View Full Version : 1st Gen Dakota Tech
- Smells like Fuel
- Grille Guard for 88 dakota 4x4
- 1996 Ext.Cab 3.9L
- new member ride
- 94 lift kit? how high
- Gas Mileage
- '91 3.9 V6 revving up & down on its own HELP!!!
- remote door locks/starter
- Stroke and Bore
- Question for Crazy4x4RT
- Crazy Idling
- Weird transmission problem: is this truck worth buying?
- 1990 Dakota Rear End
- 89 Dakota stuck in 4wd...
- PCM's
- 93 slt ext cab
- disk brakes locking
- Temp Gage
- 'Ello
- inertia seat latch
- dies in cold weather after running a while
- Performance cams
- looking to get some headers
- im looking for a lift kit
- electric fan
- Larger tires...
- Fix one thing and other pops up
- 1987 Dakota Transmision Help
- MY check engine light no longer works???
- 96 dakota fuses
- brake issues
- splash shield source?
- heater core
- 91dakota 4+4runs great leak on trans??
- '87 3.9 Problems
- Blower Motor Resistor Block
- shift kit for 46RE
- 95' Dakota with electrical problems when starting
- CEL on with multiple codes
- 1988 Bed Caps, anyone sell them?
- Dodge Dakota 1992 "maintenance required" light
- Dashboard lighting(speedometer, rpm, etc), radio, and inside dome light not working.
- Coolant leak: any ideas?
- hoist
- oil change lesson
- 1991 Dakota 4X4 - Bringing it back to life
- Heater Question
- Equalizer Installation
- 1992 318 Dakota w/fuel wiring problem
- Noise
- Dakota 4x4 center cap
- 93 dakota 5.2L dies while driving
- mystery coolant leak
- Splines
- 94 3.9 V6 Stalls
- Ebay clears???
- 88 V6 Dakota Tune up time, any recommendations?
- eBay ball joint kit review
- 3.8 to 5.2...will it bolt right up or not?
- black smoke
- Need a new radio, which one?
- 1990 V6 overheating
- Torsion Bar
- Tightening Belt
- Differntial cover
- 4wd to 2wd
- Brakes?
- 408 stroker in 318 block
- Gauges quit working when lights turned on
- Fuel Pump replacement
- ebay headlights?
- Oil leak - sender unit?
- 87 dak, what to do what to do
- Will it fit? 94 RAM 1500 Trans in my 94 5.2 Dak???
- 96 Dak owners, where does this go ?
- catalytic converter
- cruze control ?s
- 1992 Dakota Baby
- Polygraphite front end kit
- Truck smells rich, like unburned fuel?
- Painting Drums/Calipers
- 95 Dakota Bumper help
- Subwoofers
- about to change the heater core....any advice!
- Dakota rockcrawler
- carb
- speedo ??
- Radio
- 94 318 le stalling HELP
- 4x2 to 4x4
- Headers & Oil pressure sending unit
- engine drain block?
- Anyone want to buy a MAGNAFLOW MUFFLER?
- FAILED SMOG/Emmisions TEST? Any SMOG EXPERTS OUT THERE?
- Dak died - I think this may be it, but, erh, what is it?
- distributor drive shaft
- Broken suspension bolt
- gears!!!!!
- 93 dakota code 52 - engine rich
- 93 dakota wont shut off
- dakota wont shut off
- 89 Dakota park,dash and speedo quit
- Turbo 93 dakota
- Air Conditioner Acting Funny
- Mopar performance computer
- R134 Recharge and a new/used gas tank.
- 1992 w150 5.2 sensor
- Won't Start in Park? :S
- free rollbar
- Rebuilding the V8
- easy power gains for the 5.2 318
- REALLY NEED HELP.. 93 dakota no spark, no fuel
- Shocks & Exhaust
- lost antifreeze
- Anybody have ideas of what this problem could be?
- No Power On Accelleration. Advice?
- trans.line help please
- Electric Fans for sale.....
- engine tech? has anyone heard of this brand
- Electric Fans
- Dies and will not start again?
- PERPLEXED
- Is this the bad splice?
- engine rebuild
- Better gas mileage
- 91 dakota a/c
- Main oil seal leaking
- New Game - Lunar Battle!
- k&n
- Weird problems
- water in exhaust pipe
- Need Help! Computer wireharness problem? Please Read!
- Plenum Intake Gasket - About how long does it take to replace?
- 3.9 rebuild
- What Would Take Out A Cat In Two Months?
- Buying New Seats But Kinda Confused
- torque ratings.
- Brake Light/ Signal light question
- stock 3.9 to stock 5.2
- newbie to Dakota: will I like the 1995 in snow?
- Blower/Blower Motor
- 3.9 performance
- where is the oil pressure switch on the '95 dakota?
- 1990 dakota starter problems
- totaled or not?
- glove box lock
- Front end grinding noise help
- Parts?
- Plenum Gasket Leak??
- Looking to rebuild my transmission
- fuses
- 96 Dakota -- Won't Start
- lowering a dakota????
- peeling paint & no fan
- which auto tranny?
- grille guard movement
- 94 Dodge Dakota
- More Performance off of a 2.5 4cyl???
- Replacing the Rear Sliding Glass
- Are door hinge problems common?
- found place for few good parts for the 1st gen dak
- hood??
- 1995 Dodge Dakota Sport Customization??
- Transmission Repair Manual Found!
- Quick Dumb Question
- HELP???!!!
- long tube headers?
- Speed Gov
- timing problems
- little help??
- 88 Dakota Radiator Fan Stuck On
- 1st Gen Dakota Group//FaceBook
- 92 Dakota swap question???
- Tow Points and Offroading Questions
- Used or Aftermarket Pulleys?
- fuel leak
- How to Install 20' Wheels on 94 Dakota
- 96 3.9 won't idle after waterpump change
- power options
- compatability question
- overheat with AC on
- cuts off while driving
- strange taillight problem
- good brakes, soft brakes, then no brakes...Update
- running problems!!
- HELP
- NP231D Transfer Case 93 Dakota
- '95/'96 Fan Shroud
- Lift kit?
- Vote...
- Stumble on deceleration
- Idle problem just after startup
- engine swap
- 91 dakota w/ 440 for sale!!!
- 1995 Dakota Info?
- Dakota 1995 trouble
- Car/Truck of the Month
- disc brake sticks
- 92 DAKOTA BUCKET SEATS!!!!
- 91 Dakota sport V6 horsepower
- Wiring Diagrams/Service Manual
- I found 2 different lift options but which one?
- check light
- V6 or 4 cylinder???
- Fan does not blow
- 1988 Ignition switch wiring
- Visual Difference 46RH vs. 46RE
- new catalytic converter
- my 89 dak 4x4 home
- electrical gremlins
- Engine swap question
- A Few Things
- Big Small Block in a Dak?
- Transmission compatibilty : 1990 3.9L = 1992 3.9L ???
- deer atack
- Heater doesnt blow out the panel
- Reset Maint Req instructions?
- speedometer not working
- Smelling gas in Cab?
- 1994 Dakota Tach Fails to Register RPM
- a few problems
- How big can I go?
- 1994 dakota. a questions..
- Gas spitting out of carb?
- Interior door handle trim
- How to check for the check engine codes
- Ignition fuse keeps blowing
- Little Red Express (Dakota)
- ROTM nominations open
- HAULING WEIGHT WITH 1ST GEN.
- bog
- 1992 3.9L with issues
- Couple little things
- confusion...
- couple noises
- Another dieing Dakota question.
- need help with TBI
- Loss of Power
- Jet Stage 2
- 93 Dodge Dakota 3.9 ltr exhaust
- Parts Help
- '94 V8 Trans Question
- No fire from or to coil after replacing clutch
- 4 Banger Dakotas post here.
- Odd Problems With '92 Dakota
- Very strange
- Brake,hazard and turn signal fuses blowing
- 89 Dakota A/C Issue
- new 31s on my 91 4x4 with no rubbing
- 92 dakota..
