View Full Version : 1st Gen Dakota Tech
- brakes
- Can SS muffler crack be welded?
- rear axel question
- My transmission fluid/filter/pan gasket change thread
- the things i do to myself (my day today so far, new project)
- buying 1993 4x4, what to look for??
- hey whats this stuff
- Rear lights dont work right
- AX-15 rear trans seal
- Need new exhaust! Help?
- dodge dakota transmission
- 2000 Mustang rims???
- Mopar Performance High Performance PCM
- Little update
- Horn, Dome light, Radio problem
- Can my day be any worse
- AX-15 tranny from a 96
- 96 Dakota wiring harness
- ***Rules and Tips for the Calendar contest***
- Hello every one
- Odd rattling noise?
- Parting out 93 Dakota
- lift questain
- Autolite XP
- Anyone here rebuild their own heads before?
- I've got some play in my tranny pilot shaft!
- Help with Transmission
- IDing
- 3rd gen rear axle into 1st gen truck possible?
- What is normal operating temp?
- Climate Control Light(s)
- Is it a bad heater or evaporator core?
- 1994 SLT heater core replacement....I need so advice please
- Lifting 1991 2wd
- Incorrect shifting / tire size question
- 1992 v6 Dakota no fire
- 93' Dodge Dakota Fuse Box Diagram
- '95 Dakota. Are the headbolts TTY?
- 91 suspension lift on a 89
- Got another dodge dakota
- What the heck is going on? All my needles going crazy...
- Replaced the Fuel Pump
- What, Where, and Why (Vacuum?)
- fuel needle moving a lot?
- new problems
- Noise on initial startup
- 1992 dakota 5.2liter alternator power surges
- 91 Dak A/C Question
- Oil Pressure!!!
- Rust Problem...
- Starting problems
- Vacuum Canister....I think
- Ignition Lock Cylinder Retrofit?
- No fire
- Bought some tires, hope they fit
- Crank sensor
- motor swap
- Mind Boggleing Stalling Problem 1991 Dakota
- Subwoofer
- 95 sport problems pls help
- nv3500 difference
- NV3500 to NV4500
- HELP - looking for transmission...
- slt rear drive shaft
- Weird smell
- decoding engine numbers
- Newbie lookin for some help
- catalytic converter
- Ideas?
- So confused
- Hyperboost O2 module?
- weird problems
- not shifting right
- tranny swap from 89 to 93
- parking brake removal
- 92' Rebuild.
- Catalytic converter
- Blower fan switch?
- 89 dodge dakota
- Oil pan??????????
- dakota ignition wiring
- Turbo Question
- dakota wiring help?
- Nates 92 3.9 4x4 build
- Out of all the spots on the brake line....
- Orifice tube or expansion valve
- After much consideration...
- hello
- 93 Dak conking out
- No spark or check engine light
- Took my IAC out and cleaned it up (LA engine)
- Upper Control Arms
- Swapin a 440 into a 90 Dakota
- 2 fluid change questions
- 94 dakota sport v6 egr and dies intermittently
- Intermittent Bucking
- Fuel pump??
- 1989 3.9L Oil Pan Gasket Replacement
- steady popping noise?
- No Spark when Hot. Suggestions please
- high volume water pump?
- major vacuum leak
- 4x4 swap or conversion question
- My New 5.2 where the 3.9 was
- Fuel Injection to Carb Swap 5.2
- Few oxygen sensor Questions
- a few questions about my 94 4x4 v6 dakota
- It's been a long time coming....
- What radiator to put in the 5.2 transplant
- bubbling over into overfill bottle
- 1991 Dodge Dakota LE Stalling
- V6 aftermarket camshafts?
- And so its begun!! 3.9 to 5.9 swap!with pics!
- Make it growl.
- is it worth it?
- 3" lift keys on ebay
- 93 5.2L heater stuck on heat
- transmission shifting issues
- Fixed my fuel gauge
- 3.9L exhaust questions
- Im leaving...
- tranny trantsplant
- Coolant Leak at Firewall
- Left motor mount for 96 Dakota 2.5
- 93 dakota won't start
- no rear brakes
- Push Bar, $55
- supercharger options
- 87 Dakota 2.2 into 57 D100 5.2 Build
- electrical head scratcher
- Freeze Plugs Leaking on my 92 4x4 5.2
- quick question
- alternator going out-upgrade time?
- trans fluid in the driveway :-O
- coolant leak in 95 5.2 v8
- 1996 3.9L 4x4 Head Gasket replacement
- 87 Dakota Build
- 87 engine swap
- Front brakes...
- Will a '93 3.9 ECM fit a '92 3.9?
- 95 v8 dakota trans question
- Dakota Over heating!!
- 91 starting and stalling problem
- Cooling System Upgrade
- 4x4 problems/ issues
- ball joint dyi help (4x4)
- taking off idler arm
- 2.5 Starts, then instantly dies
- brake too hard, break something pt2 HLP
- coolant hose
- stupid question
- Rear U-joint issues
- 1991 dodge dakota stalls when in gear
- 1992 speedometer cable and sensor
- rims
- Hurst NV 3500 Shifter from Jeep to fit Dakota?
- Coolant leaking out of intake manifold
- 3.9 1.7 harland sharp roller rockers
- 89 3.9 v6 help
- 3.9L 1990 Dak Convertible 4x4 rebuild mods...
- vibration?
- Drum won't go back on.
- 93 dakota 4x4 3.9l to 5.9l swap Questions
- i need some help!!!
- 318 or 360????? WHERE DO I TELL THE DIFFERNCE?
- Discontinued brake line parts
- dakota troubles :/
- 93 Dakota v8 Rocker Arm Bolts
- 1996 dakota sport problems!
- Crankcase Breather Filter
- Long hill climb issues...
- Front passenger side vibration issues....
- Bigger Tires
- My Turbo Build.
- 1991 Dodge Dakota Catches Fire
- Ignition switch
- 1990 ASD Relay Location
- No fast idle!!!
- What rpm do you shift at?
- Electrical problem with radiom dome lights, mirrors, etc
- 1990 Dakota Cranks But won't start
- Transfer Case Drain/Fill Plug and Oxygen Sensor Size
- Electrical Problem
- First of many questions... Tachometer jammed or something?
- Issues Shifting
- cam numbers?
- Rear sway bar mounting 89 Dakota
- 87 Dakota 4cl, 5spd. What tranny???
- Got my transmission out... tips to get it back in? lol
- Electric Fan instillation
- Leveling Suspension After Lift
- 93 Head Bolts
- Trans fluid sample is concerning
- 92 4x4 318 V-8 Ext Cab Transmission & Transfercase Leak
- 1993 Dodge Dakota with no fire
- Video of my Dakota's issue
- Rough Idle within 5 seconds of starting--- then fine.
- cracked open the rear diff case... now what? (need quick reply if possible)
- Powers up, turn key, no start/crank
- radio help
- Few different things...
- Blew up my T-case!
- Brake lights
- no spark or fuel
- U-Joints
- Brake light
- 3.9L to 5.9L Questions
- Transmission, What will work?
- A/C problems. And its 100 degrees
- 95 2.5 Won't Start ~ A Continuing Saga....
- Need help with a few changes
- Two torque converters?
- A/C not so cold...
- Throttle body to carb
- It Just Dies... Part II
- throttle body modification
- turbo rebuild?
- tie rod ends?
- Intake Hose
- Interior trim question
- door
- take shocks out for ball joints?
- another radio / dash light problem.
- Fire
- Dakota belt tensioner assembly
- Bumper Guard
- Look what I got!
- code 22?
- 16" Wheels
- How hard is it to to replace drum brakes?
- Wont Start, no hair left to pull
- V8 VS V6 Opinions
- Rear End, true 2 wheele drive
- Fuel Gauge, already have bed off
- It just dies...
- Transmission Questions
- Hurst Short Throw Shifters??
- A few transmission / V6 related questions
- door molding's
- Horn Wiring
- Airbag light on after heater core work
- removing trans cooler lines
- Newark Auto does have carpet for a first gen 4WD with ext. cab
- Did my first AC job on my 1995, center vent at 42 degrees :)
- lift keys for my 94' 4x4
- body lift... electric fan?
- Transmission Lines
- Idle High In Park & Neutral
- Help!!
- E85/flex fuel conversion possible?
