- body parts
- 6 lug to 5 lug
- 3.9 v6 convertible colectible ?????
- 1990 2WD Steering Rack Replace
- Wheels
- Rear End
- May want to go to a V8
- brake and turn light
- Coolant in the Oil?
- V8 conversion, carburetor, no EFI
- automatic window conversion
- Neon issues
- Lowering Questions
- 95 4cl engine
- AUTO DOOR LOCKS
- Calif. Emissons
- Piston to cylinder wall clearance
- Please Help! u-joints
- 94 3.9L exhaust
- 5.2s Excessive fuel consumption
- Bad fuel pump/regulator on 96?
- slippage
- Gas Tank...
- 95 dakota wont stay running
- Carrier bearing
- heat and dashboard
- ProStart
- dakota lift
- ASD
- Rear end ratio?
- remove interior door panel
- Dakota Rims
- Transmission Cooling?
- 4Wd
- 3.9l v6
- strange noise
- 94 transmission
- Neutral/bakeup safety switch location
- truck is in distress!!!!
- Rear Bumper
- Anyone with experience cutting springs
- 90 V6 Automatic
- '92 Dakota running issues Cured 04-07-07
- lift kit /q
- Coolant Temp Sensor
- Dash/Tach illumination issues
- Oil Problem in 89 Dakota 3.9L
- how to center steering wheel
- Transfer Case Problem
- 318 Magnum
- Will seats from a 93 fit in a 90???
- Cat for 96 Dakota Sport?
- Body Lift Questions.
- 95 Dakota Transfer Case shifter Hard to move.
- driveline hum
- Vibration While Braking
- Need to know truck value
- 95 dodge dakota fule gauge wont work
- New clutch for a 1991 dakota
- 96 Dakota problem
- lift question
- Bigger tires
- Car and truck of the month, vote now!!
- 95 dakota 4 cyl. engine runnig rough and cutting off
- Rear end help needed
- headlights
- 1st Gen suspension mods for the strip
- What controls the IAC?
- performance chip
- I want power
- Pistons for 1988 Dakota Sport 3.9L
- emissions probolems
- 89 Dakota Fuel System Problems
- check engine light/overcharging
- No brake lights
- rearend size
- Smoking Near Heater Hose
- 93 Dakota 4x4 problems
- Rachet Shift?
- Headlight Bezel
- swaping engines?
- Finding old parts - dealership?
- Decal schemes
- No Heat
- NGK V-GROOVES FROM NOW ON
- wierd engine lite
- Oil Filter Relocation
- Heater Core For Sale
- Lubricants - what oil do you use?
- Replacement Wheel info
- Had a strange problem today
- 1993 V8 4x4 5.2
- bed
- heater fan relay
- Rapping sound in '96 dakota
- Got rid of those black wheels and went chrome
- Fuel Issue
- 93 Dakota chug-a-lugging
- Interior parts
- dipstick number
- V8 swap
- 1996 DAK No Heat - Good Heater Core and stat
- my 2nd 1st gen... help
- crank sensor
- HVAC Controls Having Issues
- Transfer Case Vacuum Lines
- dashboard instruments
- Head light\Dimmer switch malfunction
- 1996 Dakota Transfer case (needed)
- 4x4 lever engages, but no works
- wheels from a 92 dakota 4x4
- Throttlebody spacers?
- Wheres the fusible link?
- Problems with my '92 Dakota
- 92 fuel problems
- '91 Dakota 3.9L - NO INTERIOR HEAT
- Anti-Lock brakes
- 1990 Dak No Start
- Squeaking
- governer questions
- Fenders, I Need Help
- 95 transmission
- 1988 Dakota won't start
- leaky transfer case.. questions.....
- thunderform subs
- Tranny electrical?
- 89 over drive not working
- Drawing for ECU
- 92 loosing power in hard acceleration
- Dakota loses power on angle or turning
- talk about a tuff Dak
- Wheels
- Needed: Chrome exhaust tip
- EGR bolt
- ecu testing?????
- Starting Prob
- replace oil pump drive gear & bushing
- light ring around ignition switch?
- 88 dakota rear brakes sticking?
- additives
- Something I have never heard of before.
- Rain leak-think I fixed it!
- How do i...
- 87 Spark Issues
- Dakota 1st Gen Do It Yourself Information
- Seats
- reset maintenance light
- Engine oil pressure
- Moto advice
- Front Grill
- Code 36. Does anyone know what it may be??
- The Cleaning Power of Synthetic Oil!!!
- 318 Stumbles
- For all the slammed dakotas
- Overdrive
- Whats Wrong?? 1989 dakota sport 3.9
- superchager
- 1993 Dakota 4 x4 front abs sensor
- Blower control switch
- U-joints and transmission oil change
- clear front lights too
- pic of clear tails on
- clear tails
- Clear light assemblies
- Where is the EGR Valve on a 96 Dodge Dakota
- Will not come out of reverse to go into park
- 95 Dakota Mirror button
- attack of the rust
- Eureka
- Rough Idle and a Vibration (long post - SORRY)
- new starter
- no start, possible dead fuel pump?
- 90 Dak No Start - Trouble Codes
- Just thought i'd let you know
- 426 hemi into a 95 dak
- Stereo
- Need Help Pittman Arm removal
- Dying Dakota
- another problem i think
- 4x4 grinding
- Stuck Blinker
- I know everyone likes the 40 series....
- Lubrication question: weight on or off...
- Carb'd Engine wiring?
- still no heat
- Heat problem no information listed
- Do V6 and V8 dakota have the same rear ends?
- Door Latch
- swapping from fuel injection to carb
- I got me a 93
- Vehicle Protection System
- Car Won't start Code shows Cam Position Sensor
- Aftermarket parts?
- Where to get After Market Parts?
- engine swap fitment
- suspension mods/wheel tire combo's
- Temp gauge doesn't work
- tranny ?
- "anti theft device"
- I need some power
- 94 4x4 Lever Won't Move
- How much did you pay for your Dakota?
- the 318 is fun but i want more
- 92 dakota
- Speakers...
- No Heat
- Dodge dakota 1995 V6 3.9L 5 speed won't stay running
- How do I remove my Clutch Fan???? Whats the trick?
- New 92 dakota owner here
- v-10 engine
- New member with a question
- bodylift
- Low beam headlights not working
- Who makes the Black Steel Wheels.......
- Ebay SS Shorty headers for 2nd gens on a 1st gen?
- Getting a Dakota
- Wiper Linkage Bushings
- What's wrong with my truck?
- tires
- Bumpers???
- 1993 dodge 3.9 gas gauge not working please help?
- 91 dakota stalling
- picture of my Dak
- new to me 96 dakota sport club 4x4 115k miles
- water in the headlights
- 87-90 grill on 91+ truck?
- How many teeth are on the input shaft for a 5 spd transfer case?
- Dakota 3.9, 5.2? which one is better on fuel.
- Is it my thermostat?
- 95' Dakota
- 95 Dakota keeps cutting out.. Why
- Truck is running like crap!!!
- rear veiw mirror mount
- What Fuel Injectors?
- 03 R/T Wheels
- Computer question.
- FYI on Transmission Mounts
- Power Steering
- wheels
- I've searched everywhere!
- 94 dakota w/blown motor
- Needed gear ratio for 1996 Dakota transfer case...
- Axles and the such
- rear-end woes
- another headlight ?
- P1391
- Proper plastic paint prep?
- Making headlights new again
- New K&N
- more power
