PDA
View Full Version : 1st Gen Durango
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63
  1. backup lights inop
  2. Recall Question.......
  3. Ball Join Reimbursment address
  4. Started the mods
  5. New user here
  6. Ball Joint replacement
  7. crank problems
  8. Fed up with tranny problems!!!!!!!!!!
  9. What Mods really work? I have a grand to invest.
  10. Look what Santa Brought me...
  11. 1998 Seat Belt Problem
  12. performance help?
  13. Power steering pressure sensor
  14. What about the ball joints on my '98 D ???
  15. Need HELP with 4x4!!
  16. Looking to buy a Durango!!
  17. Mirrors
  18. Recall Info...Are you imcluded????
  19. Heater Core Removal
  20. Biggest wheel size....
  21. Radio Lights
  22. 03 Durango automatically unlocks while in motion
  23. Serpentine Belt Replacement and reverse rattle?
  24. No Floor Heat= Frozen Feet!
  25. 99 Durango ABS help
  26. durango lifts
  27. Durango worth it or not???
  28. Question about tires
  29. TURN SIGNAL PROBLEMS
  30. Factory Running Boards
  31. Hard start after cranking, rough idle and stuck in second gear
  32. 2000 Durango Blower Motor Resistor
  33. Please Help w/ sick 99 Durago
  34. Recall
  35. Recall
  36. Dodge Durango Recall. BALL JOINTS
  37. 2000-2003 Durango Recall
  38. Need Help Bad
  39. Durango Issues
  40. remotes
  41. Tune Up
  42. Coolent question...
  43. Need Dodge Parts...
  44. New member needs help with check engine light
  45. duals
  46. Durango vs. Grand Cherokee
  47. Different ? Club-Cab and Quad-Cab ?
  48. Just bought a Dodge Durango.
  49. replace with limited slip
  50. Engine Controller Versus Temperature
  51. Buy a Durango ?
  52. Looking for roof rails
  53. 5spd durango
  54. Need some help plz
  55. Sputtering R/T
  56. R/T Lift?
  57. O 2 sensors
  58. Transmittion slipping
  59. Fly Wheel welded to the Torque Converter?
  60. FIrst post, soon to be new owner what to look for in 99?
  61. RPMs
  62. rear breaks locking up when wet
  63. Best Lowering Kit for 2X4 Durango
  64. flashers and turn signals not working?
  65. Pulling to the right?
  66. Brakes.....
  67. Rattle in Dash...left side
  68. Tires or Duals?!?!
  69. Remote acting wierd
  70. Plastic rivets?
  71. front wheel-grinding like noise?
  72. New Member
  73. Hello All!
  74. COIL
  75. Hey i need some help
  76. Hey, We got a 99 and need help...
  77. front axle
  78. 2" rear shacle lift kit??
  79. mopar valve covers are in
  80. '98 a/c not working
  81. Durango questions from newbie
  82. Type of Headlight bulbs
  83. hitch cover
  84. newbie to the Durango
  85. 02 durango lift
  86. What is this??
  87. Here We Go Again! 99 Durango Turns Over, but Dies...
  88. 4X4 embelem
  89. Cruise Control
  90. 2000 Durango
  91. Runs a little rich, sounds like its detonating...
  92. '99 Durango 5.9L Oil Consumption
  93. Center Caps for 1999 Durango
  94. hazards flash when signaling right?
  95. Brutal
  96. good heat at front vents, cool at rear vents
  97. need help. 99 5.2L durango "surging"
  98. Rear-end noise
  99. Blinking Rear Defroster Light
  100. Projector headlights for the Durango?
  101. Rear speed sensor?
  102. 5.2? or 5.9L?
  103. Spark plug gaps
  104. NEED HELP with my FRONT BRAKE install!
  105. COOLANT LEAK VS HEATER CORE
  106. noise, can't find source
  107. A/C Problem
  108. 99 Durango Shifting problem
  109. Remote starter Problem
  110. 2000 Durango Seems like a bad Fan clutch???
  111. "A" arm bushings
  112. weird vibrating feeling
  113. Oil Sludge?
  114. TRYING TO CHANGE HEADLIGHTS
  115. Uncontrolable acceleration??
  116. My Dodge Dealer is a joke HELP
  117. ABS lite and BRAKE Lite on WHY !!!!
  118. RUMOR ABOUT FRONT END FALLING OFF
  119. Heater Problem
  120. Speedometer and Odometer not working
  121. trans slow shift when cold
  122. trans shift slow when cold
  123. towing capacity
  124. 1998 durango stalls
  125. P0420 code
  126. 99 Durango - Shifting/RPM Problems
  127. My Latest Problem - Transimission shifting late
  128. Question!
  129. Roof Cargo Rails
  130. Projector Headlights
  131. bcm,pcm or atm
  132. tps and the tranny
  133. 99 durango water pump removal
  134. Thermal Fan Clutch?
  135. 2001 durango running rough
  136. Durango Doesn't start first key turn, Does on second
  137. HELP! Freeze Plug corrosion...
  138. Lowered Durango
  139. Clicking Brakes
  140. Hard Shifting
  141. 98D, ABS lite and Brake Lite on, then off
  142. 98 Durango Problems
  143. Tire/Wheel combination
  144. dodge durango sparkplug change
  145. shutter in rear end...diff. clutches?
  146. Doors won't stay locked!!!
  147. speedometer dropped to zero
  148. Help New Member What performance Add on's are worth doing ?
  149. Slow starting engine
  150. Lousy A/C in 03 Durango
  151. Where is the Transmission control module?
  152. Misfire idle on 2000 5.9 durango
  153. blown intake gasket/stalling no bus odometer
  154. Fuel economy help
  155. My Durango...
  156. I put on a flowmaster
  157. 2003 Durango Intake
  158. Check Engine Light
  159. I everyone, just bought 2002 and love it!!!!
  160. 2002 A/C Side vents Bad
  161. Transmission swap
  162. 99 slt durango
  163. Need Help w/ Edelbrock T.E.S Headers
  164. Check Engine Light On
  165. R/T, Whats different???
  166. Another Thank You!
  167. My New Pics
  168. transmission shifting
  169. New Tires
  170. Need Help! AC Leak Condensation Buildup
  171. Erratic engine idle in park???
  172. A/C FOUL ODORS CONTINUE.....DURANGO 2000
  173. Cruise Control Problem
  174. Multiple Electrical Problems
  175. true dual
  176. Anyone try out these mods????
  177. Just got new tires, Goodyear Fortera, awsome !!
  178. OD OFF Lite came on when climbing
  179. best look'n shell
  180. front a/c hot, rear cold
  181. Speaker Replacement
  182. Retrieving problem codes
  183. Part #'s for OEM plugs, wires & cap
  184. Trying to enjoy my Durango from overseas!
  185. where do I report bad ball joints?
  186. tools needed for ball joint replacement
  187. 2000 Durango Questions for new owner!
  188. Timing Chain
  189. 2002 Durango front A/C problems
  190. FOUL SMELLS FROM THE A/C ON DURANGO 2000
  191. 2000 Durango Extended Warranty Advice
  192. put your truck away charley's come'n
  193. thermostat question
  194. Factory Ride Height '00 Durango R/T
  195. 98 Durango- tranny problems
  196. check engine
  197. Durango Squealing Brakes..
  198. 1999 durango hesitation and sputters
  199. GSport radiator hose installed
  200. 98 durango programming remotes?
  201. 4.7L HO cam kit
  202. rear air
  203. 2000 Durango brake question
  204. 2000 one piece billet grille
  205. need favor - Please measure shock length: 2wd or 4wd
  206. 2002 Cd Player Install
  207. blower motor bad or not??????
  208. service'n A/C
  209. Speed Sensor Help
  210. Durnago V8 Freeze out plug replacement
  211. Durango Tent
  212. Blinkers and Radio intermittent
  213. shelby style parts?
  214. passenger door lock problem
  215. 2002 rpm surge
  216. 2000 Durango Trans shift issue
  217. 98 durango trans prob
  218. Where to buy Dodge badging / rear lettering?
  219. Throttle Body Spacer
  220. '98 Headlight probs.
  221. DTC - "pnone"
  222. specs?
  223. Hot wire for the park lamps on a 99 D
  224. SRT hood for us
  225. Pics of the New Durango
  226. limited slip
  227. Now something else!!!!
  228. KnN High Flow Air Filter for 99 Durango
  229. timing chain replacement
  230. rear speaker?
  231. 4wheel drive problems
  232. squealing drum brakes
  233. Need Highway Tires
  234. Stalling or no start NO BUS on odometer
  235. 2000 Durango
  236. $14.95 supercharger???
  237. Your Durango Impressions Please
  238. new gauges, needing replacement needles
  239. 99 5.9 durango hard start
  240. unable to disarm the security system
  241. Quirky
  242. Fuel additives?
  243. Low washer fluid warning light
  244. 455 error again!
  245. Gears slipping, tranny slipping, or evil trolls?
  246. Mobil 1 ATF okay for our transmission?
  247. 2001 hitch
  248. OEM Towing wiring harness and socket
  249. '99 Owner w/Question's
  250. 2001 Trailer Wiring Problem HELP!!!!
