bolts
- Overheating on 5.2 Thermostat??
- Fitzall 220 AMP Alternator Install?
- Electric Fan Not Working?
- electric brake controller help needed
- Crazy 4.7 Longblock price
- 4.7 Engine Install?
- heater core removal
- Virginia-minneapolis bound
- 2000 durango slt plus transmission solenoid
- No start. Clicking Relays
- 2000 Durango 46RE Transmission Problems
- Where to buy timing set for 4.7 Litre
- 33's on stock 98 durango?
- 1999 vs 2000 Wheels
- '99 Durango water pump questions
- 4.7 Rebuild?
- Idling problem... happened twice...
- Transfer case question...
- New engine
- pulsing battery draw
- What transmissions will fit my 2000 Durango
- Durango ildling problem
- 01 4.7L Durango steering shot...
- What are the torque specifications for the transmission pan bolts?
- New Tires
- Flowmaster
- Water pump replacement stubborn fan clutch nut
- Loud noise/vibe in front end
- Check Engine Light
- towing big enclosed trailers. need advice
- 2000 4x4 need wiring schematics
- Looking for a steering knuckle
- ATF+3 v ATF+4
- i need to find neutral safety switch located
- I think my Water Pump is out please help me :-(
- auto locks dont work on gate.
- AT tires on a R/T?
- Window Clips
- 2002 2wd durango rear brakes
- burned out headlight
- 99 Durango Bearing Or Differential Issue
- Touched POS on battery with tool, now won't run?
- Blowe Motor replaced but barely blowing air out
- Changing Trans fluid/filter Q
- 2000 4x4 battery draw
- Help! Changed Battery now it won't start!!
- 2003 Durango Transmission
- Low Compression
- how many quarts of oil in 98 D
- Adjustable Shocks
- Gas gauge shows "Full" all the time
- Recalls
- 4 Wheel Alignment Woes
- 99 Durango turns over but doesnt start
- Engine Swap
- Clattering on cold starts
- 99 Durango oil pressure gauge
- 4 Wheel Drive Linkage Grommets - How to install??
- Odd door buzzer and lights not working issue
- Headlight/Steering Column Issues
- Headers 4 sale (5.9L and 5.2L)
- 2000 Durango Rough Start-up
- gas tank,fuel pump,and regulator.
- Ball Joints
- when slowing down and reverse i hear clicking.
- Transmission Diagnostics
- 46RE blues
- Transmission Troubles
- power steering hoses
- 99 slt brake caliper pin-type/size?
- Help
- Rancho lift with stock rims
- 99 durango cranks but doesnt start.
- turn signal problem
- 99 sunroof makes noise when starting truck
- Service 4wd light is on and
- longevity of Durangos
- 00 durango idle problem!!!!
- Truck problems
- ac evaporator drain
- Airbag jitters
- Exhaust Smell - Cat bad?
- P0320 / p0725
- new codes
- Radiator cap
- Edelbrock Shorty headers 5.9D
- Plugs and wires
- Torsion Key and Shackles to lift a D
- New Member with Radiator questions
- water running sound?
- Differential is Scrap
- quick question before I leave for a 9 hour trip tom.
- Fuel efficient Motor Oils
- Oil Pressure Fluctuation
