PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59
  1. dakota R/T wheels for sale metro detroit
  2. Smog/air pump
  3. What is it?
  4. Cigarette Lighter problems
  5. Handling
  6. Fastest in your dakota
  7. grill guards
  8. stalling on a low tank
  9. Rough idel and Tick when first starts
  10. 1992 dodge dakota
  11. 88 backfires/sputters/stalls
  12. Tach. off
  13. rpm's at 50mph
  14. Solid front axle
  15. Body Moldings For 1st Gen Dakota?
  16. Poor Gas Mileage!
  17. 96 V6 Starter HELP!
  18. Gas Milage on my '95
  19. Reworking a 1989 Dakota Sport
  20. 92 dakota won't even crank
  21. 93 A/C trouble
  22. dakota stalls on brake and clutch
  23. exhust system
  24. back seat compartments.
  25. Wipers on a '90 just died.
  26. tranny bands?
  27. New truck..what would you buy?
  28. Dont let the CTDs win this month! Vote DAKs!!!!
  29. what transmission?
  30. Turn signal problem
  31. delayed shift 92 dak
  32. 2001 durango DTC code
  33. Sporadic starts.. turns over fine, runs sometimes.
  34. 1991 5.2L and E85
  35. looking for drop springs for 87-96 dakota
  36. Axle swap
  37. 92 Dakota misfire code 27
  38. oil presure
  39. Low beams not working.
  40. 1991 Dakota 5.2L Question
  41. 96 Dakota Keeps overheating help!
  42. '96 SLT 3.9L V6...only stalls when idle (mostly red lights and stop signs)
  43. Engine swap. 90 Dakota.
  44. Dodge wheels ???????
  45. 93 dakota fuse diagram needed
  46. Fuel gauge problems...
  47. Tranny/Clutch problems need help ASAP
  48. can i resurface this??
  49. 92 Dakota using oil and pressure gauge problems
  50. 92 Dakota starting problems when warm
  51. Head Gasket
  52. 2wd V8 front coil springs
  53. wheel backspacing
  54. Do they
  55. Carb. motor swap
  56. Rear Limited Slip DIff?
  57. engine swap?
  58. Anyone pulled a Timing Chain?
  59. RWAL computer won't give codes
  60. LED Scanner Help
  61. paint
  62. Ignition illumination and interior dome light stuck on?
  63. '93 Dakota 3.9 sounds like a diesel...
  64. Parking Brake
  65. I need a Transfer Case
  66. U Joint
  67. 89 Dak runs rough, stumbles
  68. Towing weight questions...
  69. sea foam first timer
  70. exhaust
  71. oil pressure
  72. replacing stereo any suggestions?
  73. new to first gen.. some ?'s
  74. She said it looks like an old mans truck!
  75. 93 with 318 won't start NEED pointers, please.
  76. a/c question for a 1995
  77. 95 Dakota wants to stall on takeoff
  78. stupid ac question
  79. dakota over revving
  80. Toolbox for a 1995
  81. intermittant stalling
  82. Where is the RWAL computer?
  83. Just bought 94 dakota!!!!
  84. no 12v at a/c compressor
  85. problem could be. brake and turn light problem on 95 dak
  86. 91 Dakota 318 Starting Problems????????
  87. Wipers Not Working
  88. 1992 dakota 318 magnium part out
  89. help 1990
  90. Funny Smell by Passenger Door
  91. unfortunate occurance
  92. transmission
  93. question regarding the infamous splice. Pic included
  94. questions on my 88 3.9
  95. 87 dakota
  96. Aftermarket Part Out
  97. "wanted" '95 dakota lowering springs
  98. Random Codes
  99. 93 3.9L oil pump Question
  100. Chewed Vac lines
  101. Dead Drums and Shoes
  102. AntiLock and Parking Brake lights
  103. NO Spark and Power to the FUEL pump 96 Dakota V6
  104. 94 dakota v6 5spd pilot bearing issues
  105. 89' V6 Noise follows RPM - harsh rattle
  106. Trans lines on a 96
  107. New '87 Dakota Owner - Swappable Parts Range?
  108. 93 dakota, just won't start
  109. 95 Catalytic Converter
  110. dakota question
  111. Arizona Residents Unofficial Meeting 5/26/07
  112. 91 3.9L needs new life
  113. Loose Timing Chain?
  114. 92 3.9 noise after shut off
  115. does any 1 have experiance with dodges auto shut down relay
  116. 92 steering play
  117. Quick transmission question
  118. muffler ?
  119. My engine won't idle
  120. Exhaust
  121. Exhaust
  122. blasted transfer case
  123. '89 Dakota Rust Repair
  124. Flexplates keep breaking
  125. No crank
  126. 93 dakota 318 hestation
  127. '88 Dakota with a code 26
  128. I Think It's Time To Say Good BYE!!
  129. exhaust
  130. 1996 Dodge Dak 3.9 problems
  131. 2WD Front Rotor/Hub replacement
  132. couple questions on '92 dakota
  133. Ticking
  134. V6 bogs down & does not want to shift
  135. Rear Differential
  136. Problems with 87 Dakota
  137. i have an odd headlight issue
  138. bye bye dakota
  139. need tires, rims, and lift suggestions
  140. valve cover gasket torque specifications
  141. how to get a new steering shaft?
  142. auto shut down relay
  143. Starting issue
  144. life of your battery
  145. 1989 DAKOTA WILL NOT TURN OVER ?
  146. 93 dak 3.9 problems
  147. no tail lights or left signal light
  148. Possibly buying an 89
  149. Gas Gauge and Blower not working...
  150. Wanted: steering column
  151. AC low-high problems
  152. New Rims...
  153. May want to sell my dakota
  154. Will my 1991 w150 with an A500 auto shift
  155. Anybody know if
  156. New owner 96 Dakota SLT. Brake/Gas Line
  157. 1992 dakota spark issue PLEASE HELP!!
  158. 89 3.9 v6 dakota dies when temp reaches normal
  159. body swap
  160. starting problem
  161. Turbo 2.5L
  162. TRANY IS GONE I NEED HELP!! ***UPDATE***
  163. Pin Stripe...
  164. '93 Blowing Auto Shut Down Fuse
  165. 94-95 2WD DAKOTA 3.9
  166. Body lift install
  167. disc brake upgrade kit
  168. Cheap mods
  169. Body Lift Help...
  170. muffler choice/ tailpipe diameter
  171. water pump?
  172. What tranny do I have
  173. Tongue weight
  174. Rims, Rims, Rims....
  175. Power mirror and cruise control don't work
  176. New to the 4x4 World.....
  177. 3.9L problems
  178. Fuel Problems
  179. Year One Dakota I think
  180. Tachometer
  181. 95' Dakota Questions
  182. 93 Dakota transfer case
  183. gas mileage?
  184. 96 dodge dakota rough idle
  185. mufflers
  186. How do you make the tape deck play the other side of the tape?
  187. Ok does anybody know (concerning 3.9 Liter performance parts)
  188. transmission bracket
  189. O2 sensor
  190. new to forums w/ some Qs
  191. Engine loading up
  192. Q3 mufflers
  193. engine break-in
  194. Tire Help
  195. Who's got
  196. 96 Dakota Parts
  197. 1995 Dakota A/C
  198. 1994 Dakota Gas problems....
  199. Got a question for ya'll
  200. A/C on 1990
  201. 1995 Dakota A/C
  202. Hows This look?
  203. What Could Go Wrong?
  204. What's the difference between
  205. Pistol Grip
  206. need some help
  207. Cold Air
  208. 96 dakota fuse box diagram
  209. Side exit exhaust
  210. The widest wheels possible
  211. pcm location/ignition module test
  212. 92 Dakota New Water Pump Leaking at bolt
  213. Lift Kit Questions
  214. 94 dakota to ramcharcher swap
  215. HELP!! Dakota possessed and stalling
  216. Mirrors
  217. Exhaust Questions
  218. electrical
  219. should I oil guard?
  220. Price of a 95
  221. what are a few ways to...
  222. should i/ is it possible....
  223. Hello
  224. Philidelphia area dodge owners
  225. 1993 Dodge Dakota Backfires and lacks power
  226. Steering Sindle nut
  227. TRACTION
  228. damn O2 sensor
  229. Help! 1990 Tachometer bouncing around?
  230. 90 Dodge Dakota
  231. low idle speed at operating temp
  232. time to buy another dak
  233. Need 1994 fuse diagram, no owners manual
  234. 92 Dakota exhaust manifolds
  235. subwoofer box
  236. poor gas milage
  237. 96 No Spark 3.9L
  238. parting dakota
  239. Strange problem witht he truck
  240. 1987 engine swap questions....
  241. axle code
  242. Front Coil Springs for 91 Ext Cab
  243. Rear brakes lock up
  244. Ball Joints?
  245. Lower Springs?
  246. Help offered...
  247. radiator
  248. maintenance required
  249. Dakota 4x4 Oil Pump Replacement
  250. Inhereted a 92 Dakota 4x4; Worth Fixing?
