PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. dreaded pax footwell water puddle - part ID please
  2. Replacing Left Steering Spindle/Knuckle 1998
  3. 2003 Durango won't stay on after replacing the battery
  4. Durango bounces at 43-4500 RPM
  5. transmission won't engage
  6. Threw a P0601 PCM Internal Ctrller Failure
  7. Trailer wiring 99 durango
  8. 99 durango 5.9 tick
  9. Blocked everywhere but here
  10. Transmission rebuild time
  11. Stalling problem
  12. 03 4.7 Durango- Best replacement engine?
  13. My Infinity Amp is no more
  14. Ignition Coil and Number 8 Cylinder Misfire
  15. 1st Gen 2002 dodge durango slt+ 4.7L 4wd problems
  16. Sealing up the factory airbox
  17. Upper Control Arm Nuts - Alignment Shop??
  18. 5.2 Timing/Fuel Sync Issue
  19. 4.7l durango radiator hot side?
  20. coolant drip leak - pax wheel well / '03 5.9 Durango
  21. Durango is leaning
  22. 2002 Dodge Durango brake lights
  23. Putting in Harland Rockers, I broke it, help.
  24. Instrument Panel light and Dimmer switch not working.
  25. Question about amount of atf+4 needed.
  26. Durango 4.7?
  27. Infinity speakers blown
  28. Car comes on but won't start
  29. Left Turn Signal Issue
  30. Bolt size for wheel bearing
  31. 99 Front End Updates
  32. 01 Durango gear box
  33. 2000 SLT 4 wheel drive problem
  34. Problem refilling antifreeze...need help.
  35. 4.7L Timing chains - any failures here?
  36. 1999 dodge durango V8 5.9L
  37. oem parts
  38. 2003 rear blend air doors durango
  39. 2001 Durango: ABS & BRAKE! light back on after repairs
  40. Issue with trailer lights/plug
  41. throttle body interchangability
  42. Completely new front suspension, sway bar issue
  43. Blown water pump questions
  44. fading brake pedal
  45. 03 Durango AC issues
  46. P0755 code
  47. electric ac cooling fan removal
  48. 2000 Durango, No Radio
  49. PCM Replacement Question
  50. 4.7 power steering flow conrtol valve/spring
  51. Driver's Panel Won't Power Windows
  52. Front end clunking
  53. 03 4.7 over heated and kicked a rocker, need help!
  54. It blows, because it doesn't, blower fan woes.
  55. Cruise control activates the wipers!
  56. 02 engine swaps
  57. 1999 Dodge Durango Rpm Issues
  58. '02 Engine Temp Gauge vs '00 Temp Gauge
  59. 99 Durango lift kit
  60. ford taurus electric fan conversion
  61. 02 durango tranny
  62. Parking brake release handle for durango 01
  63. HELP !! Alarm issues
  64. Temp Gauge Problem
  65. Sluggish Going Up Hill
  66. Engine ejects spark plug
  67. Front brakes keep dragging?
  68. oil in coolant
  69. What the heck did I do?--Heater hoses
  70. think its fuel filter im stranded
  71. radiator fan
  72. 4.7l durango injector size
  73. '03 Knuckles - ABS/Non-ABS interchangable?
  74. over heat issue
  75. Transmission starting in 2nd gear
  76. Adding a 2nd Electric AC fan help cool condesor
  77. 2000 Durango 4.7l error code p1391
  78. Transfer Case Control Module Question
  79. 2002 D 5.9L no start
  80. Security went off, D won't start
  81. Changing oil pump
  82. 99 5.9 durango
  83. 2003 Durango 4.7/sluggish with no power
  84. HELP..Rotted Body Mounts
  85. Driveshaft /Rear Differential
  86. 2003 Durango R/T NEW "no bus" issues
  87. 4WD inop
  88. 2000 Durango brake line issue
  89. Ac woes in 01 Durango
  90. Front end diagnosis help needed
  91. Check engine light
  92. Computer question!!!
  93. Brake light and abs kick on an off
  94. Great brakes but....
  95. Can it run without a cat converter?
  96. Auto Shut Down Relay going on and off!!!
  97. What usually goes bad when?
  98. Road Trip!
  99. 01 durango r/t wont start
  100. 98 dodge Durango ac problem
  101. 45RFE Transmission Range Sensor
  102. Won't Stay Running Sometimes
  103. Beyond frustrated! 2weeks of guessing!
  104. Radiator Recommendations
  105. Low Gear Oil?
  106. my 99 D sinks like a rock
  107. Bled brakes but no pedal.
  108. A/C blower not working.
  109. remote door locks not always working?.
  110. 2001 Durango 4.7l Rev then Stall on Start
  111. Mileage
  112. P0420 error code just went out
  113. 1998 vs. 2003 Brake Rotors?
  114. ABS & BRAKE LIGHT Stays On
  115. 99 Durango Trouble
  116. No running lights
  117. Coding out!!!
  118. Asd going haywire!!!
  119. Ac
  120. problem with abs breaks
  121. Limp Mode & PCM p56028 470ab
  122. spark plug wires
  123. 2001 durango engine troubles
  124. 2002 Durango reae hatch won't open.
  125. Ball joint? or Control arm replacement
  126. Oh what now?
  127. Oil situation after a new plenum.
  128. Is my master brake cylinder bad?
  129. 2001 second row seats
  130. Not Vaccuum leak???
  131. 2002 Durango r/t brake light don't work need help
  132. ABS and brake light
  133. Major tune up advice.
  134. changing PCM
  135. Overdrive Snap Ring in Transmission Pan
  136. removing cross member
  137. AOK..Transmission Fluid Change/purge suggestions to keep it that way ?
  138. Help!!!
  139. 2003 Durango R/T won't stay running
  140. Brake light problems
  141. Popping out of gear - 99 durango 5.9l slt
  142. 2000 Durango in North Georiga
  143. need help buying bushings
  144. 1998 `rango headlight switch probs
  145. 2000 Durango p0320 code
  146. Motor Mounts
  147. Low idle and shutting off
  148. Flooding and Misfire
  149. 2002 Durango R/T 5.9L
  150. Heater core residual problems
  151. What is this thing?
  152. Muddy Monday: Big Red Dodge Durango
  153. Durango R/T 5.9 Transmission 46re problem
  154. Did My Mechanic Tamper with mileage? and tranny question
  155. Just replaced radiator...
  156. Where is my coolant going?
  157. 1999 Durango security fiasco.stranded in parking lot
  158. Front End Vibration
  159. catayltic converter
  160. Help anyone
  161. Diagnose Squeak
  162. Rear wheels lock in reverse - 2002 Durango SLT 5.9
  163. 1999 Durango 5.9 Overheating Radiator Hoses Failure
  164. diagnostic codes
  165. Fuel injector plastic tip?
  166. I love my Durango but I think it loves my mechanic more
  167. Brake calipers mounting issue
  168. 2001 Durango overheated 3 times
  169. Voltage zero on instrument panel when started!
  170. 98 Trans Temp/O/D off please assist
  171. Ball joints installed $%@#^$ Knuckled !
  172. What are you towing with your Durango?
  173. Dangerous Abs issue after changing brake pads.
  174. 1999 5.9L Running Hotter Than Normal
  175. 2003 lower ball joint video
  176. enginge swap
  177. Lower window with motor not working?
  178. Help! 98 Durango alternator/fusible link problems
  179. California Spec/4.7 Engine swap
  180. I need help finding this leak
  181. Why do my new shocks squeak?
  182. Replacement Heater Core Selection
  183. 00 4.7l Oil Pump
  184. New to the forum and have fuel question
  185. Need help with Infinity speakers
  186. 2001 dur shift cable
  187. Need input.. motor shot?
  188. Muffler Options
  189. shuts off randomly
  190. factory to aftermarket head unit
  191. Door adjustment and or alignment on 2000 Durango
  192. No start on a 98
  193. 2002 Durango R/T muffler
  194. stalling and throwing code p1391
  195. Proper Tire Inflation Pressure?
  196. Bolt Torque Specs
  197. 2001 Durango Interior lights issue.
  198. 14.7 Volts Every Where?
  199. Rear lghting ground 2001 durango
  200. No brakes
  201. ABS Sensor
  202. Overhead console swap 01 to 03
  203. to lean to rich!!
  204. 03 4.7l Durango Issue
  205. 2001 Dodge Durango 4.7 Neutral Safety Switch Location
  206. 98 headlight failure
  207. blend door issue maybe ?
  208. Just got a 2000 Durango SLT at Auction
  209. 2002 Durango Excessive Oil Consumption
  210. 2000 5.9L stumbles and backfires under acceleration
  211. Viewing the T S B's ( Technical service Bulletins )
  212. engine idle and transmission have mind of their own
  213. Where to buy fuel pump
  214. Need help removing front axle
  215. keyless entry
  216. My 2002 Dodge Durango will start but wont stay on
  217. remotes signal range short
  218. 2001 Durango R/T won't drive
  219. Rebuilding a Durango 5.9L Magnum Engine...
  220. Durango stumbles after start up
  221. 99 Durango won't start
  222. smog / computer chip problem
  223. 2000 Durango ODB Pinout/8 wire
  224. 99 Durango 5.9 cranking but not starting
  225. 2001 Daytime running light bypass?
  226. Ambient Air Temperature Sensor
  227. Dead spot under load
  228. Exhaust question
  229. Cruise Control Fails to maintain speed
  230. po522
  231. No heat - help!!!
  232. vent and cruise control?
  233. Shopping for exhaust
  234. 1998 Durango tilt Wheel Lever removal
  235. 4 wheel driver
  236. What's your spring wishlist?
  237. Ash tray pops open when I run over a bump.
  238. ABS sensor broke off!!!
  239. transaxle drivetrain
  240. Parking Cable Tensioner ..No longer made by Dodge
  241. No Chime for keyless entry program mode
  242. rear view mirror swap
  243. Fuel pump amperage and leak detection
  244. Identifying Front and rear axles
  245. 4wd moan and clicking
  246. '99 5.2L 2WD Overheat and Oil Pressure
  247. Acronym Abyss. PCM, ECM, BCM all the CM's
  248. dual exhaust
  249. rear end rebuild 2000 Durango
  250. 01 durango vacuum leak at servo cruise control
