View Full Version : 1st Gen Dakota Tech
- Can't tell if I have an auto transmission issue or this is normal.
- 94 Dakota Slt 5.2
- brake lights
- Possible PCM Failure??? No Spark!!
- Drop in fan replacements
- 1996 Dakota 318 oil pressure
- 1989 dodge dakota
- charging problem
- 92 schmetics
- What's this door seal part called exactly?
- 1990 Dak Grille Ideas
- '93 Dakota V8 5.2L SE Lower Control Arm Bushings
- 93 Dakota, 5.2L, Code 41 Fault Code
- Bad ground???
- Dakota air vent control help needed
- 92 3.9 throttle body
- West coast mirrors?
- 6 speed manual
- No overdrive
- 1993 5.2, O2 and Map Sensor codes?
- 1988 Dakota Cruise control
- oil help?
- 1989 Dakota transmission pan substitutes?
- FREE 1992 Dodge Dakota
- Kegger mod on the V6
- Guys...I did a thing...
- 1991 Dakota doesn't start after I put gas in it?
- 5.9 Magnum fuel system help
- Complete Electrical Failure
- Fun With Ball Joints.
- source/part # for vacuum switch on 4wd transfer case 89 dakota
- Transmission problems?
- rebuilding wiper transmission
- Intake Manifold
- $500 Texas truck
- 93 & 94 Transmission Compatability
- 92 dakota 3.9 vaccuum reading
- Missing and backfiring
- Davis unified hei ignition ?
- Brake (bleeding) problems
- Help truck idles up to 2000 rpms
- Sheetmetal patches?
- trailmaster upper control arm
- engine swap
- 91' Fender Flares?
- Engine swap
- passenger door electrics reversed
- 1995 crossmembers
- Steering Column Cover Replacement
- 1995 Dakota problems
- Heater Cores
- Instrument cluster wiring diagram
- Help Locating Wiper Transmission
- Death rattle from the rear center of motor
- Bagging a '91, tips?
- 2 Wheel drive performance suspension
- Bull Bar
- a/c not blowing as hard as i think it should
- Steering Linkage
- 4bt swap
- Tires
- Wheel cylinder nut size.
- factory aluminum wheels
- 3.9 six cylinder EFI vs. Magnum six cylinder
- 95 dies while driving-when hitting a bump or stalls
- These upper ball joints...
- finally found a nv3500
- Brake issues.
- Module package, fuel pump 1990
- 1992 Dakota LE shuts off unpredictably
- Broken tail housing
- '89 Dakota - No spark
- AC Stopped
- dakota runs bad
- Mopar Performance Computer - Auto Computer in a Manual Truck
- Can't Get The Timing Right! Please Help
- 87 seems to be starving for fuel
- 6 prin Fuelpump connector HELP!!!
- Parking Brake Question
- No oil pressure
- Trusted place to buy a lift?
- 94 Dakota shuts off while driving!
- Rims.
- 1992 Dakota SLT
- Exhaust Y-Pipe Versions? (87-96)
- 95 Dodge Dakota 4x4 Ext Cab Lower Ball Joint Help
- fan shroud dakota 92 V8
- Radio problems
- dakota no power
- 3.9 to 5.2 Swap - Torsion Bar Question
- shelby dakota cooling fans
- 1995 dodge dakota 3.9 fuel system
- Timkin rear axle repair bearing question
- 1992 Dodge Dakota No Power at Fuel Pump
- porportioning valve
- 1990 dakota 3.9 info please
- 94 Dakota idle problems
- single cab bench seat
- No start after timing/head repair
- 1st Gen scantool ????
- AC Seals?
- Last Chance
- 1993 dakota 3.9 automatic transmission questions
- 1993 dakota 5.2 v8
- Rear Drive Shaft Sizing/Compatibility? - Junk Yard Pull
- Intermediate steering shaft?
- wheels
- exhaust manifold stud broken
- New axles 5 lug conversion ?
- 1993 and 1995 Dakota
- '96 P300, P301, P302 Codes
- 1992 Dakota 4x4 door emblems
- Steering binds
- Fuel pressure
- How to remove door lock cylinder?
- Oxygen sensor location
- Check engine light
- tips for rebuilding LA 318
- 93 intermediate steering shaft help
- Abs
- LS1 swap 😉
- Need a 231 transfer case 92 Dakota
- 93 Dakota transmission problems
- Oil pressure
- Random sudden loss of RPM..
- trans help plz
- Gas Tank
- 95 Dakota 4 cyl to 318 magnum
- Rebuilt 42RH transmission symptoms.
- How to best remove fuel pump ?
- Has anyone found a rollover valve
- Greetings! And a transmission question...
- 1993 3.9L 2WD Dakota Transmission swap
- Help! No start problem
- Electrical Issues
- 91 5.2L smog pump
- 3.9L Injectors
- Update on old issues 94 Dak 3.9 Magnum
- 94Dak 3.9 AC
- finished 1995
- alignment problem
- No torque converter lockup, no overdrive
- 89 dodge dakota 3.9 v6 chugs and dies
- Torque Converter Solenoid Replacement
- Lund MoonVisor wiring
- Lug nuts?
- put '92 ax15 in place of '91 np535
- New forum member with questions
- Setting valve lash 3.9
- Rear driver side wheel locked
- Timing Chain Cover Leak
- Swaping to v8 ecu fitment
- running warm at highway speeds
- 92 Dakota 4x4 clutch fork problems
- Inconsistent Injector Pulse?? Please Help!
- IAT Sensor Causing A No Start??
- A-518 to 46RH Swap
- 93 Dodge Dakota lift help
- 95 318/3.9 swap
- Power gone.
- 95 Dodge Dakota Manual Trasmission Speed Sensor
- Oil Pressure Issues (87 Dakota V6, Base Package)
- 93 3.9 no power to fuel pump
- Egr delete
- 92 dodge dakota running bad
- 91 Dakota 4x4 problem
- Awful Metallic Noise While Trying To Start 95 Dakota
- 1st gen v6 to v8 swap ?'s
- Anyone out there? Old suspect solder joint/Auto Shut Down fuse
- Injector output circuit
- 96 Dakota Service manual need?
- ASD fuse (Auto shut down) issue
- Engine Loping at low speeds
- 1989 Auto transmission question
- re upholster bucket seats
- Fual pump issue? Need help please...
- more fun with fuel pumps
- Need a 5 speed trans
- timing belt
- what is it
- throwout bearing
- dash lights
- noisy engine
- My headlights aren't working
- Wiper bushings
- Possible fuel pump issues...
- 1998 wheels
- torsion bar
- 95 Dakota 2.5 randomly dies and randomly won't start
- dakota 93 fender removal
- Temperature gauge 96 dakota
- 87 Dakota Need Help SOS!
- heads up fuel pump auto zone
- 1990 lil red express dakota
- Wipers don't work
- 1989 dakota and crankshaft position sensor
- Wiper delay inop.
- Wont go past 50mph
- Trailmaster Suspension lift - WTB
- 1991 3.9 V6 auto to manual swap help
- 1996 Dodge Dakota 3.9 V6 Overheating
- extension housing bushing
- Brake problems
- 1990 dodge 2wd v6 5speed
- Tach not working
- DD43 trail master lift
- Extension Housing Needed - Please Help
- U Joint Retainer
- need help finding 89 fuel sending unit
- NP231D vs NP231J Rebuild Kit
- 95 Dakota fan
- 93 body lift
- idle flucuates
- Body Mount Question
- Rusty lower exhaust new exhaust questions.
- 94 dodge dakota odd noises
- Wont' stay started
- Transmission oil filter
- Front axle won't engage
- Does an '89 have an o2 sensor?
- Rim size
- Dakota won't start after overhaul
- How to change rear wheel bearings
- 4x4 Bump Stops
- Source, diagram, or part # for plastic hood rest bumper
- Roof
- Removing headlight base, need info
- Thorley/Mopar Headers
- Trying to upload pics
- lifter issues
- 95 dakota parts
- Heater Core
- Heater hose routing please!
- v8 injectors vs v6?
- 93 Dak 2wd Lift question
- 42rh transmission
- 95 exhaust on a 87
- Missing Horn
- Where does PCM/ECM sensor ground wire attach?
- Engine dies
- 1996 dakota 3.9 v6
- Front End Clunk / Pops
- Tming Chain | How To Install It From Scratch??
- 95 dakota has me stumped.
- I'm Worried; 94 dakota gently rocks side to side
- 2wd suspension upgrades
- 95 Dakota 5.2 Troubles
- Tips to reach ~300 HP on a EFI 318?
- 1995 dodge dakota 5.2
- 93 Dakota Hard Starting cold
