PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. Where is the the fuse for the overdrive switch in a 91 Dakota?
  2. 95 Dak LED headlight kits?
  3. Starts, runs for about 3 seconds, and dies
  4. Note to Self
  5. 90 amp vs 120 amp alternator
  6. Dual exhaust kit
  7. CV Joint or axle bearings or both?!?!
  8. Replace headlight switch?
  9. Fuel problem
  10. Pcmdifferwnce between 92 and 93
  11. Anyone selling a m1 or a Hughes intake ?
  12. 1990 Dodge Dakota Trans Fluid type and Loud trans noise
  13. Dakota tailgate hinge repair
  14. Airgap plenum
  15. Its alive!!!!!
  16. Wires going to trans and transfer case
  17. Another No Start Thread
  18. Hood latch
  19. 1994 Drivers Door Latch
  20. 5.2 magnum exhaust
  21. No taillights
  22. Wipers wiped out!!
  23. 87 Dakota 2.2l fuel pump
  24. Tribute build.
  25. Time delay relay
  26. Fuel Pump assembly to tank gasket.
  27. Sealed beams conundrum
  28. Dakota Tribute build
  29. Door Locks and Accuator
  30. 01 Dodge Dakota not shifting correctly no bus on odometer
  31. No key for parts truck
  32. ‘92 Dakota 5.2 Oil light/pressure
  33. will 3.9 and auto tow a race car and traailer
  34. 98 Dakota gas gage
  35. OBD schematic
  36. Difference in radiators
  37. 94 Dash & Interior Electrical Gremlins?
  38. '91 5.2 power loss and tuneup question
  39. Towing Question
  40. Hood Latch Stuck
  41. Transmission issue and valve body
  42. Convertible question
  43. 1993 Dakota 5.2L AC Clutch
  44. 93 Extended Cab A Question on Disassembly
  45. 1993 Dakota A/Cquestion
  46. whining while accelerating
  47. Need Some Advice
  48. AC/Heater not working
  49. Stereo Part II -- Front Speakers
  50. Surging at 60 mph
  51. No oil to valve train
  52. 94 4x4 camber adjustment and control arm issues
  53. Temperature gauge
  54. Heavy Duty Shocks??
  55. Going from 2.5 AMC to 5.9 Magnum (Engine mount confusion)
  56. 95 Dakota no start
  57. Rust removal
  58. Fuel Pump Issue - Ghost in the Machine?
  59. Transfer case question
  60. 95 Dakota 3.9 mag Sputters, or bogs down intermittently during accel
  61. NOS parts websites
  62. Idle issues
  63. Factory hangars?
  64. Will a 318 from a 99 fit my 95
  65. Proper Piston/Valves timing after timing chain slippage
  66. 1987 Dakota Maintenance
  67. 1991 dakota 5.9
  68. Mopar crate motor
  69. 1992 Dodge Dakota 2WD v6 wiring issue
  70. 92 dodge dakota back glass
  71. Harlland sharp roller rock choice?
  72. Factory still fender weight?
  73. Injector harness
  74. Wiper blade problem
  75. 1st and 2nd gen rear frame
  76. 4 barrel mpi intake
  77. Good set of replacement headlight housings
  78. 92 dak body part swap
  79. Swapping 5spd to an auto. 1996 V8 Dakota
  80. Stereo
  81. Battery gauge is maxed out almost
  82. no power to fuel pump
  83. fuel gas gauge don't work
  84. tranny issue?
  85. First time dodge dakota owner
  86. Help: Truck will not run, starter just click
  87. What manual transmissions fit with a 95?
  88. 93 Dodge Dakota, no fuel, no spark
  89. Turn signals
  90. Leak on front axle...
  91. looking for bellhousing
  92. Changing my automatic to a 5-speed how the wiring can be changed
  93. A998 to A500 transmsission swap
  94. EGR Valve code 32
  95. Front fender replacment
  96. What do these electrical connectors under the steering wheel go to?
  97. advice on buying this truck
  98. Changed Spark Plugs--Ran Into A Major Problem
  99. HELP!!! chnged a parking brake cable now abs light is on
  100. code 15 for my dodge dakota 1992
  101. One wiper blade working...88 Dakota 3.9 V6
  102. Fuel problem
  103. Need to Replace a Bad Engine
  104. Need some help from the professionals.
  105. Front axle making noise I think it's due to this
  106. RWD 98 Dakota Sport v6 ATF stalls in reverse and while stopping...
  107. Need help with frame and body project
  108. Bogging down and back fire
  109. Starts & Runs Than Starts & dies 10 min later.
  110. 1987 3.9 62,000 miles.4x4
  111. Alternator problems?
  112. Suspension parts questions.
  113. Sub box???
  114. Wiring harness issues
  115. Help with torque
  116. High pitched whine coming from front driver side wheel well area.
  117. 1995 dodge dakota runs then dies
  118. Swap from V6 to LA V8 pics
  119. From Under The Under The Hood or Take Part of The Front End Off?
  120. 1992 Dakota v6 2wd ext cab body lift
  121. Harland Sharp 1.7 roller rockers WORTH IT
  122. 93 Dakota 3.9 died on me while driving
  123. Excessive Cooling
  124. Good set of shocks for 93 4wheel?
  125. No start, no spark, no fuel, heeeeeeeeelp!!
  126. 1992 dodge dakota
  127. Code 32...EGR?
  128. 440 first gen dakota
  129. 93 o2 sensor
  130. Wiper blades keep coming loose from wiper arm
  131. Help Decipher New No Start Symptom Please
  132. 1996 Dakota swap from V6 to LA-V8 what will work?
  133. 94 Dakota chugging at the lumber yard...
  134. bad day for my '92
  135. What is this called? Some rodent or pest ate these wires
  136. 93 Dakota radio doesn’t work
  137. 1992 dodge Dakota 4x4
  138. 92 5.2 Dakota questions.
  139. Low oil pressure...88 Dakota 3.9 V6
  140. 94 Dakota 4x4 ...best site to buy suspension parts
  141. 92 LE V8 No Automatic Shift Advice
  142. vacuum lines
  143. "Y" pipe
  144. :D
  145. 46RH with a 5.9
  146. shifting linkage adjustment
  147. New to the Page - burning oil
  148. 1998 rear axle tags from pumpkin
  149. EGR tubes??
  150. This should sound good
  151. Alert Buzzer
  152. '92 Dakota 4x4 - Rear brake valve assembly
  153. Temp gauge acting weird...88 Dakota 3.9 V6
  154. 1996 Dakota hates me
  155. Misfire, bad coil? Plug?
  156. motor swap
  157. Comparable tranny
  158. Front end vibration
  159. Intake manifold help
  160. Rusted Out Shock Tower/Upper Control Arm Mount
  161. 1987 Dakota with nv2500
  162. Mechanic picked the truck up today
  163. I made the front page!!
  164. Change In MPG
  165. Anybody looking for a chrome grille??
  166. fuse box layout
  167. won't fire when cold
  168. what type of tranny fluid does a 1996 3/4 ton 5 speed manual use
  169. Won't fire when cold
  170. Having stressful problems with my 94 Dodge Dakota
  171. Random knock
  172. brake light stuck on?
  173. Did a REALLY dumb thing and broke my truck. Laugh at me.
  174. Plastic Dash piece will not stay put
  175. Another 3.9 to 5.2 swap. Keeping Ax-15 Manual
  176. Engine knocking(?) before starting
  177. 1991 5.2L losing power when deep in throttle
  178. Outside Door Handle Issues (Both Sides)
  179. New roller rockers
  180. New tv cable bracket
  181. random shut off
  182. Performance upgrade time
  183. Could this be an issue with the blend door?
  184. 1987 Dakota crank no start
  185. 94 Dakota Heater and Radio stopped working.
  186. 95 Dakota slight miss and strong exaust
  187. Stalling Issue Stopping
  188. type of oil to use
  189. Backup Light Switch Not Engaging Lights
  190. 1987 Dakota
  191. Removal of vapor canister...88 Dakota 3.9 V6
  192. Timing issues 95 3.9L V6 Magnum
  193. 95 Dodge Dakota lift kit.
  194. Can We Talk About Caps?
  195. 89 Dodge Dakota engine swap
  196. Stalling problem driving me batty
  197. Transmission swap
  198. 93 3.9 Wont Start (not ASD/Splice problem)
  199. Loud ticking and low oil pressure
  200. 1996 dakota will not start when warm
  201. Trans shifting weirdly
  202. Vibrations...88 Dakota 2WD V6
  203. '94 with 3.9 Magnum v6
  204. Fuel lines
  205. What does this button do? 88 Dakota 3.9 V6
  206. 95 dodge dakota won't start
  207. Installed a 8.8 rear and more!!
  208. Possible intake swap on the cheap. Brand new
  209. 92 2wd Dakota Sport overdrive not working
  210. She's alive!! Make mine a 5.9 please!
  211. 95 Dakota 5.2 oil pan removal
  212. brakes apply by there self
  213. List of maintenance
  214. Tying to find a abs hyd unit part # 12-2012
  215. Outside door handle.
  216. 94 Dakota
  217. Another set of rt wheels on a 1st gen 4x4.
  218. Anyone know if 94 5.2 pcm will work on 93 5.2
  219. 93 5.2 cranks but wont start at operating temp
  220. Fuse diagram for 2000 Dodge Dakota?
  221. Which year 5.9 computer for 96 swap?
  222. Oxygen Sensor
  223. 96 2wd Auto 3.9l oil pan
  224. Fuel Gauge Aint Worth Fixin'
  225. Lower control arm pivot bolt wont come out; differential in the way??
  226. Squeaking nose when turning steering wheel
  227. Rewiring headlights
  228. Merry christmas everyone
  229. Original speakers
  230. Idler Air Control Valve Issue
  231. Where is the time set?
  232. Air Filter Housing Gasket
  233. Throttle Body Cleaning
  234. Limited Slip Differential
  235. Upper Control Arms
  236. Gauges don’t work in my 1988 Dakota HELP
  237. Black substance in anti freeze overflow
  238. check engine light 88 3.9
  239. What Is It Called & Where Can I Buy One
  240. Holy forum update. Or chrome mobile update
  241. 93 dakota transfer case
  242. What should a head gasket job cost?
  243. Are all the nice ones gone?
  244. Driver side window
  245. MAP Sensor Location
  246. Heater Doesn't Blow Hot Air
  247. could someone take a driveshaft measurement for me?
  248. Random message, anyone?
  249. Misfire/Jerking when driving?
  250. 5-spd whine
