View Full Version : 1st Gen Dakota Tech
- 90 3.9 build help
- **** ton of work need some input
- stock tire size
- I can't figure this out
- Parts prices
- People with true duals...
- cold air not really cold?
- 1992 dakota sport 4x4 tranny interchange
- 95 318 Dakota Solid Wide Track Axle Swap questions
- Front end loads
- brake light issues
- help reinstall front drive axle
- question with trans lines
- things might be broken
- someone...
- question on towing
- Hi a newbie here, have bench to bucket seat question, has anyone done a bucket seat c
- Well i feel stupid
- 1996 (08) dakota vs 1998 (03) dakota
- prostreet dakota??
- So confused. Lighting issue.
- Updates, Questions, and Suggestions (spc. Appearence & Body)
- fuel pump
- 1995 dakota sport wat to do
- torque converter
- need help with radio please help
- 92 Dakota Steering Problems - Hard Pulling Driver's Side
- polished 15x7" ultra wheels
- 94 Auto Trans. Help Please
- whats next on the repair list for a bad idle?
- Fuel injector ohm rating
- Short Shifter
- hard shift from stop
- What is the "official" color of our tan interiors?
- Ford explorer sport trac wheels on dakota
- Converter
- Looking for a set of heads and a intake mani v6 magum
- I'm selling my LSD
- Convert rear Brake Drum to Disc Brakes?
- Spindle Specs.
- M1 Intake
- How to check for a vacumm leak
- A head scratcher...
- I really need some advice.. Please help
- Auto to Manual driveshaft swap
- ABS Diagnostic giving a Brain Error
- Odd Transmission Problem
- Newbie Needs Help
- Manual RP steering
- tired of my dodge dakota
- Temp Sensor..
- MIL Codes ('96)
- 96 dakota diagnostic codes
- Twin Turbo v6 dakota
- Wont start...
- Fuel Leak
- Engine and bellhousing bolt patterns.
- Change oil on dakota? Remove Skid Plates?
- Sway bar!!
- 92 Dakota Transfer Case
- New Here
- my truck after lift keys and bath!!
- Can't find lift kit!!
- my transmission burnt up today what to do?
- whats up with this
- power steering issue
- Help Please! Gas gauge issue
- weight of a 95 dakota
- Sweet news and 2 questions.
- service manual
- driverside floor
- Transfer Case Problems
- Computer swap
- OBDI (Pre '96) Codes
- dakota problem
- 1995 dodge dakota 5.9 360 swap
- ball joints
- transmisson shifting
- 93 5.2 Dak-smooth warm up, then idles badly, hesitates on hard accelleration
- Getting ready to do motor swap in '92, and I have a few questions
- Rough shifting follow-up
- Header replacement
- 95' dakota shifting problem
- Electrical problems
- *****Need SOME Good ADVICE ****
- Engine Stalls. ECM Connerter Issue
- Quick question!!
- What do you think?
- 1995 dodge dakota
- wiper / turnsignals don't work
- Help please-1995 dakota turns over but wont start
- need help badly! (ignition cyl replacemement)
- ah snap...
- Pcv
- 1996 4x4 problems?
- Dodge 318 4x4 biuld. NEED HELP BAD
- Hazard lights work only with turn signal on
- Hesitation issue
- New Performance parts!!
- will my plans work?
- Another v6 to v8 thread
- Center Link Questions
- Power Steering Leakage
- Transfer Case Oil?
- Brake and ABS lights on HELP
- Exhaust question
- instrument panel electrical problem
- few quick questions?
- Transmission question
- Dakota is getting no power to anything!
- dakota not starting
- GEN light?
- trouble finding parts
- Dodge Dakota Warrior
- lift kits????
- Hey 95_318SLT Your Famous!
- My weekend camo project!!!
- Infinity Amp?
- Truck dies occasionally
- Sway bars in Daks
- Anybody in AZ or UT?
- Accident SUCK
- Jokester at the assembly plant
- cat
- need help please
- Stalled!
- Torque and quarter mile
- 93 2wd 3.9 no power to wiper motor fuse good
- EGR sensor?
- transmission swap
- Driveline Bucking/ Also Front end susp. Rebuilding
- title issues HELP (TEXAS/Arkansas)
- shocks
- need bucket seats
- dual exhaust questions
- A few quick questions.
- Brake Caliper pulling truck?
- 91 dakota motor oil helpi
- Maint Reqd
- 3.9l LA to magnum swap
- Engine Swap, 3.9 to a 5.2
- motor swap
- Torsion Bars!!
- rough running ' 93 dakota 5.2 litre
- Need source for 5.2L flexplate
- Fuel Pump Problem 1988 Dakota
- Whats wrong :(
- Cup Holder
- Shackles or blocks?
- need help with my truck not passing emissions
- My Dodge Don't Work!
- 1992 4 cyl dakota running very lean
- Rear sway bars for Gen I 2wd?
- is this bad?
- If someone wants a pair of aftermarket lift keys...
- My Official Solid Axle Swap Thread (The Project Writeup)
- Moving on
- Can I run 95 Dakota with out IAC pluged in?
- pics as requested..
- Winshield wipers!!
- rough cruise in lower gears
- Paint
- Problem with Codes
- interior lighting issues
- Whining sound?
- Never seen this Dakota before.
- Seat Belts not restraining
- Chime Buzzer removal
- 92 5.2 magnum stock cam specs?
- Fuel Gauge/pump question
- Cheap Power Adders 5.2l Magnum
- Better Exhaust?
- windshield visor?
- steering shaft?
- looking for a gas tank
- 87 dakota parts
- Cummins Dakota
- random question
- 91' dak running bad
- Regular cab bucket seats into ext. Cab?
- Local Dakota/Ram/Mopar Meet in Dallas, Texas
- new guy here need some help please
- 3.9 swap
- Black Interior Panels
- Welded cross member?
- No fuel no spark no lots of stuff
- Heater fan resistor block
- Bog and high idle
- Speed sensor?
- strange
- Help with Blinkers
- Maintenance Light
- 1/4 1/2 3/4 1 ton
- Durango rims?
- valve covers
- I bet you can't top my stupid moment of the day...
- Some New Paint
- another win!
- truck died!
- alot to fix not enough time
- Please Help! 1990 Dodge Dakota No Spark!
- 95 Dakota splice & ground locations
- Stalling
- GenII 16x8 wheels, tire size
- Master Cylinder
- You know you own a Dakota when?
- 1991 dakota with a 318 tranny problems
- bought something for the dak...
- throttle body spacer
- need some help deciding...
- Intermittent fuel injection trouble
- Need some pics
- Front wheels now rub the caliper banjo bolts
- rear abs
- doors and fenders 94 onto a 88?
- Rear end gear oil
- Header question
- 1995 3.9L ECM removal and install??
- 1996 dakota 4x4 with v8, whats it worth ??
- 4 Cylinder to 318
- Truck problems, need some help
- HELP dodge experts
- To Tap or not to Tap
- eliminating the ECU....
- '95 Cruise Controls switches are loose.
- Trans line cooler fitting
- Transmission
- Oil Pan replacement problems
- Leaf Spring Bushings
- Minor Idle problem.
- post your highlight pics!
- Very irritating...
- tail lights?
- gas leak after tree pull???
- 1st Gen Bucket Seats
- help
- Rear Brake Clips
- LA 318 into 89 4 banger question
- Exhaust, Tonneau, Gas Milage
- e brake
- What does this wire do?
- 1995 Dakota "Radio Eater"
- rust!
- Watch Phoenix, AZ obituary page....
- Driver Mirror Issue!!!
- Octane questions......
- Bigger Tires Better?
- Going to install foglights
- Slow
- I have to do WHAT?!?
