PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. '93 5 speed is stuck in 4lo
  2. 92 dakota
  3. 92 dakota wont start, no spark, how to test cps
  4. Topper Interior Light
  5. 88 dakota 4x4 transmission
  6. AC compressor model on 2.5?
  7. How to Bleed Hydrualic Clutch On 88 Dakota
  8. What happened??
  9. coil spacers vs new springs?
  10. AC Clutch Removal-Grinding noise
  11. Dakota Rot
  12. Mopar Computer, is there nothing for my 1996?
  13. Gear ratios for auto RWD, what is going to get best whp on a 7.25?
  14. Engine will not die
  15. Steering play
  16. code 15 on 91 Dakota
  17. 91 3.9 whines in overdrive
  18. Engine stalling when going into reverse
  19. My '95
  20. Need 92-93 fuel pump
  21. 1995 Dakota 2.2Liter 4 cylinder engine temp issues
  22. Radio choke relay
  23. 90 Dakota Brakes?
  24. 92 3.9 not starting
  25. 46RE automatic basic question
  26. 1993 dakota with the lift kit
  27. lifts and tire size
  28. Overdrive Button Issue
  29. 95' Dakota 3.9L Plugs and Gap?
  30. Valance
  31. funny problem with ac blower
  32. Transfer Case????
  33. Replaced headlight switch on '93 Dakota
  34. 5.2l throttle body
  35. 96 Dakota 4 cyl breaks up at high RPM?
  36. idols funny
  37. 1994 Dakota - Should I go for it? Plz HELP!
  38. 88 dakota 3.9 v6 auto bogging problem
  39. 1992 V8 Dakota won't spark!
  40. Should I buy this 94 Dakota Sport??
  41. Will Not Start Sanity Check...
  42. Looking for a limited slip or posi
  43. Very rough idle while in gear
  44. 10 sec 1st gen
  45. Turn Signal Electrical issues
  46. PCM Question
  47. Temperature Gauge reading incorrect
  48. rack and pinion rebuild
  49. Brake help and Rad Please!!!
  50. Dieing issues
  51. Help! 88 Dakota voltage issues!
  52. Help! 1990 dodge dakota wont start.
  53. Quick "low fuel" light question
  54. Fender flares?
  55. Camshaft Distributor Gear Wear
  56. windshield wiper arm removel
  57. modest exterior mods.
  58. Hallowed out cat?
  59. 55 mph drift.
  60. V8 Plenum repair kit
  61. anyone looking for clear taillights?
  62. Interior light short?
  63. Ok so I think a lot is going to hate me but F it!
  64. Tips? Please help!
  65. 89 Dakota 318 magnum swap.
  66. 88 dakota notbgetting fuel
  67. low idle.
  68. 87 dakota wont start
  69. Bent as hell inner tie rod; easy to replace?
  70. 1992 Dakota Low speed intermittent stalling
  71. Frame swap help?
  72. spare tire rack...
  73. engine and transmission
  74. 1992 dakota lifting questions.
  75. '95 dakota moving leaf springs
  76. loosing battery life
  77. Street Fender Flares!?
  78. 95 A/C Questions
  79. Box compatibility between years
  80. Running problems
  81. ax15 behind a 318?
  82. steering wheel
  83. 3.9 to 5.2
  84. 95 Dakota off road help
  85. DIY!! Fuel sync without scan tools
  86. No juice to coil
  87. How to paint a chrome bumper?
  88. Hi Dodge people
  89. Which tranny line is which?
  90. Where to find a 92 manual
  91. Trail master lift photos please.
  92. Where can I find red headliner material?
  93. 1991 Dakota 4x4 Project
  94. Spark plugs
  95. Body damage and now a replacement truck Pics!
  96. Trailmaster Kit
  97. 92 3.9l automatic trans problem
  98. Help! Wiring a Rear View Mirror with map light.
  99. trans question
  100. disconnecting the rack & pinion unit from steering column
  101. Crate Motor
  102. 92 dakota 3.9 timing chain
  103. hard to start
  104. Truck shakes and it is not dependant on Speed or RPM
  105. Crankshaft Pulley for 1990 Dakota
  106. 1987 Indy 500 official truck on craigslist
  107. New Carb new problems...
  108. 1990 dakota door latch
  109. 6 lug to 5 lug?
  110. What is the best way to deal with this rusty frame?
  111. Davis Unified Ignition system ?
  112. some parts I might let go of
  113. General issues/questions
  114. 1994 dakata Slt 3.9.....no front brakes
  115. 1993 3.9 Dakota Error Code DTC: 23
  116. Switching from EFI to Carb 1993
  117. Strange Trans Issue, Will not engage any gear
  118. transfer case problem ?
  119. wheel spacers
  120. Final drive ratio??
  121. Hissing From Peddle and it's getting hard to depress
  122. towing capasity?
  123. Fuel level issue
  124. Steering?
  125. Electrical issues in my 89 dakota sport :(
  126. Fuel level sending unit for 87 dakota?
  127. 1993 dakota fuel issue, new pump
  128. Check Engine Troubles
  129. then and now
  130. Stalling / Jerky in 2nd gear
  131. Welded Diff?
  132. radiator questions
  133. hood/ hood scoops
  134. Trailer Tow Packages for 91 Dakota?
  135. Hard top removal kit. Thoughts?
  136. v6 to v8 swap speedo question
  137. 94 46rh??
  138. a/c
  139. Will a 360 tranny bolt up to a 318 motor?
  140. what yr was the dakota serp belt system added??
  141. Alternator change out
  142. Gauge Problems
  143. the new dakota :)
  144. Mopar Performance High Performance Computer ?
  145. what flywheel do i need ?
  146. 87' Dakota feels like diesel and stalling.
  147. Can the transfer case from a 1996 Dakota be disconnected without being removed?
  148. 91 Dak 4x4 transmission question
  149. BKCowGod's Dakota
  150. ? Good place to get center caps ?
  151. v6 to 4cylinder engine swap - NEON?
  152. towing a car trailer?
  153. bleeding breaks not working
  154. #40 Ignition Fuse blowing when key in "ON" position
  155. nv3500/4500 transfer case?
  156. 93 4x4 V8 sounding strange
  157. E-fan upgrade & steering cooler
  158. 95 Dakota Flickering Headlights!!!
  159. 42RE Question
  160. Ditching the back seats for some bass.
  161. Truck won't push passed 3200 rpms.
  162. 44RE or 46RE? Also a PCM swap question...
  163. 93 dakota stalled oil light came on
  164. Towing a Dakota (behind an RV)
  165. Mystery Resistor
  166. 93 Dakota shuts off when slowing down in neutral
  167. center console
  168. gas gauge?
  169. Switching the transmission
  170. 94 V6 starting and dying
  171. U bolt flip
  172. New to owning a truck can any one answer a few questions
  173. 1991 Indy 500 Brochure scanned in along with some others
  174. questions/upgrades to the 3.9magnum
  175. 1993 3.9L MT 4x4 Charging question
  176. Not having a good day help
  177. 89 dakota 318...
  178. charging problems 1991 v8
  179. e fan swap 3.9
  180. looking for some answers
  181. Are the ASD & Fuel Pump Relay the same thing?
  182. Upper and lower ball joint replace (96,2WD)
  183. To MSD or not to MSD?
  184. 93 dakota sport 2.5 clutch stopped engaging out of nowhere?
  185. Newcomer fuggerbunk
  186. Truck won't start, with the solution!
  187. sorry for the crosspost.... put it in the wrong section - brake problem
  188. Code 41
  189. 318 swap transmissions
  190. Drivers door nearly falls off when opening
  191. 1992 Dakota with 5.2 V8 has starting problems
  192. Prothane Opinions [anti-sway bushings]
  193. 98 in a 94?
  194. Rear end axel bearings question
  195. High oil pressure
  196. Need help with ignition problem
  197. Transmission pan leak issue
  198. 92 dakota 3.9 possible vacuum issue
  199. Code 27
  200. Question for those with the 231HD transfer case:
  201. Idle Control + water in exhaust??
  202. another "my 4x4 doesnt work" thread...
  203. Is your extended cab damaged? FYI
  204. Tranny problems
  205. 88 payload
  206. 46RH not shifting
  207. broken steering column/no lights
  208. odd noise in park when cold
  209. 4 Low transfer case
  210. Dakoda 87
  211. Lockup vs Non-lockup a518
  212. 93 d250 wiring harness.
  213. radio won't work
  214. 51 code
  215. 318 la heads
  216. 1990 Dakota No Spark
  217. trans swap
  218. Accidentally drained the wrong fluid.. Please help
  219. Bad Vibration in Overdrive
  220. 135-140psi compression but bad MPG
  221. Its Raining!
  222. Question on upgrading bulbs
  223. 92 dakota bucking
  224. Lift / level out front
  225. 1992 5.2 4x4 Motor Mount Swap
  226. Trading my V6 for another truck - Advice?
  227. Suspension Issues?
  228. transfer case rear output shaft height?
  229. Help!!!
  230. Help!!!!!
  231. Looks like time for a new muffler guys.
  232. 92 dakota 3.9 no fuel issue
  233. H.P. and MPG upgrades?
  234. 3.9 woes
  235. Click sound from engine - pls listen
  236. Transmission Question(s)
  237. Shaking at 40-50km/h
  238. 94 dakota temp guage problems *****help*****
  239. 94 dakota temp guage problems *****help*****
  240. Need help finding some parts!
  241. '91 won't start
  242. Intermediate steering shaft question
  243. "Shocking" question...
  244. alternator overcharging and bad electrical conection.
  245. 1993 Dodge Dakota, to buy or not to buy?
  246. Lesson learned: 95 dakota drive shaft
  247. electric fan questions...
  248. 94 Dakota 4x4 Steering
  249. Newbie question: 89 Dakota timing belt 2.5l
  250. grinding noise from 92 Dakota front end
