PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. Normal or bad oil pressure sending unit?
  2. Auto trans problems
  3. dakota is KIA
  4. Fuel Gauge / Gas Light
  5. Bed rail caps
  6. clunking noise a high speed
  7. Whinning noise higher speeds
  8. suspension
  9. The hunt for a Bush Guard
  10. Truck stalls upon bumps
  11. Braking issue...
  12. Transfer case?
  13. LA 360 swap help
  14. 11 Mpg
  15. New to Dodge, couple of questions...
  16. 93 dakota burnin up headlight switches
  17. 89 v8 project stalled, need help
  18. Fuse box diagram
  19. v8 mount plate to motor mount ears
  20. Weekend SNAFU
  21. Air Conditioning
  22. died down the road :S
  23. 95 dakota xfer case problem
  24. 1993 No spark after flex plate change
  25. Selling My 1992 Dakota
  26. A/C / Heat stuck on defrost?
  27. hate to do it but i love the engine
  28. 1988 Dakota Project?
  29. 92 Dodge Dakota Sticky Gears
  30. Rear brake bleeding?
  31. 1987 Dodge Dakota
  32. 89 vert trans prob
  33. Overheating Need Help?
  34. Same damn problem just another day
  35. Dual Exhaust question?
  36. SOAB of the day
  37. New to df 1st gen dakota
  38. exhaust help
  39. Help!!!!! Truck wont start
  40. A little help from the Dodge gods
  41. "New" dakota in the house
  42. Performance Chips
  43. Fuel Issue?
  44. Turn Signals and Hazard Lights gone
  45. Logans dakota sas....
  46. Fuel pump 5.2 or 3.9 ? switchable ?
  47. transmission confusion
  48. Dead Tach, POOF!
  49. 1995 3.9 not starting again!
  50. anyone try this. TIRE SIZES
  51. Magnum 3.9L carb intake
  52. swap's done!!!
  53. looking for racerback
  54. 1992 Dakota 3.9L 4x4 Just bought No Spark
  55. drivetrain help.
  56. My 91 Dakota made my weekend great!
  57. Volt meter not working...
  58. Plans to Paint the Truck
  59. ABS and E Brake light on -.-
  60. spacers
  61. Spider Gears
  62. New member: a word of thanks and brief overview of problems solved
  63. Intermittent Engine Stumble
  64. My Official Solid Axle Swap Thread (The Project Writeup)
  65. Rebuilt Transmission problem ?
  66. 1995 Dodge Dakota Transmission
  67. Son of a...
  68. 89 dodge dakota engine swap
  69. 87 Dakota - Passenger Door Stuck
  70. 95 Dakota no start solved because of info here!
  71. bolt pattern adapter plate...
  72. Access panel (in the truck bed)??
  73. 1995 Dodge Dakota A/C
  74. help me!!!
  75. help please!
  76. Very hight freight charges to Finland
  77. ecm?
  78. New Parts. Pics and questions
  79. Summit headers, good buy?
  80. Could really use some help here fast - Throttle Body size
  81. need rim advice... in bad position :P
  82. Won't start
  83. Electric fans w/ custom shroud
  84. Trans. pan drain plug
  85. Cheap IFS lift options?
  86. Fan relay on '93 3.9 Does my truck need this?
  87. Won't go above 3000 rpm
  88. 93 4X4 3.9 headlights not workin AGAIN!
  89. SAS options
  90. Suspension Lift for front of dakota
  91. Need a drivers side upper control arm for 4x4 88 Dakota
  92. '93 magnum 3.9, hard start, and fluctuating idle
  93. Problem with my '92 3.9L
  94. mp high performance pcm for sale
  95. turn & flash
  96. Question about Tire Sizes
  97. Rear Drive Shaft Reinstallation
  98. 89 Dodge dakota transmission Troubles
  99. My 96' I just bought
  100. Transmission Slip Yoke
  101. Moonvisor help!
  102. No Brakes!!!
  103. need help again
  104. Foam On Auto Transmission Dipstick
  105. 5.9 heads on a 5.2 engine
  106. coolant leak
  107. Changing Idler and Pitman Arm
  108. Old Kota found fountain of youth
  109. window seal/door seal
  110. Another sending unit/pump question.
  111. Parking Brake light on. Spring switch?
  112. Overdrive
  113. 99 Dakota Parts
  114. Gas tank size
  115. Replace '88 3.9L with a '98 5.2L?
  116. Im lost on this issue HELP!!
  117. Engine Numbers? 92 Dakota
  118. quick trans questain
  119. Newer truck = better gas mileage?
  120. Pa. inspection???
  121. cleaning intake manifold
  122. Transmission Pan Gasket
  123. Transmission Delays
  124. Axil change out???
  125. 3.9 ?
  126. Brake smell?
  127. cam help
  128. need opinion/answer right away!!!
  129. tonneau cover
  130. 94 tranny problems?
  131. Leaf Spring Purchase
  132. 1992 Dodge Dakota v6 won't turn over
  133. adapting 1991 Dakota 5 speed manual transmission to 1994 Ram 3.2L engine
  134. HELP! Turn the key and no power to ANYTHING
  135. idles fine then dies
  136. trans cooler lines???
  137. 42 or 46 rh
  138. 95 dak electrical issues
  139. How to test fuel pump/sending unit out of truck?
  140. Wheel Problems
  141. trns q.
  142. Ecm
  143. Not shifting into first gear???
  144. Brake help needed
  145. Imap
  146. my new truck
  147. Looking for specific type of 2011 Calendar...
  148. Engine swap question
  149. Dies than starts right back up
  150. Carb for the magnum
  151. A1Cardone
  152. tire size
  153. More HP
  154. Upgrade Tranny
  155. 92 V6 Dakota Distributor
  156. 318 swap
  157. supercharger on a 92 dak
  158. 96 3.9 stalla after 10 minutes idling restarts 1 hour later
  159. Truck runs Great, but!
  160. Stalling problem, cleaning parts.
  161. High idle, and slight stutter.
  162. Rear Brakes Won't Adjust
  163. would a 318 V8 fit my v6 dakota?
  164. whats the name of this part
  165. body lifts
  166. Pinion Nut
  167. She's Dead Again!
  168. 1987 dakota location of fuse box
  169. Transfer Case Question
  170. Putting 3inch body lift on...
  171. Best place to order the Lock Right locker
  172. Wheels Fitting On Tire
  173. truck won't start. Help please...
  174. Need New Shocks
  175. brake problems - help
  176. Improved Brake Components?
  177. Transmission coolant line routing
  178. Vibration
  179. Lift and tires
  180. Please help
  181. cab mounts
  182. '91 3.9, need to find hall effect pigtail
  183. 1995 Dakota 318 idles rough low vaccum
  184. 96 dakota interior smell
  185. grinding noise in front end
  186. 1993 dodge dakota stalling? help
  187. 46RE Trans Pan Bolt Torque Sequence?
  188. Disconnecting fuel rails
  189. Runnin, but rough, then dies...
  190. HELP! Motor mount
  191. Temperature "sensor" wiring
  192. Fuel pump relay wiring
  193. will these work..
  194. where can u get a 3 inch body lift
  195. 1989 Dakota Electric Fan Install
  196. HELP gas in oil
  197. Anyone know what this plugs into?
  198. Best oil & filter for a 3.9?
  199. 95/96 dakota SLT crashed for sale
  200. 94 4x4 front ball joints
  201. hids $50 with shipping
  202. Stiffer Rear
  203. 87 3.9 Intake Manifold.
  204. trans questions
  205. PCM Death?
  206. Engine noises
  207. 1995 dakota 3.9 stalling and wont start right away
  208. 1992Dakota Steering Shaft Question
  209. New Busted Dakota
  210. More Engine timing... And Carb help..
  211. Cold Air Intake
  212. A/C Evaporator
  213. 94 Dakota Help
  214. 3.9 pics..
  215. thinking about it........
  216. Rocks n Pushrods..
  217. header leak
  218. 92 brake issue PLEASE HELP!!!!
  219. 92 Dakota wont shift
  220. 3.9 backfriss
  221. Fuel Line Broken
  222. Clutch Slave Cylinder / Clutch Line Assembly
  223. 1989 Dakota 360 Swap Thread (Carb)
  224. Well.... IT happens
  225. 2 in body lift kits on 2 wheel drive dakotas
  226. Problems with idle on my '95 3.9 V6.
  227. My Official Solid Axle Swap (Discussion Thread 2)
  228. Engine Timing
  229. 89 4x4 dakota with 91 2wd rear axle assembly
  230. Mpg problems
  231. shifting problems
  232. smog pump
  233. cranking ware...
  234. mopar brand trans fluid vs dex2 and other brands
  235. Strong gas odor....
  236. Trucks been sitting all winter. what should I do to get it back up and ready to run
  237. 94 dak ext cab mounts
  238. Pre-Mag Exhaust Manifold's
  239. BAD VIBrations
  240. 92 dodge dakota 4x4 drivetrain question
  241. Temp Sensor/Sender
  242. how to get more horsepower
  243. A/C Problems!
  244. 1987 Dakota
  245. 92 dodge dakota Transmission Issues question
  246. 4cyl to v8 swap, driveshaft ?
  247. Confused on 1st gen rockers?!?
  248. Quad Beam Lights?
  249. Power Steering Leak
  250. newer electronics for the old dog.
