View Full Version : 1st Gen Durango
- Borla muffler
- Durango Parts
- help
- 2000 durango ABS Module Making Noise
- 98 slt 4x4 ?
- my new rt
- Fluids
- Happy birthday Kensai
- Performance computer
- ? Driver-side seat belt is stuck ?
- 2003 Durango: How to tell 2-wheel ABS vs. 4-wheel ABS?
- Vents in '99 not changing
- tires?
- Lagging after fill up... gas cap?
- steering column help needed
- Hello all, new here and have a couple questions
- splarkplug wires?
- im a sick individual
- Blower works know
- Can anyone direct me to 2002 Durango Service Manual?
- 2003 Durango Brakes: 2-wheel or 4-wheel ABS?
- replacement lens
- brake lights wont brighten
- Fix your heated seats for free
- HID Headlights
- 2000 Durango Lights Flash when unlocked and locked with Key FOB??
- Trans stuck in first.
- Performance chip
- Another 45rfe problem
- 33's on 98 Rango. Stock Height (For now)
- Changing Vehicles
- 2003 Front brakes on a 2001??
- Durango pulls/follows rutts in the road after alignment
- 03 Durango engine not cooling & blowing cold air w/ heater on
- Heated seat not working
- 1999 5.9 Problems
- steering column noise
- 4.7 rebuild kit help
- 02' durango recalls?????
- Occasional starting issues 2001 Durango 5.9
- Putting a custom subwoofer box in 98 Durango
- 2000 durango itermittent start
- Audio and ABS questions.
- Transfer case
- 02' durango drivetrain noise????
- Idler pulley arm
- 00 4.7L D 4WD jumpy
- 98 5.2 44re band adjustment, conflicting info
- 98 Durango 4x4 Shuts Down while driving!!
- Tranny leak
- rt trans
- Happy New Yeaar
- 45 rfe transmission, 4.7 02 durango
- Interchangeable Parts by Year
- Two problems
- 02' Dodge durango problem
- 1998 Durango tranny issues
- Just got a '98 Durango
- 03 Durgano Front Bumper
- Body work
- Torque converter issue
- 99durango blwr problem
- 2000 Durango 46RE Tranny
- front axle breather hose vent valve
- Heat coming out barely warm
- Just getting started
- Clutch problems
- Parrott hands free kit - no sound out of speakers
- Can anyone tell me who makes this ball joint?
- transmission problems?
- lets see your lifted Durango's
- 03 durango rear wiper,security light
- wont blow up
- ye olde speaker question
- Plug confusion
- Homemade CD's in Stereo?
- 98 durango blend door
- 98 Durango 5.2 jerks at speed, engine miss?
- Tow hitch
- Persistent Reading Misfire #2 Cylinder 2002 SLT 4.7
- knocking engine
- oil pressure question!
- O2 Sensors
- Tranny ?s
- help on muffler
- Check engine icon lights up
- Reflash
- Newb 98 Durango Runningboard retrofit question
- 2001 Durango won't run
- Orginal Battery in a 2002 is this possible?
- 2002 Durango Trany Update
- Tune Up?
- ball joints on first gen durango
- awd?
- Royal Purple ATF
- Window frozen closed
- Radio Bezel removal
- Trans Question
- old pic
- please help durango running light problem
- ABS doesn't work but no ABS light on
- Flashpaq Superchips?
- Heater core
- 2000 durango trans, slipping
- backup light?
- 2000 durango door locks and alarm goes
- What would I have to do to put 33's on the D?
- rear passengers
- 2000 Dodge Durango - Can the 4.7L and 5.9L interchange?
- Alternator broke now car won't start
- Can anyone provide information on the NV133 transfer case?
- watcha think worth 8k
- transmission/diff straining noise HELP!!!!!!!!!!!!!!
- 98 durango..new starter,,no power
- Georgia ANYONE? help me for some extra xmas cash.
- What the He!!
- 01 Durango Engine runs hot @ idle in cold temps
- big UHOH
- Any Idea's ???? I'm Lost!!!
- '01 Durango dilemma
- Trans relearn and sludge
- Rotella 5w-40 in a 4.7 opinions + MMO
- durango new starter worked..but new issues
- On/Off Road All Terrain
- Need some advice on 1st gen Durangos
- Durango not starting
- 02 Durango 72K To Flush or Just Drop Trany Pan
- '99 5.2 p0205 code
- no cruise no horn. please help.
- 2002 Durango - overfueling/MAP reading
- 01 durango not starting, checked battery & alternator an its not that, please help!!
- Pictures of radio installs
- what causes a weak engine start?
- 8 Lug Conversion Question
- 99 Durango SLT 5.2L - Oil Dipstick issue.
- 2002 Key Fob & Low Antifreeze Question for new Durango owner
- new to the rt
- IAC problem - Stalling / Idle high
- Best year
- Transmission Issues
- 98 durango wont turn over
- blower resistor wiring help
- cv joint and ball joint.
- Odometer not rolling?
- 02 Durango won't start
- 'Ol Coyote's at it again!!!!
- d blew up
- 2000 durango crankshaft pos sensor problem
- 2000 durango p340 problem
- soldering vs crimping
- Side Mirrors
- 2000 durango heater problem
- gauge cluster
- Battery or Something else?
- 2WD Durango
- catalytic converter.
- 98 durango shuts down when i step on the breakes!!
- Help Please
- 2 ?'s transmission and diff
- Grille Guard
- Engine Code 0622
- No AC/Heat/Defroster - is there a fuse?
- Airbag light
- Stuck in park!!!
- Spark plugs?
- 2000 R/T trans. question
- stock suspension,rims, and tires
- What is this coming out my radiator cap?
- New HVAC vent problem
- Fuel octane/check engine light
- black truck polls
- Black truck poll
- Help Please- Durango stopped running
- ATF+3 & ATF+4 Facts
- 98 Durango Transmission problem
- '98 heater
- color of diff fluid/?
- Heating and suspension
- Main Page Photos
- what does this size translate to?
- Passenger Automatic Lock not moving
- Are Gabriel Shocks a Good Shock?
- Durango shifter stuck in Park
- Wheel Lug Size on a 2002 Dodge Durango
- maintenance question!!!!
- Skid Plates?
- Bad Alternator?
- Dueler RVT at Wal-Mart for 2002 DD SXT with NV133
- Replacing a bumper cover on a 2002
- 1560$ for a ECU in Sweden
- difference between 4x4 suspension vs 4x2
- help with rack n pinion?
- A/C Cutting out when I floor it
- suspension lift for the DURANG!!!!! question
- T/S & Body Lift
- 2003 dodge durango engine light problem
- Spak plug fouling question(with pics)
- Update
- Service 4WD light on ~ 4X4 will not engage
- Help Please
- 03 Durango wont start scenario ..switch, battery,...??
- Wandering oil pressure
- Buying a Durango?
- Testing a Stock Coil for Output???
- OEM rim Sizes
- Lower Ball Joints; How to get the boogers out??
- 01 durango tranmission overdrive shifting in and out constant
- TMR Mod
- Left over PCM for 2003 Durango from my swap
- Turn Signal Issue
- Rear Brakes 99 Durango
- Please Help Me Dodge Gods Multiple Drivetrain Noises!
- other options for 16 inch rims
- Hose separating / blowing coolant
- Dodge T-Rex and Frienn Durango in Comp.
- Drivers side seatbelt mechanism getting wet
- 500 mile roadtrip
- Oil Pan Gasket is Weeping on Me...
- Brake Controler
- Cable Adjustment
- P0430 1999 durango
- Error Code P0203
- Head lights help
- 02 Rear end howls
- PCM Install?
- 1999 durango service manual
- Middle of Nowhere Auto
- How to find out if PCM is bad
- 4.7 made me angry help
- 4.7 engine interchange
- Transmission help...
- Idle issues
- New guy needs transmission help...
- p0171
- heater not hot
- got any suggestion or have I covered my bases well enough?
- 35's on 20's
- Numerous codes
- Brake & ABS Lt. on above 35mph + C.C. out
- apperently mud is bad for bearings
- Blinking D
- 2000 Durango Trailer harness wires??
- Rear Axel Speed Sensor / Rear ABS Sensor DIY
- Should I change Transmission fluid & where to buy gears
- is a T/S lift worth it?
- Temp sensor on rear differential
- What would make a Battery just die.
