PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. 2003 durango brake problems
  2. Will a P5007207 PCM work in a 1999 Durango???
  3. 2000 Durango 5.0L, no start
  4. 2002 four wheel drive issue
  5. 16 to 32 tooth crank sensor
  6. HELP 2000 5.9l - Replaced TPS & STILL SURGING!
  7. tranny mount replacement
  8. 99 Durango Transmission problems
  9. performance brakes
  10. help with balljoints
  11. Steam coming from heater/AC vents
  12. Alarm system disconnect
  13. 3rd Gear in the 46re Transmission
  14. Getting 3rd Gear in the 46re Tranny
  15. 2000 Durango OEM Thermostat ??
  16. turbo in a 2002 durango ?
  17. Hydra's Vacation
  18. 3" Body Lift, 99 durango, 4wd
  19. brakes/rotors help
  20. 02 Dur rear heat not working
  21. Water leak..? Rear Jack compartment..
  22. heart transplant
  23. how to take the differential out?
  24. Severe Cavitation Damage to Water Pump
  25. no longer a durango owner
  26. huh??????
  27. Totm voting!
  28. 99 Durango, NEED HELP WITH STEREO
  29. Help! (I'd like your input please)
  30. Electrical/Won't Start...Help Please!!!
  31. 1998 Durango Service Manual?
  32. Transmission Oil Capacity
  33. newbie needs some upgrade advice
  34. Change bearings in transfer case?
  35. Transmission / rear end noise
  36. Water in the driver-side footwell
  37. Stock fog light for 2000 durango, driver's side
  38. need your opinion
  39. Power outlet
  40. air cleaner?????
  41. 2002 Durango Service Manual
  42. Need your help on TOTM!
  43. 98 deck
  44. brakes
  45. power programmer
  46. TPS Sensor
  47. Drag racing the Durango
  48. Band question.
  49. Control Arm Bushings - Do Or Not Do
  50. fan clutch
  51. Rubbing noise when turning sharp
  52. how to replace radiator neck
  53. Crankshaft & Camshaft Postions Sensor DIY
  54. Fuel presser bled off
  55. Engine interchangeability
  56. 32 or 16 tooth crank?
  57. heater problems
  58. heater problems
  59. Temp. gauge position
  60. Need Ball Joint Boots
  61. what did i do now
  62. check engine?
  63. Save Gas?
  64. ahhhhhhhhh. what did i do?
  65. 2001 OBD code P1763 and limp mode
  66. ABS light and Speedo FYI
  67. 2002 Durango slt
  68. driver side control panel
  69. brake problems now
  70. idle problem
  71. 4x4 lower control arm bushings '98 D 4x4
  72. low output spd sensor rmp above 15mph
  73. Ummm, is this backwards or what?
  74. AC/HEATER Problems
  75. 02 durango drivers side seat warmer
  76. Part No for PCV Valve Pipe
  77. CODE: P0340 & P1391 - CMP/CKP Location
  78. '99 4X4, 5.9L Torque converter shudder
  79. hey guys.......
  80. Longevity & Power Of Your Rig!
  81. Stereo Removal
  82. An original (dum) question I hope...
  83. Brake system re-work, no fluid to RR??
  84. that evil HVAC box
  85. 1999 Durango Won't Start
  86. Got the sputters again.
  87. Lift Suggestions???
  88. Long Cranking at Cold Startup..?
  89. Autolite Copper plugs ok?
  90. South Georgia anyone?
  91. torrsion bars
  92. check engine light because of spinning tires
  93. Suspension Q
  94. 99 Durango 5.2 4x4 did not want to shift above 3000 rpm
  95. Needing help with O2 sensor and codes
  96. New here..... had a question.
  97. Dual exhaust/mufflers/cai kits
  98. New Multi Carrier!!!
  99. 03 r/t steering wheel controls
  100. Exterior Enhancements
  101. Computer reprogram???
  102. Loud Popping Noise
  103. P/S leak fixed..some good news for a change!
  104. Tire Pressure's
  105. Intermediate Steering Shaft
  106. rear axle
  107. Need Wiring Diagram
  108. Day Running Lights Module - Same as Dakota?
  109. 98 durango check engine light question
  110. 98 Durango 5.2 to 5.9 Swap?
  111. horn wire
  112. Wheel Stud
  113. P0205 DTC on a 99 Durango
  114. 99 Durango trans question
  115. brake caliper on a 02 durango
  116. squeaky front end?
  117. check engine light??? P0455
  118. Slipping seats
  119. engine miss
  120. Coolent leak
  121. hatch stuck
  122. Is the Hotshkis sway bar kit worth $500 bucks?
  123. Help with alarm system
  124. Would appreciate HELP
  125. Schematics and other info...
  126. Remove front axles better mpg?
  127. Wiring Help NEEDED asap... =)
  128. What can I do about the TPS on a 1999 Durango?
  129. 02 Durango reving up and down 200-300 RPM
  130. Abs light
  131. 99 Durango Xenon lights
  132. Engine Smoothness
  133. Horn got wet - now it sounds wimpy!
  134. 1999 Durango alarm arming question
  135. Will wheels off a 2nd Gen fit 1st Gen?
  136. Exhaust Question
  137. 99 bodylift steering extention help?????
  138. Trailer Turn signal Problem
  139. Throttle position sensor question
  140. Question on Power window motor repair Durango 1st Gen by Mean Green
  141. Blown Tranny Seals???
  142. 98 durango gas light problem
  143. Help! 1998 Durango ABS/Brake lights on!
  144. no illumination lights in dash
  145. 99 Durango trans ?
  146. 02 durango won't start
  147. Sidewinder Custom brakes done
  148. The Fastman Trans
  149. 1999 4x4 Polyurethane bushing kit (help find)
  150. 98 Durango 5.2 - revs faster when going over bumps
  151. Replace Push Rods Help
  152. a/c not cold
  153. 99 durango 4x4
  154. 2002 4.7L D needs a Tune up at 98k. Any suggestions?
  155. Looking for Idea pics
  156. tranny fluid changes
  157. engine miss
  158. 2001 RT misfiring?? Please help
  159. P1781/P0781 - Low Acceleration + Engine Light Trip
  160. Rusted Window Trim?? After Market?
  161. Central Timer Module Tech Question
  162. Durango Turns over long time before starting
  163. Won't Start Unless its Hot Outside
  164. Durango Gone Gutless
  165. Quick interior question
  166. 2001 durango 4.7
  167. 2001 durango no rear heat
  168. durango lift?
  169. ignition lock cylinder
  170. Will 35x12.5 tires fit my stock durango?
  171. Engine won't start
  172. Hauted Durango
  173. suv 2003 sludge
  174. cost of tranny re-build
  175. 2001 durango 4.7
  176. won't start when hot
  177. Need Help Please
  178. headlight replacement not bulb
  179. Dodge Duranogo Problems
  180. Check Gages / Batery Gages over charge
  181. stuck in 1st
  182. 2008 Durango Assembly Plant Tour
  183. Durango
  184. ball joints
  185. How to change rear diff fluid?
  186. Throttle Body SPacer for a 4.7
  187. 98 durango can't figure it out.....
  188. vacuum problem
  189. P0159 o2 sensor
  190. headlight crazy
  191. Y Pipe for Gibson Cat Back?
  192. ABS light, parking brake light, and speedometer issue?
  193. my 99 durango 318 5.2 blew
  194. First Generation Durango Air-Con
  195. Replacing fan clutch - How do I keep the pulley from slipping
  196. some questions for the "D" experts?
  197. Blinkers and brake lights not working...Please help!
  198. Headlights Going Crazy!!!
  199. band adjusting screw for 99, lost
  200. Engine REVS high at start
  201. Won't go into OD
  202. Do these taillight guards look like they will fit?
  203. overheating
  204. DF Video!
  205. 2000 dango
  206. Superchips ? Worth it
  207. replacing water pump
  208. A/C Compressor Problem
  209. DIY Turn Signal Switch Replacement
  210. disconnecting beeper in 98 durango ?
  211. Engine code help
  212. Seat Belt Replacement
  213. Replace Cat Converter????
  214. What water pump?
  215. Picc
  216. Front half shaft replacement
  217. new member looking for help
  218. 2000 dodge durango owners manual pdf
  219. 5.9 Rango Fuel
  220. ctm help
  221. Diff fluid change
  222. soft brakes
  223. Durango brake problem
  224. Removing front driveshaft
  225. 2003 4WD DURANGO 5.9 Overheating Problem
  226. Dodge Durango window regulator replacement
  227. 1998 durango engine wiring harness
  228. caliper bolt holes stripped?
  229. Electrical Problem
  230. MSD Blaster SS Coil
  231. Where is the oil going?
  232. ticking on acceleration...??
  233. Missing engine
  234. oil drop now engine blown
  235. Need help with transfer case!!!
  236. Relocating the IAC selonoid
  237. Engine sputtering and won't idle, NEED HELP!!
  238. HELP: ABS and Speedo not working together
  239. 2000 Dodge Durango
  240. brake light bulbs, speedometer, & Dr sd window
  241. I think it's possessed!!!! PLEASE HELP!
  242. Yet another towing thread
  243. 2001 5.9 lost coolant and overheating?
  244. Brake lights out, but tail lights work-help!
  245. In need of help!!
  246. 2001 R/T AC clutch or compressor
  247. Day Running Lights
  248. Transmission issues, need advice.
  249. 02 ball joint on a 99?
  250. code p0138. O2 sensor.
