View Full Version : 1st Gen Dakota Tech
- 94-95 transfercase
- NV231 Transfer Case
- Putting back together
- Exhaust & Cat Issues
- Wind/Rain Coming Through Door Seal on 1995 Dakota
- what to fix? code 34
- Engine Interchange Question?
- intake plenum repair
- daggum bird under my 93!!!
- O2 codes P1032 and 1035
- What is a good Spark Plug for 94' Dakota w/ a 318?
- Misfire 5 and 6 cylinder
- Loss of acceleration power, shaking, and dies
- Edlebrock air gap
- EGR valve
- Weird Stall Issue (R to D)
- hard starting/stalling driving me nuts!!!
- Got er done 87 dodge dakota
- 93 Dakota 4X4 auto torsion bar adjust
- Problem with '94 Dakota w/ V-6
- Turn signals not working on 1992 Dodge Dakota
- 94 to 95 mirror swap
- Ram or Dakota?
- changing fuel filter
- damage to 1995 dakota after being towed
- What has same engine?
- Front axle grenaded! Pics!
- 88 dakota rear brake issue.
- Major issue with my brakes!!!
- cheap susspenssion
- Steering wheel hub
- Finally Drove It!
- 5.2 vaccume pressure
- body exchange
- Leaky exhaust dough nut = bad millage?
- Transmission swap 93 Dakota 318
- Water Pump Threaded Heater Port
- Bad o2 sensor with no check engine light on?
- 96dokota headlights
- 93 Dakota Water Pump
- 4 hi not working, 4 low does
- 1987 only starts when cold and wont when warm
- Looking for answers to problems with my dakota
- 93 Dakota Help
- Temperature gauge shot to the top
- cold start runs like crap,,warm runs fine???
- LED tail lights
- Please help!
- 4x4 Light stays on
- 96 42re problem..HELP
- Broken and desperate
- 89 2.5L to 5.9L swap thought
- Anybody runnin 33's?
- HEI Distributor
- running hot, help?
- Replacement fuel line
- Stock exhaust size?
- ATF leak at radiator
- 89 dakota headlights
- So....
- 3.9 to 5.2l swap 92 dakota help
- 1990 transmission adjustment?
- King of the hammers
- tachometer doesn't work
- Tractor Muffler
- Herculiner,Drop-in,Line-X,Rhino.........
- Transmission Throttle Valve Cable
- Help with this ass.
- Fuel Usage Question
- Programmer
- Turn Signal Flasher
- weird click..
- factory fogs
- ABS light
- Abs
- lost my od
- command start
- truck doesnt move once it warms up
- road bumps/shuts off my truck.
- Front Brake Pads
- Bed swap please help
- winter windshield tip.
- Askin the cold weather guys
- I'm new to the site too
- replacement transmission
- New to Site!!!
- Wheel cylinder.....
- 1993 Dakota Temp Coolant Sensor Location
- Flowmaster dual system for a 1992
- How to take out the governer???
- lift and tires
- 89 dakota body lift
- Sudden power loss
- 2nd gear seems to lock me out more than it should...
- If a squeal doesn't change with engine revs, then it is probably????
- 1993 4x4 Suspension Lift
- 5 speed AX-15 bell dust shield question
- 94 Dakota tires rub
- Catalytic Converter Placement
- 2" body lift kit
- Help! '91 Dodge Dakota 4x4 3.9 no spark
- $30.00 CAI installed on 94 dak.
- Check out this sweat sas>>>>>>>
- engine rebuild question
- Headlight issues
- CB/Radio combo wiring diagrams
- 95 Dakota problems
- Rear shock mounts
- fender flares
- Please confirm this wiring...Pics attached
- problem shifting gears
- type F fluid
- 96 dakota 318 4x4 transmission
- NP231 Parts Interchangability.
- Electrical issue, will not start
- Sorry if im repetitive
- 1989 Dakota Payload
- increasing rpms..slow take off
- My first problem...
- Transmission issue
- Heater doesn't seem to be getting coolant...
- Suspension is SHOT
- Horn problems
- Differentials?
- My 96 2WD Lowering plans, based on the 2wd to 4wd hangers FAQ
- ABS issue?
- Need help please - weird engine pause
- You guys gotta love this!!!
- WTF new code?
- Heavy Hood
- 3.9 or 5.2
- doin a 360 swap on my 88 dakota, any advice appreciated :-)
- Just bought a 1996 Dakota 3.9 and needs some assistance...
- 225 75 15 tires on 4x4 dakota?
- What is it?
- Diff tags
- Intake leak
- cyl. misfires, engine harness
- Instrument cluster wiring harness
- Front axle won't disengage
- Help with 92 Dakota Stalling Possible Fuel Pump
- Rear Bumper
- cranking but no start!
- headlights
- po748 code dakota
- tb air horn size.
- A518 neutral safety swaitch wiring
- 91 5.2 that has some starting issues
- 4inch Suspension lift kit
- Sway bar- from 80's Ram
- Newb with a pair of 'Kotas
- P1032 error code
- I think its the splice, confirm?
- Grill swap
- 93 dakota cold start issues??
- Cps mod.
- 93 3.9 auto down shifting
- New and looking to trade my Yota T100 for Dakota
- 87 Dakota, Rusted Fuel lines, Soft lines?
- cylinder misfire
- Temp Sensor
- Remote Door Locks
- Newbie ?
- Having backfiring and spitting and spuddering issues only when cold and cold weather
- Headlights not working
- bumpers???
- transfer case
- A couple check engine codes
- 87 to 89?
- Bypass exhaust sensors
- Transmission Swap Issue
- My big box
- radios and subs.
- 93 3.9 4X4 transfer case lube
- No reverse 1995 dodge dakota
- engine swap help needed 1st gen dak
- 2500 Leaf Springs
- loss of power popping through intake.
- 95 Dakota 4x4 v8 transmission mount
- 1995 dodge dakota
- E-3 plugs
- help please transfer case problems
- V8 5.2 Oil pressure switch?
- Save $40
- High RPM after changing IAC
- Front Drive Shaft interchange????
- How to bleed a clutch?
- tv cable adjustment
- OKwhere is it?
- Give me a break!
- Tranny question.
- Fuse box
- spider gear install question
- What is it worth?
- Hard Cold Start.
- New Fan
- Fixed my shift indicator needle position
- tranny leak
- Bulb Question
- SOS- stranded
- Repinning a dash harness
- floor mounted shifter
- 318s rock
- Finding the "Notorious" bad splices
- Need help with pcm swap. Anyone know?
- Starting Fluid Threat??
- 96 into 87 ?
- Lookin for some....
- Timing chain cover gasket 5.2L
- Whine in Rearend
- Another Timing question
- 93 Dakota 4X4 auto- Lemon?!!
- 1989 Dodge Dakota Speaker Size?
- Brush guard for 1st gen dakota??
- Now the next minor problem
- 5.7 Hemi pics post installation
- Clutch issues
- Auto to manual swap
- 3.9 to 5.9 swap on the cheap!!! Less than $1800
- Tranny save! 3.9 to 5.9 swap!
- Overdrive Issue
- Temp/ heater problem
- need help with tire size
- Oil light flickering
- Engine Knock when cold?
- Exhaust Question
- Header question
- '95 Dodge Dakota high/low beam issues
- So I'm thinking of a solid axle.
- Engine mount modding
- Cracked torque converter
- Anyone here adjust their backlash on their own?
- anyone have wheels??????
- Heater core replacement
- 90 Dakota, no brake pressure after...
- drive shaft
- Manual Transmission Conversion
- 1996 V8 Dakota No Radio/No Cigarette Lighter/No Engine Light/No Start
- True??...
- aamco vs hughes
- heater core 1990 dakota
- Now the good news!
- transmission issue
- All I did was!
- floor shifter plastic housing.
- 94 door hinge
- running rich
- tail lights question
- Charging problem 96 Dakota
