PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59
  1. Intake and engine mounting question
  2. Need help wiring to accessory power switch in 92 dak
  3. Posi rear
  4. 1992 dakota 4X4 ECM ?'s
  5. speed control power relay
  6. Shelby Dakota on Ebay
  7. awd cyclone killer
  8. How to access windshield wiper linkage on 88 Dakota?
  9. Engine Light
  10. 3 questions for 92 dakota
  11. QUESTIONS QUESTIONS QUESTIONS!!!
  12. My 94 LE
  13. vaccum problem 92 dak
  14. Dumb question.
  15. 88 Dakota won't start. Possibly starter?
  16. truck needs a lift
  17. TUNE UP
  18. Whos interested?
  19. Center caps for 89 Dakota wheels needed
  20. newbie needs trasmission help
  21. Truck stalls when it's warmed up.
  22. speaker help
  23. Parts Quest
  24. ReaR Diff
  25. need help wiring an alternator
  26. Shaving The Door Handles
  27. Looking for info for an 87 "Indy 500"edition Dakota
  28. May Ride of the Month Voting!!!!
  29. Reverse problem
  30. o/d and speedometer not working 95 4x4
  31. rear brakes
  32. clear corners found on ebay
  33. Small Block Swap, Intake Question.
  34. v6 5 speed behind a 360
  35. trannys
  36. Rear axle mods
  37. black interior
  38. What do you think?
  39. Car and Truck of the Month, get involved!!
  40. Anti-lock brakes
  41. 92 dak questions
  42. transmission type
  43. 96 4 cylinder conversion question.
  44. v8 conversion
  45. low side retrofit adapter nipple 89 dakota v6 -- no luck!
  46. Parts quest
  47. crate engines
  48. dash lights out
  49. custom console
  50. Vibration on a 93 dakota sport 4x4
  51. Vibration on a 93 dakota sport 4x4
  52. How do I change the time?
  53. tire size
  54. Water in the exhaust!
  55. Problem with a 1993 Dakota
  56. newbie 3.9 mods, pre magnum
  57. Newbie here Q's
  58. 91 Dakota intermitent stalling problem-HELP
  59. Clear corner lights.
  60. Weird
  61. Changing water pump on 94 dakota 318 v8 need help......
  62. a few questions
  63. throttle body help please
  64. 1994 Dodge Dakota wiring question
  65. Electrical Question.
  66. ax 15
  67. 2.5 out of Daytona ???
  68. spindle
  69. ram wheels
  70. lowering
  71. my 93 dakota le runs like crap, advice?
  72. 63 inches seem right for a 96 dak rear,
  73. Dead Part or sabotage by a mechanic?
  74. need quick fix
  75. what size is the head light
  76. exhaust is done and have new intake
  77. Back Brakes
  78. anyone have a Dak up on jacks? rear width
  79. 95 dakota tachometer
  80. carbed 318?
  81. rear axle questions
  82. Stalled, can't figure out why
  83. problems with my dak help please
  84. converting my 91 to power steering?
  85. 1ST GENERATION CUSTOM DAKOTAS
  86. question about my 91
  87. Dakota Roll Bar
  88. 3.9L question
  89. Wiring a 5.9r/t
  90. April Ride of the Month Voting!!!!!!
  91. Should this be an engine concern?
  92. 1993 Dakota Speakers
  93. 3.9 Issue... Strange
  94. vacume and wiring
  95. 93 V6 runs bad on warm days
  96. What is this inlet for?
  97. towing
  98. raise the front end
  99. difficult to engage gears in man. trans...
  100. temperature sender 1990 dakota
  101. seats
  102. 91 ECU interchange
  103. opinions on bodyside trim?
  104. e-fan question
  105. Radio Problem
  106. 92 Dakota clutch adjustment
  107. Pulley/ belt ?
  108. just bought 96 with 3.9 , any KNOWN problems
  109. attn any one who us open ellement filters please help
  110. exhaust tips
  111. truck box for 93
  112. 100,000 mile maintenance
  113. Question abt A-frame on 93 Dakota
  114. $200
  115. 2000 durango rt question
  116. exhaust is quiter
  117. Positrack question
  118. tonneau cover
  119. 89 Convertible Dakota question
  120. just a few pics of my beast ~
  121. Console problem
  122. Dakota Exhaust
  123. another v6 to v8 swap question
  124. dual exhaust
  125. ecm 95 dakota??
  126. 360 question
  127. 360 question
  128. ok once again wheels
  129. amazaing truck ~
  130. air hat fullintake from 97 or newer 5.2
  131. air filter
  132. Some Fun with dak (pics)
  133. Grinding noise before 4wd is engaged.
  134. timing chain
  135. Engine swap
  136. Transmission options on a '90
  137. 2 questions
  138. 360 swap.
  139. 91 Dakota rear axle swap
  140. Heat/Air seems to always run.
  141. thermostat temp?
  142. msd and trottle body
  143. shift light
  144. tires
  145. New Dakota Driver
  146. Vacuum Line Question
  147. Axle fell off...
  148. New Dakota Owner here...
  149. Another question: electric fans
  150. 87 dakota suspension
  151. upgrading airflow / intake..
  152. What is my dak
  153. GEN 1 cold air intake?
  154. Exhaust header question
  155. 94 Dakota Revlimiting at 4K???????
  156. High Idle
  157. 93 v6 isn't fast enough
  158. Horn problems
  159. Dakota air cleaner interchangable?
  160. got my 46re the other day
  161. need info please
  162. Tune Up
  163. 1993 Dakota Tire Size
  164. 1993 Dakota Air Intake Options
  165. 87 to 98 3.9 swap
  166. Hot/cold running problem
  167. body kit
  168. tranny question
  169. Ram 318 to dak?
  170. An Oldie but goodie
  171. oil pressure gauage installation
  172. 1996 dakota sport fog lights/running lights???
  173. Convertible
  174. Chrome Shifter
  175. Paint starting to flake off
  176. intermittent wiper problem
  177. Steering problems
  178. (95 Dakota R/T?????????)
  179. air ride for 95 dakota any ideas?
  180. 1994 Dakota Help
  181. Oil light PLEASE HELP
  182. 96' dodge dakota v6 magnum passenger door stuck wont open, any advice or help please?!
  183. oil pump
  184. 3.9 cam question
  185. FIberglass fender for a 1989 dakota
  186. 92' 3.9 Magnum noise
  187. How much HP can I get from a 3.9 in my 92 Dakota 2wd?
  188. smoke from engine help please
  189. '90 3.9L bogging - HELP!!
  190. 1991 318 intake ????
  191. 3" lift kit installation question???
  192. how to spend $500
  193. 318 standards?
  194. suggestions for increased towing capacity
  195. High performance disc brakes
  196. websites
  197. new motor
  198. Engine randomly stalls NEed Advice!
  199. long starts.
  200. gear ratio?
  201. Help Please
  202. hestitation, bogging HELP!!
  203. HELP breaks sticking
  204. '95 dodge dakota accessories???
  205. ground effects?
  206. [Deleted]
  207. [Deleted]
  208. [Deleted]
  209. [Deleted]
  210. [Deleted]
  211. [Deleted]
  212. [Deleted]
  213. [Deleted]
  214. [Deleted]
  215. [Deleted]
  216. [Deleted]
  217. [Deleted]
  218. [Deleted]
  219. Anti-Freeze Leak
  220. voltage problem in 93 Dak
  221. Brake Lines
  222. engine swap
  223. 1989 Dodge Raider help
  224. 1989 Dodge Raider help
  225. 4x4 question
  226. Newbie to Dakota Simple Question???
  227. engine swap
  228. Limited slip
  229. Wiring Schematics
  230. Radio Issue????
  231. header exhaust leak
  232. My 1987 Dakota, V-6, auto, 4x4
  233. Coolant leak on driver side somewhere
  234. temp gauge
  235. Wheel swap questoin?
  236. 5.2 Throttle Body
  237. Early Dak 4 banger questions
  238. oil pressur e?
  239. Mant Req
  240. New and just got a 94 dakota with miledly worked 318
  241. Noise in Tranny
  242. cat and timing chain
  243. My 1987 Dakota 4x4, 3.9L, auto
  244. ENGINES
  245. help!!
  246. Newbie, cruising for info and ideas
  247. dixie customs
  248. Engine stalls and won't start
  249. 96 gas mileage
  250. exhaust for v6 mag
