PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. Burning Smell coming from belt next to radiator fan
  2. Steering question
  3. Noise from Rear Differential
  4. Need to know OEM torque converter number
  5. bumper
  6. a/c blower motor for back of Durango
  7. Automatic door lock feature on 1998 D
  8. Dodge Durango 2001 heater problem
  9. 5.2L oil pressure falling at low RPM
  10. Need help locating front bumper for 2003 Dodge Durango
  11. Durango beeps 3 times when opening the car
  12. Dodge Durango
  13. Hot time in Atlanta
  14. quick question about the Converter lock (trans)
  15. fender fairings,door steps
  16. 2003 4l7L Front seal leaking
  17. Valvoline atf+4
  18. Pass,Side Rear brake locking up...
  19. Coolant system pronlems! Need Help!
  20. Front Bumper Replacement Parts List
  21. Still have code p0733
  22. transmission mod
  23. Something's killing the battery
  24. Flowmaster 52557 mufler install pics
  25. Help With R/T Transmission & Codes
  26. Up Dodge Creek...
  27. fuel pump or fuel pressure regulator
  28. Fan clutch always running when engine started?
  29. 1998 Durango Cruise Control
  30. need to drive to PA to see grandpa in death bed "rear drum brakes-rear axle bering"
  31. In need of help on 99 Durango
  32. K&N/ Ebay CAI
  33. 2003 ABS Problem - need help
  34. A few Questions...
  35. Front air warm, rear air cold
  36. Right front brake sticking
  37. sludge problem fixed, now p0725 and p0733
  38. A/C question for the Guru's
  39. Brighter back-up bulb?
  40. Ambient temp sensor PLEASE HELP!!
  41. Bead lock Pros/Cons
  42. Having major issues with my durango.
  43. P0601 code that comes and goes
  44. Lower Class Club
  45. Wheels/ Tires
  46. Seafoam
  47. Rear Main Bearing Cap
  48. Heated Seats
  49. Throttle body Spacer
  50. Standard Equipment on 2003 Dodge Durango base model (SXT?)
  51. Did the Grill insert Mod on my "D"
  52. Tech gurus< NEED HELP! Oil sludge build up
  53. Need Advice removing Spark Plug Wires
  54. How can I get more rumble from my RT?
  55. recovery money sweeeeet
  56. 4.7 Identification?
  57. Transmission Mod
  58. Smog test fail because of new computer
  59. Durango Air Conditioning Problem
  60. Leaking Antifreeze
  61. Body Code plate location?
  62. Dakota of the Month Poll
  63. Transmission fluid in gas tank?
  64. Need cooling/radiator info
  65. Fuel Injector Code/Issue
  66. Front Shocks - ?
  67. woofer decapitated
  68. 2002 Durango Question
  69. Major Tranny issue, Please help.
  70. Anyone Try Pure Acetone!?
  71. Rear Passenger side door will not unlock.
  72. Brake Light Issue
  73. 2001 dodgedurago 4.7 rebiuld turns but wont start
  74. 1999 Durango, ABS engaging at low speeds.
  75. Low Compression on Drivers Side Engine Bank
  76. Testing Numbers Are In!
  77. Fan Pulley Burntout?
  78. 2000 fan clutch tread
  79. Another awesome A/C issue- this one self inflicked
  80. overheating at idle
  81. Help, Air bag light/ cruise control
  82. codes! po715
  83. 46RE shifting problems Park to Reverse lock up
  84. 2001 RT Transmission problem
  85. 2000 Dodge Durango 5.2L Questions
  86. Crash repair
  87. 2001 Dodge Dakota Fog Light Fuse
  88. Battery Gets Drained / Press Gas to Start / Engine Still Running After Removing Key
  89. 2003 Dodge Durango 4.7 D.O.A. Please Help!
  90. Hughes Custom Performance Intake Manifold
  91. 2000 5.9 Stalling when in Drive, but not Park
  92. How to lower rear seat?
  93. Got bored..
  94. Transforming to old into new.
  95. someone please helf
  96. IAT location
  97. Vibration 2003 Durango
  98. Throttle body size/custom intake
  99. U joint loose? Something in driveterrain?
  100. 99 Durango a/c do I need a vacuum to refill
  101. 4.7l Durango Headers So Expensive!?!
  102. 2000 Dodge durango Trailer wiring running lights problem
  103. 2000 5.9 trans glitch
  104. New Hood Pins WooHoo!
  105. MIL Light, need help
  106. Need Help on removing door panels
  107. My 2003 Durango totaled from a a Hail storm what would you do?
  108. Disgusted
  109. Finally took some pics of my Durango
  110. Rear passenger side wheel locks up !
  111. 200,000 miles!
  112. 2000 SLT Durango 5.9l A/C Lines sweating heavily
  113. Mopar Luggage carrier
  114. 4.7 heating problems
  115. Durango A/C Testing
  116. HELP! Torsion bars? Springs? What do I do?
  117. Reliability questions: Considering Purchase Durango 5.7L RT
  118. 2000 durango - pedal to the floor problem
  119. 99 D, transmission issues
  120. leak rear of water pump
  121. horn help
  122. Looking at getting a Durango
  123. (Upper) ball joint replacement
  124. what gears?
  125. tow worthy
  126. my cooling fan will not shut off
  127. New Member, Big project
  128. Check gauge light on.
  129. P0753
  130. I bought new tires for my 20"s but tires are to big.
  131. Desprate Measures
  132. Wretched, evil, b*stard dealer...
  133. Dodge Durango Transfer Case 351
  134. 98 Durango Motor Swap... Need Help...
  135. Overheating when a/c is on . . . Help
  136. Sputtering and Bogging???? Help
  137. Lifter issue or bad combustion spark plug?
  138. Speedie lube screwup oil 4 quarts over
  139. What Happened To My Turn Signals And Brake Lights???
  140. 99 Durango won't start after driving
  141. Manifold Heat Shield Comparison
  142. Ignition Coil Pack Meltdown, 4.7L Durango
  143. 99 dodge durango wont start
  144. Install lower ball joint '02 D R/T 5.9L
  145. Misfire deteccted
  146. Very bizzare !! Won't start and no gas gage!!
  147. What's a good rear end?
  148. 2000 D SLT, 5.9L, 108,000 - New Vibration
  149. 99 Durango Timing and Head Gasket
  150. Steering wheel buttons not working
  151. A couple of Comments, and a couple of questions
  152. tail lights out HELP
  153. New Flowmaster pictures
  154. Air Conditioning Air Flow Problem
  155. Upgrades complete...
  156. 5.9 studding and loss of power
  157. weird tire question..
  158. 2001 Durango 4.7 OverHeating Problems
  159. Low Power At Startup
  160. Cap and Rotor Change Out
  161. Fuse Box Door Panel
  162. 1st to 2nd shift
  163. performance module?
  164. Support TOTM Dodge Truck Voting
  165. 2000 Durango A/C Puzzle
  166. Head Gasket Issues???
  167. aftermarket cams
  168. oxygen sensor relay?
  169. Do you have rear a/c?
  170. 1999 Durango Right side door?
  171. Shocks for 2003 Durango...Monroe Reflex?
  172. 4.7L Tranny Oil Lines
  173. trans funkyness
  174. They Giveth & They Taketh Away - No Govt Backed Warranties
  175. hey i need help with the right side front window
  176. biggest set of tires
  177. lift kit?
  178. O/D Solenoid
  179. need help
  180. Non A/C belt
  181. P0731 code w/ no od???? help????
  182. power window problem
  183. brakes?
  184. code retreival
  185. Engine Oil Pressure
  186. Transmission Fluid & Filter Change: Help
  187. dirty differential fluid causing this?
  188. Dash light
  189. cranking torsion bars to get a lift?
  190. Headers/cams any one?
  191. Trunk space?
  192. Axle jacks
  193. PCM Fried
  194. Strange behaviour from and about 2000 (about) Dodge Durango
  195. 01 Durango Software
  196. A/C Doesn't seem to work right
  197. Transmission Problem
  198. Strange taillight behaviour ≈2000 Dodge Durango
  199. Window regulator voltage problem
  200. 5.9 Timing
  201. Rear Heater hose routing
  202. P0420 advise please!
  203. Squeaky durango
  204. AC Blower Removal
  205. Engine Fan Wobbly
  206. 98 Durango A/C Whining Noise?
  207. 2001 Durango R/T Questions
  208. Oil in 2001 5.9 kegger. What to swap in it's place?
  209. Any Florida residents?
  210. ooops!!!
  211. 5.9L, 5.2L, 3.9L, and 4.7L Custom Ram Air - DIY
  212. want to bypass 2001 infinity amp.
  213. 2003 AC Problem?
  214. Time for some upgrades
  215. Oil Pressure Sending Unit
  216. Why did you park so close...
  217. 2003 SLT A/C Fans Not Blowing Hard
  218. Mpg???
  219. 5.9L Opinions and Complete Loss of Oil Pressure
  220. Time for some fun?
  221. About to set it on fire and roll it down a hill!!
  222. engine trouble for a 98 durango maybe someone can shed a little light on
  223. 98 durango front brake problem
  224. 2000 dodge durango ---bad brake issues???
  225. Temp Problems and Bad Dealers
  226. Door locks
  227. Cut firewall to change A/C core.
  228. New Exhaust
  229. 2002 durango A/C problems
  230. Brake Problem
  231. Transmission Rebuild @ 66k
  232. High idle
  233. New Flowmaster.....
  234. Broken Vacum hose
  235. Need info on 99 Durango Compressor
  236. 2002 Durango RT 5.9
  237. How to remove sticky window viser glue?
  238. 02' Dodge Durango Mirror replacement ?
  239. Rancho 3" Lift Kit
  240. Brake Fluid Flashing
  241. engine overheats
  242. Starter help....
  243. fender flares
  244. need help
  245. New ‘tap/tick’ in cylinder #8?
  246. For you NJ guys...
  247. How much tranny fluid
  248. Oil Leak
  249. been gone for a bit
  250. 01 Durango-Wiper Problem
