View Full Version : 1st Gen Durango
- 2003 Durango Rack & Pinon & Front-end Alignment
- Neutral safety switch issue
- Front brake problem
- New guy w/ Dodge Durango 5.9V
- Knocking sound coming from interior?
- Am I freakin' insane?
- Are these rims gonna work
- Something weird with tranny
- hi new to site... tail light problem
- Quick 2003 ball joint question
- Headlight switch or ctm?
- How much engine noise with your 5.9?
- Trans Erratic, Help !!
- No More Gatorback
- 46re rear band strut
- A/C problem: Black box in cab leaks and is loose, no cold air.
- stock torsion key vs. new Suspension Max key
- Very strange and inconsistent howling noise
- Crankcase breather
- P0441 and coolant problem?
- My check engine light doesnt come on with the key on
- 99 ram 46re into 01 durango rt
- overhead "remote controls"
- Inner / Out Tie rod
- 4.10 Gearing Is In
- Hissing sound with A/C & defrost
- Need help to release the cable lock on shifter
- Winch Bumper
- durango 5.9 headache
- can't locate turn signal flasher
- 4.7 to 5.7 swap
- Anyone with crazy stereo installs? 8 Track Players?
- 2001, SLT, Tilt lever removal
- Fastman TB?
- Engine tick at no load
- Clunking Sound when backing up :-(
- Could use some HELP with my 98 Durango
- ABS and Brake Light
- couple questions
- heater core
- Off topic... I'm excited to go visit my son!!
- Steering Wheel Turned Upside Down?
- More Durango trouble
- Ticking and loss of power
- 5.2 to 5.9 swap
- Transmission Issue No Reverse!!! Please help
- 99 durango door latch
- 2000 5.9 won't start
- P0068 MAP/MAF-Throttle Pos Correlation
- Brake Lights and Turn Signal problems...
- Question
- transmission 46re
- How do you change a PCV Valve
- MODS!! *atleast ideas)
- Missing Coolant in my 5.9 r/t
- Everything flashes!
- Yay
- Occasional drop in oil pressure
- Replacing Stereo
- high rpm while driving
- Gas Mileage and horse power
- Hesitation to start when warm after sitting
- Turn Signal Problems
- 98 Durango Dies On idle
- Another Overheating Prob
- I need a pic please!
- cv nut size
- sas on a durango
- 1998 Durango Frame
- P0740
- Keyless entry works to unlock/lock doors, but panel wont...Wierd!! Please Help!!
- Won't shift out of 1st gear.
- Tranny issue
- 117 or 136??
- 32x11.50x15 on stock 15x7 rims
- how to paint rims black?
- no 4x4 selection
- ABS pump won't stop pumping!
- Where Can I Get a Build Sheet?
- 99 durango help
- Cabin air filter
- Cummins powered Durango
- "help" 99 Durango 5.2 dieing after it warms up ???
- Part ID need help.
- Rear End Noise Help!!!
- Does anyone know who sells a lift
- Newbie at possible liftts and ideas!
- No HEET! Help
- Where to find fuel Filler and Vent Hose
- Steering wheel, steering shaft, alignment problem.
- how do i test fuel pump relay?
- 98 Durango Steering play
- 2001 dodge durango
- Horribly off topic sorry
- Strange starting problem
- reverse lights STILL not working
- Torque converter issues, need advice
- Front turn signals not working.
- v10
- 99 5.9 durango died while driving-wont start
- Idles rough, stalling, and power locks
- security wont reset w/ passenger door
- Anyone replaced the license plate light?
- no air from back vents
- What speakers are you using in the doors.
- Questions about mufflers and tips!
- 2001-2003 Headlight knob/assembly
- Oil pressure gauge is high
- Power Lock Question
- Outter tie rod bolt size ?
- Dead Durango
- weird sputtering sound coming from engine of 01 durango r/t 5.9
- Durango & Dakota bypass hose
- New member saying hi
- Newbie and Chip/Programmer Question
- Heater
- In dash nav system?
- 2000 Rango lug nuts
- Tranny slipping big time.
- Question about an oil burning issue.
- Radiators-2001 Durango 4.7 L
- Help!!!!!!!
- need help
- Heater
- lowbeam toggle
- rear band adjustment 44re
- Muffler Offsets
- Suspension lift for 2000 question
- Linkage disconnected from shifter???
- Need fast wiring help! stuck in blizzard
- Gear Selector Issue
- Battery suggestions
- Hey guys noob here...? for ya
- Dodge`s crappy transmission~s
- Starting Issues
- Slamming into reverse
- Advice on maintenance at 200,000 miles?
- When to change differential fluid
- New Bumper
- Can't get out of park!
- burning odor
- what year transmissions fit?
- cheap lift but not a body lift
- Reverse hard to engage
- Gotta love Durango's....
- Post-Plenum repair Charging Issue
- Overdrive Unit Removal 46re trans.
- Still not working after new IAC
- New from North Alabama
- No heat and its -20 HELP!!!!
- Check Valve In Trans. Cooler Line
- Tire sizing question please help
- Remote door lock weirdness...
- Replace IAC now idle way too high.
- no brake lights
- Autibox oil level
- Air/Fuel Mixture thrown off
- LOTS of problems!
- Headlight replacement
- Transmission left me
- newbie
- Possible Battery Issue?
- neutral park switch wiring harness
- 2001 Dodge Durango will not start!!!
- Help! Blower Motor Not Working
- Turning a Durango into a Shelby S.P. 360
- Blower motor pigtail assembly help
- 19 below. No overdrive.
- Transmission Overhaul Manual
- Oil Pressure gauge drops and rises.
- Identifying Big Red
- First time in 4WD now i have noises....
- new durango
- transmission question?
- 5 days of ownership, 1st problem encountered
- Stuck in 4lo
- How do you install a mechanical oil pressure gauge
- door locks gone mad
- Front License Plate
- Plugging it in
- Oil Pressure Issues
- Rebuilding the 360.
- Axles
- Parts from Dakotas for Durango
- Speedo not working!!!
- Durango killed the radio star
- alternator?
- growling noise and brakes pulsating on '99
- 1999 durango smells like propane
- 2002 Durango R/T Intermittant running problem
- Engine swap Question
- Need Help Removing My Transfer Case
- Heat, but no heat
- Tire promotion
- Not sure about this
- dual exhaust
- 01 dodge durango help p1790 @ p0734
- 01 dodge durango
- wont start
- owners manual- 1998 D
- 2000 Durango radio controls
- Tire question
- Cleaning headlight lenses
- 4x2 d lift
- 4X4 Trouble
- Oil Filter Size
- Frozen windows
- Is it my T-stat??
- Durango 46re trans problems
- Intake question
- 98 Dodge Durango will not reach operating temp
- Transmission on 98 Durango
- 2001 Durango SLT+ crappy ride quality
- noise when moving slowly after letting off brakes
- A/C Condenser Question
- How To replace and fix a broken power window regulator on a 1998-04 Dodge Durango
- performance computer`s
- Can I bypass my tccm? 01 durango
- Cant stop the Squeak!!
- Replacing my heater core.
- Transfer case hard to shift, keeps breaking linkage.
- More Mileage Chat
- custom cai
- Halo projector lights?
- Little more power
- Fail Safe Tstat
- Overdrive ?
- Hmm... Heat isn't very hot...
- Trans question
- Clutch fan to a electric
- WTB DURANGO R/T Saeat, non HEATED
- Heat/ac blower problem
- HEELLLLPPPP! With a 5.2
- Engine just started vibrating!! HELP
- Blower motor
- fuel pump?
- Blower issue again...
- engine tick
- Rear wiper won't turn off!!!
- Please HELP!: Durango throwing electrical codes
- 1999 Durango Won't Start
- no heat
- starting and idling
- HID Install Questions.
- Ball joints
- Need help ID'ing this rear deflector
- no rear heat
- Vehicle Theft Security System won't turn off
- Clock spring? How hard to change.?
- Rattling noise near transmission
