View Full Version : 1st Gen Dakota Tech
- Won't go into park shifts real hard
- Replaced engine, runs but backfires and very little power
- transmission temp gauge questions....
- replacing motor mounts
- How to make engine more peppy?
- Removing door panel
- Parts Swap
- Front shocks
- Replacing clutch in 92 Dakota 2 wheel drive
- Unique Hood Damper Kit
- Tranny help/advice locating a kit
- spindle change ?
- transmission?
- lift kit for first gen dakota
- engine wireing harness
- 96 dakota sport, 4cyl, seized electric radiator fan.
- High idle, 96 Dakota, 5sp, 4cyl
- Wheel spacers Yay or nay ?
- fuel regulator
- Pondering an engine swap
- 91' Dakota antilock and brake lights stay on
- Blower motor electrical gremlin
- looking for some ideas...
- Electric radiator fan thermostat question..
- emissions removal
- 1994 dakota charging issue
- Yet another OD question.....
- 1990 2wd lifted finally
- Transmission/ OD Issues 92 V8
- Just to make sure before i possibly waste money
- 94 2wd balljoints
- Cuts off while driving
- 92 dakota tranny problem
- 1994 dodge tranny problems
- electrical problems
- Mismatched tire sizes?
- 92 dakota wont start
- Cylinder head bolts V6 3.9l
- eletric fan
- Interchangeable years?
- 12v plugin issues
- universal pillar gauge pod...
- Growling noise
- Chevy small block swap?
- front seat
- slow cranking- now made better with smoke
- 96 not starting
- 91 5.2 sport t-case Question
- 95 Dakota fuel pump or ASD location
- New 92 dakota owner
- manual/power windows
- 1994 dakota Elec. problem
- Trying to replace fuel pressure regulator on 92 5.2L Rail
- 88 tcase in a 93
- 88 4x4 Bushing Help!
- Helping Grandma with truck - Not starting
- Are Anti-Sway bars interchangeable from 2wd to 4x4?
- Couple 1995 problems!
- 1989 dodge dakota stumbles on start
- Dodge Dakota 1996 dies when coming to a stop
- Auto Trans Line Size
- Dimpled bushing?
- 1994 with a carb?
- Visor Wind-Drag & FWD Slow-Down
- 1994 headlights/rim problem
- new water pump leak
- 2wd conversion
- 1993 Dakota 5.2 V8 Auto T-Case upgrade to 1994
- The pick up on the coil goes "round and round"
- Transfer-case carnage Pics!
- Trans mount
- Runs good and shifts better with clean 60 pin connector
- Roar sound
- pictures of bush bar mount
- Heater Problems
- Suggestions on what to do with a 87 dodge dakota
- Does the rack and pinion fit???
- '92 Dodge Dakota tranny help
- New project needs trans help
- No Air from vents
- Solid axle swap
- Suspension lift for a 1990 2wd
- hi guys 12 sec motor build pics update
- What did I do??????HELP
- troubleshooting voltage issue
- Trouble Code 27
- 95 dakota 3.9 IAC STUCK OPEN
- Question for discussion
- Efficiency Brainstorming
- 92 dakota no power to coil, fuel pump
- need help with 4x4
- dakota rims tire size ?
- front wheel locking up
- Sliding floor mat
- Fuel Pressure Regulator
- 1988 3.9 wont idle
- 1987 Dakota door handles/latch
- 93 Dakota problem, please help.
- 1989 dakota frnt axle actuator
- Diesel Conversion,Who Has Done It?
- ASD Relay & Ignition Problems
- trans fluid disappearing
- How to replace ignition switch in a '92 Dakota?
- Ball joint popped out of control arm
- Front locker installed, now all 4 locked. True 4wd!
- What is this sensor on a 96 Dakota, please?
- 96 dakota, Trying to replace front grill but cant get to the bottom bolts!
- brakes still wont bleed
- Rear diff bearing sets
- Replacing/Fixing 96 Passenger Door
- Short somewhere
- help with new air filter
- Fuel pump fitment
- 95 magnum in 88 premag dakota
- Clunking when put driven in 4WD
- Overdrive problems
- Swap PCMs
- Transmission
- 94 5.2 mods?
- alternator upgrade...
- Small fog lights!
- '96 Fuel Pump/Regulator Problems
- Engine runs pretty cold
- Transfercase swap
- Deleting roll over valve
- Custom Visor Lights
- running lean
- 96 dakota trans question
- 93 dakota wont start
- Torque Convertor?
- fenders ?
- Chicken lights
- 1994 trans issue
- Weird clunk/grind in drivetrain/brakes
- Cold temp rear gear oil
- aftermarket mirrors
- 3.9 Intake and Exhaust Bolts
- Atm y wits end......
- Flame Thrower?
- Alternator??
- Brake Question
- Combustion Leak Tester Question
- 95 Dakota 3.9 Stalling- need help
- Is it worth fixing?
- hood shopping
- Yep! Wont start again...
- Flatbed
- brakes wont bleed
- 1988 Dual Shock Help
- Smoking
- 93 dodge dakota v6 magnum axle/transmission problem
- oil pressure issue
- 94 5.2 v8 battery issues
- NP205 Tcase
- blower motor
- axle swap help!
- Dakota water temp is a little high
- 1995 Dakota headlight problems
- 46rh overdrive unit
- tranny problem
- Bucket Seat Swap
- 95 dakota how to pull airbag code
- transfercase swap
- clutch pedal
- Engine swap
- New Steering Wheel Off Of Center
- water leak
- CB radio question
- Please Evaluate the Interior of my Transmission
- Help for new add ons
- Air (Smog) Pump removal - belt size
- 3 inch body lift
- to rebuild or not?
- Could This Be Oil Pressure Sending Unit??
- 87 4X4 photos
- need help plz !
- Are '94 & '95 Transmissions Interchangeable?
- Tires
- 94 Dakota Dies at Idle in Gear
- POS no start no fuel or spark
- where does the sensor that plugs in here come from?
- Ride Of The Year! Go vote.
- Fairbanks Shift Kit?
- Weak Heat
- Big block thread.
- Hesitation and pooping thru carb
- MarkIII interior
- Map sensor
- 92 dakota 5.2 injector electrical problem
- Rough drop top for sale in Philly suburbs
- off road shocks
- 96 3.9 Throttle body
- tranny question
- Thermostat question
- 87-96 Chassis Build
- Check engine light.
- 1987 Dakota 4X4
- T-Case Rebuild Kit ?
- Dakota chassis swap
- Dakota Dually?
- Question...
- 1991 V8 Auto Radiator
- My 93 dakota
- Reverse light switch?
- Dash Lights
- 12 second dakota =)
- Grease fitting locations on a 94 2WD
- '93 42RH and '89 42RH: Identical?
- Mirrors.
- New member, new truck
- 12v power outlet
- Give me your opinion
- wont start (yes, another wont start)
- Another crank no start puzzle
- Need advice - CV Boot
- Next motor.
- weird problem shortly after cold start
- no overdrive in my Dakota
- 94 dakota 3.9 magnum no power to fuel injector
- Dakota Overdrive issue
- 5 speed swap parts list....
- Vacuum lines at transfer case
- airaid econoaid
- Automatic downshifting
- HELP ! need pics or info about 89-90 dak master cylinder brake lines.
- 2wd help 96 dakota
- Aftermarket Gauges?
- Cam timing on a 5.2
- Bed cover
- Heater control light?
- Is it possible to convert a 46re to 46rh?
- v8 swap help
- Transfer Case Compatibility
- Engine issues of some sort....
- Code 27??
- About to Hard-Wire my Overdrive...
- Upgrades !!!!
- Emergency brake doesn't work
- HELP! i need an answer to get my spindle!
- My dodge
- Dakota won't start - fuel pump?
- EGR Delete?
- Dodge Dakota Auto Transmission Slipping Still..
- Overdrive Intermittent, Running Out of Options...
- Winter traction-sandbags-tires
- Cummins 10 speed?
- Front Hitch?
- 95 Dakota Weak spark
- Gauge needles. How to replace them?
