PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. Fog lights quit?
  2. Power Window Tech Help Please (w/pics)
  3. positraction
  4. Interior lights won't hut off!!
  5. TCM Fun!
  6. 3/9 Wheel Play Drivers Front
  7. i need some advice
  8. 02' Durango exhaust help
  9. 02' Durango exhaust help
  10. 02' Durango exhaust help
  11. Is a 5.9 a 5-1/8 neck for the trottle body ?
  12. Car starts but will not run
  13. Need Help
  14. o2 sensor, '99 durango 5.9
  15. Gauge cluster says 'no bus'
  16. durango leaky power steering
  17. 45RFE Valve Body for Durango 2000
  18. NC get together
  19. Another misfire story...
  20. 4.7HO swap to standard
  21. Easy one: Please help me identify this part.
  22. 6 Lug to 5 Lug??
  23. Detonation and rough idle
  24. Performance Mods 02 SXT.....
  25. Orlando get together Feb. 28th
  26. Detonation and rough idle
  27. Time To Part Ways!!!!!
  28. Loss power but everything still running... 2002
  29. Missing Hose
  30. Oil frothing???
  31. Electrical Problems – No headlights, 4WD, power door locks, plus more!
  32. Just replaced the oxygen sensor...
  33. performance chips
  34. Front Blower Motor Not working
  35. Motor swap
  36. Newbie w/ some questions.
  37. You may be right..
  38. check engine light
  39. Removing cat?
  40. Windshield Washer Resevoir Needed
  41. freeze plugs
  42. Avery noob question
  43. Need Winshield Washer Resevoir
  44. Rear Hatch Binding
  45. o2 sensors
  46. Durango 5.9L timing marks....Help!
  47. 32's????
  48. Pictures for those who learn visually!
  49. Vacuum Lines
  50. borla muff race
  51. Manual trans in Durango?
  52. odd start? old battery?
  53. blend doors
  54. Vibrating Steering Wheel
  55. Body lift debate: Do it myself or a shop?
  56. bad computer??????
  57. Performance Mods 02 SXT.....
  58. power steering pump
  59. big problems! computer? electrical?
  60. Wheel center caps
  61. Best durango for mpg
  62. taking off brake caliper????
  63. Help with Durango 4-Wheel Drive Please
  64. Speakers
  65. 2000 Durango 5.9 Head Gasket Questions
  66. transmission issue.
  67. transfer case vacuum line help
  68. 03 D w/ 4.7 running rough
  69. 2001 5.9l slt durango
  70. Belt alignment issues
  71. 1st generation offtopic thread
  72. t/s lift
  73. Which motor is best?
  74. red spark plugs
  75. Front Bumper
  76. Flex Plate Clicking Noise
  77. Show us your 1st Gen. Durango!
  78. Can condensation in fog light blow bulbs?
  79. still not sure
  80. '00 D 4WD Dash Light Out
  81. just want to be sure on spark plugs?
  82. 02 4.7 durango dies when stops
  83. rims
  84. Upper Ball Joints. Can I go cheap?
  85. Inner Tie Rod End Replacement Help
  86. 2003 Durango 4.7L Head Gasket Replacement - Do It Myself
  87. Good Ride?
  88. 98 durango 4x4 5.2
  89. 01 duranango sport 4x4
  90. How does the AWD system work on the Durango?
  91. MSD coil installed now car wont start
  92. Diagnosing electrical issue
  93. Diagnosing electrical issue
  94. 265-70-16 Goodyear Wrangler RTS tires?
  95. Durango into a tank
  96. Brakes making me upset
  97. can i donut my D
  98. 01 durango 4x4
  99. 01 Durango Brake issue
  100. Need to revist the subject
  101. Donut tires!?!?
  102. Need info on Valve Spring replacement
  103. Compass recalibration???
  104. Heater Blower Resistor
  105. what is this part for or DO?
  106. please help
  107. Carfax (Off Topic)
  108. Gas?
  109. 2000 Durango 4.7. What years will fit?
  110. 2000 Durango 4.7. What years will fit?
  111. vaccum line ?
  112. hooking up trailer lights/electric brakes
  113. common upgrades, deletes, mods
  114. No compression in cylinder 1
  115. Ticking
  116. it woke up
  117. O2 sensors driving me crazy
  118. overhead display
  119. Is it worth tuning the 5.9 RT Engine?
  120. Do these work?
  121. Two question on lowering and rims.
  122. wacky headlight problem
  123. question about parts conversions
  124. Grinding Brakes?
  125. 2002 Dodge Durango Slt Emblem
  126. Heater switch
  127. Help Plzzz
  128. overhead display
  129. air and heat
  130. 01 w/ 4.7 Stumbles and stalls at stop when cold
  131. MSD Ignition
  132. need help wit front end suspension on rt
  133. speakers
  134. Vibration
  135. 4wd options when pulling another car
  136. suggestions on rotors and shocks
  137. 4x4 question
  138. Wheel spacers?
  139. Has anybody had luck on a 4.7 crank pulley?
  140. Trans problem
  141. Miscellaneous Towing
  142. 35s on a 2001 Durango?
  143. Just bought my Durango today
  144. Towing with a 1st Gen Durango on 20s
  145. Terrible Gas Mileage on 01 Durango
  146. transmission questions
  147. Need Some Help With Motor Blower Resistor Fix
  148. 99 Durango wont start, smell gas
  149. 98 Durango pop noise and growling (as if out of gear)
  150. 01 R/T with no 4 hi/lo
  151. 2002 4.7 4X4 SXT stalls when warm
  152. New security key
  153. What does this picture mean?
  154. Brake pedal issue
  155. 99 Durango wont start, smell gas
  156. 5.2l mpi not running right, lots of fuel smoke
  157. Back windows not going down
  158. 2001 4.7 Durango has loud start up noise like a playing card in the spokes!?
  159. 2001 4.7L Valvetrain question
  160. Clicking Noise - 2000 4x4, 5.8L Engine
  161. Anybody had this one before?
  162. hi im new and just got a durango
  163. window tint shade
  164. WTF?? no start
  165. Legal Tires
  166. 02 Durango lleft and right brake lights inop
  167. Brake Light Problem???
  168. Heatercore Bypass Project
  169. 4 Wheel Drive = No?
  170. Intermitten Transmition Issue
  171. no buse code in odometer
  172. Offset for wheels?
  173. New Member & Trans troubles
  174. Do I have low tranny cooler flow?
  175. 98 durango, how to remove splash shield
  176. Rear Gate door stuck
  177. engine swap
  178. Has anyone tried this?
  179. some questions
  180. 2000 durango headlight problem
  181. Durango rpm question
  182. 99 durango rebuild
  183. heater core bypass project
  184. Cooling Fan Assembly Removal on 5.2L V-8
  185. 2000 durango headlight problem
  186. More HP's?!?!
  187. Trim Q's
  188. Durango q's
  189. Water pump replacement
  190. Durango engines and knock.
  191. Headers
  192. Oil pressure
  193. 1998 dodge durango with running problems no codes
  194. newbie
  195. 00 Durango not starting
  196. Resonator removal?
  197. A/c Compressor
  198. question about 4x4
  199. what should oil pressure read during normal acceleration?
  200. Check engine light
  201. brake lights always on
  202. Front end noise
  203. Front Window Tints
  204. 2003 Durango RT burning oil?
  205. 33/1050/15's installed, impressions.
  206. Ball Joints
  207. Up next
  208. new here
  209. Fuse D ????
  210. Rust Spot
  211. Preparing for my hub replacement
  212. codes????
  213. My son drove my 99 durango 5.9 with a bad waterpunp
  214. Need Help with 1999 Durango V8 5.2 Engine
  215. 2000 dodge durango trasmission failure
  216. Transfer case problems
  217. 2000 Durango Plug Wires
  218. wiring harness
  219. Help with electric problem
  220. 2000 durango check enging code P0441
  221. brakes don't brighten
  222. 2000 Durango code P0441
  223. Power window assembly issue
  224. cruise control
  225. Instructions to Replace a Radiator
  226. 03 4.7 Durango Died out of the blue
  227. sludge
  228. question about squeeks!
  229. 98 D 5.2 High Idle 2100 rpm w/codes
  230. 2000 Dodge Durango 5.9l V8 SLT Battery Drain
  231. 01 durango not getting power to fuel pump
  232. Time for some new brakes!
  233. What happened to the "Do It Youself" thread???
  234. Lift Kit
  235. Lift Kit
  236. All Hail
  237. Dash Air Flow Problem
  238. Help with 98 durango 5.2 4x4
  239. ABS comes back!
  240. po108, 123, 505, 113 HELP
  241. 2000 durango
  242. Alas, poor D, we hardly knew ye...
  243. 98 5.2 lazy starter issue
  244. Help!
  245. rear audio issue
  246. dont want to remove dash
  247. rear wiper...?
  248. mobil 1 0w40 ok to use?
  249. A/C Condenser- Looks like a leak
  250. 4wd works, dash light does not
