View Full Version : 1st Gen Dakota Tech
- Solved my cooling issues
- To much red interior
- My bumper cracked in half towing my boat yesterday
- Reuse cat with new headers?
- code clearing
- Just a pic of getting a little muddy.
- "Pop" sound coming from right front, when turning
- Throttle Body Cleaning
- Radiator Suggestions
- 93 Dakota, 5.2L Wont Start In Park
- Getting the 46RH overdrive to work without the PCM
- Tips on mountain driving?
- Leveling the rear to match the front
- Anyone know what the timing should be set at for a 5.2 magnum v8?
- 93 2WD Dakota Extended Front Brake Lines For Lift Help
- So for anyone looking to replace their backing plates...
- ac questions
- What Have I Overlooked??
- 89 power window switch AND manual questions.
- 1990 dakota. Loss of oil pressure and over heating?
- 1992 dakota
- Battery dies after sitting just over a day new Bat
- Mirror Question
- Hey Ralph P
- replacing the seat
- Please help with these two issues!
- New here with a couple of issues
- 91 Dakota AC system
- 2002 5.9l magnum & 46re swap into a 92 dak
- 1990 dodge dakota 4x4 sport convertible
- 92 Dakota brakes
- 88 4cyl wiring issue
- Transmission
- 89 parking brake adjustment?
- Fog lights for a dodge dakota 1998
- 96 Dodge Dakota owner. Few question
- They DO work!
- Spring above to below
- 88 Dakota wiper motor
- Large Steel Cables from Cab to Bed. Purpose?
- Best oil filter 88 Dakota 3.9 V6
- Need some help: Transmission
- Repairing door hinge on '95 Dak
- 1995 1/2 crank position sensor
- Trans swap question auto to stick
- Rear end swap on my 1994 Dakota
- ISO: 94-95 5.9 ecu
- 1988 3.9L Backyard Salvage
- Fender flares
- Odds and ends shared with other cars?
- Blue Smoke After New Cylinder Heads
- Transmission Band Adjustment Questions
- 92 dodge dakota vents
- Code 37 and 45
- 96 Dakota keeps killing, HELP.
- Lift
- Engine brackets help
- plugs....wires......argggh
- 92 Dodge Dakota 3.9 V6 sport cab 8ft box Issues
- Lift questions?
- Check engine light
- Torsion bars ?
- '98 5.2 swap into my '95
- Convertible Windshield Trim
- Transmission Identification
- 92 dodge dakota
- transfer shift options
- 93 dodge dakota Transmission
- Where to find replacement driver's side window weatherstripping?
- Help me
- U bolt question?
- Front axle (hub) bearing
- Progress so far
- '95 Dodge Dakota Oil Pressure Light Flickering
- Magnum advice needed for 88
- Switching from bucket to bench seats
- Early vs Later Dakota Brake Differences
- 1993 interchangeable windshield wiper motors?
- Convertible Door Glass Removal
- 6 inch lift and 33 or 35s
- Vacumn Lines
- Shudder when shifting
- Parts for sale over in Classified
- 96 Dakota cross member
- Anyone replaced the NV2500 with NV3500
- Anyone have a passenger headlight assembly for a 94 Dakota?
- 95 dak power window motor replacement
- Engine Swap
- cant find lower control arm bushings
- 1994 Dodge Dakota 3.9 4x4 Transmission Help
- Super high mileage
- Leaf spring bolts
- rear bumper
- Lift springs?
- Need suggestions on 5.2 magnun
- Seat swap. 98 to a 93
- first gen lift
- No brake light on one side
- Transmission Options
- Stalling issue
- WTB new control arms
- High Pitch Whine
- Horn Wiring Issue
- Motor and tranny mounts
- '91 ignition (key)switch cross-reference?
- code 32 and 45
- Mystery Rattle
- PCV grommet ??
- Dodge glass
- I think it will clean up!
- '87/'88 Dash Vents
- rear slip yoke ?
- spider gears
- U joint style 7290 ?
- Wheel Hop
- Aluminum driveshaft
- Best place to buy front brake pads for 88 Dakota 3.9 V6 2WD?
- Well this is a first
- Difference in brake rotors from 4 wheel abs to 2 wheel abs?
- 2.4 Swap
- Mystery Vacuum Lines
- 92 base dakota 2.5L cranks wont start
- ABS Codes
- 1996 dakota V6 3.9l owners
- 93 dakota 5.2 2wd. Front Brake problems.
- No WONDER my wheels rub!
- Wheel spacers
- Little cracks in the bed where the tail lights mount
- 1993 dodge Dakota Dana 44 TTB long travel swap
- Help! 92 dakota v6 3.9l died and wont start
- Passenger Fender Vacuum Ports
- Manual transmission on a 5.2
- Charging Issue - Code 41
- replacement sun visors
- Interchangeable control arms
- 92 dakota 3.9l 5spd (help)
- 93 dodve dakota v8 le
- Ball joint help
- p/n safety switch ground
- When cranking, need gas?
- K/N Air Filter
- Rear Creaking Noise
- Exhaust Routing for 91 Dakota Lowrider?
- Dash cover for 1988 Dodge Dakota
- Timing Tutorial
- Help with the glove box knob 88 Dakota 3.9
- Gas Pedal Response
- Caliper pin bushings
- Timing chain tensioner
- Leaking Oil After Replacing Water Pump
- 90 Dakota needs more clearance
- 87 dakota 3.9L La to 318 La swap
- Need advise
- 99 ram 2500 axles
- 2000 - 1993 body swap
- If I wait long enough,
- '96 3.9 4WD problems
- 4x4 trans question
- Question on FSM procedure for adjusting drums
- Crossing Generations
- Intake finished
- 92 dakota 3.9l spd
- Washer Level Float Sensor
- Fender Flares first gen Dakota
- 1992 dodge dakota (need help)
- 92 Base Dakota
- Arglegargle! Hulk smash!!!
- 89 Exhaust Manifold Studs, bolts, and washers
- Dakota convertible door latch anatomy
- 1993 dakota 5.2
- Problems with bushings
- 92 dakota mysterious wheel cylinder bolt size?
- wet passanger floorboard
- Budget Lift 2wd 1993 Dakota
- Bad calipers?
- 88 dodge dakota
- schematic
- just bought a 2000 ram 1500 2wd 5spd basic truck magnum v6
- How much play is in your steering box input shaft?
- Rear Main Seal
- HVAC Blower Motor
- Need help with identifying an engine part.
- Oil Leak test
- Transfer Case
- Oil Pressure Indicator
- Will only start with air filter cover off.
- 1996 Dakota fuel pump
- Torsion bars
- Oil Dipstick
- Dodge Dakota code 27
- Clunk and jerk when giving gas and letting off
- Pulling the transmission
- Had the rear brakes done in a 94 Dakota. Now the ABS and brake warning lights stay on
- Bleeding brakes
- Help with blend door, or whole heater box assy
- 93 dakota wont start
- Starts out in second gear when in Drive
- Rare First Dodge Ram
- Throw out bearing going bad....
- Interior Color Change
- Poorly made parts
- Seat Belt Options?
- My truck died!! I'm clueless!!
- Grinding sounds when turning/Headlight Switch
- Capricorn, V8 ignition timing
- Chassis number location.
- looking to swap engine
- Leaf springs
- Hi! New owner of a 94 SLT v6 rwd, have some questions
- Signs of a mucked engine?
- Tailpipe rusting off of muffler
- Performance camshaft with stock ecu
- Need some advice
- 1989 3.9L Cylinder Head Bolts
- Hood Hinge Foam
- Bent axle from slamming on brakes?
- Mod please looks and sticky this (9.25 swap, with disc brakes)
- 1984 dodge dakota 1994 318 magnum swap
- 95 dodge dakota 3.9l v6 2wd 4-5code
- 90 Dakota 3.9 lifter clatter
- 1995 dodge dakota v8 slt. Starts for a second then idles rough then dies.
- 1995 Overheats when still EXCEPT in neutral
- Tie Rod Ends
- timing chain
- 88/89 Dakota v6 to 5.2 or 5.9L magnum
- 92 Dak...Hesitation, Stumbling, Skipping.
- Peened housing retainer?
- Modifying the stupid fan shroud! (Pics)
- Upper control arms
- Tire question
- Tie rod end
- Deceleration on acceleration
- Cab mounts
- 88 Dak 3.9L Oil Pressure Gauge reads High, Coolant Temperature Gauge reads 0
- Recommendations FOr Shop To Restore My Truck - Dakota Connection Browns Summit?
- 1996 factory service manual
- 1994 Dakota clock spring
- swaps?
- Front lower control arms, bushings
- Bed Removal
- 4x4 stock ride height
- Parking brake won't return to original position after release
- 5.3l GM in 1995 Dakota 5.2l?
- 3.9 to 5.2 swap
- Piston Surface Rust
- Hi! I'm SteveTheTrafficCone
- inline fuel pump??? need help asap please.
- Rare walker Evans prerunner
- HVAC Heater Valve
