View Full Version : 1st Gen Durango
- Engine Change
- Grinding noise
- Durango Accelerates on its own
- stalling auto???
- luke warm heat
- new to dodge and these forums i just bought a 99 durango
- 03' Durango problems with lights and other things
- driver window regulator
- '01 Infinity Speaker Issues
- driver front window
- Help with driver side panel cover broke
- Air only blowing out at windshield
- regearing!
- Could use some advice
- What is the difference between NV233 & NV244 switches???
- Power locks squealing
- 2001 dodge durango steering wheel control
- Lift Questions
- 2000 durango
- The End
- need help
- suspension problems
- suspension lift question
- TRS question(s)
- 03 overheating issues
- Need a 1999 Transmission Oil Pan
- 4X4 not working... running out of ideas!!!
- 2003 dodge durango assembly
- 99 Durango Not Shifting
- headlight auto mode
- Dual ccfl halo black crystal headlighs install
- Abs light blinking
- Durango Repair Manual
- Rear air repair question?
- Shocks/Struts recommendation
- 2003 durango purchase?
- Intermediate steering shaft.....
- HELP! Gen 1 window issue
- Neutral safety switch
- Tranny
- 98 Durango Tranny Jerking
- Differential Noise
- 99 with ABS, Brake & Check Engine Lights on.
- Power Window Help Please
- Exhaust clip thread.
- Low RPM hesitation problem
- '99 Durango 5.9L: Low Compression in Cyl. 1
- TCCM bad or 4X4 selector switch bad???
- Check Gauges
- window issues
- Tuned port injection swap
- whining at 30+ mph
- 01 dingo key wont turn
- this darn chime
- tranny issues
- Passenger door won't open
- Looking at buying a 2000 Dodge Durango - need your help!
- Broken headlight switch 2001
- 2000 Durango SLT
- Oh Deer, Bumper trouble!!
- do I need to remove rad to get to water pump
- windshield visor
- 4.7, 4X4, 2002 Durango won't start - unique message
- Hard starting
- Help with my '98 Durango....
- 5.2 year difference question
- Air Intake
- Joining the Durango gang
- Help. Quick question
- 1999 Durango no spark, no fuel
- Thank You from a newby
- Replacing factory Infinity stereo-speakers also?
- Programming a key fob?
- Mud flaps for the winter
- 1999 5.9L Rough (bouncing) idle = IAC
- Removing Broken Bolts! Help!
- rough idle
- Heater Core Change Bad Ground????
- flat towing and "car" hauling with the D?
- steering/pitman arm issues
- wheel hops when turning sharp left
- Issues with transmission and 4x4!!!
- 2001 Durango 4.7 2wd/ Engine Transplant
- Engine swap
- 2000 durango won't start ! Please Help !
- Thermostat? Radiator? Still Overheating
- not as dead as i thought?
- Help locating power and ground wires under the hood
- Starting - staying running issue
- Help I need some direction
- 1999 Durango - 5.2L 2WD - Need some honest opinions
- Engine Light on
- Brake and spindle surface question
- can u swap a 2000 4.7 w/ sumthng else?
- Transmission Oil Pan Rusted Through
- Durango Running and Starting issues
- Is my Durango Dying? - *help*....
- Durango Down. Help Needed
- Tranny rebuilt Did i get ripped off ?
- The Whine
- shes dying
- Flushed heater core and radiator now no heat and overflow bubbling
- Electric cooling fan
- Fan Blade Broken (photos)
- 2003 4.7L SLT Durango Rough Idle
- t/s lift.
- Transmission issue??? Weird symptons!!!
- pinion bearing replacement
- Help please 5.9
- 5.5 tuff country suspension lift
- Help! How do you remove fender on a 2001 durango
- will not stay running when cold
- Fluxuating idel
- How do I remove the lower control arm and torsion bar? help!
- tru lok lsd clutch pak rebuild
- intermittent transmission issue
- Fuel injectors
- Abs & Brake light
- will not start all the time
- Really stupid spark plug question
- 2000 Durango CE light on please help!!
- I've been busy
- New tires
- my headlight is dim
- P1762
- Which AC thread to read?
- Changing Dash lights?
- 2001 Durango, ABS brakes
- 2001 Durango service 4x4 light
- 99 Durango long start when cold
- 4.7l whine
- need power suggestions PLZ!!!
- First Durango Tow Experience
- rear sway bar broke?
- Thank you!
- 02 durango won't start
- tranny leak
- odometer reading "no bus"
- Truck wont start and i have lots of school this week...HELP
- Yet ANOTHER high idle problem....
- tps question
- How many miles on your truck?
- For sale
- 2003 Durango - Dead
- To those with an amp/sub.
- 99 Durango Starting Issues
- 2002 durango right front cylinder ticking noise
- Engine turning off while driving
- 02 Durango SXT brake problems
- New guy here/heater core
- 2002 Durango - 5.9L factory exhaust diameter?
- P1737, P0740 and P0750 Help Please
- Tranny wont shift into o/d...help my mpg's!!!
- trailer light problems please help
- factory trailer light problems please help
- My Durango Starts Up Funny - Sometimes
- Overheating saga
- burning raw fuel? code 0171
- All Power Windows dont work
- wd-40 to prevent rust?
- 2003 4.7 Performance considerations...
- Remote start
- turn signals/hazard lights blowing fuses!
- Remote door locks
- Wont start in Park but will start in N, Also has a hard time shifting into 2nd
- New tire recommendations??
- 98 Durango 5.9L NO HEAT!
- No tail lights or cluster lights
- Shift kit a DIY?
- Synthetic drive line fluid?
- 2003 4.7 Durango Sport - RFI Engine Noise
- Diesel Conversion
- Check trans fluid in neutral ???
- No Oil pressure
- shackles
- A/C Line repair
- P1740 TCC or O/D Solenoid Perf..some info please:)
- Possible transmission module issue?
- Passenger side brake light does not work
- What's this in my rear end?
- 03' durango5.9l awd 4x4 t/s lift and body lift kits
- Transmission Speed Sensor
- New subscriber needs help!! Check Engine light
- I want your ideas PLZ
- Clutch Fan Question
- Single DIN 7 inch LCD audio deck
- 2000 Durango 4.7L crank no start
- Battery relocation kit?
- 99 Durango Mystery
- 98 durango issues
- 98 Durango 5.2L 4x4 oil pan removal?
- Here We Go Again
- Gas cap Pressure
- Check Engine/slow idle/A/C inop mystery
- Rack and pinion leaking
- New here with some problems
- new here wih trans issue
- transmission problems
- Key stuck in ignition
- power window regulator
- '99 Won't start, no gauges, idiot lights on all because I replaced TS Flasher
- Dual Battery set up
- '99 5.2L oil leak.....???
- 01 Durango removing steering wheel
- 44RE transmission clutch pack destroyed
- New to forum with major durango malfunctions
- Is my 5.9 durango supposed to be this slow?
- Replacing O2 Sensor
- Coolant Bubbling - NOT OVERHEATING
- CV Joint?
- Tranny Electrical?
- Heater/AC control Vacuum Hoses
- Cannot bleed rear brakes ABS
- Overheating
- Code P0601 PCM Internal Controller Failure??
- breaking-in brakes
- code P0740
- New tail light housing = parking light fuse (#4) blowing
- Help
- Engine Swap Info
- Trailer wiring ?
- mounting fogs behind the grille
- Problem lowering the spare tire
- passenger window
- Transfer case clicking
- Tps
- Emission
- 98 No rear brakes rear line rusted through
- Clutch pack disintegrating
- 1999 Durango Owner's Manual
- Floor Mats
- Truck won't start... HELP!
- Trans taking a dump?
- Long Crank
- Engine gets hot going up hills
- Need advice!!!!!! on 2001 durango
- Is This Safe?
- 99 durango chirping like crazy!!!
- Not Running Right. Head Gasket???
- Very intersting stuff regarding installing a system
- Passenger side floor flooding
- New here, questions
- I Don't Know What To Do Anymore, Someone Please Help Me!!
- does T/S lift reduce travel?
- I don't know what it is but I think I like it.
- 180 thermostat
- Are 2000/01 MAP sensors interchangeable?
- 2000 durango help acted like dead battery but wasnt dead
- t-case swap 99 durango?
- Just replaced the PCM and the engine dies
