- 1996 dodge dakota 5.2
- Sway bar mounting plates.
- Mini-Camper conversion
- 94 4x4 conversion
- 94 Dakota Tensioner Pulley Issue
- WANTED DEAD OR ALIVE, your parts!
- problem and need some thoughts
- 94 dakota 5.2 problem after warmup
- Fuel gauge
- Driver side taillight issues
- oil in the air filter...
- Filters
- 92 Dakota V8 alternator
- 1994 dakota no spark
- adding a smog pump to a non cali 95 dak?
- wheel tire size question
- Oil Filter Bone Dry 1993 Dakota 5.2
- looking for new headers
- Water in floor Boards
- removable door ideas?
- 1991 crank shaft sensor
- LED Tail,Turn Lights
- Electrical issue...
- 1996 Dakota parts
- Club cab owners Click here!
- Lost key to a 1996 Dakota
- A500 42RE 42RH Shift Kit and Overhaul Q's
- where is the low pressure service port located on the 1995 dodge dakota 5.2 V8?
- 302 v8 swap
- '91 dakota upgrades
- 1995 Dodge Dakota - GD Upper Ball Joint Won't Budge
- tires for 1993 dakota LE 4x4
- Some trouble with my trucks
- recently added another dodge to my history of trucks
- Mad smoke
- 95 Dakota will not start
- 2nd Gen Headers
- Headliner Board
- 3.9l ram pcm on 3.9l dakota
- dakota no spark/start
- v6 Magnum trans on a Non-Magnum Engine?
- what other engines will fit my truck and what parts can i re use?
- HHR Fan Conversion
- We need a ROTM entrant!
- 5.2 timing cover replacement
- 1st gen parts
- 1989 3.9 v6 TBI to Carb swap?
- trailing wiring question
- Pics from my first Off-road park trip
- Once in a while it won't start!
- How to find what tranny I have
- Bed light bar aka roll bar pics.
- Good idle but stumbling above 2K rpm
- My 87 truck build up
- Locker help
- HHR Fan Wiring
- bad IAC driver circuit in PCM?
- vent lever
- exhaust improvements
- Timing issue again
- Jeep style door removal
- How do I use Lucas Oil Stabilizer?
- Why did you buy a Dakota, and
- Trying to find a lower bump stop
- Tail light guards.
- Fuel pump died
- Newbie needs some ideas!
- still fighting injector issues
- Finally got a Dakota 4x4!!
- Mirror Question
- parts from other models that fit
- 318 block questions
- 95 Dakota Instrument Panel Light
- Wanted
- Cranking my torsion bars
- 1990 Dodge Dakota 3.9l V6 4x4 Budget Overhaul
- 5.9 Motor
- Electric Fan Help Quick
- A little advice on a 2wd lift
- Another problem with my Dakota
- Need photo of ABS Press Mod Valve 92 Dak 2wd v6
- Firewall Pics Please
- Location of voltage regulator on the ECM Board? Looking for a 91ish Dakota ECM Map?
- 96 2.5 throttle body upgrade
- 91 Dodge Dakota 4 cylinder 5 speed - Timing issue
- I need help with voltage regulator issues. 1991 Dakota 5.2L
- What transmission do I have?
- torque converter clutch solenoid
- PowerTrax LSD
- hitch installation
- Straight Pipe
- 1992 V8 Dakota Auto Tranny Problems
- engine cuts out while coasting
- front axle center pin.cross pin????
- 87 Dakota
- new distributor but truck still wont fire
- transmisson swap
- Losing tranny fluid somewhere...
- Lift question
- Magnum Motors
- need help with performance!
- HELP! PLEASE! components inside distributor are all mangled
- 1996 dodge Dakota 2.5 motor
- 46re trans issue shifting 2nd to 3rd
- Gonna do a v6 to v8 swap
- Cylinder misfires
- My kegger mod
- Oil Pressure issue
- 5.2l Engine on CL, what do you think?
- Help!!! Please
- 3.9 V6 throttle body to carb
- 2.5 to a 3.9 swap
- 91 dakota compatiblity swap
- Roll pan...are you a fan
- fender clips
- headers/ y pipe
- 91 dodge dakota new pump runs like crap
- 95 318 Dakota
- Auxiliary/transfer fuel tank install
- Cold Start Problem
- Spark at dist, no spark at plugs
- Failed emissions
- ECM change
- rebuilt trans or junkyard trans and engine
- transfer case/ gearbox oil change
- No Lights
- 93 stereo color code?
- 94 Dakota V8 Magnum - Out of time/missing problem!
- Needed 1995 Dodge Dakota Rear End - 8.25"
- 1995 Dodge Dakota - Coil Spring Removal
- Tranny fluid change, wondering for part number/price??
- 93 dakota engine tranny swap
- Still can't get transfer case removed
- Replacing inner tie rod ends - 1995 Dodge Dakota
- My new 52mm throttle body
- over heated on the beach
- Tire sizes. 30s or 31s
- How much should I sell it for?
- Hoping for a quick answer.
- Substitute for C-3561 Upper Ball Joint Removal Tool
- Ball Joint Removal Question - Lower and Upper
- cv halfshaft boot questions
- Advice for my 93 dakota
- 94 dodge dakota fuel pump cap, need help
- Fusible link issue - could really use some advice
- Oil Pressure
- Torque converter question
- Cam broke?
- Need some advice! 96 Dakota
- New tires
- Has anyone seen this set up before?
- 1995 dodge dakota stalling when warm
- Clutch problem Please help
- Shuts off all the time
- Frame Repair
- Squeeking noises.
- Swap questions - 5.2 or 5.9?
- O2 Sensor questions
- club cab rear seat removal?
- 96 dak
- Trans temp gauge using factory gauge
- 1995 Dodge Dakota - Lower Ball Joint Removal Question
- 93 dakota trasmission rebuild
- key cylinder removal?
- My Dakota. What Ya Think
- 1994 dakota engine timing issue
- Clutch petal link
- Water pump & timing chain
- No start?
- Rear end rebuild prep
- 318 swap help....
- 1995 Dodge Dakota - Creaking and Banging After Sway Bar Link Change
- Torsion bar key removal
- how much is my truck worth?!
- 1996 Dakota wiring diagram needed
- 1992 Dakota, startup issues after refueling.
- Code 32
- A500 hydraulic lockup vs a500 electronic lockup
- flush mount bed box?
- random cut wires.
- 1995 Dodge Dakota - Did I Install my Sway Bar Upside Down?
- 96 trouble cold starting and stumbling
- water pump failure/replacement
- radiator question
- 1st gen full length headers
- Prothane complete bushing kit
- Bucket seat w/center console swap with pics
- Broken throttle body part
- longbed/single cab with camper shell - need pics
- '94 Dakota won't fire
- What is that thing? in the engine compartment.
- Tranny Swap
- Transmission swap?
- Strange fuel pump issue.
- Engine temp dial on dash not working
- manual locks to power?
- Removing Door Windows!?
- New to me 96 Dakota
- Vehicle Speed Sensor wiring
- need new tranny
- Indy Pace Truck Dakotas
- transmission
- Gas tank won't fill up completely
- 1995 Dodge Dakota Sport license plate bulb cover (clear) needed
- Ticking and overheat issue
- another Dak won't start
- Odd code reported by PCM
- A/C blows when rpms are lower
- Timing chain time
- 1990 dodge dakota sport questions
- 95 Dakota won't start....
- very annoying squeak!
- Dual battery setup with pics!
- 88 Dakota Steering problem
- 2wd to 4wd
- 4x4 probs
- v6 nitrous
- 96 Dakota 3.9/auto trans won't start
- speedometer chirping
- Does my Dakota hate me? I can't get to that 3rd bolt.
- driveshaft noise
- Lifting Questions?????? Under 500$???
- Seat Belt Questions
- Need a fender (Central NJ area)
- Aluminum wheel fitment problem
- vibration? help
- No spark on 93 318
- Need Gap Setting for Autolite 3923 Spark Plugs
- engine timing sensor
- 95 Dakota 2wd/318 Running Rough
- 4x4 coil overs instead of torsion bars?
- dixie horn in my truck
- A500 Transmission
- Junkyard Alternator Swap?
- Help Me Find Door Seals Online
- Does anyone know how to get PCM module number
- 91 3.9l is chugging
- will this fit?
- 1995 dakota abs reset
- transmission doesnt want to shift into 4th...
- Idle @ 400
- 1992/94 Dakota wiring problems
- 2nd gen fuel tank
- TC Weight
- OK, am i doin somthing wrong
- kegger mod question.
- Side window visors
- Truck Tent
- Shaky/ sluggish start
