PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63
  1. those with bodylifts
  2. Durango ABS Not Working?
  3. Door not opening
  4. Shifter stuck in park.
  5. High Mileage Durango
  6. '99 Durango, 5.9L Stalling problem
  7. where is the best place to find...
  8. clock setting
  9. Rear End Conversion
  10. Trans slip - cold
  11. door lock noise ???
  12. 03 Durango Engine code?
  13. new durango owner with question
  14. Portable Auto MP3 player
  15. Anyone have fog light problems?
  16. trans 2000 durango
  17. OEM Exhaust Replacement
  18. Code P0442
  19. I love the hemi
  20. Durango 7 pin connector factory Wiring of the hitch??? UPDATE
  21. 2002 Durango electrical problem?
  22. HELP! Power door locks going haywire!
  23. How do I know if I have Limited Slip?
  24. Factory Radio w/ 10 Disc Changer 4 sale
  25. Pics of T/S + Body lift
  26. 2000 durango Revving
  27. keypad programming
  28. is it 5.9 magnum??
  29. 99" Durango SLT dying
  30. Backspacing
  31. Newbie
  32. Heater Core?
  33. Leaky front end after torsion adjust
  34. Rough (maybe) idling 03 5.9
  35. Thermocouple quit
  36. PO456 SMALL EVAPORATIVE LEAK
  37. Engine ID
  38. Tire Size
  39. 1998 Durango Won't shift
  40. 98-03 Durango Hitch (Tow Package)
  41. changed rear end, still grinding
  42. LIFT
  43. bull bar
  44. Need advice on shocks
  45. 2000 Durango blinker
  46. Cruise Control Issue 02 RT
  47. Noisy Rear End
  48. squelling noise
  49. Rear wiper no worky.....
  50. Steering Issue
  51. hitch with shackle lift
  52. hydraulics
  53. 10 disc changer remote control
  54. rear/front axle fluid change
  55. Body Lift
  56. Electric Fan
  57. code p0302
  58. 2000 4.7l timing question
  59. Stiff steering on 00 durango HELP
  60. 2000 Durango - Wiper fluid not pumping
  61. Freeze plug
  62. New owner with a problem
  63. draining coolant ??
  64. '98 Durango Steering / Suspension problems
  65. Shock Absorbers
  66. Help on removing radiator fan
  67. P0456 engine code
  68. Column Shifter
  69. rear hatch holes
  70. Infinity speakers
  71. Durango front bumper replacement
  72. Brake Issue
  73. 3 questions
  74. Guarantee period on a PCM
  75. Iridium Plugs
  76. COLD AIR INTAKE and K/N
  77. new to the dodge family need help
  78. DRIVERS SEAT BELT.
  79. Hypertech III programmer
  80. SECOND/THIRD/FOURTH OPINIONS/ADVICE WELCOME
  81. rear end grinding
  82. Steering Wheel Controls
  83. 3rd row seat install?
  84. Power Locks
  85. 5.2 weird noise?
  86. Electrical Problem 2000 Durango
  87. Anyone with a suspension lift?
  88. What is that hole for on the bottom of the Are rest
  89. Can recall repair be done AGAIN!?
  90. Best Replacement Bulbs?
  91. front end
  92. '01 Durango with Fog Lights
  93. Fog Light Replacement
  94. Runaway engine overrevved
  95. Stereo problem
  96. stock spark plugs ???
  97. 03 durango strange noise when shifting into gear ???
  98. A few questions about my 98 Durango
  99. 1998 Durango freeze plugs
  100. HIGH BEAM SWITCH
  101. 1998 Durango SLT 4x4 5.9 tranny problems
  102. Code PO441
  103. 98 Durango stuck lift gate...
  104. CD Player
  105. 2000 Durango 4.7 low idle & stalls
  106. Rear Speakers Rattle using Bass setting
  107. Rims?!?!?!
  108. o2 sensor
  109. Rearend
  110. Roaring during acceleration, please help
  111. Radiator Fan Relay HELP
  112. Durango Storage
  113. Happy Holidays
  114. ABS 2w or 4w
  115. How wide can I go?
  116. Superchip tuner
  117. Radiator Fan Relay Question on 2001 4.7L Durango
  118. whats most restrictive?
  119. rear diff
  120. output speed sensor cuircuit code
  121. strange noise on cold starts
  122. TIRES
  123. lower
  124. engine starting to run rough......
  125. window motor problems
  126. New gauge installed
  127. goin to buy a Durango.. your opinion
  128. RT vs. SLT + suspension
  129. oil pressure problem
  130. Cost For PCM For 2001 4.7L
  131. hemi thoughts
  132. Seasons Greetings Durango Owners
  133. wont start in park
  134. NUGGET DURANGO OWNER
  135. Wet floorboard
  136. Turn Signlas
  137. how to take door panel off
  138. Ball Joint Issue
  139. TotYear
  140. Relay Questions
  141. oil leak
  142. Strange Problem very strange
  143. Rear Wipper Replacement
  144. Superchip 3715
  145. Stalling '02 Durango
  146. Magnum head replacement...
  147. Tires and torsion / shackle lift
  148. RT vs. SLT
  149. 2000 D just shut off while driving it!
  150. 02 Durango Lifts??
  151. I need a '99 / '00 4.7 Engine
  152. Security fuse Location???-98 Durango
  153. 98 Dodge Durango
  154. stall/sputter problem on the highway
  155. Headers
  156. Brakes lock up
  157. coolant temp sensor
  158. Battery keeps dying??!!
  159. 03 Durango A/C Blower Motor (Pack)
  160. 01 durango surges
  161. Exterior Accessories
  162. Not enough heat
  163. speakers
  164. Engine oil grade
  165. my durango to my rescue
  166. blower motor resistor
  167. 98 Durango rear diff
  168. P1491 Code Question
  169. MMO
  170. PCM Problem? Need help!
  171. Mopar DVD kit Durango BRAND NEW 1st gen
  172. SAFE RPMS FOR 02 R/T
  173. Heated Mirrors Not Working
  174. Durango thermostat?
  175. Replace starter
  176. Air seals for direction air flow past radiator
  177. durango won't shift...
  178. engine sludge
  179. Rear Heat in my '03
  180. Ok, NEWB question.
  181. after market grille
  182. What size muffler
  183. tough steering
  184. Need Advice...98 Durango or 99 Grand Cherokee?
  185. HEY! Get your votes in!
  186. leather or leatherette
  187. trying to figure where a sensor is.
  188. Stock Speakers
  189. CEL CODE
  190. 1998 fuse/circuit problems.......
  191. Battery Problems???
  192. Losing Oil Pressure
  193. Fluid change
  194. Damaged Rims...can I get replacements...??
  195. ToTM voting
  196. 2001 D 4wd engaging problem
  197. Regular Matinence
  198. Programmers for the D's
  199. Lights
  200. Shelby SP360 Durango need help!
  201. What do you think about this 97?
  202. Idle
  203. tierods
  204. Small Vent Hose Dilemma....HELP!!!
  205. Engine Size
  206. Lift Kits??
  207. Mean Green...
  208. Code: P0500-speed sensor malfunction
  209. Putting a lift on a durango??
  210. How to change the rear end gasket
  211. I really need your help...Brake,electrical,alarm problem...
  212. will a jeep tranfer case fit a 99 durango
  213. Engine hesitates on the highways
  214. Squeaking Front End???
  215. Deck works, No sound
  216. Straight Pipes
  217. thinking to buy a 2003 durango.. help wanted
  218. Fuel Pump life expectancy?
  219. lighting?
  220. mirrors
  221. should i buy?
  222. CTM stuff
  223. durango question
  224. Tranny stuck in 1st gear
  225. High performance Shocks?
  226. evaporator unit
  227. Start my Thanksgiving with car problems....
  228. ENGINE CODE P0505!
  229. tranny question
  230. new guy with some questions
  231. CTM location
  232. Cold Air at Passenger's Feet
  233. 2000 Durango 4.7 Stalls when cold
  234. Metal in the Fuel System?
  235. H2O pump
  236. Why did this solve my Idle speed issue..??
  237. Battery Problem.....
  238. Buying durango what to look out for?
  239. Cooler and electric fan purchase....
  240. general mataince?
  241. What kind of fluids to use?
  242. strting problem help
  243. brake pad removal
  244. 2001 Durango Leveling kit
  245. 01 Durango Leveling Kit?
  246. 01 Durango Electrical Ghost.
  247. speaker probs
  248. 03 Durango Mods
  249. P1740 fault code
  250. Fair price?
