PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. Bugs in the electrical system??
  2. 1991 Dodge Dakota
  3. 92 dakota shifting issue
  4. Spare tire extension tube
  5. Start or No Start
  6. Ignition problems
  7. 1990 dodge dakota
  8. codes
  9. Dakota fuel pressure low
  10. Driver's Seat issue
  11. 1988 Dakota gas tank
  12. 96 3.9 timing cover question
  13. Code 1-1 and hood latch stuck
  14. Driveshaft differences
  15. fuel delivery issue
  16. Mileage
  17. Trans hose
  18. 92 Dakota 3.9L
  19. ac compessor clutch
  20. stumbles and sometimes stalls
  21. Front wheel whine..
  22. 95 Dakota trans slipping jut changed fluid 6 months ago does not looker smell burnt
  23. Timing on 91 3.9
  24. Radio Help!
  25. Upper control arms
  26. 95 2.5l crank/no start
  27. Stalling coils,ASD hot to touch.
  28. 1996 Dodge Dakota
  29. When it Rains - Transmission Problem
  30. 2wd hubs on 4wd will they fit.?
  31. 2nd Gen 3.9l used as short block for 1st gen
  32. need part
  33. Starter Issues
  34. Tuneup - What'd I do Wrong?
  35. Radio ain't workin
  36. Where is paint code?
  37. Reoccurring wheel bearing issue
  38. got this hood protector off a 95 dakota, but ain't got no holes on my 93 for it.
  39. I never thought it would happen...
  40. 96 V8 5.2 4x4 - ABS and park brake light on, no fuses?
  41. 1990 Dodge Dakota LE / water in floorboard
  42. Looking for the bodyside upper tape decal for my '95
  43. Something Neat!
  44. horrible gas mileage
  45. Front wheel has clicking sound
  46. Ignition Lock Replacement
  47. When A Trip To Have A Flat Fixed Goes Wrong
  48. warm weather and brake binding problems
  49. Hot rodded 318 vs factory OBD1 PCM
  50. Strangest things happen to me
  51. Where to begin
  52. Fitting 33" Tires
  53. ECM Pin Diagram 1995 and 1996 - 5.2L
  54. 4WD Transfer Case Vacuum Ball
  55. How do I remove this water pulley? 92 v6
  56. No spark
  57. Hard start after at operating temp. Backfire.
  58. '95 V6 2wd Tune up Parts Questions
  59. Push Bar for 93 Dakota?
  60. 1988 Dakota 3.9 V6: How to clean throttle body
  61. 1989 Dakota high emissions
  62. 1st gen control arms
  63. 96 V8 5.2 4x4 transmission pan removal
  64. upper and lower radiator hoses both hot
  65. start and idling issue
  66. New member
  67. Seats?
  68. start /no start
  69. 2nd gen lift on 1st gen dakota?
  70. extreme cooling radiator
  71. help 94 Dakota fuel pump not running
  72. 1996 Tow Inquiry
  73. Hard jerk when put into gear.
  74. Oxgen Sensor 88 Dakota 3.9 V6 2WD
  75. Rear wheel and tire max width
  76. 88 dodge dakota
  77. What radios from other vehicles fit first gen Dakotas
  78. Jerks, & REALLY NICE People
  79. '95 2WD - Electrical Problems
  80. Auto 3.9L Dakota with a manual ECU
  81. Code 41
  82. 1992 possible pcm problem??
  83. EFI control solutions for OBD I - 95 Dakota 5.2L
  84. 93 Dakota 3.9l auto- rpm tach all over
  85. Repeat after me
  86. Stock exhaust size for 92 v6?
  87. Hello fello Dodge fans
  88. 1992 5.2l o2 sensor swap
  89. New member with fuel pump wiring problem
  90. Swapped ac compressor, lines, and dryer. Now truck has trouble starting
  91. Intermediate steering shaft
  92. New Member From Roanoke,VA
  93. 1995 Dakota 2WD Radio Problems
  94. 91' 4x4 318 interesting transmission issue.
  95. Proportioning valve
  96. fuel sending unit wiring
  97. AC Schrader valve for high side
  98. 2wd to 4wd conversion
  99. truck is having some TC issues....suggestions?
  100. The mess i have gotten myself into.....
  101. Transfercase exploded
  102. A bad light switch?
  103. Is there a good synthetic for a 93 5.2
  104. Cold are intake/ More efficent muffler
  105. Engine swap
  106. She's getting on up there!
  107. Front end damage
  108. Cold air intakes for 93 Dakota 5.2L Magnum
  109. Plenum Plague -- which years/engines?
  110. Most common vacuum leak locations on the 3.9 V6
  111. 1987 dodge Dakota 3.9 upgrades.
  112. Truck died while at the stop sign. 88 Dakota 3.9 V6 automatic
  113. Cab Fuses --Any Always Hot?
  114. 92 HVAC lever stuck
  115. Dies, bad idle, missing, all somewhat random.
  116. Finally finshed the body restoration 88 LE
  117. led light conversion
  118. led light conversion
  119. Help - Jumpering the fuel pump "ON"
  120. Does the lift kit include the spacer for the shaft?
  121. 94 RWD ABS/Brake Light
  122. What does this thing actually do?
  123. Flexplate question
  124. 94 Dodge Dakota Magnum Speakers
  125. Getting top nut off shock.
  126. Muffler question
  127. NEW HERE! Anyone still active?
  128. mix and match fuel tanks?
  129. Tire Rub
  130. body paint question
  131. Auxiliary Wiring Questions
  132. oil pressure gauge is close to high
  133. Transmission Band Adjustment
  134. To stop...or not to stop.....
  135. Location of intake manifold temp sensor? 88 Dakota 3.9L
  136. Windshield wiper arms slam
  137. Blower motor not working
  138. Combination valve question
  139. whats the biggest tires I can put on stock suspension and where do I get parts?
  140. 1995 Dodge Dakota not getting fuel out pump I beat on tank then it fires up shut truc
  141. Dakota Warrior??
  142. ECTS failure without coding
  143. Crankshaft position sensor- location
  144. Rear diff slipping
  145. Why do my tires slant like this?
  146. Help!! Broke A Part While Cleaning The Throttle Body
  147. Hood Adjustment
  148. Aftermarket gauges with factory wiring ?
  149. Wire Harness Taping Tips
  150. Door got jammed up, fixable?
  151. Difference between EGR valves?
  152. How do I take door pins out of 92 Dakota?
  153. At Wit's End With '91
  154. 92 Dakota LE bounces like a boat.
  155. Stalling on me
  156. Install Brake Master Cylinder
  157. 1995 Dakota 2.5
  158. Engine Suddenly Quits
  159. 1995 2.5 Fuel pump rollover valve
  160. Bad clunk and vibration after having wheels rotated and balanced
  161. Is it Priced Right
  162. Blower Motor Removal
  163. Dash Cover
  164. 89 Dakota 4x4 won't engage
  165. Exhaust bolts?
  166. 1991 to 1996 swap.
  167. Source for Parts
  168. Transmission pan & control arms
  169. Trim removal for paint prep
  170. Battery Requirement
  171. 1990 Dakota FSM
  172. Anyone else adding USB ports?
  173. truck bed help please
  174. NV3500 question
  175. 1987 Dakota carburetor bowl vent location?
  176. Help in removing 92 Dakota upper ball joint
  177. Fuel Tank looks bulged... Leaking if "topped off"
  178. What should I do about my CAB MOUNTS?
  179. 1st gen dakota ect sensor threading problem
  180. Fuel Pump Replaement - what else to replace while I am in ther
  181. Throttle Kicker
  182. Clutch sensor bad?
  183. Ram 50 roll bar
  184. Edelbrock fuel injection
  185. Dakota frame
  186. AC Bypass Pulley?
  187. Solid axle swap
  188. No power to ecm?
  189. gas gauge stuck but i know it works
  190. 88 Dakota - bringing her back to life -- need some pointers
  191. Is a5.2 a 318 or vice-versa?
  192. Strange Fuel Problem, I think.....
  193. Rim size unknown
  194. 89, base 2.5l issues
  195. What is this vacuum line called?
  196. 88 v6 dying when pushing in clutch
  197. 92 dakota
  198. Transmission problems
  199. Oil light flutters and blinks
  200. Rebuild kit for steering gear
  201. Happy New Year Everyone!
  202. Installed 2nd gen wheels
  203. 95 Dakota air bag light staying on and blower not working
  204. Headlights Don't Work
  205. 1996 Dakota 3.9L Knock Sensor?
  206. New to forum/95 dakota sport
  207. 88 3.9 swap
  208. 1988 Dakota - Swap in 318 Magnum
  209. Back to the scrap yard or why did the early Dak get a cool dome light?
  210. What are these strange hood contact things?
  211. What are the battery terminal small gauge wires for?
  212. Drum backing plate
  213. Driveshaft and Control Arms 96 Rescue
  214. 1990 Dakota Starting/idle problems
  215. Fog / Driving light mounting options
  216. torque specs for 1987 dakota 3.9l 4x4 thermostat
  217. 1987 (only) stock intake manifold
  218. '96 Dakota Parking Brake Blues
  219. Wheel spacers and hub centric rings
  220. spare parts anyone?
  221. Idle RPM
  222. 1995 and 1996 parts interchangeable?
  223. 1992 Dakota V6 Y-Pipe - changing Manifold for Y-Pipe?
  224. Steering knuckle Can anybody tell me where to find one
  225. 95 dodge dakota
  226. Maiden voyage
  227. AC Hose
  228. Stranded on side of road because I am an idiot
  229. Difference in 1993-96 2wd and 4wd cab
  230. Trailmaster suspension upgrade?
  231. Lighting issue.
  232. Cold running problem
  233. Truck stalled and now will not start
  234. Roll call
  235. Seating Arrangements On The Three Generations
  236. 96 v6 loose timing chain symptom
  237. Weird rhythmic bump
  238. front windshield removal
  239. Switching headlights
  240. tail light brush guard
  241. driveshaft removal
  242. 4wd hi not engaging
  243. Transmission line question
  244. '92 dakota 5.2 fuel injection to carb
  245. Tach Quit
  246. my oil pressure is back
  247. 1990 lower control arm bushings
  248. driveshaft info
  249. This doesnt look right
  250. JS 96 Dakota
