PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. Fast idle issues, not kicking down
  2. no dash lights gauges not working
  3. nominations open
  4. oil weight
  5. 93 Dakota seats
  6. One more "it won't start"
  7. i need help finding a lift
  8. 92 Dakota blower problem
  9. beafing up my 318
  10. i need help!
  11. valve cover breather
  12. Recommendation on trans cooler and additional items for plenum replace
  13. Shes alive
  14. High Milage club, how high can you go?
  15. Tail Lights
  16. Pics of Mikes Freebie 88 Dakota 4x4
  17. V10 swap?
  18. Need Help
  19. Inner tie rods
  20. 94 5.2l Heat Selector Cable problem...
  21. low oil pressure when hot...
  22. 88 3.9 runs rough
  23. MY 94 Dodge dakota
  24. aftermarket ign. wiring
  25. sweet dak on craigslist...
  26. power steering pulley removal, 96
  27. Oil Weight
  28. Bigger Cam
  29. if i pull my battery terminal should my dakota run?
  30. help with charging system? (alternator/battery)
  31. 87 Dakota Surging on Highway
  32. Hello from Missouri!
  33. Cowl Induction Hood
  34. best way to lower
  35. manual hub conversion
  36. 3.9 magnum early carbed intake?
  37. fuel filter
  38. Off-road Dak meet, Colorado
  39. Dak Meet - not 56k friendly
  40. sure grip
  41. v6 to v8 swap
  42. 4 wheel drive in 92 dakota won't engage
  43. TBI spacer??
  44. What happened with your experience?
  45. I could use some help with my idle problem
  46. Dash Removal For 93 Dakota? How?
  47. starting issue...
  48. Blower motor resistor
  49. 96 Dakota water pump
  50. Running out of ideas... Fuel gauge not working...
  51. Part number
  52. Need some input
  53. V6 transmission into a V8?
  54. So what do you do with old wheels/tires after getting new ones?
  55. Terrible noise turning right with 4X4
  56. dash lights
  57. can any1 help and tell me what wheels these are
  58. Overcharging Problem
  59. wiring problem
  60. Charging Problem. To high to low!
  61. Fuse problems
  62. Wiring Diagram Radio Dakota Sport 88
  63. Frame swap
  64. 33s need more lift? Headers?
  65. Please Help-Heater Fan doesn't work?
  66. 87-96 Dakota Unimount For Sale
  67. magnum 3.9 swap in 88 dakota
  68. trans cooler question
  69. interior lights, dash lights, and the radio
  70. brake lights & turn signals
  71. need help w/ heater core
  72. four wheel drive question
  73. Big problems
  74. New Dakota Owner A lot of Questions
  75. squeaking belt or pulley
  76. Question for Crazy4x4RT
  77. Prevent Rust
  78. Unidentified noise
  79. 12" subs for sale
  80. Motor Build
  81. Front hitch!
  82. MP Computer on ebay
  83. does anybody have experience with fuel pump rebuilds?
  84. A 318 swap??
  85. plow wiring harness
  86. Spindle nut size?????
  87. wheel bearing problem
  88. My 95 Dakota willn't idle in cold weather
  89. Lifting the torsion bars past the rubber stops
  90. wheel bearing question
  91. headers what you got?
  92. Dakota Single cab Parts wanted
  93. Help Please
  94. my poor ole besty needs sum help maybe fuel pump or filter maybe both take a look...
  95. transmission question
  96. Straight axle?
  97. Shock options
  98. Need a transmission
  99. rpm gauge swap?
  100. running light/dash light problem
  101. odd coolant leak!?!
  102. A word of thanks
  103. Wiring Harness Problems
  104. Gear ratios?
  105. COTM / TOTM voting open
  106. transmission differences
  107. Question
  108. Putting a plow on a 96 dakota
  109. Part Number, please.
  110. unimount
  111. water pump leaking?
  112. 94 Dakota speedometer/odometer won't work
  113. Good alignment shops?
  114. puttin a fuel infected 318 into my tbi 91 kota.. help?
  115. cut fenders for big tires (pics?)
  116. December sucked!
  117. more wiring issues, no taillights and no panel lights
  118. 1992 Dodge Dak wont start in cold
  119. 93 dakota engine/transmission swap question's
  120. Need Bumper
  121. New Wheels
  122. broken hood latch cable
  123. 1993 dakota auto trans
  124. NEED HELP ASAP please!!!
  125. 95 dakota 4x4 wont start -starter
  126. Improve MPG - Megasquirt?
  127. 94 3.9L Dak
  128. new n need help
  129. Having trouble (newbie)
  130. what does a vss do?
  131. New to Dodge
  132. Starting Problem
  133. Master Cylinder Replacement.
  134. New truck in the works
  135. tail light ground
  136. performnce chip off ebay for 5.2
  137. ABS code 7 and brake light problem
  138. newbie with a few questions.....
  139. Weak Brakes
  140. Rear window decal/tint
  141. A call to all you Off-Road Dak owners...
  142. Fuel Gauge Still Out
  143. Posi-Trak
  144. throttle body
  145. Need Help ASAP
  146. Check Engine Codes 17 & 37
  147. Abs...rwal
  148. What kind of jack do you use after lifting?
  149. Rollover Valve on Fuel Pump
  150. '95 radio and HVAC troubles
  151. No control arm bushings
  152. Larger tires, adjust spedometer and odometer?
  153. Prevention of crap in upper control arm bracket?
  154. 95 dakota shuts off after running for 10 minutes
  155. '95 Dakota stopped running
  156. radiator issues
  157. I've got treats HERE for all of you!
  158. Dakota in DF TOTM
  159. door hinge
  160. 1996 Dakota getting hot
  161. New Bushings?
  162. 1991 Rear slider window latch
  163. dakota v6 to small block mount kit for sale
  164. Help!!
  165. HVAC control unit removal...
  166. Wiring Dakota to tow all types of trailers
  167. 91 headlight door swap question
  168. 93 Dak idle problem.
  169. Timing question.
  170. Front Axle question from a newbie
  171. 93 dakota-cig lighter fuse?
  172. anyone know where to find front fenders for a 92 dak sport?
  173. 95' Dodge Dakota Sport: Acceleration loss, engine's shakes, back-fire's
  174. Upgrades
  175. Absolutely no heat now...
  176. Fabricating a Parking Brake Cable
  177. 95' Dakota Won't Start?
  178. Soldering connections
  179. Blinkers too fast with trailer
  180. DAk meet and greet update
  181. won't start
  182. Clutch Fan?
  183. 91-96 dak lift keys
  184. Headlights Intermittently Turning Off
  185. 91, 318,4x4 Starter won't engage...
  186. wheel help 91 dak
  187. Anyone else getting garbage hose clamps?
  188. Replaced blower resistor, still no 2nd position
  189. Drum brake adjustment
  190. Newb w/ towing questions
  191. a few before and after pics of my truck...
  192. Problem
  193. 3.9 V6... anything I can do to increase power?
  194. 96 dakota getting hot
  195. Hey
  196. If Money Was Not An Issue...?
  197. 92/v8 tranny?
  198. 92/v8 tach?
  199. Towing a Camper this weekend
  200. need help on 91 v6 4X4 dak
  201. 5 speed
  202. Preferred Meet and Greet STATE Location
  203. 1991 issues
  204. Truck won't stay running when cold
  205. How to get the spare tire off
  206. sea foam vs Luca gas treatment and where is boost?
  207. Beginner Question on blown front diff
  208. found problem while replacing Egr Valve
  209. rim backspacing and stuff...
  210. 1996 lights wont turn on
  211. 3.9 to a 5.2
  212. Bumper brackets
  213. Spark Plugs
  214. OBD 1 Codes
  215. will a 5.2L a ax-15?
  216. Escapades of the Cursed Dodge Dakota, nearing finalization!
  217. Looking for lenses
  218. 93 5.2 transmission swap
  219. Gas Gauge
  220. R/T Wheels pics
  221. type of suspension
  222. Stripped lugs, rim wont come off
  223. Fuel Question
  224. 91 Dakota 4x4 engine/front diff/frame insolators
  225. vacuum hose
  226. Head lights
  227. Floor mats/ carpet
  228. lift?
  229. trying to hook up air/fuel gauge
  230. Torque Converter LockUp Question
  231. Is there an excorcist in the house ?
  232. 1991 Dakota 3.9 litre Overheating
  233. Thermostat swap! Need help. 1995 3.9
  234. COTM and TOTM vote now
  235. No Start After Water Pump Replacement
  236. 1993 Dakota Drivability Problems
  237. 94 3.9 water pump fan removal HELP
  238. check engine light
  239. Dodge Truck VIN Decoder! and INFO!
  240. 1996 4x4 318 project
  241. 92 dakota 4x
  242. exhaust leak need help
  243. 92 Dakota Issues...
  244. 93 Dodge Dakota heater blower?
  245. how many different steering shafts did they make?
  246. fender flares
  247. head line like circus tent
  248. Anti-sway bar
  249. 1996 Dodge Dakota Fuse Panel Diagram
  250. Transmission Also
