PDA
View Full Version : 1st Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. emblems
  2. Noise....
  3. Been Way To long
  4. Cold air intake?
  5. Almost Done!!
  6. Speedometer problem
  7. werid problem
  8. Nov. DOTM Nominations
  9. 4wd problem...please help!!
  10. sorry guys
  11. Got my cruise control issue solved!!
  12. Source for carpet
  13. Dakota interior replacement
  14. Windsheild wiper issue
  15. Sold my 94 Dakota
  16. HELP!!!!shuts off when it reaches operating temp
  17. Fuel pump/filter
  18. FAQ file downloads
  19. 91, 5.2, no spark...
  20. 93 Dak 4x4 axle hub nut size?
  21. Gas tank filler neck
  22. pulling tranny...need advice
  23. Traction Bars for 4x4s!
  24. bent...uh?...WTF
  25. 5.9 swap
  26. Man I wish I would've
  27. Forum issues?
  28. 1995 SLT 318 V8 exhaust question
  29. building a 3.9
  30. a little problem
  31. Turns Out There is a problem!!
  32. Water pump problem
  33. 91 Dakota 4WD problem
  34. New diff!
  35. Dayton Timberline AT II
  36. 1995 dakota 4x4 fuel issue
  37. Got my build sheet....
  38. Transmission fluid question...
  39. Will it all interchange?
  40. timing belt change ?
  41. Air in Brake Lines
  42. 92 dakota heater core swap
  43. Popping noise in the exhaust under heavy deacceleration
  44. Name that screech?!?!?!
  45. What Years Fit???
  46. Door Hinges Cracking apart, and I finally got it fixed (TONS of pictures)
  47. egr sys woes
  48. 1993 Dodge Dakota V-8 5.2L ignition coil problem?
  49. Idle is surging
  50. What Happened/did you do, to your truck today?
  51. question about 5 speed swap
  52. Got the clear lights
  53. seats....
  54. Synthetic Oil Dakota Question?
  55. rebuild
  56. Stereo upgrade/Electric fan help??
  57. FIRE!! Vacuum/Smog Sensor
  58. bench seats
  59. Fuel system? or fuel pump?
  60. Gas Mileage ?
  61. My Last Tire/Wheel question
  62. Stereo, Dome Lights, Hood lamp, Power Mirrors problem!
  63. TV Cable
  64. trans problem
  65. pulling codes????
  66. Need help with truck!
  67. DIY: Rebuilding a Trac-Lok LSD
  68. Tires on wheels question
  69. my wipers quit
  70. first dodge dakota
  71. Wiring Harness,
  72. local junkyard prices
  73. Need Big help
  74. Door Hinges cracking apart at Door
  75. '92 Will Not Idle When Cold
  76. 95 Dakota ASD fuse keeps blowing
  77. TPS Question
  78. 92 dakota ...drivin me crazy
  79. cv halfshafts
  80. Is it true that Mobil1 isn't true synthetic anymore?
  81. Anybody have this exhaust system?
  82. Clear Headlights
  83. Intake Holley Carburetor hissing??
  84. I can't seem to stop...
  85. pitman arm. 93 dakota
  86. Radio Power shuts off when i turn on head lights/dash
  87. EGR Tube Problems
  88. Question about truck I just bought
  89. Need some help...
  90. might sell my dak for a dodge ram 2500
  91. question about a ranger roll bar
  92. Same Problem?
  93. dakota skipping
  94. Air pump removal - 91 5.2ltr...
  95. Fuel pump???
  96. painting a muffler
  97. tires
  98. dakota brush bar--1992
  99. 92 dakota
  100. motor swap
  101. truck has no power
  102. hockey puck lift?
  103. dash lights went out a day after stereo install??
  104. Torsion Bar Question
  105. Rim and Tire sizes
  106. 93 radio wire diagram(4 speakers) colors?
  107. 93 parts replace question
  108. Gas Gauge
  109. Real time help heater core
  110. 1992 dakota wont stay running
  111. body work
  112. My 87 Dakota Express
  113. My 95
  114. Sway Bars??
  115. Motorvation spacer and K/N Filter
  116. powerbraking?
  117. wheel hub assembly
  118. Truck takes too long to start
  119. My 1992 Dakota
  120. How to disconnect fuel lines from fuel rail?
  121. Control Arms
  122. Few stupid questions
  123. 87 3.9 2wd vibration problem
  124. 2H or N on a 4x4 93'
  125. 1992 Dakota
  126. Fuel rail/line retaining clip.
  127. sway bar
  128. Engine temps....
  129. Stalls When Restarted
  130. code 15 help?!?!
  131. question..
  132. leveling
  133. I need mroe lift,
  134. odd issue
  135. Which manual transmission to use
  136. will 35's fit
  137. 93 Broke Shock bracket/TAB
  138. Radiator leaking
  139. New Dakota Owner, I need help with a few things
  140. Slave Cylinder?
  141. Okay heres a poser for you guys ABS
  142. Trucks been sitting 5 years... alive again!
  143. a few pictures after bath
  144. Ok help NP435 In 91 dakota 2wd
  145. 1993 dodge dakota Trans Rebuild (46rh)
  146. What size transmission do I need?
  147. I dont drink it, but I love beer
  148. pre-running a 1st gen
  149. 35" tires
  150. Turbo
  151. 93 dakota Failed Inspection help
  152. New guy with a problem
  153. Looking for rack and pinion or 93 Dak 2WD
  154. T-case slip joint
  155. New
  156. My new TOYS!! 10,000Lbs Winch
  157. Vacuum hose problem...
  158. Rear end
  159. front axle swap???
  160. speaker quextion....
  161. 1990 Dakota will not start when warm
  162. Bogging down problem
  163. squeaking sound
  164. No Spark
  165. Need info on a 1994 Dodge Dakota 4x4 transfer case
  166. Another new part!!
  167. 92 dakota - dies when put in gear while cold
  168. timing cover/harmonic balancer trouble
  169. 5 speed swap
  170. Awesome Junkyard Find!
  171. Sticky Rear End?
  172. Removing body trim
  173. MD Newbie w Question 1995 Dakota
  174. 318-360 swap help
  175. no brake pressure...
  176. '93 Dakota 5.2L starting problem
  177. Noise that i cant figure out!!!plz help.
  178. Temp gauge
  179. Linkage bushing?
  180. Clouded headlights
  181. Ignition Lock Cylinder replacement
  182. can't switch cold to hot (climate control)
  183. Control arms and ball joints....
  184. Front Differential Noise
  185. dodge heating system.
  186. 15" rim center caps
  187. Erratic Shifting
  188. first time wheel/tire buyer
  189. Random build opinions
  190. Aftermarket Gauge Install???
  191. Transfer case leak!!!
  192. 92 dakota stalls in reverse and while stopping
  193. Transmission oil change
  194. replacing clutch 93 dakota sport
  195. 87 aftermarket gauges?
  196. Dash board lights
  197. spedo/odo adjust for tire size
  198. 90 rear end
  199. 1987 dodge dakota
  200. clutch oddity
  201. steering Rack 1993 4x4 Dakota?
  202. flex plate issues
  203. DOTM Oct.
  204. 1992 Dakota choked
  205. transmission issue
  206. Just to make sure
  207. So close
  208. 1991 Dakota questions please
  209. spedometer
  210. 1993 Dakota Steering Problems
  211. Water Pump Question
  212. 93 v6 flywheel to 2000 5.9L
  213. Transmission question
  214. New member, need some FLUID info help.
  215. DOTM Oct. Nominations are open.
  216. Where can I find...
  217. PCM swap from automatic to standard?
  218. Vibration....
  219. 88 Sport
  220. need v8 torsion bars
  221. soild axle idea
  222. Rear end pushing
  223. Got new parts!!! :D
  224. Oil Pressure....
  225. replacing engine
  226. '94 Brake issue
  227. Wheel Bearing or Ball Joints?
  228. For the new guys, or maybe some old
  229. Freeze plugs....
  230. will 2.5L ecu work on 5.9L?
  231. Caliper Guide Pins
  232. 1987 Dakota Express!!!!!!
  233. gearin up for the 5.9 swap
  234. Crankshaft Position Sensor question
  235. 93 Dakota only starts in Neutral
  236. having nothing but issues....
  237. what size rims
  238. Shifer linkage/ switch adjusting help NEEDED!
  239. Who the heck are ya anyway!?
  240. Alternator question....
  241. Still not quite right....
  242. Check out this 1st gen
  243. ECM mixed with water ?
  244. Ignition Still not Right??
  245. Looking for Advice - 1991 Dakota
  246. Tire choices
  247. Propane tanks.
  248. Torsion Keys
  249. Roll Over Valve
  250. Newbie Intro and Question
