PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. how important?`
  2. Facepalms.
  3. 96 Dakota mirrors
  4. Fuel pump not working
  5. MPG drop by 30miles+
  6. Interesting article on stand alone EFI
  7. Fuel Tank
  8. 1st Gen front grille
  9. frame mounted hitches
  10. Crazy idea
  11. Replacement front hub?
  12. 1996 Dodge Dakota
  13. Won't go into any gear
  14. 4wd shifter buzzing
  15. Bad fuel pump?
  16. 4th gear weird
  17. 93 Dodge Dakota cranks but wont start.
  18. hp tuners jtec
  19. 89 Dakota fuel pump issue
  20. Rainwater in cab
  21. 92 2wd Rack and pinion replacement
  22. 1st Gen Dakota Control Arms
  23. Failing fuel lines on 1992 dakota club le
  24. tranny prob;em
  25. See Spot Run!
  26. Turning Radius?
  27. 3.9L to 5.2L update
  28. Oops I did it again...
  29. Best Place to Look For a Dakota?
  30. Tranafter Case
  31. Exhaust manifold
  32. Upper Ball joint
  33. Lower Control Arm Struggles
  34. Quick Overdrive Switch bypass question!
  35. Finally purchased a 5.9 engine.
  36. Today I Learned (TIL)
  37. Broke Drive Belt
  38. Alignment
  39. Again With the Intermittent Issue. This Time Code 42
  40. Help .... No start problem
  41. 1993 Dodge Dakota V6, Gas Gauge doesn't work after fuel pump replaced
  42. Murphy Love Me Long Time Part WhoCares!
  43. Dome light
  44. 1996 3.9 1st gen dakota no spark
  45. Need help finding rear rotors 6x4.5 to fit my 92 dak.
  46. ABS 56026829 1994 Dodge Dakota 2wd
  47. Need help with Upper control arms
  48. Possible grounding problem
  49. 2ND Gen Durango NV244 Transfer Cases Compatible with 1ST Gen Durangos?
  50. 1994 dakota 2wd front hub assembly
  51. 1994 dakota 2wd front hub assembly
  52. Timing Issues
  53. 1994 dakota mods Advice
  54. 95 5.9 dakota...NEED HELP!!!!
  55. 1993 Dakota Control arm....PLEASE HELP!!!!!!
  56. Push Button Start
  57. Flywheel size difference between V6 and V8?
  58. Electrical and over heating.
  59. Water pooling on passenger side floor
  60. Fuel injector electrical connector
  61. Rough idles for a few seconds and dies
  62. V8 318 Carb vs efi transmissions
  63. Gauge cluster going crazy
  64. 93 Dakota 4x4 Upper control arm bushings
  65. 1996 Dodge dakota head light not working! Need Help ASAP
  66. 91 obd1 codes repair protocol?
  67. Wiring diagram help
  68. header article of interest
  69. Dakota Convt.
  70. Can I get my ECM reprogrammed?
  71. Help 91 dodge dakota 4cyl.
  72. $x$ actuator vacuum diagram
  73. How To Replace The Oil Pressure Switch On My 87 Dodge Dakota 3.9L V6.
  74. 1996 V8 4x4 Build Thread
  75. 1995 dodge Dakota v6 problems. Please help!!
  76. Dropping drive shaft. 95 dakota sport 5spd 4wd
  77. E.C.U.s
  78. Deeper, aluminum trans pan?
  79. 1990 3.9 ac bypass
  80. 95 Dakota low idle
  81. T4 10w30 in my 318?
  82. Another rim fitment question....
  83. Free Gas if dressed in Bikini?
  84. Help
  85. Happy Holidays!
  86. Dodge 5.2l 318 V8 transmission swaps?
  87. Replaced ignition switch, truck still won’t attempt to turnover - HELP
  88. Front Speakers Fail Again
  89. 96 Dakota tie rod torque specs
  90. Can't separate PCM from wiring harness - '93 5.2L
  91. Another headlight thread
  92. Engine choke when hot - Dakota V6 3.9L from 95
  93. HELP!!!!!!!!!!!!!!!! 1993 4x4
  94. Murphy Love Me Long Time!
  95. Upper Ball joint issues
  96. 96 Dakota V6 Code 11
  97. Muffler Recommendation
  98. Discovered while changing oil
  99. Cruise control and airbag light
  100. Spindles :(
  101. Fuel gauge suddenly stopped working 1993 Dakota
  102. Parking Brake Pull Handle Again
  103. IAC valve stuck closed during cold start?
  104. Transmission
  105. Headlights go off when I use the fog lights
  106. Triangle Shaped Block Behind Horn Pad
  107. 96 Dakota
  108. Headlights wont turn on. HELP. Experienced Mechanic
  109. What years are compatible with an '89 Dakota for body parts?
  110. Yet another random issue
  111. What wheels do I have?
  112. Bwhuh??
  113. Harmonic balancer separated?!
  114. Rainwater pooling in footwells 1993 Dakota
  115. Update to failing overdrive in 91 dak
  116. Help with 1994 Dodge Dakota V6 3.9L
  117. Anyone running larger oil filter?
  118. Airbag fuse randomly blowing
  119. This truck will be the death of me
  120. Ford ECU in Dakota?
  121. How to renew tail gate latches
  122. Running Bad cold
  123. No heat
  124. Prep for winter
  125. Pcv
  126. Fuel pump question
  127. Heater Core Redux
  128. Coil Over rear shocks?
  129. Upgrading the sound
  130. Random misfire!!!
  131. Some more possibilities
  132. Brake Issues
  133. 1996 Dodge Dakota 2wd lift
  134. Where is the fuse block on my '89 Dakota
  135. Spring payload
  136. cracked head
  137. A/C evaporator coil
  138. Question about 3.9 to 5.2 swap
  139. Is swapping to factory LSD worth it?
  140. Fun With Fuel Lines
  141. Motor mount issue
  142. Transfer case
  143. Power Steering Pump for 1989 Dakota
  144. Where is the blower motor on my 1989 Dakota?
  145. Fuel leak around pump wiring harness?
  146. Overheating
  147. My 92 rear end
  148. Opinions on Lucas Oil Stabilizers?
  149. 93 dakota no overdrive or cruise.
  150. upper control arm pivot bar screws 06033342
  151. fuel pump
  152. Fuel pump wiring diagrams?
  153. 1st gen 4x4 upper control arms
  154. Wiper Sweep is Changing Minute to Minute
  155. 42 RH Overhaul and Swap
  156. 1996 3.9 1st gen dakota no spark
  157. Swap for a horse?
  158. Front end and alternator not charging
  159. Advice. Engine rebuild
  160. Brake flare nut size?
  161. 93 Dakota LE 2wd 3.9 auto Overdrive issue
  162. No gauges except speedo working
  163. asd fuse keeps blowing
  164. 8.25 parts
  165. What is this plack in the backseat of my truck
  166. intermittent oil pressure problem
  167. Painted my '95 dakota.......in my garage!
  168. 93 dodge dakota cranks wont start
  169. Safe to Road Trip after 285,000 miles?
  170. front mount trailer hitch reciever..
  171. 92 Dakota problem , no more ides left
  172. floor pans/trans tunnel teh same?
  173. What is under my engine air filter?
  174. 3.9 to 5.2 swap
  175. Help. Engine knocking
  176. Control arms
  177. Recommendations on a hood bug shield?
  178. ECM/PCM Rebuild
  179. 96 Dakota blower motor
  180. 95 Dodge Dakota 3.9V6 Magnum Depress Fuel
  181. Internal Frame Rust Issue
  182. 1992 Dakota No TC Lockup, No OD
  183. AC Issue PLEASE READ
  184. Rear end swap
  185. Curious about putting a straight pipe in my 96 v6
  186. Shift linkage problem
  187. Curt Class III Receiver Install
  188. eBay stainless muffler-back dual exhaust kit installed (PICS)
  189. Dakota brake lights not working
  190. A535 transmission alternatives
  191. 92 Dakota 5.2 dies, no start.
  192. Dodge dokata sport 1994
  193. 1988 2wd
  194. 87 Dakota Electric Fans Upgrade
  195. 95 Dakota Vibration Problem
  196. Alternator Upgrade?
  197. Shocking, I know!
  198. How to adjust tailgate '95 Dakota?
  199. 1993 Dodge Dakota Sport Side lights
  200. 3.9 on 3 quarts of oil!!!
  201. Need front shocks NOW!!!!!!
  202. AC lines
  203. Relay fuse issue
  204. Headlamp switch
  205. Front and rear axel width
  206. Rear glass
  207. 96 dakota e-brake cable tightening???
  208. Transmission slipping
  209. Helpful tips on installing torsion keys
  210. Key spins freely in ignition, but no start...
  211. vacuum lines
  212. 93 dakota 5.2 v8 4wd issue
  213. headlight wiring connector
  214. 1993 Dodge Dakota 5.2L v8 Mounting Bolts?
  215. Options as to how I can replace my rear speakers in my 95 dakota SLT
  216. New Member
  217. Hi, I am a new member, and I own a 1987 Dakota 4x2 3.9.
  218. Radiator Core Support
  219. Timing chain tensioner on wrong side??
  220. possible photo of under dash
  221. Buying a long block 3.9L, what’s the difference between the manual and automatic?
  222. Intermittent--Intermittent wiper problem
  223. 1995 with 288,000
  224. 96 dakota Crank No Start
  225. Rust in radiator
  226. Steering shaft coupler issue
  227. 93 Dakota 4x4, 5 speed, 5.2. Intermittent Rough Idle / Running Problem
  228. (1995) 1500 Ram Van to Dakota 3.9L swap
  229. Bigger front discs? D150 knuckles? Crown vic hats?
  230. Does anybody make sway bars for 89 2wd?
  231. Vapor canister filling vacuum lines with carbon pellets
  232. Moved distributor shaft? Sounds rough now?
  233. 93 Dakota, Crank but no start
  234. Suggestions on paint for moulding trim?
  235. rear differential
  236. Fuel Injectors
  237. Shaking over ~40mph
  238. Question on EGR and vacuum, 1995 w/ 5.2L
  239. Coolant loss
  240. Steering knuckle
  241. How to replace back window panel
  242. How To Change Check Engine Bulb
  243. Want adjustable front shocks 89 2wd QA1?
  244. Steering gearbox
  245. Wiring near alternator
  246. 1990 dakota AC
  247. Leak on expansion valve
  248. 92 Dakota 2wd 5.2 suspension
  249. AC problems.
  250. two things
