View Full Version : 2nd Gen Neon
- rebuild almost begun.
- NGC question
- Looking For Pictures of Late Model Neon's on Red and Blue Eibach Springs
- blowing wiper fuses
- 0-60 Times
- SRT4 Coil/Wires
- 03 Neon SXT Low Idle at Stop
- problem lowering the 05 sxt
- AEM Vs. K&N
- Buying parts and accesorries
- HELP!!!! QUICK 98 head egr- 00 head no egr
- PCM tuners
- Finished my retrofit...
- performance brakes
- bumper and taillight question
- Radiator/Trans cooler
- Couple Parts For Sale
- 2nd gen neon stock car
- Car turning off and all electric turns off
- Waldorf, MD car shows?????
- Gas Mileage ....
- heater core bypassing?
- Idle and Gauge Malfunciton
- Performance Mods
- Stops running sometimes won't start!
- 2000 Neon Clutch Problem?
- Compass/Temp Module - Default Startup
- SRT Spoiler
- 2005 neon with front end noise
- 2003 SX 2.0 fog lights
- exhaust and another question
- 2000 neon dosent want to shift
- 02 problems
- Exhaust Questions
- Request How-To adjust the torque struts video
- 2gn How-To's
- 04 SXT Head Gasket/Valves
- Low idle when stopped in drive
- Help! Is 98 neon heads compatible to a 2000 neon
- new here with a few questions
- Terrible gas mileage: bad plug wires or bad o2 sensor the culprit?
- gotta love Piston Slap!
- Trouble putting on PS/AC belt
- sealer for tranmission pan gasket?
- srt4 side skirts
- Spark plugs? Champion or NGK?
- About to be a neon owner
- Diecast 1/24 scale SRT-4
- Fitment of wheels and tires ????
- Central Florida Neons ????
- pulleys
- What Does it Take to Upgrade to Factory Navigation Radio?
- Future plan of Mods ...
- 05 Neon SXT swap?
- How-To Video/Write-Up Thread
- Neon pwr. windows
- Timing belt changed - Vibration/Louder?.
- rather noob-ish tire question
- trouble codes
- Runs but just wont go...i'm new to the forum
- add-on Cruise control?
- vss vehicle speed sensor
- 2004 Neon SXT Idler Puller Replacement
- 02 Neon ES questions
- camshaft sensor
- Clanking noise
- P0304 Help
- important ????
- Was it worth it??
- Headlights (not bulbs)
- 03 Neon Headlights
- very cold weather, back engine noise
- Is this normal for Neons?
- 41TE on its way out of the door.
- 02 neon limp mode, need help
- front end problems?
- 02 neon se 2.0 5speed 202,302 codes
- 2002 Neon Oil fill cap on valvecover...
- CD changer stuck (display code "ERR")
- Suddenly died.......
- 2001 Neon Se..suddenly died and wont restart..multiple codes
- Where to buy?
- 04 sxt dodge neon performance parts
- dodge neon pads and rotors?
- How long did your original tires last?
- Questions on modding
- Time For Fun During Vacation...
- Not getting power to the coil about motor swap
- 03 sx 2.0 fuse problem
- How do i put a new PS pump Pulley on?
- Side markers, blink with turn signals or not?
- Light dimming.
- swaybar size
- new to this
- 04 SXT Head Replacement
- HELP! Engine Mount Removal
- Cam sensor location
- 03 sxt neon
- 03 sxt dodge neon
- My Future Mods
- what is this part called?
- tire replacement
- Top End Noise and Mis Fire
- oil question-new neon owner
- FOR SALE: Hawk Performance Brake Pads for Dodge Neon
- FOR SALE: Brembo Brake Pads for Dodge Neon
- 2003 neon needs new clutch
- 2nd gen Neon race car wiring for ignition/starting
- Rod Bearings
- I might buy a neon on Tuesday, need some advice
- FOR SALE: 2001 Dodge Neon ACR
- Rough Idle(Bad) smells rich
- corbeau seat for sale
- Need help with cooling fan
- High idle problem
- HVAC Blower Motor
- Oil on spark plug thread cylinder #1.
- Transmission issues
- 2001 neon head light help
- 2.0 mods?
- 2003 sx no start
- SRT-4 rims on sxt
- Quick opinion needed...Multifunction Switch?
- Just stuck 04 neon sxt
- Header Question
- What lights are u running?
- My 2002 sxt question?
- Clunking noise when going over bumps
- 2005 Neon SXT.
- Need some help with my 2005 SXT.
- Solve this puzzle?
- Shifter question
- 'Hey there' from new member...
- been a while but...1st gen SOHC pacesetter header on an 04 sxt?
- auto->manual and engine questions 05 Neon SXT
- Neon reverse problems
- Rims Question
- door problems
- 2004 neon 41te/a604 no 2nd gear
- Radio volume issues
- New to 2nd gens, not to Neons
- Front axle nut
- 2000 neon new to the forum shifting problems.
- Starter Removal
- 2001 Neon with a new ECM
- Oil in Spark Plug Chambers
- 2003 Neon coolant leak
- Help! Heater Core
- Thought it gave up the other day...
- belt tensioner pulley
- Opinions on a 2004 Neon SE. New member
- Hey guys new to the forum names pauls paul got a 2000 neon 98 durango neon trans prob
- 2005 neon idling high, really high
- Just a question
- Electric Fan question
- 2004 Dodge sx 2.0 problems
- HELP!!! 2004 Neon Issue...MFS
- Favorite mod?
- transmission problem
- Forsale tallights!
- Need help!!!! Torque converter?
- 2005 dodge neon sxt---please help!
- Drive Belt Tensioner Replacement
- 2005 neon studded snows
- Timing belt change on 2002 neon
- Dodge Sx 2.0 Sport
- Exhaust...
- p0700 code
- 2004 Neon SXT...Issues, Issues, Issues...
- catalytic converter
- 2004 Neon Windshield sprayers...will not spray fluid
- Newbie here...Neon behaving weirdly...PLEASE ADVISE
- 04 dodge neon wiper problem
- Random studder at idle.
- Idle problem, revs from 850 to 1500 rpm.
- Fuel Gauge acting funny
- Flywheel???
- Oil problem?
- Need info on Front Clip
- new to forum, lookin for a few parts!!
- 2005 neon/sx2.0 top speed?
- Auto 4 spd trans 2nd gear shift when cold.
- transaxle problem!!! HELP!
- Snow Tires?
- Can I get some help please??
- No 2nd Gear in auto trans neon
- 03 dead
- Parting out car
- PO204 injector open circuit help?
- Suspension Questions
- neon nose clip swap
- 05-SX 2.0 4-speed auto
- Help help help 2001 neon
- Bent Valve - Safe to Drive?
- Srt cluster =)
- Unidentified Problem...help!!
- Thumping in the rear???
- what happened 2 the plugs?
- 2nd gen 5 speed trans Help?
- HELP! check engine light code 0700
- replaced headlights now im getting an error code p1193
- 0335 and 0340 Error Codes
- Covering Hubs
- Help me!
- Prothane Bushings...
- Belt squeal?
- Stock Rod Length?
- brake calipers question???
- Neon not getting a spark
- Performance Mods/Body Kits
- 2005 Dodge Neon SXT - Idle slowly drops to 550 RPM
- 2004 Neon automatic transmission trouble
- 05sxt exhaust diameter/side exit/ and tuning
- weird noise on front wheels - 2
- 2001 dodge neon trans problem
- 05 Neon SXT Drone at speed
- Gauge Cluster Issue...
- Car trouble
- MadDog STS's
- Suspension, Engine mods.
- Solid motor mounts?
- Engine acting weird...
- Crazy idea with my 04 sxt
- I need help Fast, Neon Wont Start.
- My CAI tales.
- tail light question
- Clutch problem :(
- Erratic Gauges & limited crankability
- Thinking about putting a PT engine in?
- 03 sxt auto trans wont shift please help
- Weired oil light flashing and beeping problems
- Expert Required 02 to 03 Engine Swap
- 2004 SXT Shudders at 2K RPM
- 2004 Neon SXT Valve Job Questions
- aftermarket camshaft help
- 03 sxt
- Final word on fuel filter 2005 SXT
- Neon Sxt Parts
- Cost of having battery cables replaced?
- need help on Oil light problem.
- humming noise/ new timing belt
- Razo
- turbo for a 2.0l neon
- important!
- Mystery problem:/
- 2002 Neon LE Flickering needles / lights
- 2004 Neon electircal problems
- How many Motor mount does a 2005 Dodge Neon have?
- error code 51 - 2004 dodge neon sxt
