PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59
  1. front shocks
  2. 92 Dakota 318 02 sensor
  3. vacuum diagram info
  4. Heater Blower
  5. 360' engine. single cab dakota
  6. 91 dakota wiring prob.
  7. 1995 dodge dakota 3.9
  8. 93 3.9 dakota u joint problem, Need HELP!!
  9. lights in general
  10. 88 dakota bogging and other questions..
  11. 1988 dodge dakota
  12. dodge dakota 1995--3.9
  13. oil for manual transmission
  14. 1989-1990 4WD Transfer case
  15. mirrors
  16. 89 TRAN PROB
  17. swap ~ ? 360 into 92 dakota
  18. 79 LRT CAB
  19. 93 3.9 weird idle
  20. Trans troubles!
  21. O/D Lag (35-50 mph) before shifting
  22. is this possible ?
  23. NO 4X4 !!!!!!!!
  24. throttle body cleaning
  25. need motor
  26. Jet performance module
  27. 93 Dakota Rear Window
  28. 95 Dodge Dakota
  29. Fuel tank strap bolts; which way to go???
  30. KEYS LOCKED IN TRUCK!!!
  31. Fuse box layout for 94 Dakota
  32. Help, leak in cab
  33. 1993 DAKOTA REAR WINDOW
  34. Tachamoter part??
  35. '96 Dakota light bar, grille guard, side steps.
  36. 96 Dakota light bar, grille guard, step bars..
  37. Shocks for 4wd
  38. need more help with my brake system.. PLEASE!!
  39. 1 more question
  40. having problems bleeding the brakes
  41. Overdrive and Stalling issues
  42. 1993 dodge dakota rmps and exhuast question
  43. Heater not blowing hot
  44. Help! I think i put in the wrong tranny fluid!
  45. 90 Tachometer Problem
  46. 92 dakota starting problem
  47. Cold Start OK Warm Start Random
  48. Rearend
  49. anther beginer question
  50. Battery won't hold a charge
  51. feasible to swap v6 for v8?
  52. Gauge lights
  53. Hidden Hitch and Rollpan?
  54. Need help with OD problem, 93 Dakota
  55. Washed the truck
  56. 96 Dakota sport 5speed wont idle at all
  57. headlight probs
  58. begginer question need help!
  59. 96 dakota blower motor circuit inop
  60. spark knock or valve rattle
  61. MOVED: For Sale!
  62. new to the forum
  63. 92 Dakota Starting Problems
  64. Fan only blows on floor
  65. FAQ's Ideas
  66. **FAQ -----General Info, Common problems, Factory Service Manuals**
  67. 95 FUEL GAUGE FLUX
  68. 93 dakota issues
  69. Running boards
  70. My Dakota wont start
  71. 91 Dakota wiper help
  72. new member needin a fix!
  73. MOVED: '01 Durango - AC warm at low rpm, decent at high rpm
  74. OEM keyless entry
  75. 87 dak wont start.
  76. glove box lock
  77. 94 RWAL module location?
  78. sub box
  79. Tranny issue - Please help me out!
  80. nitrous on 5.2
  81. suspension
  82. troubleshoot this crap
  83. code 41
  84. bumper valance
  85. brake calilber bolt thead size
  86. My Little Accident
  87. Need help finding these parts
  88. aftermarket exhaust for 3.9/fuel gauge problem
  89. 96 dakota Sport Questions
  90. 95 w/3.9 computer?
  91. Stuck Hood On A 1987 Dakota L4
  92. fuel tank
  93. Looking at used 93 Dakota with 318 ???
  94. lifter noise on 3.9
  95. idle problem...
  96. 91 Dakota 2wd
  97. Bumper
  98. service manual for the 95 Dak
  99. Transmissions?
  100. tranni fluid
  101. 92 3.9 problems
  102. Stalling Help
  103. choke/ rich
  104. buying a 1992 dakota
  105. keyless entry
  106. headlight and brake lights
  107. 1990 dakota popping and choking down
  108. wipers
  109. Solid motor mounts?
  110. 1990 V6 automatic transmission starting problem
  111. 91 5.2L trans prob. and no gauges
  112. quickly dropping MPG
  113. Throttle body spacer
  114. 88 dakota will not idle
  115. Brake Help
  116. 93 3.9 to 360
  117. 93 dakota brake light problems
  118. 1988 Tranny Issue
  119. 95 SLT Club cab 5.2 auto 4x2 value
  120. Gas tank filler gasket
  121. 342 MPG with a 5.2 V8
  122. intake air temp sensor
  123. removing the ac clutch
  124. Check engine light
  125. 93 Dakota 3.9 fuel pump issues
  126. 93 dakota rmp/idel problem
  127. performance tune up
  128. 2 simple Q's
  129. Air Bag light on
  130. 1989 paint peel
  131. Evaporator core
  132. bed removal
  133. Anyone looking to sell a 91-96 clubcab?
  134. New Section Moderators!!!!!!!!
  135. 95 318 not running
  136. has any built or change out the consol
  137. 92 318 PCM dead??
  138. MOVED: co2 emission
  139. How do I disable Daytime Running Lights on 94 dakota
  140. 93 Dakota shifting/idle issues
  141. 94 Dash Problem
  142. Headers for a 3.9
  143. Need new Rotors and pads
  144. New be on rearends. 93 3.9 4x4
  145. August Car & Truck of the Month!!!!!
  146. 93 Dakota Issues
  147. Testing a fuel pump.
  148. rear end question 93 3.9 4wd
  149. Bumper step pads
  150. 91 dakota
  151. Tranny leak on a 93 3.9 4x4
  152. Woes of my 3.9L 94 Dakota
  153. I am new
  154. My A/C 96 w/ 3.9L
  155. 92 dak 34 fault code
  156. 98 dakota ac problem
  157. 93 Dakota problems.
  158. Perfromance enhancements
  159. Changed Computer, now backfires
  160. No power
  161. burning smell under hood - like rubber
  162. motor advice please!
  163. seats
  164. Shelby Dakota Light Bar...
  165. 96 Dakota Air Conditioner
  166. 90 dakota plezzzz help
  167. Stalling Issue 92 Dakota Sport V6 3.9
  168. 1992 5.2 shuts off
  169. Fix or Junk '91 Dakota 4x4 in Accident
  170. Won't start when hot, '92 V8 Dakota
  171. Heater will not turn all the way off
  172. '96 V6 3.9 nearly stalls on first takeoff
  173. 125mph Speedo/Cluster Questions.
  174. 1993 won't start
  175. 3.9 to 5.2 swap. Will it work?
  176. lift kit for 88 4x4
  177. Help truck died...
  178. 92 dak with 94 engine
  179. Wiring diagram
  180. 89 Dakota Wiper Switch
  181. 89 Dakota Wiper Switch
  182. $wd wont engage.
  183. front brakes/ ABS
  184. Power Steering seal
  185. 360 dakota
  186. molded dash covers...any experiences?
  187. Any aftermarket center consoles?
  188. carpet
  189. Painting interior & new headliner questions...
  190. speaker question
  191. Driving long distance with oil leak
  192. PARTS FOR MY 93 DAK
  193. 94 Air Conditioning Question
  194. Oil cooler needed
  195. OD not working ... HELP!
  196. 94 dodge dakota help!!!!!!!!
  197. New Member w/ "new" 96 Dakota problem
  198. 1990 Dodge Dakota
  199. stalling issue
  200. July Ride of the Month Voting!!!
  201. ere else any ideas what to check thanksno power to ecu unit on 95 dakota 318 magnum
  202. Rear End Replacement
  203. Roll Pan
  204. How to remove the bed..is it difficult? 93 dakota V6
  205. Body Mount Torque Specs
  206. Bag it baby \m/
  207. few questions- tow rating and seats
  208. oil pump advice
  209. 93 v6 wont start...HELP!
  210. 1990 3.9L won't start
  211. positrac
  212. How do they do it??
  213. seat covers
  214. 95 dakota 4x4 318 oil preassure
  215. Supercharger on a 94 dakota?
  216. 93 Dakota Bumper Covers
  217. Fuse box layout
  218. '95 V6 complete nightmare
  219. 1991 Dodge Dakota /v6/3.9 eng
  220. 1990 truck
  221. Manual to auto swap how to wire overdrive
  222. door
  223. 2.5 4 banger
  224. Caliper Stuck???
  225. suspension?
  226. ABS. Rear-Only, or All Wheel?
  227. 1989 Dakota Sport Convertible 4x4
  228. MOVED: Fun in the MUd pics ~
  229. June Ride of the Month Voting!!!!!!!!!
  230. Cowl Hood
  231. Gear indicator
  232. Voltage
  233. No torque converter lock up!
  234. 92 stalling and rough idle
  235. Green triangle in tach & maintenance req'd
  236. tire fit
  237. rear end help needed
  238. overheating
  239. What is this?
  240. Fuel and ignition
  241. tire fitment
  242. Tranny problem, slips when going into gear.
  243. pickup to suv conversion ?
  244. HELP ME!!! 87 dakota
  245. transmission whirling noise?
  246. Trans slip?????
  247. where is oil pressure gauge
  248. 93 electrical problem
  249. windshield wiper arm
  250. Engine cut out at high rpm
