PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. Lifts: 3" 6" ???
  2. Transfer Case Control Module Location, TCCM
  3. wickedflow or 40 series ???
  4. dango rooors
  5. So i got my trans back in and
  6. Brakes and Rotors 03 Durango
  7. Engine dies 'sometimes' when put in Reverse???
  8. New guy with 02 Durango
  9. MP3 / Ipod adaptor in 2003 durango
  10. Mpg
  11. Unusual Loud Blowing Question!
  12. aftermarket radio help
  13. Hidden subwoofer locations?
  14. 2000 d transfer case leaking
  15. 318 block 1998
  16. 2003 Durango Radio Trim and removal
  17. Temp Issue
  18. couldnt get KM2's... so i got these
  19. Flowmaster 40 StockIN/DualOUT Sound Clip on a 4.7 D
  20. Alarm freaked out
  21. Prochargers
  22. a fresh problem
  23. Flowmasters check!
  24. nominations open
  25. 2000 durango
  26. 2003 5.9 R/T Starts, but starts to stall when stopping
  27. axles again
  28. Door freezing problems
  29. Rear door lock question
  30. Transmission Problem
  31. 99 durango cuts off
  32. Difference between the 99 and the 00
  33. is it posible to do "true duals" on a durango 4.7???
  34. new radio?
  35. iPod Integration
  36. 2wd 2002 Durango tranny mount
  37. will I have clearance?
  38. 02 Durango Sport Emblem Stickers
  39. 5.2 vs 4.7??
  40. volume control on stereo
  41. A few different questions
  42. 4 wheel drive, and tranny problems??
  43. 45RFE/545RFE-HD2 reprogramming kit/shift kit
  44. PCV Valve, please identify these pictures..
  45. Engine problems??
  46. one more lift question
  47. PCV Relocation kit
  48. Got the new tires and gave it a Wax.
  49. Issue with middle row seats
  50. Sas
  51. Power door locks unlock...but won't lock
  52. help with 4*4
  53. big question
  54. Axel support
  55. What Vehicle(s) Use This Transfer Case?
  56. Muffler Size
  57. Just bought 99 Durango, Guess what, tranny problems
  58. need help with a P0344 code
  59. 03 Keyless Entry/Tire question
  60. 98 5.2 Alternator or Battery PLease Help
  61. 4WD working ?
  62. Engine Oil and Tranny Fluid Capacity
  63. 35's on 98 durango
  64. 98 durango for sale 5500 or b/o
  65. 98 durango cyl.5 misfire
  66. Change 3rd brake light bulb ???
  67. Crank Shaft Harmonic Damper
  68. 2000 durango 4.7l suddenly??? HELP!!
  69. Cold start trans slip
  70. Interchangeability of 99 to 02 bumper
  71. Where to find a Mopar Performance PCM ?
  72. Strange tranny noise
  73. I need rims!!! 1999 durango
  74. dire need of tech help
  75. Looking to purchase a 99-03 Durango
  76. 1999 Durango throwing P1765 and P0753
  77. TPS Problem?
  78. no tailights 2002 dingo
  79. OEM Heated Seat Install
  80. 2002 Durango Console
  81. Battery issue
  82. Tranny Problems that a friend is having.
  83. 2003 Durango / replace front bumper (guard)
  84. Help my 99 durango is pissing me off!!!!! Problem after Problem
  85. Final conclusion for lift
  86. Is an 11" x 4" tranny cooler too much?
  87. so my 46re stoped workind so
  88. Infinity speakers
  89. Running Crappy
  90. 2000/ Lights go out with High Beams
  91. Help. Transfer case differential Problems
  92. Need Center hubs on 2002 Durango - Help!
  93. Picking up a King Size bed
  94. squeak
  95. 98 Durango cd plyr wont take cds
  96. 1999 Durango Fog Light Switch
  97. Heat problem
  98. Durango water pumps?
  99. Starter DIY 5.9L and 5.2L
  100. Clikity Clank...No more 2 wheel drive?????
  101. Parking lights dead
  102. re: abs and brake warning on
  103. cant get it out of "park"
  104. third row seat?
  105. 2001 durango audio system problem
  106. What size rear brake shoes and drums
  107. End of the month is approaching
  108. Daughters 2000 Durango oil pressure problem
  109. Headlights
  110. nv242 planetary question
  111. Does Duragons slide in the snow??
  112. Slidding in the Snow!! Cop didnt believe me
  113. 1998 318 V8 and 4x4 tranny and transfer case for sale.
  114. Oil Seal needs replacing....
  115. 99 Durango 5.2 dies in reverse when cold.
  116. the lift
  117. help!
  118. Delayed shift until it warms up then ok
  119. 99 durango tries but wont start
  120. Big time lift
  121. Strange noise....
  122. 2 Problems with the D
  123. 2000 Durango 4.7 cold engine knock lasts 0nly 25-45 seconds...
  124. dash warnig lights flash on and off
  125. hello all i'm new and have an issue and hope someone can help
  126. 2002 Rear Wiper blade replacement
  127. P0753 Code Issues
  128. imput speed sensor
  129. thank you every one
  130. DIY Help!
  131. Issue with interior lights
  132. replacing the rear heater core in a 2001 Dodge Durango
  133. Blinkers
  134. D 03 Vs D 00/both 5.9 SLT 4WD
  135. New owner, Bunch of friggin questions
  136. Transmission shift issues
  137. Headlamp Issue
  138. Crazy idea
  139. Could i fit 35's?
  140. ac help please
  141. I'm back!!!!!!!
  142. (Solved)3-4 shift issue then lockup issue
  143. New Years Resolution
  144. cold weather trans wows
  145. Catback exaust help
  146. Truck of the month
  147. 2000 headlamp replacement problem
  148. Massive drop in gas mileage and power
  149. Wires from the Head Unit
  150. how to verify hitch class
  151. Help!!!
  152. Truck of the month
  153. electrical issue solved kinda...
  154. Interior light/door switch?
  155. Rim help
  156. What is this connector?
  157. transmission pblm no reverse all of a sudden
  158. Burning oil/tire smell, cannot tell WHERE it is coming from
  159. Electrical Diagnosis and Testing
  160. passenger floor only blowing cold and wont turn off
  161. Amp Wire. where to run it Thru? (02 Durango)
  162. rims
  163. rims
  164. 03 durango brakes pulsating
  165. V3 camera installation
  166. transmisson issues
  167. Power Locks Not Working
  168. need help with headlight problem
  169. 01 Durango electrical issue
  170. front abs going on
  171. problems withe the ds 46re....
  172. Restore Engine Formula - Gotta Try this stuff
  173. Happy New Year
  174. check engine light being funny?
  175. 2002 durango is stuck in park
  176. 99 durango 5.2 low oil pressure sometimes
  177. no rear heat
  178. suspension conversion
  179. 2001 5.9L RT Wont Start
  180. 2001 Durango Died in traffic, won't start :(
  181. durango tires anyone??
  182. Rear pinion seal
  183. Uneven front brake wear
  184. 2001 Lower Ball Joint Question
  185. Need Seat Belt Button For 98 Durango
  186. Electric Doors
  187. 2001 Durango Or 2002 Jeep Grand Cherokee
  188. Replaced trans filter, new one was way different than the old one? Problem?
  189. Transmission Error Code after tranny shop?
  190. TOTM Truck of The Month voting
  191. Oil Consumption Issue
  192. iPod integration in a 2000 Durango SLT
  193. shutting off at stop signs
  194. 03 Durango rt idler pulley
  195. Gear oil on a 2001 RT
  196. motor rebuild
  197. How can 5" and 6" speakers both fit?
  198. Camshaft Sensor or Fuel pump problem???
  199. 33 inch all terrain tires
  200. Steering problems
  201. 2000 4.7 common o2 problem
  202. 98 Durango Cranks but No Start - Replaced PCM, Other Ideas
  203. coolant capacity
  204. heater blowing cold air wont get hot keeps over heating
  205. 35 in tires with a 3 in body lift???
  206. Air Box Help
  207. Any problem buying Valucraft $29.99 rotors?
  208. Strange Issues with 2000 Durango
  209. Cam and Head Recommendation?
  210. TCCM - Parasitic Drain in 2WD / Fuse A ??
  211. 2000 D OEM running boards
  212. No oil pressure on initial start
  213. 1998 Durango little heat problem
  214. 2000 Rt Durango mystery humming noise..
  215. Dual exhaust
  216. need help from anybody with a 98,99 durango
  217. True or Procrastination?
  218. np231 vs nv231 hd
  219. Quick question.
  220. Howdy
  221. Loose Steering?
  222. Headlights and Interior lights Dimming?
  223. 1999 Durango upper control arm
  224. 1999 o2 senser question
  225. Heat
  226. Posi? Also question about power?
  227. REAR LEAF SPRING Question???
  228. Cost of heater core replacement
  229. engine mods?
  230. Where is the Neutral Safety Switch located on my 2000 Dodge Durango?
  231. Apply brakes and dash lights dim
  232. 02 durango to 00 dakota brake interchangability
  233. 98 Durango NoooB questions, Shorting out heater pannel
  234. Gas in oil
  235. Vehicle hesitates few minutes after starting in cold weather
  236. 99 durango battery cable
  237. blower motor stays running
  238. 3" body lift, 99 durango, bumper problem
  239. How to change instrument cluster light color
  240. body kit experience
  241. weird won't start electrical issues.
  242. Locked rear door help?
  243. b-kenny1
  244. wiring questions
  245. Another SLUDGE thread--(sorry)
  246. My fan is a little noisy
  247. windshield wipers
  248. Decided to take advantage of the somewhat clear NW weather and quick question
  249. Forum Clock FUBAR
  250. 2000 - Strong Vibrations/Pulls to the Left above 65MPH
