PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. Fuel Gauge
  2. Airbag Light 1996 Dakota
  3. 1991 Dodge Dakota 5.2 L LA
  4. At wits end with my 89 Dakota v6
  5. Starter, Ign Switch, Key Cylinder, other...
  6. My Truck is a Transmission Killer - HELP!
  7. Transmission
  8. Crank no start
  9. Help with vacuum line
  10. Kegger intake for a 5.2 Magnum
  11. High idle, no temp reading
  12. Passenger seat won't fold forward?
  13. Leftover wires after reinstalling heater assembly
  14. 1993 Dodge Dakota 318 V8/5.2 liter with 46RH/A518
  15. Dual fan conversion
  16. seats
  17. Horn ring
  18. 96 Dakota 3.9L 4x4. Replaced oil pump, lost oil pressure and started knocking
  19. Engine swap questions
  20. 92 Dakota transmission problems need help plz
  21. What's a Magnum?
  22. 3.9 Liter Exhaust Ideas
  23. Missing Part on Manifold
  24. 3.9 liter Cam 1991 vs 1993
  25. OBD plug in, has no power. 1996 Dodge Dakota.
  26. Coil Spring Rates
  27. Build Sheet Location 1991 Dakota
  28. Help me please
  29. heater motor fan quit working on first two settings
  30. Hesitation,and low idle fix for me
  31. My manual steering rack is practically flopping around on the passenger side
  32. MAP and TPS sensor
  33. 1993 5.2 Heater question MICE attack
  34. 93 Dakota 5.2 Hood won't pop, cable not attached
  35. Fuel pump module alignment?
  36. vehicle swerving
  37. Replace front bump
  38. 1994 SLT a few different problems.
  39. Valve train
  40. Torque converter differences, RE to RH
  41. Use 1987 head on a 1994 roller block
  42. Ignition Switch or Key Cylinder?
  43. 93 Dakota w/5.2 Brake Line question
  44. Front Lift with V8 Coil Springs
  45. Code 31
  46. '94 Dakota body swap
  47. Ticking Noise Only in Drive?
  48. LED front turn signal bulbs....
  49. Burning alot of transmission fluid.
  50. 96 Dakota Clock spring
  51. 87’ 3.9L fuel tank sending unit
  52. 5.2 to 5.9 swap. 1995 Dakota 4x4
  53. Anyone convert 94+ non-return fuel system to earlier type with return?
  54. Np2500 transmission mount bracket bolt thread pitch
  55. Getting live sensor data from an 89 Dakota on my phone
  56. Ignition actuator rod problems
  57. 1st Gen turns over but won't start No "check Engine" light.
  58. What is this vacuum fitting? [Pics]
  59. Install keyless entry control
  60. 1990 Dakota fuel pump
  61. AC Issue
  62. 1996 Dodge Dakota 4x4 3.9L Front Upper Control Arms
  63. AC Evaporator
  64. Pilot bearing sleeve direction on 92-95 L4 2.5L Manual Trans
  65. brake backing plates rusting away
  66. code 62
  67. Engine and Tranny Source
  68. Fuel Pump
  69. Removing rear glass
  70. Considering swapping out AT for MT - 94 3.9L
  71. Window switch causes e brake light to turn on dash when engaged to
  72. Detached Oil Dipstick Tube
  73. 5.2 4x4 motor mounts
  74. 94 Dakota No Electrical Except Hazards
  75. 94 Dakota No Electrical Except Hazards
  76. 90 V6 no ignition for 5-10 minutes when cold outside
  77. No spark on 93 Dakota 3.9
  78. Coolant in Oil
  79. difference in crankshafts
  80. Truck barely runs after new flywheel and clutch
  81. What the Clutch?
  82. Dodge Dakota Fuel Economy From Model Year to Model Year
  83. Can't Remove Engine Mount. Please help!
  84. Intermittant AC
  85. No power at ac clutch
  86. 89 Dakota no crank no start please help.
  87. Hotter Than Hell Steering Column Shroud!
  88. Fan
  89. Instrument Cluster Interchange
  90. 1992 Dakota not starting
  91. Will This Part Really Work?
  92. Exhaust manifold is stuck on really good!
  93. 1987 Dodge Dakota Speedometer Gear Question.
  94. Dakota Racing Team
  95. Engine harness connector
  96. 3 Engine codes
  97. Additives, Lubricants, and Fluids
  98. Starter wiring
  99. 96 dakota 318 swap
  100. 1994 dodge dakota transmission search
  101. Alternator not charging
  102. Engine swap on 92 Dakota 3.9 5 speed to v8
  103. 91 Belt Tensioner
  104. Curious Coolant Behavior
  105. Information on the 1991 Dodge Dakota little red express
  106. Need Picture of where air cleaner tube attaches
  107. Fuel tank compatibility
  108. 1988 3.9 running problem
  109. Riddle me this 1995 4wd 5spd 5.2l
  110. NP231D Transfer Case
  111. 93 Dakota won't kick over
  112. I'm done!
  113. Aftermarket muffler
  114. Key ring light stays on and drains battery
  115. What to Do About Seat Belts?
  116. Small amount of oil in coolant
  117. 94 starter bolts
  118. Wiper motor won't work..
  119. 1994 dodge dakota 5.2 v8 No crank no start and no power to dash or any lights
  120. AC Fan/Control on the Blink
  121. 1992 Dakota 5.2 v8 shuts off when driving
  122. Dash light LED conversion
  123. 92 dakota 3.9L v6 magum computer swap
  124. Exhaust leak?
  125. Steel Rims to fit 265/??/R16 tires?
  126. code 62
  127. Glove Compartment Light Bulb
  128. Bulb Socket
  129. '96 3.9L Fuel Injectors?
  130. 1995 3.9L v6 swap with a 1987 w150 318, 727 trans and np208 transfer case.
  131. Heater Blows Cool Air
  132. Center Caps
  133. Door glass installation
  134. Knock knock. Whose there? It's pinging that won't go away
  135. Axle swap compatibility question
  136. A/C troubleshooting R134A converted 93 Dakota V8
  137. Seat Belt and Tire Questions 93 Dakota V8
  138. Out of the Woods after 13 years, the resurrection of a 89 Dodge Dakota V6
  139. 93 dodge dakota computer interchange
  140. 89 HVAC vacuum hose routing?
  141. Dakota Center Link Question
  142. sold the truck
  143. Tachometer on the Blink
  144. I cant figure this out! My 94 dodge Dakota keeps dying.
  145. 1996 dodge dakota 5.2 slt 2 wd
  146. 4WD upper control arm mounts
  147. New memeber and my 94 Convertible project.
  148. Need Help troubleshooting radio & radio wiring
  149. If you have a slipping belt, especially when cold or fan locked read this!
  150. Paint Codes
  151. 92 Dakota
  152. Intake manifold bolts
  153. Iso Sealed beam headlight buckets
  154. Pinstriping
  155. 96 dakota 3.9l to 5.2l swap
  156. 92 5.2L ECM compatibility questions
  157. Just scored a Shelby
  158. Output speed sensor location
  159. I broke a vacuum orifice
  160. 94 Dodge Dakota 5.2 V8 Fuse Box Wiring
  161. 94 dodge dakota automatic transmission id ?????
  162. Trk won't start no spark
  163. 1988 Dodge Dakota problems when warmed up
  164. Still won’t start
  165. alternator/generator
  166. 93 Dakota turns won’t start
  167. Bed tie downs
  168. 95 auto trans
  169. Stubborn Noise
  170. Leaf Springs
  171. 1995 stock 3.9 to a 318 or 360 with carb
  172. Stalls under load
  173. Leaking Power Steering Fluid '93 Dakota V8
  174. Where can I get a fuel pump harness?
  175. weird fuel issue
  176. Rocker arm oil guides
  177. 96 3.9 SLT 2WD Front Brakes ~
  178. Finished the 360 swap, runs great :)
  179. Can I turn my 318 LA into a magnum
  180. Searched everywhere for weather seal
  181. Engine Makeover
  182. Hey can someone help
  183. Replaced Power Steering Pump
  184. 1992
  185. Has anyone here run an AX-15 behind a 5.9/360?
  186. Cup Holder 1st Gen Dakota
  187. 94 Dakota, stalls when put into gear
  188. Brake Question
  189. 1988 TBI Vacuum Manifold - Where to Find Replacement?
  190. Master Cylinder Replace
  191. The 10-year Clunk
  192. 1996 Dakota U-Bolt Plate.Saddle
  193. 5 speed(ax-15) loud gear roll over
  194. 1993 3.9l cranking no spark
  195. CODE 23 IAT Sensor
  196. Wheres the classifieds ( for sale ) items on dodge forum ?
  197. 5.9 Swap Compatibility Questions
  198. 1995 Dodge Dakota
  199. Trying to find transmission plugs
  200. Engine swap 1987 dakota
  201. No power to coil pack on 1993 3.9l Dakota
  202. Need help from anyone who has dealt with the torsion bars on the first gen Dakota 4x4
  203. 1989 Convertible Dakota Starting issue
  204. Valve Cover Gasket
  205. 94 Dakota 42RH Transmission Slow Shift 2-3
  206. What is different about the np231 in the 93 that makes it not interchangeable
  207. Please help strange problem. 94 dakota 5.2L v8
  208. 93 Dodge 2.5 acceleration issue
  209. 93 4x4 with a 5.2l and Auto transmission need New t-case
  210. 94 dodge dakota rim issues.
  211. Dodge Dakota 1996 SLT Electrical problem
  212. 96 Dakota SLT Ext.cab 318 magnum, automatic
  213. 92 dakota rebuild, fuel system?
  214. 89 Dakota crank no start
  215. Found the damn problem!
  216. No power
  217. Fan blower dead
  218. 91 Dodge Dakota 3.9l starts but no accerleration
  219. Crank sensor issue-- I forget
  220. 89 Convertible Transmission Gripe List
  221. I feel and hear a soft clicking sound
  222. 318 V8 Engine Swap - 1995 Dodge Dakota
  223. I give up. 93 dakota=hell on earth
  224. Things to watch for on 95 V6 with 195k in rust belt?
  225. 93 Dakota 4x4 transmission problem
  226. Ignition Switch.
  227. 3.9L performance parts disappearing
  228. How Does ABS Work?
  229. Huh? master cyl question
  230. Headlights
  231. Ever have a day ...
  232. 42RH transmission loses prime/slips on first drive after overnight
  233. 94 Dakota
  234. 1990 Dakota Walker Evans edition
  235. 1993 dakota sway bar
  236. 1993 lift issues
  237. 1990 3.9 liter Dakota
  238. Bent Transmission Kickdown Linkage - Where to Find Replacement?
  239. O2 sensor
  240. Need help identifying electrical connector
  241. 1996 Dakota SLT Extended cab 4wd
  242. ABS warning light
  243. 94 Dakota abs bleed process help, please
  244. New member from Greece
  245. Tachometer issue in 1992 dodge Dakota
  246. Voltage Regulator?
  247. Diagnostic help
  248. Transmission trouble and codes
  249. Winter Gearbox Project?
  250. 87 Dakota 2wd automatic: Help!
