View Full Version : 1st Gen Durango
- Transmission Problem.
- Engine wet wanting to stall out
- 4.7 no compression
- Replacing a new door 1999 durango
- 2000 4.7 4X4 Spare Tire Winch Assembly Question
- A/C Compressor
- A/C Problems
- key stuck in ignition, engine running
- onboard diagnostics
- 1999 Durango making whining noise
- Strange RPM Issue?
- 03 Durango RFE trans problem
- Catastrophic Coolant Leak with Spatters of Oil
- Need New Lift Supports for the Rear Hatch
- 1998 durango fan speeds
- Maintance schedules
- P1495 Leak Detection Pump Solenoid Circ
- Power window switches not working
- a/c compressor with groaning noise - 99 durango
- Ambient air temp sensor location
- oil change
- 4.7 exhaust manifold studs/bolts OEM replacements
- Lower Ball Joints need replacing
- U-joint or Wheel hub?
- cutting out at 30-40 mph
- Stalls at idle
- hello from stunami
- Runing All Sencors
- New engine
- 2001 dodge durango makes squeaking noise
- Replaced radiator cap after leak...still a small leak
- Vibration/tire wear/drifting
- Incredibly horrible gas mileage
- 00 durango elec issue
- Its official :/
- Just went fully synthetic!
- 2000 running rough and pulsing
- Pics of stock Rims painted black
- 03 duango
- Temperature problem
- Lower Balljoint removal-4X4's
- Is it possible to leave the dash in?
- CTM Fuses
- Rear coolant hose line broke. Suggestions?
- Improving Gas mileage in my Durango 2000
- A/C issue I've not seen before
- 1999 dodge durango brakes lock up/ no brakes
- 2000 Durango 4.7 TPS?
- 01 4x4 Problem.
- 2000 durango not blowing air
- Car shutdown while driving....
- 01 4.7 where are the oil passages in the head located?
- Heater smell
- 4.7L Overheats - Sometimes
- Headers.
- 99 slt 4wd problem
- Carlisle 2011 Chrysler Nationals
- 2000 Durango 2WD Lift Opinions
- Towing capacity '03 AWD Durango Plus
- Dodge durango p1732 code, i need help
- Overheating issues after changing timing chain...
- 01 Durango w/ 4.7 Noise on startup that lasts a few seconds, HELP!!
- 1999 dodge durango shut off while driving
- It's been about a month since buying it...
- Durango Starting Problem(s)...
- which one?
- P0545 - A/C Clutch, or EGT Sensor?
- 2000 durango blue smoke issues
- 1999 Durango: Frozen Caliper or Clogged bake line?
- Please help with frozen caliper on 1999 5.2L Durango
- ? about axle gearing
- here goes .... o2 sensor question
- P code Help ?
- Should i buy this durango
- Exhaust Header Shopping - Reviews?
- A/C Problems
- Shifting Problems on my Durango
- Picture game - Coolant leak
- 2003 SLT strange transmission indicator light problem
- I have some dash cluster lights questions. Re: LEDS
- 1999 dodge durango transmission slipping/stalling
- Slip Yoke ATF leak help!?
- 2003 5.9l Overheating quick
- tail lamp positive lock electrical connection corroded...
- Happy 4th Everyone
- 2000 4.7 4x4 SLT AC question
- how much for a new radiator and where should i get one ?
- 2000 durango pinion shaft nut size
- rear differetial?
- more overheating problems
- 2003 5.9 timing chain cover
- poor acceleration
- P1740 help
- durango getting hot
- Add-a-Leaf for 2003
- hard turning
- T/S question for 2003s
- wet carpet
- Xplod wiring harness
- Need advice for limited slip rebuild
- AC noise
- Security System armed itself and I Need Help
- 2000 Dodge Durango problems
- chime noise
- HELP 99 durango wont start
- Speed Output Sensor
- My 99 durango wont start now.....
- Overheating
- engine block plugs
- Rear Air issues with heat and A/C
- remove/Replace Intake Resonator/Air Hat 5.2
- Uh oh.. Sway bar..bracket missing!
- DSA Anti-Spin Differential Rear Axle
- 2000 Durango...Need help to identify this problem if any
- 99 Durango wont start.
- Need drivetrain help... I think
- 01 Durango SLT 4.7 problems
- Bump stops... no clearance.
- 2000 Durango 5.9 maintenance
- Overheating in Africa
- Ticking noise while turning left.
- Hawk LTS brakes grinding already!
- Power Seats Not Working 98' 4x4
- OverDrive switch not working
- My 5.9L sludge monster - proof on film!
- Tailgate light?
- Battery gauge said 0 but Bat. and Alt. are fine?
- Help with codes
- Tire ? and recommendations
- Transfer case switch ?
- Custom Roof Rack needs weather stripping
- 99 brake lights wont come on
- steering/gear box leak
- 99 5.9 won't stay running
- 03 4.7 misfire #6 help please
- Front End Suspension Lifts
- Interior Lights
- does anyone know if this will solve my stalling issue on my 2000 durango??
- Correct Flair Nut to fit Brake line
- 99 durango 5.9 4X4 SLT ABS sensor questions
- Tire questions from the Brit (with no idea)
- Tick/knock in the Engine, P0203, P0208, P0301, P0308
- Need some advice on spark plugs...
- compression on a 5.9L
- does shifting sound normal
- '98 Durango - Knock, Tick, Slap?
- Brake Light Trouble
- Cleaning the rear A/C on a 2000 Durango
- Power windows not working 2002 durango
- 1st gen control arm
- 02 durango r/t need help
- Rear A.C ??
- whistle sound( puzzled)
- Exhaust manifold rust out
- trans problem
- looks like new plugs and wires
- tranny Fluid Change
- E-Fan Problem Fixed
- A/C Compressor Bolt Specs
- Speaker Question.....
- HELP! 2000 Durango - Modified Intake; A/C vent stuck on floor! Vacuum? PICS!
- Remote lock/unlock (dumb question)
- Whooshing sound with brakes - soft pedal?
- 2000 Durango Power window/lock not working
- P1391- replaced sensor, made it worse
- Fuel filter
- Shackle lift.
- Any quick fix for a blocked A C drain ?.
- valve or motor...?
- NOx-ous Problem – 2002 R/T
- Pusher fan in front of condenser...?
- transfer case maintenance
- A/c help!!!!
- E-Fan question
- E-Fan Woes
- My D don't move and rolls in park!!
- Play/Slack in Steering
- brake problems HELP
- HID flicker and HIGH BEAM INDICATOR ALWAYS ON?
- Brakes Proportioning Valve??
- My Newest Project
- Brake Drum Nightmare!!!
- need help with my ac
- P0455 Code; 4.7L
- Heater Core Replacement Check List?
- 03 Durango 4.7 Ignition coils
- I want your opinion on upgrades...
- Pmsl, (not) why did my wheel almost fall off !
- Muffler Delete?
- 2003 Durango 5.9L V8 R/T - Idle Problem
- 2002 Durango Brake Nightmare
- P0340/P1391 2001 Dodge Durango
- 2000 durango trans swap
- 2000 Durango Vacuum line issue
- 03 Dodge Durango R/T Rough Start Problem
- Brake bleeding
- Vibration Troubleshooting?
- DIY: Replacing standard power mirrors with heated power mirrors (Durango Edition)
- Thermostat Question
- Please read BEFORE posting in this section
- Vacuum feed to AC/Heater control panel on 1999 Durango
- Changing Crankshaft position sensor
- radiator fluid boils but truck doesnt overheat
- Replacing R/T Emblems
- My 2002 Durango....
- how much power?
- Rough acceleration...misfire??
- Wanna Have some fun!?!?!?
- DIY: Adding a overhead console w/ temperature and compass (Durango Edition)
- new to this forum...quick engine question
- Battery Keeps Dying
- rear diffrential fluid???
- Energy Suspension Is Now Making Replacement Parts
- Running only on number 2468 cylinders
- Pushed my luck one time too many
- New to DF :-)
- Blower Motor - Not working at all.
- Hesitation / Missing
- anyone know brakes?
- Rockauto
- 2001 R/T Transfer Case Issue
- Blower Motor Solution
- Just COMPLETED the 1st stage of the evap and heater core replacement!
- No brake Pedal pressure
- Caliper flare nuts Metric or SAE?
- p0505 idle air control system
- Tuning help
- '02 with Steering issues
- Headlights remain very dim when shut off plus other stuff
- Rear door speaker replacement/door panel removal
- Fuel Pressure Drops to Zero
- 2002 Durango Transmission Code
- $550 to change plugs and wires? 'scuse me!
- Code P0753 1999 Durango 5.2 44re Limp Mode No First or Overdrive HELP!
- coolant leak by fan?
- Keyless Entry battery replacement
- 2003 4.7 Durango engine noise
- tranny problem??? possible torque converter??
- Durango VS Jetta
- 2000 5.9 a/c clutch locked up
- 2002 Dodge Durango Lug Nuts
- 2001 R/T with Superchips 3715 - Great
- Battery drain
- High Milleage?
- front suspension sqeak
- AC Compressor started tapping
- She overheated, again!
- A/C blows just not thru vents
- 2002 durango stalls, but not all the time
