PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 [58] 59
  1. 93 2.5 headgasket?
  2. transmission?
  3. my $1000 beater project
  4. couple newb questions :)
  5. Any writeups on Engine removal?
  6. 93 dodge dakota wiring diagram
  7. 92 dakota problems
  8. time for new brakes and rotors??!!!
  9. 1993 318 Dakota Exhaust..
  10. Dumb question
  11. thermostat
  12. fuses
  13. '93 6 cylinder
  14. 96 Dakota won't idle
  15. 96 Dakota won't idle
  16. Bad gas mileage 1993 Dakota
  17. FUSE KEEPS POPPING
  18. Replacing Rad
  19. How to install Engine Belt 95 Dakota
  20. Limited slip diff
  21. alteza tail lights for a 93
  22. 1993 Dakota heating problems
  23. Largest tire on 2wd 92 Dakota
  24. power mirror help
  25. Free Horsepower??
  26. changing starter having problems installing it
  27. SNOW PLOWS??
  28. console
  29. 1991 Dodge dakota 4x4 Pickup
  30. Who made the 2.5L Engine
  31. ignition problems
  32. 93 dak u-joints
  33. new to me,but not new too dodge
  34. 1994 318 dakota upgrades
  35. Cooling fan problems
  36. rpm's
  37. Bucket Seats
  38. why cant i find any thing in search?
  39. a bit extra power
  40. new update on 3.9 blown head gasket
  41. 2 questions
  42. heater problem
  43. 94 Dokota 4x4 wont move
  44. 96' 2.5L OBD Code P1391
  45. Suspension Questions. Please Help
  46. Trouble with fusible link blowing...
  47. 94 van alternator rotation
  48. HELP! Something wrong with my tire
  49. 92 dakota - Not running good
  50. 24v cummins bitches!!!!!!!!
  51. 92 dakota - bad gas not running good when warm
  52. 91 dakota being parted out
  53. Help please..
  54. Tranny getting bad....
  55. ?'s about front clip swopping
  56. '96 dakota 6cyl...Temperature concerns
  57. 96 5 speed
  58. 1990 3.6L
  59. Dakota 87
  60. 97 up wheels on a 92
  61. 24 valve CUMMINS in dakota anyone???
  62. Headers For A 90 Dakota With A 74 360
  63. radiator
  64. Wheel needed
  65. 92 3.9 to 5.9 engine swap
  66. 1990 3.9L stalls when comming to a stop
  67. 1993 Dakota Sport...no rear brakes...
  68. Dakota 3.9 and V8 Question
  69. 8.25 Question
  70. dead dakota-no start
  71. rims
  72. 3.9L V6 Please Help
  73. blower resistor values
  74. common problems
  75. windshield whipers quit
  76. resistor location
  77. where is the resistor located?
  78. 1994 dodge dakota heater dosnt work
  79. 3.9L V6
  80. newb
  81. slipping tranny
  82. Gas
  83. New Truck
  84. Hello Im New
  85. 1988 Automatic transmission
  86. Brakes
  87. Cold air and hat
  88. Mirrors
  89. 90 v6 wont stay running
  90. 3.9 blown head gaskets
  91. HELP, I need a PCM like Last week
  92. 518 trans swap? & trans info too
  93. Which MSD ignition to use?
  94. '92,V8,318 CU.
  95. Rear brake line replacement
  96. Engine Swap
  97. p1391 Help!
  98. Stalling/ ticking problem
  99. BAD FUEL PUMP
  100. Suicide Doors
  101. Where can I get a Brushguard and accessories?
  102. Big job almost done
  103. engine swap
  104. '93 doesn't have brake/turn lights or dome/radio power
  105. help with lights
  106. Need Help 95 Headers
  107. motor swap??
  108. problem removing shocks
  109. problem removing shocks
  110. Any videos of racing?
  111. 95 3.9 Auto tranny shot?
  112. 96 dakota, longgggg starts
  113. 95 dakota making wuring noise
  114. Valve Covers for 90 Dak
  115. 92 3.9 problems..
  116. windshield wipers
  117. 90 Dak Will Not Start When Engine is Warm
  118. Electrical short underhood
  119. Whats My Dakota Worth!?
  120. Help older Carberated Dak problems
  121. Help plzz any one with an older carb dak
  122. 3.9 facotry specs
  123. miles?!?!?!
  124. High idle????
  125. 92 Dakota 3.9L Where is the OBD port in the truck?
  126. Engine Noise
  127. 87 dakota ignition switch
  128. starter , bat, relay wiring diagram 96 Dak
  129. what skirts fit my 92?
  130. Help, Need ground effects for 92 Dakota?
  131. O2 sensor problems.
  132. '91 V8 5.2Liter ignition troubles
  133. Door locks
  134. fuel pump? dropping fuel/long starts
  135. need engine help
  136. firing order
  137. No overdrive !!!!!!!
  138. distributor
  139. Just bought a '94 Dakota. Help..
  140. brush on bedliner
  141. tire pressure for 31"
  142. DAKOTA NO START ?????????/
  143. P0441 Evaporative Emission Control System Incorrect Purge Flow
  144. Dakota V8 Hooker Headers
  145. Changing the water pump in a 94 Dakota
  146. Bucket Seats
  147. Questions
  148. 93 dakota, Backfire from intake
  149. 91' Dakota with no fuel getting to injectors
  150. Blower fan for AC in 93 Dakota
  151. Dakota Sport just wont act right. . .
  152. Replacing ball joints.
  153. 97 seats in 94
  154. Steering wheel not grounded can't find how to ground, horn thus not working
  155. Parking Brake Problems
  156. long box vrs. short box and wheel base.
  157. check engine
  158. Parked to close to the mud hole.
  159. Lift kit
  160. I need three inch front lift!!!
  161. 93 Dakota backfire intermittently
  162. slipin tranny
  163. my rearend!
  164. 93 4x4 lower control arm bushings
  165. 91 Dak wont start, fuel press 10psi, should be 15...?
  166. 94 Dakota instrument panel failure
  167. problems with my 92
  168. 95 Radio
  169. new to dakota, 4x4 help plez??
  170. TAC. (RPM Gauge0
  171. 4x4 problem
  172. Painting
  173. 91 daytona won't open up all the way
  174. Truck Massage--humming vibration problem
  175. Truck Massage--humming vibration problem
  176. V-8 Conversion
  177. 94 Dakota V-8 (5.2) Sport Possi or Limited Slip?
  178. Noise comming from tranny
  179. Best Transmission For Towing.
  180. Engine noise 3.9
  181. 95 grille removal?
  182. 97 valance on a 96 dakota (update)
  183. 94 v-6 3.9 L dodge dakota firing pattern?
  184. 88 dakota blown head gasket
  185. engine code 12
  186. 91 dak v8: threads on fuel inlet barb?
  187. indy500dak owners
  188. '94 3.9L cooling problems
  189. 95 Dakota 3.9 Computer Problems
  190. 92-93 performance
  191. A/C Heater problem
  192. Diagnose This... if ya can 1991 Dkta 4x4
  193. 88 dakota performance
  194. Need in fo on parts
  195. 1993 Dakota CD Player
  196. putting the sport in a 96 sport
  197. where to buy NEW door panels
  198. gauge pod from AAR
  199. wiring problem
  200. brake lights on
  201. Will this work in my 1992 Dakota?
  202. Air Conditioning
  203. 1992 Dodge Dakota...no idea whats wrong
  204. '90 Dakota Wiring Diagram?
  205. check engine light does NOT light 1987
  206. Hissing sound from brakes
  207. rear end width flange to flange
  208. new and have a problem!
  209. 93 dakota stalling
  210. '95 Dakota Transmission Skip
  211. HEADLIGHT SWITCHE WOES
  212. 1991 dodge charging problems
  213. Engine ID
  214. 95 dakota running poorly
  215. 3.9 to 5.2 swap
  216. Interchangable throttle body?
  217. Throttle body spacer/ Power Tower
  218. width of the rear in a dakota
  219. rear shock mounts
  220. for sale 1988 dakota 440,727,8 3/4 323 posi
  221. parting out 87 dakota
  222. Idle on 2001 R/T
  223. 92 magnum?
  224. 3.9 questions...
  225. Grille
  226. loud whining noise
  227. 1 Wiper Arm Not Working
  228. 1991 v6 horse power/ and magnum hp?
  229. MOVED: need parts
  230. Need a sway bar. Help?
  231. Need a sway bar. Help?
  232. 2" body lift, what size tires?
  233. "Y" engine
  234. Lift kits, consoles,
  235. Bumpers, Roll Bars and Nerf Bars
  236. leaks and floor board full of water
  237. no fire...need help
  238. blew rear axle
  239. blower fan?
  240. 1992 lil red express dakota
  241. Headliner kits available.....
  242. Two types of rearend- ?
  243. What is 1st Gen. rearend width
  244. 1991 V6 Dakota
  245. 96 and older dakota owners
  246. 1992 Dakota Trailer Wiring
  247. 93 Dakota Lift kits
  248. im still not sure what the flywheel cover is...
  249. help!! whats the flywheel cover called
  250. '95 Sport
