View Full Version : 1st Gen Dakota Tech
- Pics of my new (to me) engine
- V8 Dakota oil
- 1992dakota v6 4x4 rear end problems
- Ignition switch replacement
- 1990 Dakota Drag truck to sand dune racer
- Trailer Hitch Suggestions
- 02 Sensor Thread Size
- Front shocks
- Should I Upgrade from 1996 2WD to 2009 Big Horn?
- No dash lights
- 1988 Dodge Dakota - Hole In Top Of Coolant Tank?
- Beltline
- Bad idle, barely runs, and backfires WTF???
- 1995 PCM in 1992 Dakota
- Stubborn Rust on Chrome K&N Air Cleaner Cover
- Running rich - no codes
- replacing distributor.
- 94 Dakota 2wd Shifter cable
- 5.2 to 5.9 Swap - Compatible Vehicles
- Ecu swap
- 1988 Dodge Dakota - Starts, Then Immediately Stalls
- Want a GenIII Hemi in your 1st Gen?
- 94 5.2l hesitation while accelerating?
- Hole in Bellhousing??
- drier questions
- 1st gen dodge dakota metal body mounts
- Rear Backing Plates
- 1988 Dodge Dakota - Interior Ground Wire Location
- Bad coil Maybe??PCM???
- How to Remove Oil Pan - Confusing Instructions
- Noisy rocker arms?
- Lumber load up!!!
- Engine Noise & Erratic Fuel Sync
- 1988 Dodge Dakota - Smoke Coming From Throttle Body & Cracked Vacuum Line
- Frustration
- thermostat spacer
- 95 Dakota passenger door won’t open
- Long Tube Headers
- brake light on
- truck runs great
- really rare dakota
- Seat Belt Buckle Swap
- theoretical alt upgrade
- No gear at all
- Sludge inside block
- 91 Dakota 5.2 No Spark
- 87 Dakota hemi swap
- 1988 Dodge Dakota - Lightbulb Hanging Inside Dash?
- Code 41 and 46 overcharging
- Hall effect distributor
- Disappearing coolant and wacko coolant temp gauge
- Air stuck on defrost vent.
- 95 2.5 crank,no start
- From the vaults at Chyrsler Corp
- Nothing happens when I turn key
- Is there a difference between a stick shift crankshaft and a Auto crank?
- Advice/Help Needed - 1988 Dodge Dakota 3.9 V6 - Fuel Pump Assembly Replacement
- need window help
- 95 Dakota - Pinion Seal Leaking
- Is my PCM RFI or Non-RFI
- cooling fan circut
- a/c oil capacity for '87?
- 1989 Dakota inner fender / splash shield
- 88 dakota breaks seased. Calipers? Hoses? Or contaminated break fluid? I don't know
- PCM help needed . . .
- 95 Dakota 5.2L 2WD - Inner Tie Rods
- reducing bed wobble?
- 1992 2WD Parking Brake Adjuster Help Needed
- Stuck shifter
- ‘95 Dakota extended cab seats...
- head on and working.
- Fuel pump banjo clamps
- AC Routing colors
- '87 dakota v6 cuts off without warning
- Turn signal lever came loose and now no signals??
- AC works then doesn't
- Steering shaft
- 1989 Dodge Dakota Sport Restoration - Lot's of photos!
- 1995 dodge Dakota no spark no fuel
- Throttle Valve Cable?
- Needing information on 1990 Dodge Dakota
- Best Way to Haul a Pickup Bed?
- 93 transfer case
- Doors & Fenders the Same?
- 93 DAKOTA floor pan
- Found metal Chunks in my Rear Diff
- '96 Dakota burning some rubber!
- Bought a Truck!
- Transfer case swap
- Heater Core Removal
- 1993 4x4 with locking front hubs
- where are they?
- Need some expertise - new owner - 1996 5.2 4x4
- Feels like RWAL is activating
- '95 Dakota - Rust Repair,or Replace?
- 95 dakota running lights
- 22 engine code
- O2 Sensor
- to tape or not to tape.
- Spark Plug type for the '95 Dakota 2.5
- Transmissions
- '87 Speedometer dead in the water
- Hard time finding 1995 dakota 3.9l lower steering rod.
- 2.5L to 3.9L? Possible?
- 95 Dakota - Where to find drum size
- A/C
- 1993 v6 wont rev past 3800rpms?
- Starter bolts
- 95 Dakota - Solid Lug Nuts - Where to Buy
- Power Vent Windows
- is it worth it?
- Broken off seized lug nut
- reverse lights
- 95 Dakota 5.2L - Rear Main Seal Replacement
- got the head off.
- Why does it run rich?
- Reman Auto Trans Curiosity
- Anyone heard of Regitar USA?
- 95 dakota killin me...
- What is this? 1995 Dodge Dakota 5.2L
- Torque Wrench School
- 95 Dakota 5.2 - Where is G103 ground?
- Fault code 34
- Late shifting
- 95 Dakota 2WD - Remove Upper Control Arm
- Where can I get these connectors?
- 89 Dakota a/c question.
- Won’t start
- 1991 3.9l Cranks but won't start
- map sensor removal
- IAC replacement
- Off road lights
- Grounds.
- Fuel pump black hose connectors
- O2 Sensor Replaced Still Getting Code
- Interior trim
- broken control arm cant find a new one
- Transmission Band Adjusment
- 1995 Dakota Fog Lamp Assy Replacement
- 88 dak gets hot when ac running
- Model Types, etc
- Driving down the highway and suddenly the engine cuts down to half power
- 1995 Dakota 5.2L - Rusted Through Floor Pan
- 2013 Dodge Dart Limited
- AC Evap Removal
- 89 side marker HELP!
- not a bunch of info
- hard to find.
- Running Rough after timing chain replacement
- Ralph!? My 95 has an intermittent long crank.
- Leaf spring plastic shims
- Looking for some ideas
- 1995 Dakota No power at fuel pump after replacing
- Bragging on myself
- hood release cable broke.
- add cruise
- Frame differences?
- 96 dakota has issues
- 318 swap first time engine swap!
- Dodge Dakota headers
- charging rate
- New to me
- Hooker 5803 long tubes. Anyone using?
- 92 dies in motion
- A huge thank you
- O2 sensor
- When parking lights activate, left turn signal independently stays on
- 2wd Coil Springs part number / max spacer lift
- let me fix it boss...
- 1st Gen Dakota Y-pipe
- v6 timing to mitigate knock?
- Cruise Control Won't Turn Off
- Surging Idle and High Idle after O2 Sensor Replacement
- My Dakota
- Rollover valve
- Camshaft position sensor?????
- Cheap Syn. Oil
- Relay box
- 1995 dakota 5.2L ASD circuit problems
- 1988 Dakota HSP Valve Bypass
- 1993 vs 2003 wheels
- Need help!! What is this.
- Cleaning upper intake
- Spark plug n wires- 5.2l 318 V8
- 93 5.2 automatic 2 wd engine wiring harness
- 91 Dakota 3.9 to v8 swap
- Box height question
- Wheel bearing seal installation, rubber facing in or out?
- Stranded, swapped ecm, lasted 2 days
- 2” spacers, look good I think.
- Stalling dakota/ now a nightmare
- Looking for engine wiring harness for 93 5.2 Dakota 5.2
- Intermittent shuddering
- Oil pressure sender/switch before or after filter?
- 96 Dakota 3.9 want start
- Dually Dakota / Gambler 500 Project
- 1993 dakota radio???
- Stalling Dakota
- Body mount washers
- Wanted 42RH Slip Yoke
- Turn on Lights, Dash Instrument turn off
- Bent center link?
- 92 crank no start, 8 days chasing gremlins.
- two hoses underneath intake 2.5
- 92 5.2 crank no start
- 8 days now crank no start
- Transmission Speedometer seal
- Transmission swap
- Control arm mount rust
- I need a Bolt size for a 1997 dodge Dakota sport
- No Spark
- Replacing lock cylinder on 1988 Dodge Dakota
- Sourcing a wiring harness - '93 Dakota
- Regular cab seat swap
- So what are you doing?
- Inner rockers - drivers side
- Gears 7.25
- converting manual mirror to manual w/joystick?
- Need a PCM (computer)
- 1994 Dakota 5.9L
- Noisy Valvetrain?
- Hullo
- *thud!*
- 89 Dakota 3.9l v6 Code 24 TPS issues
- Restricted radiator?
- 1st gen NIGHTMARE!!
- How much dose a 1990 dodge dokota bench seat and rear axle weigh
- Relocating the combo valve?
- Gauges
- Pressing in lower ball joint
- 88 Dakota 289 - clean and simple - Bypassing some vacuum and electrical
- 94 dakota no start
- 4 wheel drive
- 1992 dodge dakota distributor replacement 3.9L
- Will a v8 dodge dakota sport rear end hold up to a big block 383
- 1988-1990 fuel pump assembly
- 87 Dakota Brake issues Update and question
- Help........code 11
- HELP!! Fuel Sending Unit for 1989 Dakota
- 2.5 hanging throttle
- 1993 dodge Dakota shifting issue
- Transmission Seal Leak
- Low Pressure Port Location?
- Transmission Mounts
- 1st gen lift
- Brake warning light always On
- An Intro and background of my Daks
- new project questions,.
- Trailer wiring not working
