PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. 96' belt issues
  2. Parts shopping and need an opinion...
  3. Jan. DOTM Nominations
  4. 93 Transmission Shifting Problem
  5. Removing my swaybar
  6. dodge is sick...need help ASAP
  7. Real quick question
  8. Work out for the dakota!
  9. Get it runing??????
  10. 87 dakota light clunk in front mystery
  11. Brakes 95 Dodge Dakota 5.2L V8
  12. sas breaks
  13. 2WD vs 4WD
  14. WTF...no spark again...91 Dakota, 318
  15. My truck junk!!
  16. idler and pitman arm
  17. 42RE park/neutral switch, 3 wire vs. 5 wire
  18. Mulitple issues, looking for diagnostic direction
  19. Transmission Cooler?
  20. I have a of Q. to ask a 1990 dakota
  21. 95 Dakota Headlights Blinking...
  22. nothin but click, click, click, click.
  23. weird issuse
  24. wobbling issues, please help
  25. Rear suspension questions..
  26. 93 Dakota automatic transmission question
  27. 93 (84k miles) Needs rear bumper
  28. tranny fill
  29. 91 no spark
  30. 90 Dakota speed sensor
  31. please help
  32. lift info
  33. Fuel issues, need some help PLEASE!!
  34. couple problems (might need some parts all you part out guys)
  35. Gear display not aligned
  36. 93 dakota Transmission problem every Winter?
  37. anyone running headers
  38. sprayed my spare black, what do ya think
  39. Rear axle....
  40. i want a locker rear end
  41. clunk
  42. where should i put the add-a-leaf ??
  43. turn signals....
  44. Manual switch....please help
  45. heat would be nice
  46. Where to put my 6X9s?
  47. gas gauge
  48. Stalling
  49. Wheel/Rim combo info requested
  50. ...
  51. 93 5.2 runs rough when warm
  52. 95 Dakota 5.2L V8 Coolant Problem
  53. its coooooooooooooold
  54. 8 1/4
  55. t case swap?
  56. Couple winter pics
  57. Determining gear ratio
  58. thinking of painting my wheels
  59. Fuel pump access
  60. Dakota bearings?
  61. tired of stock computer
  62. widest tires that will fit
  63. 4WD tips/recommendations
  64. Problem with My 1992 Dakota
  65. 1994 Dakota Heater Problem
  66. Victory for the dakota!
  67. Aluminum Radiator
  68. 1994 Dakota Cig Lighter Replace
  69. pic of lift 2
  70. pics of the lift
  71. Voltage Surges
  72. What muffler should I get for my 3.9 v6?
  73. Wiring Problems??? Wire short?
  74. Skid Plate Modification Pics!
  75. Please help! Nothing happens when I turn the key
  76. running issue
  77. 1994 Dakota Fan Clutch Removal 5.2
  78. 93 Dakota Eletrical problems?
  79. Help!
  80. FS: Brand new OEM Fuel sending unit
  81. Random problem, All gauges go max and hazard indicator comes on??
  82. Dodge Dakota issues..
  83. Rear end
  84. seat belts not retracting
  85. What did you get for Christmas?
  86. Door Handle Trim Rings
  87. what you listening to?
  88. 90 dakota hit and miss power at coil
  89. Stereo question?? suggestions??
  90. What time zone?
  91. New here!!
  92. windsheild wiper bushings
  93. bad scratches
  94. ok tranny pan replacement
  95. 94 dakota 4x4 lift
  96. add it to my list of woes...
  97. Intake valley plate
  98. fuse problem
  99. 92 dakota, new to this place, help please.
  100. Heating Issue
  101. 1991 dodge dakota
  102. east coast snowstorm and post up pics
  103. Headlight switch
  104. dash covers
  105. 1995 dodge dakota tire sizes
  106. Dotm
  107. fuel pump change
  108. *****Help finding transfercase! *****
  109. removing the pinion shaft
  110. '90 Dakota - problems, can someone help?
  111. Oops.
  112. DIY: Window Removal (Power Windows)
  113. FOR SALE: V6 3.9L dakoda engine! CHEAP
  114. ultimate dak
  115. DOTM Dec. Come Vote!
  116. '93 Dakota Free Fuel Pump Module
  117. Where to sell factory wheels
  118. another 318 360 motor question
  119. a/c heather blower motor not working
  120. just got a 95 dodge
  121. gettin her back on the road (discussion inside)
  122. 94 Dakota V8 idleing low and dieing randomly
  123. '92 having issues
  124. Bought to buy my first Dodge..90 convertible
  125. Engine flush?
  126. Dash lights
  127. Battery overload help!
  128. 1992 Error Code 41
  129. 99 3.9 Heads
  130. electric temp gauge
  131. T56 in a Dak?
  132. fuse problem???
  133. Tune Up Questions
  134. 02 Power Steering Fluid leaks bad.
  135. Having a problem with my 94 dakota
  136. Heater core lines stuck
  137. 96 dakota will not crank.
  138. DOTM Dec. Nom.
  139. Heater problem...NEED HELP!!
  140. 87 dakota A535/2500 5 spd trans leak?
  141. water pumps
  142. need help
  143. Thermostat Gasket Leaking?
  144. 96 Dak Code 43 "Primary peak Circuit......."
  145. what the F
  146. Transmission ? 1990 Automatic
  147. How does this sound?
  148. 1995 dakota headlight problem help
  149. axle seal or no? (4x4) Pics...
  150. HELP!! Trans is ticking
  151. Trouble code 37
  152. brake problems
  153. 93 Dakota Won't Stay Running
  154. key it up
  155. any write up to pull tranny
  156. Somebody help, Please.......professional oppinion needed.
  157. Headlights
  158. quick question about FSM
  159. vacuum problem... i think?
  160. tire pressure
  161. Winter Time
  162. CV boot issues
  163. Blown head gasket and need advice
  164. 90 Dakota is ill!
  165. Catalytic Converter Rattle???
  166. DIY Rust Proofing with POR-15
  167. help
  168. High beams shut off after 5-10 seconds? 96 Dakota
  169. 6 bolt to 5 bolt conversion on 93 Dak
  170. Throttle Valve (TV) Cable Adjustment
  171. HELP: Need to find a transmission
  172. Fun with fluid.....
  173. Timing Chain/thanx for 3.9 problem
  174. Need help on 95 dakota
  175. Brake Light issues
  176. Could use some help with a '93 Dakota
  177. Tailgate will not latch!
  178. trying not to BREAK it....
  179. 1990 Dakota 3.9 engine
  180. Suggestions to reduce BOUNCE...
  181. Newest addition
  182. thought id introduce myself...
  183. Parasitic battery drain
  184. ball joints, MM,s,axle seal... help...
  185. 92 Dakota 5.2l bucking over 50mph
  186. Oil is pouring out
  187. 1988 dodge
  188. One turn signal doesn't work :(
  189. 2002 4.7 NV3500 on a 5.2?
  190. OBD I to OBD II
  191. 1993 Body parts?
  192. 4x4 and 4x2 rear ends interchangable?
  193. bad idle, bogging, surging, burning black etc..
  194. update
  195. Tire sizes
  196. Brakes?
  197. Hello from WV
  198. Junk Yard Finds
  199. Ignition upgrades
  200. Need Some Help
  201. Manual Transmission Search
  202. My bumper build...er replacement
  203. T-case leaking!?
  204. black hose? transfercase?
  205. 95 dak 3.9 auto, possible low idle
  206. Coil Spacer installation
  207. New Clutch Ideas
  208. Still Shutting Down
  209. Fat bobs garage lift kit
  210. how much tranny fluid do i need? what type?
  211. Does anyone know what ref Transmision I have
  212. Cable??
  213. Transmission Slip
  214. URGENT help! Steering knuckle/ball joints
  215. Leveling Kit 2wd Dakota
  216. R/T Rims on a 96 Dakota
  217. Haven't been on in a while
  218. Where to find a seat belt?
  219. Copper brake lines anyone?
  220. My Official Solid Axle Swap Thread (The Discussion Thread)
  221. Stalling
  222. 2wd & 4wd spindles???
  223. Happy Thanksgiving everyone!
  224. tonneau cover question
  225. 95 dakota power issue
  226. Dodge dakota transfer-case and drive shaft
  227. Replacing door??? 94 dakota
  228. i might be crazy (billy joel)
  229. been gone for a bit im back and with a new toy
  230. just put some 32x11.5 on
  231. Repair options..or SAS options
  232. weird vibrations at high speeds... HELP!
  233. Bench seat question....
  234. Coolant fluid change?
  235. Need another tranny
  236. New bumper/brushguard!
  237. I got new toys
  238. DOTM Come vote!
  239. not dakota related but mopar related 2010 road runner
  240. 93 dakota turns over no start
  241. payload capacity? and disabling the ignition system for a compression test
  242. cross threaded spark plugs
  243. Some wheeling pics
  244. Gauge Pods
  245. 92 dakota major problem
  246. Speaker depth question....
  247. fuel pump
  248. Cleaning Oil Pan
  249. a little bored today so i camo'ed the truck
  250. Old gauge (dumby lights) to dash with all gauges?
