- Drivetrain vibration / rumble
- Fan clutch annoyances
- tailgate access
- Fuel injector constantly pumping into throttlebody.
- coolant temperature sensor
- 1992 Dakota 3.9v6 won't start cold
- HEI distributor swap
- Cold weather causing transmission squeak?
- knock sensors
- Opinions on Best Brand of Fuel Pump
- Changing front rotor
- Can anyone help with body mounts
- 94 3.9 Timing chain problems
- Help with a build sheet
- dodge dakota rear axle
- Resto update
- Torsion Bar Questions and Sources
- ECT sensor type
- Climate control vent mode buttons sticking
- Door adjustment ?...
- Timing Chain Question
- steering bushing
- 89 dodge Dakota engine mount
- 95 dakota 2.5 vaccum line
- V8 Swap Questions
- Quick brake bandaid?
- 1993 Dodge Dakota, Fast idle, heavy gas fumes, missing 1/2 tank fuel overnight
- 95 3.9 overheat
- Attention.
- Clip on throttle position sensor broke 92 dak 3.9l
- bolt locations /angle differences in LA 318 vs Magnum 318
- 95 Dakota lights issue
- I can SEE!
- Truck pulling to the right after moderately hard braking last night
- 95 dodge dakota
- Hurst shifter
- Need help quick (no fuel electrical continuation)
- 91 Dak no fuel on startup (electrical)
- 88 Dakota Sport
- temp gauge dont work 95 dakota 2.5
- 1996 Dakota throwing "system too lean" code
- 93 dakota 3.9 will not run
- 1994 Dakota 5.2 backfire under load at high RPMs
- PDC fuses?
- Burn off ??
- Bushings
- 96 Dakota 2wd 5spd Project
- 96 Dodge Dakota Trying to repair/maintain
- 88 Dakota 3.9: installing aftermarket illuminated oil pressure & water temp gauges
- I have a 2010 Dakota
- Rusty cab mounts help!
- 89 Dakota 3.9 with A/C
- Removing O2 sensor...is it possible?
- Dies At Trafic Lights
- 2001 dodge dakota ignition wire color
- Snowman edition?
- plate and fin vs serpentine evap core
- Fire on one cylinder
- 8 1/4 321 gear ratio 4x4
- Egr question
- Broken transfer case
- You guys might dig these pics of my latest road trip
- The Project
- 1992 Dakota V6 Y-Pipe not available
- Where can i buy an intermediate steering shaft?
- An honest Craigslist ad
- Cannot reattach glove box knob
- Converting a 1992 Dakota 4x4 to manual transmission
- 2nd gen Ram 5.9 swap into 1st gen Dakota
- 33mm stabilizer bar
- 2wd lifting shackles don’t fit
- License Plate Light and back up Camera
- Complete loss of right side tail light
- 88 Dakota 3.9 V6...What part is this?!?
- 92 5.2 wont start!!!
- Stalling woahs
- The Trailer Hitch Crisis
- Trouble replacing coil springs
- underdash fuse diagram
- Throttle Body dirty
- V6 5-speed to 318 throttle body
- Brake Calipers - 93' Dakota
- Ball joints and tie rods
- 2nd Gen shocks on 1st Gen
- How to best pry hood
- 88 Dakota 3.9...start but will not run
- 15" Wheels
- Stickum doesn't stick!
- RA Long Block question/s
- Did I find the right spot? Won't start.
- Hood won’t open
- 92 won't start
- Engine Drain blocks
- 92' dakota...alternator not charging
- for the 87-90 owners
- Staying in four wheel drive
- Alternator removal
- 1994 Dakota Brake Light Help
- Transmission Swap
- What size/type screws are used to reattach the knee blocker?
- No more Smokin1994??
- Head Gasket bad?
- 5.2 litre slight ringing sound on acceleration
- 93 Dakota 5.2L Code 21 21
- How much damage have I caused?
- No overdrive and stalls
- Biggest tire size on 92 dakota
- Got my new old ladder rack on!
- I shoulda stood in bed ...
- Lucas Oil Additive
- Fuel Gauge Problems
- Found and engine on Ebay '98 to 03 318 wont work in a 96?
- Lights on the blink
- Trans wont move the truck until at least 1000-1500rpm
- Horn won't stop/airbag light, -already changed out the clock spring. What next?
- 93 Dakota 3.9 Loping
- Drum brake backing plate no longer available. What to do?
- 1987 Dakota to ax15
- 93Dodge Dakota v6 Magnum
- 93 Dakota 3.9 engine swap
- Spongy brakes
- Terminals and clips
- 1994 Dodge Dakota 5.2L check engine light won't come on
- 94 Dakota 3.9L oil pressure gauge nonfunctional
- Universal joint problems
- 1990 2.5Litre Ignition Timing
- need steering column info
- 1993 Dodge Dakota Fuse for Windshield wipers
- Issue finding the right part to order
- 1995 Dakota Speed Sensor Issue
- 1990 dodge dakota werid situation
- TPS problem
- Engine stalling on 1991 Dakota 5,2l 4x4
- Anyone else get this private message?
- Temp gauge sensor location 88 3.9
- Broken Coil Spring
- Accidentally cut off the end of the upper radiator hose
- fender removal
- 35s
- For those who have replaced the heater core
- 2015 Dodge Ram express engine light
- Recovery Points?
- 96 Dakotos Driveshaft Hanger Install
- 5.2 to 5.9 swap and build.
- 1991 Dodge Dakota 5.2 ltr
- dakota fuel tank
- Front Winch Options?
- Free engine mod
- Question about a500 (42RH) Transmission Rebuild
- gas gauge doesnt read
- Instrument cluster
- Won't start, bad computer?
- Quick window question
- exterior door handle
- It's alive and sounds beautiful
- Where is the driver side footwell lamp located?
- 96 dodge dakota high and low beams not working
- 95-96 dakota trans output issues
- 93 Dakota Posi
- No brake light and turn signal
- 96 Dakota 9 inch rear brakes
- How to remove rear wheel bearings and seals
- wiring woes
- hello please save me!! door ajar switch
- 1992 dakota cruise control
- 2.5L 1990 dakota all engine bay bolt torques
- 91 not shifting into overdrive intermittently
- 92 Dakota 5.2 Idling issues
- Transmission swap 1994-1990
- 92 5.9 Dakota no start problems
- Are these symptoms indicative of a circulation door? Blend door?
- Can the console from a first-generation Durango be repurposed for a 94 Dakota?
- 1987 Dodge Dakota blower motor
- engine dead after pop sound
- 1st Gen Dakota Driver Side Door
- 92 dakota transmission swap??
- Extended lugs part number?
- What can a dakota haul?
- AC hoses
- 1996 Dakota engine build
- Any rough idea what the low/high limits on the oil gauge correspond to?
- Throttle Return Springs
- Issue regarding the speakers in my 94 Dakota.
- 1st gen 8ft tonneau covers
- Front brake upgrade
- Rear Disc
- 96 3.9 AX-15 vs. 99 3.9 AX-15
- Seat lever seems to be locked in place?
- Dakota Running Rough
- 92 Dakota crank no start
- Removing the bed for gas tank strap replacement
- Factory intake hose replacement.
- T-Case Vacuum Lines
- '93 Dakota V6 getting a '94 Dakota V8 engine - Build Thread
- Check Engine light
- Issue checking tyranny fluid
- R-12 to R-134a convertion ?
- Alternator getting old?
- Fender Flares?
- 17" Dodge Charger/Magnum/Chrys 300 Steelies
- engine miss 2000-3000 rpm
- 4cyl to 318 motor mount question
- Quick Question About Cylinder Heads
- Shut Down
- Looking for Press in Upper Arm Balljoint
- New dicovery ? Short belt routing
- 93 Dodge Dakota LE EXT Cab 5.2 4x2
- Truck starts like it's carbureted
- 42RH transmission problem
- My wallet is wounded!
- 89 Dakota convertible 3.9 v6 engine swap to 3.7 v6 Pentastar
- Wish I was not-as-broke
- High NOX - Didn't pass smog - Need Help
- Intro and hemi questions
- need help finding parts
- 88 3.9 aftermarket air cleaner
- Before i go and buy a brake booster....
- 1995 Dakota Dies In Forward only
- Mobile A/C Evacuation Services?
- WTB 1989 Dakota RF Wheel Flare
- 92 4x4 Actuator
- Gas tank strap broke
- 93 3.9L Bad PCM?
- 92 Dodge Dakota error codes
- Finally found a new parts truck! '95 318 motor into a '93 V6
- 95 Dak 3.9l clean but low idle 500rpm
- Broken Coil Front Spring - Where to get
- 1988 Dakota LE fuel pump module
- Speedometer cable replacemen...88 Dakota 3.9
- Automatic transmission question
- Real axle bearings?
- busted hinge from door
- Instrument Panel--How Hard To Remove
- Need to Replace Fuel Pump
- blend air door 88 Dakota 3.9 V6
- 92 dakota 3.9L no spark
- Update on rear frame resto
- Ac compressor torque
- Leaking coolant and wobbly crankshaft
- 1996 dodge dakota
- Interchangeable parts between 90' and 95' Dakota
- factory bucket seat tracks/rails for sale ?
- 93' Dakota Build
- A/C 1, Dakota 0
- Dipstick tube again
- NP2500 to nv3500 swap 87 Dakota 4x4
- 1st gen steering column
- So is everyone's driver's seat torn on the side?
- Stereo Upgrade (A Cursed Project)
- Will brake caliper on 2002 Dakota fit on 2003 Dakota
