PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. O2 Sensor problem
  2. 4.7 vs 4.7HO
  3. 4.7 Oil pressure issue - comments please!
  4. durango transmission bands
  5. 98 Durango heater Control Issues
  6. Dual air intake
  7. New guy eng. Programmers
  8. Cant Find A Lift Kit for 2003 Durango
  9. Removing tranny question
  10. Power steering issues
  11. Shifter problems
  12. LSD/4W ABS Q's
  13. 2000 Durango 4 wheel drive not working
  14. NEED HELP Rear brake drums dragging!
  15. The End ????
  16. Spare key
  17. 4.7l 0-60 time?
  18. ABS/Brake light
  19. 1999 durango 12v 20 amp light front and rear not working
  20. Tach Bounce
  21. Getting a wicked noise
  22. 99 dodge durango no heat
  23. Durango 2000 High-Lock Dashboard Light Not Coming on when Shifting
  24. Front Bump Stop..?
  25. Cosmetic lift?
  26. Help! what did I break????
  27. TRANS PROBLEM? only one.
  28. Removing catalytic converter on 98?
  29. 99 durango water in passanger floorboard
  30. Check Engine light, RPM rise, loss of fuel economy
  31. 4WD only goes into low?
  32. Exhaust
  33. Remote start
  34. Alternator or PCM?
  35. Dodge Durango 12v Power Outlets fuse.
  36. 46RE Trans.
  37. Pulling 'them' out
  38. New Durango Owner?
  39. 1999 dodge durango new motor bad mpg
  40. What do you guys think?
  41. Another 4x4 problem thread
  42. Help getting into 4wd
  43. Electrical Issues
  44. Cylinder head problem
  45. Starting issues I need help !!
  46. 2002 Dodge Durango power window problem
  47. 2000 Durango ignition wiring
  48. Durango Headlamp Replacement
  49. how to check codes for engine light
  50. New to the Durango World (Pics)
  51. Failed Smog Test code P0300
  52. Durango Mult Cyl Misfire.. Help new member please!
  53. Dome light problem
  54. not starting, checked everything please help
  55. 98 D Eating up front differentials. What's the deal?
  56. 4 wheel drive help please
  57. CEL p0455/p0442
  58. A/C Compressor Locked
  59. How to Fix Code P0141 for 2002 Durange
  60. Transmission issue
  61. Handling In Snow??
  62. Replaced resistor.. Nothing.. Replaced Blower Motor.... Nothing.. Any suggestions?
  63. 00 Durango R/T
  64. Left brake light out
  65. 01 Durango oil pressure
  66. FYI for those with coolant/overheat issues
  67. white mily substance in oil cap?
  68. O2 Sensor Question
  69. Master Window Switch Contact Cleaning---DIY
  70. Brake Smoke and Pull
  71. Just got a 03 SLT plus 5.9L AWD Tuneup suggestions
  72. Creaking/Aqueeking coming from the front
  73. Question about tires
  74. Anyone want to guess where this plug goes?
  75. 2002 Durango 4.7 started fine but died after turning on heater
  76. Overdrive
  77. Shake from Rear
  78. Heater/AC not working
  79. 2001 Durango Passenger Rear window goes down, not up
  80. Does tranny warm up in park?
  81. Keeping Battery Terminals Clean
  82. Durango Hood Swap
  83. Want to buy Posi Rear for 02 Durango.
  84. Steering Stabilizer?
  85. door question
  86. T/S question
  87. Head gasket replacement
  88. 1999 Durango just replaced Cylinder heads
  89. Electrical Problem with 99 Durango
  90. 2000 Durango RT 5.9 Parasitic Drain Somewhere
  91. 2002 slt towing
  92. Check gage light on and battery volts topped out???
  93. Gen 1 Durango OEM Security Cover - Camel
  94. What transmission is this?
  95. Reset the computer
  96. Door Lock Linkage Rods Removel
  97. Idling issues... 2001 Durango 5.9 RT
  98. Where to buy fuel hose?
  99. Gen 1 Durango OEM NiB Front End Cover - BRA
  100. starting problem
  101. A/C Heater making whistling
  102. Cold air coming from under dash
  103. Got my truck back from the paint shop!
  104. Inconsistent Coolant leak after flush
  105. I need a lil help
  106. Newbe from Wisconsin...
  107. Radiator question
  108. well I got recieved the spark plugs :D
  109. Comuter controlled camshaft
  110. 99-01 Ramcharger on Craigslist!
  111. hesitant start after sitting for a couple of hours?
  112. Whining noise when on the gas
  113. wheel bearing
  114. cold air blowing from rear vents
  115. ATF 4 for power steering
  116. Burning oil !!! 2001 5.9L RT
  117. 01 Rear Brakes - TY for the info stored here
  118. I got the 455 code again after repairing!!!!!
  119. Fender replacement
  120. O2 Sensor Problem
  121. Cluster data link engine code debug?
  122. Dodge durango emblems
  123. Rear hatch
  124. Bench seat for the front
  125. 98 Durango 5.9 voltage draw
  126. blower motor resistor troubles
  127. Just bought another 98...a few issues
  128. Can I leave my truck in Full-Time 4WD all winter?
  129. Window Troubles
  130. Power wire
  131. 99 Durango General Question
  132. I know it's not a D but....
  133. 2000 rear hatch struts Q
  134. lifts
  135. Bad Remanufactured Water Pump?
  136. Transmission Issue
  137. Looks like I need a radiator a couple of questions before I buy anything
  138. 4X4 shifting problem
  139. 99 durango question
  140. 2000 durango popping when braking
  141. 98 Durnago front differential smoking lost rear seal
  142. 2000 4.7 secondary timing tensioner
  143. Tranny maintenance ?
  144. Code P0455 / Charcoal Cannister Hose Repair
  145. No recalls on 1999 Dodge Durangos?
  146. Does ball joints need grease or not?
  147. computer updates
  148. Durango specific shacles?
  149. 99 Won't hold idle. or keep charge.
  150. How many miles on these plugs?
  151. Rear axle ratio?
  152. Can anyone confirm part fitment?
  153. Cant find fuses for power outlets
  154. Secondary door sill seal
  155. 1999 5.9 into 2002 Durango, Any Problems?
  156. 1998 Durango SLT Won't shift
  157. 2003 Durango 4x4 PCM questions
  158. Hello all, my Durango has a CPU problem!
  159. 03 durango a/c switch
  160. roof top lugage
  161. 2003 wheelbase
  162. 99 slt water pump
  163. LSD + Full-Time 4WD explanation
  164. HID Vrs. Projection
  165. Brake controller install
  166. My Plenum Repair Install.... Help??
  167. Full-Time 4WD PROBLEM!!!
  168. Coolant Issues '99 Durango 5.2 engine 4x4
  169. HELP!!! ABS Pump Stuck On. Will any ABS computer work from a 98-99 Durango?
  170. gears
  171. Help!! radiator removal
  172. Purge Circuit Solenoid P0443
  173. P0455 and Check Engine Light
  174. 5.9 waterpump replacement
  175. Totally not a Durango thread BUT!
  176. A couple of Questions
  177. Start Relay
  178. 99 durango cranks but wont start. HELP
  179. Bumper question
  180. reverse light issues
  181. 99 Durango radio wires
  182. Install of newer radio
  183. Power Antenna and Dimmer- Aftermarket Radio Question
  184. Floor heat diverter prob.. '01 4.7 4x4
  185. Stereo, plz help
  186. 02 Durango 4.7L - How to squeeze more MPG?
  187. CV Joint problem.
  188. Water Pump question
  189. Clutch Fan Replacement
  190. Need Parts
  191. Washer fluid problem
  192. Changing Spark plugs and PCV - 2000 4.7
  193. 180 deg. stat or OEM?
  194. Factory sized tires or not...
  195. Harmonic Balancer
  196. 98 durango wont heat up
  197. Brake lockup question
  198. Clicking noise at 35-45 mph
  199. ABS still engaging at low speeds...
  200. Generic question
  201. What have you done to your truck today?
  202. Transmission shifting problems
  203. Will turn off when i take foot off gas
  204. durango transfercase
  205. Storage solutions
  206. popping out of 4wd?
  207. wiring questions
  208. Lock Probelms & more 99 durango
  209. Trans question?
  210. Low Idle, Evap Leak??
  211. Electrical Issues. Help?
  212. what do you think about this set up?
  213. NV242d transfer case snap ring
  214. Where is the Torque Converter Speed sensor?
  215. 60 horsepower chip?
  216. Parts question??
  217. Specs for speaker upgrade: 2002 SLT with RAZ front end
  218. 99 durango just shuts off
  219. '99 Durango Only 1 Stop Light Works
  220. front axle seals
  221. 99 durango no power
  222. o3 with issues
  223. my ABS and brake light fix
  224. New tires, alignment and ball joints = horrible gas milage now!?!?
  225. 33x12.5 r18?
  226. Intermittent starting issue
  227. Need HELP painting rims!!
  228. Grinding and Clunking noise in front end
  229. havin to rebuild whole front end
  230. 98 Durango Stalls HELP!!!!!!
  231. Rear automatic windows not working?
  232. how much should i pay for a rear end at a junk yard ?
  233. asking those who know
  234. Durango R/T question
  235. what does this sound like to you guys
  236. Kelsey Hayes 125 ABS Module Schematics?
  237. Removing a torque converter
  238. michelin ltx ms2
  239. Durango window problem
  240. 3rd row seat removal
  241. 2002 Durango RT Tire Sizes for Stock Wheels
  242. Help! Help! Help! Couple Problems!
  243. P0441 Code
  244. Creanking Noise from Front of '03 Durango
  245. 99 Durango Brakeline Junction Block
  246. 2000 Dodge Durango
  247. new process 242 transfer case
  248. Wheel question!
  249. 2003 Durango
  250. Low RPM's
