View Full Version : 1st Gen Durango
- Changing out Power Steering Pump 5.9
- 2003 dodge durango 4.7
- Dodge ABS module disassebly
- 2001 Durango 4.7l mystery part
- How to make my 03 Durango ride smoother
- ABS and Brake Light on already replaced sensors
- Whats making my truck shake
- 03 R/T Power outlet question
- Question bout Bumper Covers
- Transmission problem
- Not shifting 1-2 2-3 when warm.
- Removing Scratches from rear panels
- Excess brake pedal travel. Brakes engage low.
- Aftermarket CV Axle
- check out this lift kit.
- Hiya guys first ten tango question
- Good choice for a tow vehicle?
- Intermittent no power to fuel pump.
- I have a 1999 durango and the compressor
- New Durango, More Problems,lol 1st Gen 03 R/T
- Anyone have the Keystone Restyling Front & Rear bumper covers?
- 2003. Evaporator Sensor
- The dreaded spark plug question
- 2001 Durango Rear Backup Lights Switch
- exhaust smell when heat is on
- Manually shift transfercase??
- Strange P0016 Code
- Spare tire
- No turn signals or emergency flashers
- Engine noise- 1999
- FYI... Backup Camera in 2001 Durango
- Would the check engine light come one for a misfire?
- Location of thermostat on Dodge Dakota
- engine more than ticking
- P0201
- 4.7L: How hard is it to change valve seats?
- Body work
- Intermittent Electrical Problem - won't start
- Interchangeable Parts ?
- 2000 Durango 4.7l with check engine light issues...
- High idle stay at 1500rpm
- Need help. Coil pack.
- Ia a 244 transfer case from 2003 Durango RT compatible with NV244 from a 2005?
- Power steering issues
- 1999 Durango Blower Motor Resistor location
- The crank case ventilation valves should only be allowing one way correct?
- Is there any way to test an vacuum actuator?
- Do I take this cable off to get the heater box out?
- won't start
- 00-03 lift kit
- 1999 dodge Durango 5.9 wont heat/no heat
- How do you get this shifter off?
- 1999 Durango
- Failed SMOG and Exhaust Leak
- Dodge 2002 Central Timing Module 56049073 AK Where Can I get one?
- Manual Transmission swap
- I need an owners manual for 2000 durango
- right turn signal
- Rough idle
- Cylinder #2 smoking
- Durango 1998 5.9L-Magnum rebuild
- AWD/4Hi Switch Light Issue
- Difference between a NV244d and a 244d for dodge ram?
- Questions about heater core & directional vents (2000 4.7L)
- Nerf bars..... With step?
- how do you reset the pcm
- ac advice
- Tail Light Covers??
- Power window not operable
- FREE BOOZE-The tired "miss at idle/off idle stumble" but I am desperate
- door locks
- 3.9 vacuum leak?
- Best suv ever !!!
- 99 Durango starting problem
- MPG took a crap
- Can't find a sway bar to control arm retainer replacement
- 2003 Front Brakes locking under heavy braking w/rw abs only
- I have a 2009 Dodge Journey starting problem
- engine died 2 miles after oil change no crank now
- 3.6 cylinder head
- Known Good Aftermarket Parts
- Jumps at 3200 RPM
- radiator cap partial pressure
- 98 5.2 ingine problem - Please help
- 08 Dodge Ram 1500 upper ball joint replacement
- Smoke out my exhaust....
- CV half shaft assembly replacement
- Durango dying when stopping and no speedometer.
- 4 WD to 2 WD???
- Heater hose leaking
- What do i need to do to fix the cruise control problem?
- 1998 Dodge Dakota code PO420
- Good Deal? 2002 Dodge Durango SLT
- Coolant flush
- 03 R/T heater hose assembly.
- 2001 Durango 4.7l V-8 issue after overheating
- mud colored coolant
- 2001 Durango 4.7l V-8 breather element help needed
- 2000 durango cigar fuse
- Heated seats conversion from Costco
- HVAC Vacuum hose diagram for 98 Durango?
- building 2000 5.9 V8 magnum
- Help!! 2000 durango ( my baby)
- Disconnecting Rear A/C Lines?
- tranny (car part not person)
- Ac has static pressure but won't engage
- 2000 Durango Rear AC Access
- 2015 Dodge Durango blows hot air sometimes
- Does anybody know an after market supplier for a sheet metal patch kit for this.
- new battery a/c blower not working,
- Turbo Question
- information center
- 2003 Dodge Durango 4WD Transmission Issue
- advice needed
- Excessive Cooling System Pressure
- 46 re shifting
- Erratic oil gauge
- Coolant leak
- Hitting Rev limiter
- 2004 dodge ram 1500
- 99 Dodge front diff
- linkage for trransmission
- P0700 and erratic behavior in overdrive
- Auto dimming mirror
- 2001 Dodge Durango
- New EQ Heads - Small Amount of Oil on top of Piston
- Constant engine noise and running super rough after rebuild
- 01 5.9L r/t Durango awd
- 2000 durango wont start
- 02 Durango 4.7l V8 major idle issues
- 2000 SLT Electric Radiator Fan
- Front seats,
- Exhaust Manifold Middle Double Bolt
- Advanced factory cam
- LOOK at this for me, need looks advice!
- 03 Durango SXT Blend Door Issue
- dodge dakota
- Took her rockcrawling
- 98 Dodge Durango
- AC compressor line melting battery cable.
- Oli consumption
- Reinstalling Rocker Arms - Bleed Down Procedure?
- the overhead light clip is broken
- Fuel issue
- Rear AC blowing hot, front cold
- leaking power steering fluid
- 99 5.2 RPM flare when cruising on highway
- 2002 Dodge Dakota no start
- Acceleration problems
- battery cables
- Gas tank capacity
- Oil fill cap
- steering feels loose
- Dash bulb replacement
- Idler arm upgrade
- What engine rotation is 4.7 clockwise or counter clockwise
- 45RFE deep or shallow pan ?
- crankshaft sensor
- Overdrive off lssue!!
- '01 4.7 coil/plug R&R
- 1999 durango questions
- air conditioning quesion
- I have no power to my brake light switch
- 2002 Durango will not go over 2500rmp
- Any Recommended "Best" 11 x 2 1/2" shoes ?
- Water condensate from AC dropping on O2 sensor
- Dodge caliber reverse ligh
- Coolish, not cold.
- Left rear turn signal intermittnet please help!!
- My van all of a sudden has no power. Replaced fuel pump and still the same
- 1998 Dodge Durango transfer case please help
- Transfer case please help
- 1998 Dodge Durango 4wd Rattle in drivers side wheel?
- outside ambient temperature sensor
- Swapped out bcm - from bad to worse
- Popping/grinding in 4WD
- Car stalls after getting to operating temp with no throttle input
- heating up and running bad
- can you slim jim open a 98 Durango
- Which Transmission do I have?
- 2003 Dodge Durango ABS Light
- I'm having the same problem as apparently everyone elae. No key faub and security won
- Control module
- Window switch issues
- 98 dakota 5.2 wont engage gears after engine swap
- 2002 dodge durango 5.9 starting problems - one click
- oil weight and type
- 2003 dodge durango stalls
- CD layer won't eject
- Lose steering to the left but not the right
- Front driveshaft rebuildable?
- Confirm these timing marks please
- Swap
- Orientation of CV U-Joint to a Spicer U-Joint
- Iac valve prob
- New member, 03 durango r/t wont switch from a/c to heat
- Magnum 5.9 Cylinder Heads - Down to the Removal Part - Any Tips Advice?
- Hood to headlight seal
- Center cap attachment
- Motor help
- 03 metal rattle in the rear.
- Lame! I don't know where these sensors go! Please help!
- 2002 dodge durango, auxiliary water pump
- 2000 Durango OBD II connection
- No Start, run a couple mins shuts down
- a/c vent odor
- AC compressor short cycling
- Questions about 2003 4.7L engine noises
- 2002 durango - shut off while driving, won't turn over or restart
- Need wheel help
- Security light wont go off
- My Durango won’t start now
- 2000 Durango AC/alternator bracket stripped bolts
- 1998 durango slt 4x4
- Trouble codes
- ac 2011 dodge nitro
- Reverse light problems
- Can you fit a Griffin Radiator in a Durango? Why yes, you can.
- Trans fluid quantity
- Beginner questions about PCV valve
- TCM location for 2000,5.2lt Durango.
- 2002 Durango 4.7 EVAP Canister Hoses
- Random idle misfire 4.7
- Transmission acting up and now can't put in gear without it dying
- Stripped caliper bolt hole in steering knuckle Best option to fix?
- 2001 Radio cuts off when adjusting steering wheel
- 1998 Durango headlights
- Exhaust suggestions
- Can I just pull my cam off?
- Wrong gas in 1999 Durango
- New PCM now car wont start
- Trans fluid capacity
- 2003 dodge Durango 4x4
- 03 Durango vibration
- Multiple issues!
- P1756 98 Durango
- 3rd gear vibration
- Are these the wrong brake shoes? Rubbing with adjuster all the way in..
- Has anyone used these ball joints before?
- Parking Lights Stay on
- 46RE Return line and Supply Line - Transmission Cooler
- 10.6V on Radio switched 12V Wire???
- Gas Tank Strap Bolt Just Spins. Once I cut it off how can I reattach strap?
- 03 durango r/t 5.9 no spark
- 99 Durango 5.2 Positive Camber problem
- 4.7 toner gear
- 01 Durango bracket alignment issue
- Best Rack and Pinion Replacement Unit?
